View Full Version : All Motor
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12
  1. I'm gone for 2 months
  2. Think you future 3.5 swappers might want to consider this
  3. exhaust leak
  4. Wb wiring into cabin suggestions/questions
  5. Reved Up Vq35 Question
  6. 3.5 swap question
  7. 3.5 Injector option...
  8. Fuel Starvation Problem????
  9. 3.5 TDC position
  10. Stupid question about VIAS
  11. Best air intake for 3.5 in a 4th gen. ?
  12. S-AFC II install in a 5.0gen?
  13. Trouble with 3rd and 5th gear
  14. 3.5 swap in a 00 differences??
  15. Leak after DE-K swap, please help
  16. Skunk2 Intake Plenum Spacer: Nissan VQ35
  17. 00vi with front strut bar
  18. EU revlimit settings
  19. Stock VQ35DE cams for sale
  20. DEK Emange ultimate and Dyno jet= not so good
  21. Oil and water pump
  22. Tranny issue after 00vi?
  23. DE-K swap help on air fuel metering code
  24. 3.5 engine stand bolts
  25. 00vi swap- Curt's kit- replace fpr?
  26. VQ Engine Math problem - Experts step in
  27. vafc II
  28. Quick question about VK56
  29. Would Dual 2 Inch Cutouts Work For Me ?
  30. Big problem with 00vi swap
  31. 2nd 3.5 swap
  32. 6 Speed Swap
  33. Where to find Ground Kit???
  34. What does it mean when both lights are lit on the Summit RPM switch
  35. VAFC2 Problem. Cannot trim fuel.
  36. Those with 3.5 4th Gens...
  37. Anyone have a 5-speed ECU lying around
  38. Fuel system questions
  39. 3.5 bottom end w/MEVI
  40. VQ35 swap with VQ30 ECU wont start.
  41. Can I use VK45DE Ti valve train in Vq35de Heads.
  42. technosquare ecu question
  43. walbro fuel pump
  44. timing chain replacement for the 3.5 swap
  45. VIAS Problem
  46. Shift_Fast_2 diagram just in time for Xmas !
  47. Removing Timing cover
  48. 97 exaust manifold on a 2001 cali
  49. 5th gen-3.0 to 3.5
  50. Advantage of a Pathfinder TB on 5th gen?
  51. Re-drilling cams to advance Cam Timing
  52. WTB: VQ35 fuel rail
  53. Big Problem With 00vi Swap
  54. Flirting with the Idea: Built vq35de
  55. 00VI- tuning required for 00 lower/injectors?
  56. VQ35 A32 w/ A32 JWT ECU will not Idle
  57. 3.5 swap exhaust manifold
  58. 3.5 Harness.
  59. My short ram 3.5 IM setup
  60. 00VI EGR Block Off Plate
  61. WTB : broken VI's
  62. How much would i be looking at spending
  63. What's best way to remove "the shelf?"
  64. Some electrical issues... Please step in!
  65. how many miles on your vq35 swap?
  66. pathfinder VI install
  67. . . . it was the Pathfinder TB
  68. downloadable fsm??
  69. Vq30dd
  70. Anyone ever have to replace the Vacuum Solenoid for their VI?
  71. do z32 injectors work with 4th gen MAF?
  72. wide band question
  73. de-k injectors in 4th gen w/ stock ecu?
  74. Hesitation and misfire on cyl 6
  75. check engine after 3.5 swap
  76. polishing lower intake manifold?!
  77. 4th gen wont start after v2 removal
  78. ok the 2nd cv axel in a month
  79. Is this common on 4th gen injectors?
  80. afc
  81. rebuilt trans pops out of third gear.
  82. Blown Tranny and/or Clutch.
  83. Bubbling Coolent?
  84. RPM questions?
  85. will a 90 se and 92 se engine swap work?
  86. Transmission Question
  87. 8000RPM reliable shortblock
  88. Swap Specific Questions?
  89. I think I may have found a typo in the FSM!
  90. 00VI: vacuum hose check, will crank but not start ? (photos)
  91. In the middle of VI swap, question on fuel rail
  92. Spare VQ30DE
  93. No crank after 5spd swap
  94. anyone with 99 cali spec with DEK engine?
  95. 3.0 and 3.5 head bolt thread pitch and diameter the same?
  96. 3.5 in a 3rd gen
  97. 98 engine on a 95 max
  98. Deck the heads?? i think
  99. plan on doing a 3.5 swap take a look. If you've done a 3.5 swap take a look.
  100. MEVI installed: manifold actuator not activating (long)
  101. Help with VAFC2
  102. pathfinder intake manifold...will it fit?
  103. Who drills 3.5 cams now?
  104. 2002-2003 intake manifold power valve
  105. 00VI concerns: IACV and PCV valve setups
  106. To all Emanage ultimite users
  107. DEK swap...coming soon
  108. I need help! NATS system malfunction..
  109. Auto transmission questions - Aaron92 and others come in
  110. It's almost race day....*veterans chime in*
  111. slick Q's
  112. ECU Compatablitity HELP!!
  113. fuel pressure problem.. and running lean!
  114. Coil Packs Causing Misfire?
  115. choices other than the Cartech/Vortech for FMU?
  116. Blown Tranny, Now what?
  117. Head work VQ30 heads vs VQ35 heads
  118. Another Pathfinder TB Related Question
  119. I have a question
  120. Calling all those using a Walbro 255LPH fuel pump!
  121. ECU differences...
  122. 3.0/3.5
  123. Im EXCITED!!! ...to say the least
  124. Please link me to 4th gen TPS/idle adjustment procedure!
  125. Safc2 wiring question
  126. To those with trouble maintaining 51psi on a 3.5 swap!
  127. MEVI question?
  128. VQ35 in formula 3
  129. TPS Question
  130. Pathfinder TB Cold Start Issue
  131. Alternate throttle signal pin & ECTS experiment.
  132. coil firing Qs
  133. 3.5 swap: car running rough
  134. Air/Fuel Tuning Question
  135. Greddy has a system to tune CVTC!!!
  136. emanage blue questions
  137. UDP Belt's
  138. Starting Problem: no spark
  139. IACV on a 3.5 swap General Question.
  140. 5th Gen TB or 4th Gen TB on 00VI swap?
  141. Need an engine for a 95 max on the west coast
  142. 3.5 swap: fuel pump not priming
  143. after dek swap im getting knock sensor code
  144. bigger injectors?
  145. 3.5 swap: Modifying fuel line
  146. what to do w/ EVAP & iacv hoses if i'm not using them
  147. Been out of the loop for a while... lil help would be GREAT!
  148. Headers design
  149. ? about shift-fast mod
  150. Have a question on converting 3.5 TB to wire driven.
  151. Emanage Blue and tach issue...
  152. 3.5 SWAPPED motors and their Tranny's
  153. motor ????
  154. Msd Rpm Switch 8969
  155. A good read about spark plugs for the n00bs
  156. EB not letting me activate VI...
  157. **MEVI-need help wiring the relay**
  158. car runs richer after cai install
  159. 00VI Starting Problem
  160. Another Complete 00VI Swap!!
  161. Unorthodox Flywheel on a 3.5 swap??
  162. Cosworth Plenum
  163. 3.5 swap in progress, need double check on timing chain install
  164. High/Odd Idle +Vacuum lines
  165. cam adapters problems
  166. Cooling System Went Caca after 3.5 Swap
  167. trouble with plugs
  168. Did the Z IM make power over the stocker?
  169. 3rd gear pull n stock 95with a dek (data log) air fuel
  170. 3.5 swap in a 5th gen?
  171. ????
  172. Vafc Ii
  173. Need serious help guys
  174. huge misfire..no codes
  175. A few questions about AFC and such..
  176. What do you think??
  177. shimming 350z thermostat
  178. SMT6 installed and need help
  179. rebuilding 3.5L
  180. got vq30de-k 2day, where do i start on removing 00vi parts?
  181. Pathfinder TB Question/with 00VI ??
  182. SS Autochrome Headers
  183. An Unsolved mystery-- (for me at least)
  184. Wb o2 time..
  185. noob questions about greddy emanage
  186. VQ35 VIAS question
  187. Help with MSD 8950
  188. Engine break In.
  189. HELP GUYS! VERY odd mechanical 3.5 swap problem!
  190. Mfa60
  191. Switches
  192. Engine Controls
  193. How often do you break brand new axels?
  194. 3.5 swap question
  195. EU version 2 has been officially released
  196. Use Innovate LC1 to replace stock front o2 sensor?
  197. 00VI Idle Issues.. Possible Vacuum Leak.. Help
  198. Tuning with fuel pressure regulator.
  199. What is the best rpm for the 00vi to open?
  200. best rpm switch to use for the 00vi
  201. Problem 2nd gen
  202. I want to modify my PCV setup...
  203. Scan Tools, whats everyone using?
  204. Idea on what air fuel for the rpms
  205. Weird Limiter Problem: EU
  206. Zeitronix Questions
  207. Vq40/vq35
  208. Pics of modified 3.5 IM
  209. VQ30 Pathfinder Manifold install?
  210. Anything else needed fo a direct swap?! : )
  211. Wideband O2 Question
  212. water pump in VQ20DE vs VQ30DE
  213. weird fuel problem now (dek swap)
  214. I HATE my engine!!
  215. Dek Swap Help asap please
  216. Re: Throttle Body For 3.5 Swap
  217. Rear o2 sensors necessary on 02 vq35?
  218. dek idel problem thread
  219. 3.5 head swap
  220. 3.5 swap having loud noise
  221. Installing a Catch Can
  222. 04 350z head fitment....
  223. Cleaning Up Fuel
  224. Wideband O2 Zeitronix Zt-2 install
  225. New Apexi SAFC-II Being Sold
  226. 5 speed convertion
  227. A/F problem for you Guru's...
  228. Prepped VQ35 from 95 to 00-01?
  229. Best clutch for 3.5 4th gen swap
  230. Lapping valves and clearances
  231. QR25DE, VQ35DE and VK56DE = Same ECU!
  232. Engine harness removal question...pretty urgent.
  233. Zeitronix now has linear output WB O2!!
  234. dek fuel rail things where to get them
  235. clutch stage = clutch stiffness?
  236. 5-speed swap...Questions???
  237. Dangers of over-revving?
  238. Did the Dyno on the DMC.
  239. Question about VAFC
  240. Wtb: Afpr
  241. Motor contemplation time.
  242. witch wire for neo to run the VI
  243. VK45DE and Pathfinder VQ35DE heads what can I use? *pics*
  244. Emanage ultimate setup questions
  245. Injector Mystery
  246. 3.5 complete . . . running rough
  247. 3.5 + Spec Stage 2 = frisbee!
  248. doing a DEK swap vs VQ35 swap
  249. Random New 00VI Information
  250. Greddy E-manage Ultimate Installation Write-Up
