View Full Version : All Motor
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12
  1. 3.5 swap starts tomorrow.
  2. Great reading for the tuning n00bs
  3. light flywheel ?????
  4. Installing wideband on an Auto...
  5. need help getting in contact with tilley
  6. Overheating problems, tested the thermostat
  7. It's official...I maxed out the stock fuel pump all motor
  8. switch for 00VI
  9. 00VI Differences
  10. Little help...
  11. Where to get a vq35
  12. Starting a 4th gen 3.5 swap, need help
  13. CAn someone inform me on the DE-k
  14. race gas in a 4.5 gen?
  15. Almost done with wring 3.5 but a question
  16. 00'vi or DE-K?
  17. Injector Connector Options (3.5 swap)
  18. 00vi running Great but with, weird start up
  19. 5.5 6 speed swap... parts list needed
  20. 3.5 clutche(s)
  21. Question For the AUTO TECHS/ TIMING ADVANCE
  22. apexi auto timer (401-A011)
  23. would this motor setup work?
  24. Troubleshooting on the 00VI.
  25. How hot is too hot for a VQ35DE?
  26. Difference bettween Full 3.5 swap&3.5/3.0 modified?
  27. got WBO2 installed, need help with tuning issue...
  28. Anyone looking for pathfinder 3.5 heads?
  29. want to do 3.5&6spd swap,engine blown
  30. want to do 3.5&6spd swap
  31. 00VI install for $$$
  32. 3.5 oil cooler line is bend
  33. Thanks MAXIMA.ORG, and Tilly!
  34. Greddy EU 2-step - good video from the dragstrip
  35. need to determine optimal octane rating
  36. Question about EGR in 3.5
  37. vq35de in 4th gen guidence needed!!
  38. VG30E questions
  39. 00vi parts advice?
  40. Sudden RPM drops and stalling (Auto)
  41. need VQ35 block/crank/oil cooler? i got it
  42. Guys Running NO EGR valve
  43. What option should I get?
  44. Pcv 00vi
  45. SAFC vs. SAFCII
  46. o2 sensor bung welding?
  47. Bored 5th gen TB
  48. VQ30DE-K and VQ30DE TPS the same?
  49. Cleaning a MAF?
  50. ECU: SUPER LIMP MODE, Why?
  51. 6spd in a 4th gen, what axles?
  52. Checking for TDC on a VQ35 with no crank pulley
  53. Need your precious advice on 00VI
  54. Cam timing theory for 3.5 swaps w/out VTC
  55. Can someone w/ 3.5 & aftermarket cams help me out????
  56. Question: blown motor
  57. intake vac hoses
  58. Considering the EMU as first performance mod
  59. shorter belt to run without a/c
  60. Extrude Hone a VQ35 Intake Manifold?
  61. Car doesn't go into gear when on - URGENT HELP PLEASE!!
  62. 00VI, Dosnt start unless I tap the gas.
  63. JWT cam discussion I'd like yall to join in on please....
  64. vq30 power!?
  65. all motor 250 to 300 hp?
  66. Technos. Ecu or afc? (02' 6-speed)
  67. new update on 3.5 swap (leak down test results)
  68. 4rth gen 5 speed in a 2000
  69. EU in but some problems
  70. MY 3.5 and 5 speed swap 55% done "I THINK"
  71. 00VI Swap Photo Gallery
  72. Manual tranny swap
  73. 1999 Wiring Harness & 1995 ECU
  74. How to check for TDC?
  75. Recommended Online Store to buy Greddy Emanage Ultimate ?
  76. idle issues - high after driving (PLEASE HELP)
  77. Who needs a VQ35...?!
  78. Can we use 350z Pulleys?
  79. 00vi
  80. VQ30 on VQ35.. timing cover questions..
  81. complete pics of DE-K swap
  82. Emanage ultimate question
  83. thoughts?
  84. 5spd Conversion Issues
  85. VTC Cam Angles vs RPM
  86. porting vg30e
  87. Tilley or anyone else near queens, nyc to do 3.5 swap for me
  88. best year 4th gen for vq35
  89. Has anyone noticed...
  90. I need more power
  91. Spare VQ30
  92. OOvi help.....
  93. VQ35DE INTAKE SHOOTOUT: FWD IM vs. Z33 vs. Z33 + MD Spacer
  94. getting a 3.5
  95. VQ35 into my Altima??? is it possible
  96. Set some new N/A 3.0L records today - ET & trap (if I'm not mistaken)
  97. 00VI w/ stock intake
  98. Problems with DEK swap...
  99. HELP!!! 00VI install gone crazy
  100. Hard start
  101. 00vi clutch issues?
  102. VQ all motor Questions.
  103. VQ35 swap questions - near swap date
  104. Possible MEVI modification?
  105. 3.5 Swap no start
  106. Dek swap questions..
  107. Technosquare ECU upgrade
  108. 3.5 motor swap using 3.0 cams
  109. witch wideband whit Emanage U
  110. 6 speed swap questions
  111. De-k Swap Ecu Issue
  112. Anyone with Pictures of DEK swap..
  113. Need some VQ30DE guys to do me a favor - coilpack related
  114. 3.5 swap issues
  115. DEK swap: Starting issue
  116. Where's the Sentra VQ35 thread?
  117. Oil Pressure?
  118. Valvesprings spec'd. Nismo, revup etc.
  119. 4th Gen Transmission Woes
  120. Should I get a VAFC2?
  121. emanage blue harness question(s)
  122. 5-speed AUTOMATIC on a VQ30?
  123. Tilleys cost for 5speed swap?
  124. SMT6 for cheap
  125. vq35 cam spacer???
  126. VQ35 - Which year was best?
  127. Emanage Ultimate is in !!
  128. compression test results
  129. VQ35 RevUp cams in non-Rev heads w/o machining
  130. 6spd, VQ35 swap on a 4th gen
  131. Ultimate vs. ECU+SAFCII ??
  132. Here is a head scratcher!
  133. 3.5 usable parts on my 3.0?
  134. Air-Fuel Ratio?
  135. Tranny gurus, please step in...
  136. VQ30 - what type of lifters do we have?
  137. Anybody with VQ35 Airflow Data ????? (NA of course)
  138. dek timing case
  139. aftermarket cams and vaccum?
  140. Q: 00 IACV removal?
  141. which axles for anniversay VLSD 5speed in a 4th gen?
  142. So I just weighted my VQ35 on a bathroom scale...
  143. 3.5 swap VI activation Rpm switch /safc/EU
  144. 3.5 Swap Water pump
  145. what version of EU supports timing and rev limit advance?
  146. 95-99 (DE) Block vs. 00-01 (DE-K) Block
  147. Altima gears in a 4th gen
  148. Do we have an injection off feature???
  149. 5 speed swap clutch pedal question
  150. Any one know about the VQ33?
  151. on the dek rpm switch
  152. need to find a fuel pressure regulator for sale for maxima
  153. need help with vq35 swap in a 96 max
  154. De-k Question?
  155. Leaded vs Unleaded Race Gas In Maxima
  156. DEK swap: Jumpy idle and knock... need help.
  157. SC'd 3.5L up and running (well kind of)
  158. 70mm Throttle Body - Will Nissan Frontier/Xterra Work In Maxima ??
  159. High-Flow Cat & Y Pipe Questions
  160. Lets Talk EGR !
  161. Couple of Motor Swap Questions ?
  162. NextGear Thermoshiled Intake Manifold Gaskets
  163. what parts have copper, brass, or bronze??
  164. How much money are we talking for a 4.0L vq35
  165. Car shuts down on me... '00VI related
  166. Cams w/ JWT Valve Springs and Shim Kit
  167. MAP/Baro vacumm hook up...
  168. Where to find ARP rod bolts for VQ35???
  169. TPS question (3.5 swap)
  170. 4th gen UDP compatible with VQ35??
  171. Another VQ35 Sentra swap..
  172. 240 HP plan
  173. Hardest part of the 3.5 swap?
  174. Has anybody noticed...
  175. upgrade injectors?
  176. 00VI EGR Guide Tube Question
  177. there should be more 3.5 swaps on 5th gens
  178. Thinking about buying EU, but I have no clue what the install is like
  179. First-timer/noob pulls off 00VI install...
  180. 3.5 VI activation?
  181. EGR w/ 3.5 swap question
  182. Question on VTC
  183. A/F ratio at Idle?
  184. What do you think of this AFPR for 3.5 swap?
  185. Port n Polishing 3.5 Heads
  186. where does this coolant sensor go on the 3.5?
  187. Pics of TopSecret Race VQ (ITB)
  188. Advanced Timing
  189. Problems after header install and vafc II question
  190. 00vi installed...have a problem...
  191. mmm 3 grand to spend
  192. 2000 DE-K: Pre-6/99 vs. post-7/99?
  193. wiring diagram for VAFC II on a 2000
  194. Genisys 2.0 Scan Tool-TIMING ADV.
  195. Question about 4th. Gen IACV
  196. Will this clear the vq35 swapped cars
  197. patch harness ?? EU
  198. 00-01 throttle cable bracket part number
  199. bare 3.5 motor or direct swap?
  200. VQ35DE Stroker Kit
  201. Plastic caps on fuel injector nozzles...?!?!?!?!
  202. 00vi and starting your car up
  203. Realistic to run mid 13's ?
  204. anyone used the msd 8950 rpm switch for the 00vi?
  205. Is it possible to use the 3.5 IM?
  206. Anyone need a Pathfinder TB Adapter Plate???
  207. which gas for technosquare ecu on 95?
  208. 00VI w/ Stock Intake
  209. another 3.5 4th gen up and Runnin
  210. Quick Question on the 3.5 in an 02
  211. Anybody know the specs on the crank bolt?
  212. Upper intake manifold
  213. quick question
  214. More timing thoughts and questions
  215. 3.5 swap question
  216. DE-K 01 in 97
  217. Quick Question about dowel pins in 3.5 cams
  218. Quick Question about dowel pins in 3.5 cams
  219. IAB and PCV for 3.5 Swap
  220. updat on SC'd 3.5L
  221. Radiator design question
  222. Flycut cylinder head to raise compression?
  223. Tach Signal..
  224. My 95 isnt getting any spark
  225. New Generation of Vq35
  226. SMT for sale for those who dont check the for sale
  227. Any Write-Ups On The DE-K Swap?
  228. These are the right injectors right?
  229. Guys w/insane N/A setups
  230. Lower plenum butterfly valve removal?+ -
  231. check out my WB02 results!
  232. Pathfinder TB question
  233. VQ Sentra Swap Finished!! :)
  234. How much timing advance on a 3.0
  235. compatable MAF's for 3.5
  236. 3.5 crank pulley removal
  237. Rescaling the factory Tach?
  238. Oil in spark plug valve 4
  239. Fuel pressure/flow.
  240. Blown coils in a VQ35 swap.
  241. Successfully running 00 EGR/00 IACV
  242. New dyno with DE-K- 210 whp and 203 wtq
  243. 00VI install
  244. VAFCII Questions + Tuning Advice
  245. 3.5 Sentra Swap.. HUGE lack of power.. :(
  246. recycle the block
  247. Which o2 sensor wire to tap for A/F
  248. 3.0 is back in... and it wont start
  249. 3.0L vs 3.5L
  250. Pathfinder TB Adapter
