View Full Version : All Motor
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12
  1. Plug coolant line or T it?
  2. A34 Owner : 350Z I/M ?
  3. Installed JWT ECU: now motor lagging
  4. FPR help
  5. Variable Compression Engine
  6. 00VI Cutaway
  7. For those with 3.5s in 4th gen,please explain ur fuel setup/fuel pump regulator setup
  8. Oil Pressure
  9. 3.5 swap- can I use x, x, and x from 3.0?
  10. Should I keep wet kit or go with MEVI?
  11. Nismo 350z 262's in my 04 max
  12. Weird Emanage Problem
  13. What's your max advance on your 3.5L?
  14. 350z Cams
  15. VQ35 in Sentra.. off to the dyno..
  16. Clutch recommendations please
  17. VQ2.0 to VQ3.5 Swap
  18. Interesting Exhaust Read Turbo and NA
  19. How do you guys think this exhaust will sound..
  20. Which VQ is this??
  21. 3.5 Oil pump the same?
  22. It's time to play NAME THAT VQ35 sound!!!
  23. WHY is this not a sticky!?!
  24. 3.5 swap: update on "whining" sound...whaddya' guys think?
  25. Why do the 3.5s sound different from the 3.0s?
  26. 350z & Max ECU
  27. 4.5 gen wha clutch u using?
  28. anyone in the nyc area do 3.5 swaps?
  29. how the heck. 4th gen tb on 00vi
  30. car wont rev above 2000 rpms
  31. 3.5 starts runs bad no fuel
  32. SE-R Engine
  33. 00VI swap, PCV question
  34. question about dek swap
  35. 3.5 swap: what the he!l is this noise???
  36. Quick CPS question
  37. Main Cat output dia.?
  38. What 3.5L ECU would you use for a custom install?
  39. MEVI install help- which ECU wire to tap for RPM? (96)
  40. Mystery Misfire - Help Diagnose(Bare with me. Long)
  41. Another DEK Swap Completed
  42. Consolidated N/A links and reading
  43. Opinions on NA/Auto Mods (2000 max)
  44. ECU Compatibility
  45. Suggestions for intake tubing for 3.5
  46. MEVI not activating..
  47. 3.5 swap problems, hesitation + codes
  48. VAFC-II tuning vs. JWT ECU
  49. VQ35 Swap using 6th gen alternator
  50. 3.5Cams install help.
  51. CEL problem
  52. Vehicle speed sensor question..
  53. VQ35HR Block
  54. thinkin of doin 3.5 swap...
  55. 3.5 swap using de-k timing equipment in 4th gen?
  56. Help with A/F tuning & Datalogging
  57. 200whp MEVI vs. 200whp 00VI dyno comparison.
  58. Potential ill effects of PCV oil catch?
  59. Knock Sensor
  60. VQ35DE Skyline Intake manifold
  61. VQ30+stock ECU+MEVI dyno?
  62. Another completed 00VI with 0 problems
  63. Vq32?!?!
  64. EU question
  65. Remove power steering belt-increased power?
  66. hooked up vias finally... not working though
  67. EU Bretheren, I have a datalog for you.
  68. Engine Build ?
  69. VQ30 Rebuild Kits
  70. 00'VI / JWT Ecu Setup ?
  71. 00Vi -Strut Bar
  72. 3.5 Swap no start - THE LAST STRAW!!!
  73. 3.5 swap complete, idles too high, can't use 1st gear
  74. ? about rear valve cover when installing 00VI
  75. New 3.5L IM
  76. Just contacted SportCompactCar...
  77. Vacuum Assist Device on 5th gen TB
  78. i can smell fuel while driving..
  79. using vafc-II if there is a bad oxygen sensor?
  80. Help installing a Autometer Air/Fuel Ratio gauge
  81. 00VI parts
  82. ECU Question
  83. **********4th Gen, Doing a 3.5 SWAP!!!**********
  84. Is it a bad ecu, bad wiring harness or could it be the starter???????????
  85. 01 MAF in 4th gen?
  86. Plastics back!!
  87. Engine Size
  88. rpm drop after giving it some gas?
  89. Guys running NO Cruize ?
  90. can clutch hydraulic issue make clutch slip?
  91. need advice on de-k vs 3.5 swap. Cant decide which to go with!
  92. Need Questions Answered Please!!!!
  93. anyone have an smt-7?
  94. With Consult, can throttle pos. and shift pts. be changed?
  95. Exedy clutch won't go on :(
  96. Car in the shop for 5 days now...
  97. problems with motor
  98. swap sensors for the dek swap
  99. 6 spd in a 4th gen
  100. VQ35 S13 swap 90% complete
  101. My 3.5 acts like it has turbo lag!
  102. Calibrating the VAFC2
  103. 3.5 fell out of my Xterra and hit the asphalt...what do I look for?
  104. What parts do I need to safely rev a 3.5 to 7500?
  105. Jus a thought on the 4.0 VQ
  106. VQ30 cold start knock
  107. problems after eu install....
  108. quick gasket question
  109. 3.5 w/ RPM switch...hearing different stories re: how/when IM valve is actuated.Help!
  110. Greddy EU install, need help.
  111. curious
  112. 3.5L: Just installed RPM switch...at what RPM should it actuate???
  113. REF 3.5 or 3.0
  114. New Motor is In !!! Pics !!
  115. 3.5 swap IM question, won't bolt up
  116. Just rec'd MSD Digital Window Switch...installation questions.
  117. 99 ecu
  118. How to remove Valves and valve springs.
  119. 2000 VI swap generic hardware list
  120. Planning a 3.5 swap...what else should I do while the motor's out?
  121. Help diagnose a misfire
  122. 3.5 swap problem again...Fuel delivery?
  123. De-K swap + full 2.5in exhaust = a max that BACKFIRES???
  124. How to: Hook up 00VI ??
  125. 3.5: What does the white paint dot on each coil top signify?
  126. Dowel Pins
  127. vq30dek swap?
  128. 3.5 swap waiting on cam spacers, specs, where to find?
  129. A little help with Diagnosis Please
  130. Can I drill & tap the 2k2 IM?
  131. 3.5: very small oil leak...what can I do?
  132. 3.5L: Is it just me or does oil pickup at startup seem a little slow?
  133. vafcII vs. neo on 06 Max
  134. A BUNCH of extra ECU crap about 3.5 swapping ... you will probably never need it
  135. P-Finder TB and TB spacer?
  136. Summit RPM Switch Backorder
  137. Those with custom transmission setups, step in.
  138. A-little DEK Swap Help...EGR and gally
  139. 3.5 Swap Completed, Credits, Tech Issues and Plans
  140. This question's 4 all of you running an adjustable FPR!
  141. Top Secret Intake Manifold for the 350z
  142. 3.5 swap question: replace O2 sesnors?
  143. WTB: Injector Harnesses/Plugs for DEK/3.5 Motor
  144. mevi question
  145. 3.5 swap + pothole in the road equals...
  146. Spec V 6 Speed Transmission
  147. 3.5 misfiring at low rpms.
  148. VQ30 Oil Pump in VQ35
  149. 2003, 2004 auto tranny work in a 95(3.5) max. ?? .. yay or nay?
  150. rear o2 sensor ?
  151. Anyone Know what the most powerful 5th gen De-k is?
  152. 3.5 swap. Getting code 0701 now! Car runs great...what's up?
  153. Hey guys...name these three (sensors?)!
  154. *cam Spacers From Tilleys99*
  155. 3.5 motor & tranny has to be from same car??????
  156. Something wrong with my 3.5? Help
  157. Think my 3.5 swap's running rich (symptoms within)...SAFC or E-Manage Ultimate?
  158. Using TB Adaptors...
  159. Full 3.5 or reg......
  160. UpRev Cipher Write Up....
  161. UpRev Cipher DDS Write-Up
  162. 3.5 Swap....
  163. 00VI Compilation
  164. What is the proper procedure to check throttle position sensor adjustment?
  165. 3.5 swap done'ish and purring...one minor issue, though...
  166. 00VI PCV Valve setup
  167. Can timing in 06 be adv. w/ obd II?
  168. What's the torque spec for '97 flywheel?
  169. How to properly adjust/set up OBX-R external FPR.
  170. 00VI Wiring Questions
  171. 3.5 owners w/ debuloz/ebay cams
  172. Are '97 3.0 ignition coils the same as those from an '02 3.5 Max/Alt/etc.
  173. 3.5 swap: please check out these 3 sensor readings and let me know what you think!
  174. 350z cams in maxima 3.5???
  175. 3.5 Swap completed...Got fuel cut off problems past 5k rpms.
  176. V afcII..diagram for 00 max?
  177. The 3.5 swap won't start...please HELP!
  178. 3.5 Swap...no fire in 2 cynlinders! Help.
  179. EU Wiring Diagram needed
  180. Hotshot VQ35 headers vs. stock VQ30 for 3.5 swap
  181. pics of my 00vi what dont i need?
  182. 100% DONE and she's alive
  183. Z IM questions
  184. How to set TDC when skipped links?
  185. what year pathfinder TB?
  186. Where to buy ARP rod bolts for VQ35
  187. 00VI swap
  188. 3.5 swap! Has anyone retained the EGR from the 4th gen? How?
  189. EU Update Has Been Released
  190. 99 Maxima Engine
  191. Help! ASAP!Hotshot ypipe, why some have bend and cant and some dont??
  192. She is alive!!
  193. rpm switch differences
  194. how to Tell if a Block is warped.
  195. Need help setting up timing gear on the 3.5 swap!!!
  196. 3.5 swap: Summit RPM Switch/MSD Window Switch question! Help!
  197. Swapping engines
  198. exhaust grounding strap
  199. Physics and air flow experts please chime in....
  200. 3.5 swap parts
  201. 3.5 swap:cranks, sputters, dies.
  202. ECU & Headers
  203. Future 3.5 swap looking for 5spd advice...
  204. Vias Picture
  205. tunning masters please chime in
  206. Help -- complete DEK swap w/transmission
  207. A couple items FS....Nismo Cams and JWT VS's
  208. Need suggestions from the VQ masters
  209. 00vi gasket
  210. So I set the new revlimit record
  211. IACV hose routing on 3.5?
  212. How many revolutions can it take to align timing marks on the 3.5?
  213. Turbo Timer on NA
  214. Turbo Timer on NA
  215. 3.5 Swap done but cant start (no spark)
  216. Misfire code help
  217. 3.5 swap under way...anyone know where I can find (a set of 6) injector plugs?
  218. TB adapter for DEK
  219. noob question: how do you decrease or increase compression?
  220. ECU upgrade ...need help
  221. Another 3.5 swap complete in South Florida
  222. Anyone (w/ experience) interested in coming to MN (on my dime) to help w/ a 3.5 swap?
  223. Performance comp: stock '02/'03 SE MT vs. MT 4th gen 3.5 swap, full exhaust, intake?
  224. question for all vq35 swap guys
  225. E85 questions
  226. Alright guys check my timing(pics inside)
  227. Ts Ecu
  228. Tranny overhaul - extra (3 instead of 2) dowel pin
  229. quick FPR question...
  230. 3.5 swap question
  231. Swapping in a 3.5 in 1 week...have several questions!
  232. STUCK: 3.5 swappers need help removing ex. bolts.
  233. 00VI Adapter Diagrams
  234. Best tuning method?
  235. stock 97 ecu timing and a/f ratio?
  236. Brake problem after 3.5 swap!!
  237. 300zx Injectors
  238. Need Help On Dek Swap Im Stuck!!!!
  239. what type of tool to remove main bearing beam
  240. 2k engine swap parts list and instructions
  241. Dek Swap Progress
  242. New personal best on the dyno...
  243. E-Blue Setup. . .
  244. Motor Break-In Opinions
  245. WWWWWEEEEEEEE have lift off
  246. Need Your Help About Cams!!!
  247. SAFC2 Wiring
  248. No EGR!?!? HELP FAST!!
  249. 3.5 swap for tilley99
  250. Spark Plug Gaps
