View Full Version : All Motor
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12
  1. cold start issue.. DE-K in my 97
  2. TB/TPS question
  3. New Apexi AFC NEO?
  4. Mass Air Flow Meter from a 300ZX
  5. VQ40DE has anyone confirmed tranny bolt pattern?
  6. Anyone know why tilley is not answering e-mails or phone calls?
  7. DE-K swap in 96
  8. weird question about the MAF
  9. Using heads from other VQ35s
  10. New dyno after 3.5 swap
  11. igntion upgrade?
  12. EU can now read the VQ30 crank signal!
  13. Street Tuning discussions
  14. Finally done 01-DEK Engine in my 97 (Video)
  15. I want to learn about EFI tuning
  16. Emissions removal
  17. OOvi install!
  18. vafc questions
  19. New Toy for my maxima!
  20. VQ35 cams for sale
  21. anyone know of a good swap for the vq30de 4th gen
  22. VQ35/4th gen with 02+ auto tranny?
  23. Removing A/C this week, question on belt ?
  24. s-afc help
  25. Power loss somewhere.
  26. 3.5 swap help
  27. 350Z injectors with 350Z ECU?
  28. auto transmission cooler
  29. Power gains
  30. made my own iacv cover plate (Pics) :X
  31. VAFC-II Problems
  32. AHHHHH so many vacuum lines on the 00vi which to keep which to remove ?
  33. IACV Adapter Plate
  34. Wideband o2 decisions, decisions, decisions
  35. MAF percentage correlated into power gains?
  36. Fuel Cell Install
  37. **DEK Swap**
  38. 3.5 swap
  39. altima 3.5 header+y pipe for maxima???
  40. 00VI swap question
  41. Valve Train Questions
  42. VQ35DE piston bore
  43. 3.5 Downtime Question
  44. Kinetix IM for FWD VQs
  45. Would you be interested in an intake manifold?
  46. Cattman headers for sale
  47. It's alive!!! 3.5 swap with cams
  48. Question about plenum
  49. emange ultimate + fuel upgrades
  50. 4th gen tranny, weakspot?
  51. VQ30 auto possible to hit the 14s with boltons?
  52. 350Z Plenum Installed *Pics*
  53. 4.3 Stroker in 4th Gen
  54. *HEADERS POLL* VOTE and please COMMENT on your choice; for a 3.5 in my 4th gen
  55. a/f tunning from a stop
  56. To sell or keep :(
  57. clarify please:what year headers? to go on a 3.5 IN my 4th gen..97-99, 00-01, 02-03?
  58. timing graph
  59. 3.5 Cams or Aftermarket cams?
  60. Knock sensor??
  61. Headers question
  62. 5speed vs. VQ35 swap
  63. emanage..... map
  64. vq35 and 4th gen auto tranny?
  65. AFR changes according to temperature?
  66. VAFC-II setup template
  67. North-south Vq30de?
  68. Are high 13's possible with a finely tuned 3.5 swap and vb mod for my auto?
  69. Fs: New Stillen V2 Supercharger Starter Kit
  70. '00 VI Swap : Rough Idle
  71. 350Z TB on 03 maxima?
  72. big time idle problem after NEW TPS and cleaning IACV
  73. Does a VQ35 Cylinder Head Directly Bolt on to a VQ30 Block
  74. Engine harness removal question
  75. Piggyback systems
  76. water injection
  77. Timing chain kit for sale
  78. Naturally Aspirated Tuning Discussion
  79. 3.5 swap needs fine tuning plz help!!
  80. about to put de-k in.... Want to get headers
  81. Apexi V-AFC II & S-AFC II
  82. MEVI vs. 00VI HELP!!!
  83. 3.5 swap... 5th gen ('00-'01) clutch?
  84. Coil Question
  85. Fuel Injector issue
  86. Clutch Question
  87. evap equipment with 3.5 swap?
  88. 350z IM on fwd maxima
  89. RPM switch
  90. Anyone used a jet vforce control module?
  91. removing swirl control valve on 01 de-k ?
  92. Want to get E-manage(old one, blue box) for NA
  93. Emergency Help Needed
  94. port / polish stock 4th gen intake/tb ?
  95. 2k2 VI control options
  96. Need VI assistance stat please..
  97. where to buy iacv adapter plate for 01 dek engine?
  98. Is it possible cruise control with VQ35 TB
  99. nismo adjustable fuel pressure regulator
  100. 3.5 swap, motor build...
  101. Apexi AFC information needed
  102. Any interest in my JWT HD Valve Springs
  103. 3.5 swap and emissions
  104. 01 maxima 300zx twin turbo swap
  105. 1 more Breathing NA TorqueMonster
  106. cheap motor
  107. VQ35 swapped
  108. G35 Manifold fitment issues
  109. ultimate exhaust for drag car
  110. Need more 3.5 cam drilling info *pictures*
  111. MEVI installation
  112. VQ Powered S13 Video Compilation
  113. SAFC-2 Configuration
  114. Dropped the VE off at the machine shop today....
  115. FS: 00VI kit
  116. got a great deal on vq35 + tranny...should i swap??
  117. how does your car run after the de-k Engine swap ?
  118. VQ35 300hp RevUp cams for <$600!!!!
  119. another 3.5 swap question
  120. 6spd swap in 2002
  121. Installing VAFC2 on 4th gen
  122. JWT valve springs necessary
  123. 5.5 vs 4th gen stock ignition timing
  124. Write up on DEK engine Swap in 4th gen ?
  125. will my tranny hold in a dek swap...
  126. O2 sensor questions..
  127. best way to remove engine and tranny together?
  128. question on removing a/c
  129. 5A valvebody
  130. Emanage Ultimate, or SMT 6
  131. Using hotter plugs in hopes to gain extra power...
  132. chassis dyno vs dynojet?
  133. Summit RPM Switch
  134. Which Piggy does it all?
  135. Exhaust cutout N/A
  136. VQ35DE 4th Gen: Shift Points and Dyno Shootout
  137. drilling cams
  138. fuel rail question
  139. VQ35 Oil cooler
  140. 3.5 swap question, very urgent
  141. Advancing Timing on a 4.5 Gen.
  142. Can vq35 maxima use Utec?
  143. Tach Going Crazy
  144. Requesting: Available N/A Mods for VQ35, please
  145. need 00-01 max injector clips asap
  146. E-gas TB
  147. Vacuum leak
  148. Servicing camshaft and exhaust camshaft sprockets?
  149. out of my knownledge problem
  150. 4th Gen MAF mod
  151. New VQ35DE 4th Gen: Dyno Included
  152. Any opinions on this ebay FPR?
  153. EGR valve with 3.5??
  154. tranny fittment?
  155. De-K swap
  156. 95 pathfinder parts?
  157. needs some 3.5 internal
  158. what kind of power would I be looking at?
  159. Any dyno comparisons of 00vi with it tied open or power valve removed?
  160. Looking for the pros and cons of different cam setups.
  161. safc II question
  162. ignition coils Q for swapped 3.5
  163. 2k max w/ full bolt ons Q
  164. 2k-2k1 maxima 5spd full swap car doesnt run?
  165. Need some info
  166. PF throttle body
  167. knocking??
  168. Difference in blocks
  169. 5thGen Tunning/ECU
  170. 2004 vq35de 6 speed in 4th gen
  171. 5th on 4th gen clutch set up
  172. 2004 maxima 3.5 engine and 6spd on ebay
  173. Tear this idea apart
  174. 3.5 Clutch setup in 4th gen
  175. VQ35DE stock injector CC's?
  176. What's the most beneficial A/F ratio?
  177. Bypass switch for ECU's?
  178. Could I Get Pictures Of 00vi Please...
  179. Motor Prep
  180. Yea right, RWD maxima...but what IF?
  181. Ideal All motor screamer?
  182. Customized MEVI?
  183. Building a custom VQ35DE intake manifold
  184. 5 speed auto for 98 maxima?!?!
  185. DE-K or 3.5???
  186. Apex-i S-AFCII/V-AFCII settings for vq35! Post #s!!
  187. What's the VQ35 cam wheel look like?
  188. O2 Simulators or O2 Sensor Extension?
  189. Some engine build pics
  190. vq35 heads on a vq30?
  191. VIAS Stuck but NOT actuator cup? wtf?
  192. Dyno tune Q's?
  193. turbo XS UTEC fuel managment system...
  194. mevi Questions
  195. need help...fuel problem
  196. MAF code after vafc install
  197. What numbers are we looking at with Hybrid Engines?
  198. apexi power FC
  199. Consequences of running 3.5 injectors/3.0 ecu
  200. Poll- Send ECU back to JWT for reprogram of 290cc injectors or tune via VAFC/SMT6?
  201. I want to make my motor stronger
  202. MEVI parts that are needed to install
  203. since ppl in 3gen don't believe me how about u guyz
  204. How Does 1999 Emission vs 1995 Emissions affect Performance
  205. 00vi
  206. Engine Simulation Software
  207. Where to Find Cylinder Head Bolt Tool
  208. A32 5spd in a A33
  209. '00VI problem... please help
  210. ahhh!! transmission wont shift after engine rebuild!
  211. VAFCII/SAFCII owners, plz step in!
  212. DEK Swap Complete - Rpms keep bouncing between 1600 & 2400
  213. wut year 3.5's can i use
  214. 8600RPM I would have known by now right?
  215. Thread to consolidate info about SAFC/VAFC, SMT-6/7 and EU
  216. 00 VI injector problem
  217. Pathfinder TB for sale
  218. What's the deal here?
  219. emanage ultimate
  220. VQ30DE fuel rail in VQ35 engine
  221. who has a JWT ECU in their 97-98?
  222. Port and polish pics
  223. Pin location for VI on 2k2 ECU?
  224. will a z32 maf work on the 3.5?
  225. MSD RPM switch??
  226. 3.5 Engine in 4th Gen.
  227. 3.5 swap pics?
  228. Cheapest place for ENGINE GASKET SET
  229. A few 00VI questions....
  230. Loosing oil fast!!!! WTF!!!
  231. Compression Results
  232. Weighed a bare VQ30 the other day
  233. Yet another 00 vi question...
  234. New SFR 350z Intake Manifold
  235. What is the fastest 4th gen auto? Check out my Dyno
  236. Fuel damper?
  237. megasquirt?
  238. Old Project of mine might not be dead...
  239. Can the SAFC II be used to increase fuel economy??
  240. how much timing is added with SAFC?
  241. Will the car run without these?
  242. 00VI VIAS Question
  243. V-AFC VIAS Engagement?
  244. How to Tune Max w/ S-AFC II
  245. For all those who swapped engines...
  246. Engine Difference?
  247. OOVI SWAP: Need Grocery List to get everything I need.
  248. Need work done in OHIO
  249. ITB's?
  250. injector CC sizes.........
