- Congrats, new All Motor moderator!
- just wanted your opinions on my 3.5 swap video
- 00vi cup position....driving me CRAZY
- Finished the swap.... but one more problem...
- Verify my timing...
- Anyone know about resonators/mufflers and sound?
- SFC-VTEC controller
- Where to set the 00VI switch over point?
- need help with 3.5...
- Vq30 sleeves?
- techno square ecu for 02' 3.5
- Fuel fittings - 00vi
- Car Wont Stop Running - Help!
- VAFCII question
- Bad fuel pump?
- Aftermarket Ring and/or Piston Question
- MEVI installed, now getting 0205
- Just want to make sure this is normal...
- Wbo2?
- vias info
- help
- Summit RPM Switch - MEVI
- Looking for a Thread about a 3.5 w/Nitrous getting 350whp!
- Boost + High Revs?
- Field sfc-hyper r
- 00VI swap running rough
- Double-checking on VAFC install
- IT'S ALIVE.....Well sort of
- 00VI Throttle Bracket
- 3.5 non-floating T.C. guide?
- Are the secondary (downstream) O2 sensors really by-passable?
- Emissions in VA, ECU not ready.
- 3.5 swap car wont start...please help
- Differences between stock MEVI equipped VQ30 ECU and USDM?
- 00VI brain teaser (unexplained cold start issue)
- 3.0 removal
- 3.5 in a 3rd gen?
- Larger MAF, fuel and timing mod
- TPS Caliberation & external Ground please advice
- Fuel pump wiring Q
- Okay... needing last minute opinions
- camshafts
- need some help
- 3.5 swap fuel and napa injector harness connections
- Supercharge vs 3.5 swap
- DEK Swap
- UDP Problem.
- 3.5 swap flexplate pin hole....
- VQ35 + 01 PF TB = 3000rpm idle
- DEK timing cover different?
- Emanag Ultimate Update 2.11
- Help with my 3.5 swap....
- ecu upgrade reccomendations
- Finally it's done - my EU writeup inside
- 3.5 cam swap, which gaskets should I replace?
- Preparing for a 3.5 swap
- EVAP, EGR & Emissions
- VQ37HR VVEL discussion..
- EU update v2.11
- To those with the 00vi and get the cold startup/stall
- 3.5 intake manifold on 3.0???
- 3.5 swap timing swap problem
- MEVI, EU, advanced timing = ........
- 00VI, JWT ecu and VAFCII question
- 4th Gen VQ30 MAF calibration chart
- Quick Question Regarding Cams
- Didn't want to ask this but I need answers
- My turn having difficulties with the swap...
- O2 Sensor Heater circuit resistor
- 00VI+injectors-rail wanted
- Timing on 3.5 motor swap... valvs bent?
- mevi slowing my car down?
- 350z camshafts
- Cam Plunger: 3.0 vs 3.5 same?
- 00VI swap, butterfly valves in LIM?
- VQ35 cam swap timing in a VQ30
- coming clean
- DEK swap - running the hoses
- Engine Dilemma
- 00VI Help, AGAIN!!
- 00VI + EGR removal??
- Anyone interested in a standalone system?
- Kinetix SSV vs. Port and Polish
- questions about 300zx 370cc injectors
- EU parameter settings. help needed
- Stupidest ideas ever? possibly but take a look anyways
- doing open headers?
- my progress on the 3.5 swap
- VQ30 Maxima, VQ35 Pathfinder, VQ35 Maxima Cylinder Flow Data
- Wondering about port and polish my 4th gen?
- need help with 3.5 swap???
- Please jump in
- Forcing the ECU into open loop with the EU
- Opinions on Air/fuel tuning options
- 6speed bell housing
- Wideband o2 sensor by fast technologies
- stand alone ecu
- A few questions before i start my install...
- Please Help Me I Dont Know What To Do!
- Different b-pipe vs MAF % usage.
- timing equip. removal BS!!!
- Walbro+AFPR=crazy A/F ratio
- Controls and Switches
- walbro 255 hp
- Do I need to adjust my AFR?
- This is why untuned 3.5's need to get a fuel adjustment program.
- vafc II wiring questions
- 5th gen wot fp
- Flywheel Installation Advice
- E-manage Blue vs VAFC II
- New OBX Headers - some photos and measurements
- Proper MEVI activation point (VID + Dyno)
- need help with my car
- emanage ultimate
- EU write-up corrections!
- Couple of EU wiring questions
- Innovate LC-1 problem
- Making connector for EU - Help!
- Building up a 5spd transmission
- 3.5 IM on 3.0
- Worst Luck EVER!!! engine swap!
- Surging Cruizin Control....Pathy TB
- CEL after swap....
- MAP/BARO solenoid
- Wideband in S pipe after cat?
- Nooberish Cam Timing Question
- Best resonator to get rid of droning?
- I need some help. VQ35 in a Sentra (pix)
- Technesquare ECU and VAFC-II
- Torque specs for Rod Bolts??
- I want to rebuild my vq!!!
- Yet another Header Question
- Problem...during my swap help..
- need some help with my motor
- Headers Comparison (95-03)
- What else to change when replacing your clutch?
- Can't reset check engine light...
- Best (budget) afpr
- Is this TDC?
- Sealing MEVI butterfly valves?
- Upgrading the transmission
- dek swap + exhaust
- Apexi AFC Neo
- Catch Can Questions
- afpr install trouble
- Rear main seal part number plz...
- a/f ratio gauge...
- Header question
- 5th gen clutch on EU'd 3.5: Almost a year later
- Installing EU tonight, just a reference b4 i start...
- Question about ITB's
- Ignition timing advance 5gen motor, 4th gen ECU PLEASE READ
- any ideas...
- sfacII wiring diagram 5.5
- Hard starting! Need help!
- Broke Timming chain tensioner
- Issue with 3.5 swap
- 1)MAF question & 2)third gear issue
- please help me find the rod weight
- Transmission mod for 6th gen?
- 5.0 Gen Valve Body vs 4th gen valve body?
- 3.5 and 6 speed swap in a 5th gen
- 350Z VQ35 in a 4th gen???
- Critique my possible VQ35DE build-up
- nismo knockoffs vs stock 3.5
- fuel psi regulator ?
- 3.5 tune up?
- 3.5 question
- Greddy EU owners Chime in
- OK!! Someone PLEASE help!
- 02 simulators
- 3.5 Injector Harness
- E-Manage Ultimate: Worth it for NA + Nitrous
- Alright I'm completely stumped...
- VSS...Auto - 5 Speed Swap...HELP
- What CAI to use on 00VI swap?
- 3.5 swap spacers.
- 3.5+00VI+7200rpms=Valve Tap!
- Set summit to 3.2k, opens at 3.3k
- EU question regarding resistors
- Putting my engine on a diet
- Vq35de Vq30de Engine Transmission Overall Exterior Dimensions
- Wide band o2 advice?
- O2 sensor wire colors? O2 simulator install
- 5-speed syncros aftermarket
- Thoughts on 5spd Auto swap?
- Sparratic issues at idle and decelleration. Simply O2?
- 3.5 swap issue! >:(
- VQ35HR Piston Pics
- Probing Q's about looking for a DE-K engine
- 3.5 Done!!!
- Dr Mod
- 3.5 swapps still going for the same price?
- 00vi idle problem need help ASAP!!
- VQ35DE in a B14 (long)
- Greddy V-manage
- Ok...what am i missing, also injector wires Q
- dek/non dek egr locations
- 3.5 intake cams in 3.0
- F/S 3.5 6speed Belhousing
- Crank and Cam sensors voltage
- WTB:Cam spacers
- How much Vaccuum for MEVI operation?
- 2nd opinion please
- V-AFC2 in a 1999ES (can spec) VQ35DE 2003
- Car dies shifting from 3 to 4th when redlined
- WTB: 3.5 Parts
- what year max = 3.5swap
- Engine harness for 3.5 swap
- reluctor ring
- Knock readings with S-afc2
- Vias nipple setup (photo diagram)
- TPS mystery
- AHHHH, HELP ME! Crank POS issue!
- What TB to use on 00VI swap?
- New VQ tech data for 2007
- 35 LIM Q's
- V-afc2 In A 99es 3.5
- Pathfinder TB - ?'s/concerns/thoughts
- Headers questions/opinions
- Pathy TB Cold Start Fixed...Pics..
- z32 maf in 00
- Cheap wideband for tuning? EU worth it?
- Which Year 3.5
- Engine removal
- DE-K Swap ?????
- VQ35 with 3.0 ECU Write-up.
- 00VI Complete (engine bay photo)
- Local 3.5 S14 Buildup
- Ridiculous starting problem persists
- Need some help finishing up a 3.0 4th gen overhall
- Proper way to tie 00VI open ?
- Pilot Bearing
- cANT get et streets to hook
- Anyone know anybody who did a roll cage in their max-any pics, experiences, thoughts?
- AFR tuning?
- 3.5 swap timing chain alignment
- 3.0 water pump gear on a 3.5 water pump??
- FS: 3.5 JWT HD Valve springs and shims
- Diagnosing check engine codes
- pulled code from ecu
- Gauge cluster options
- 00VI swap: EVAP Canister Purge Control Valve
- Help With 3.5 Swap
- 6 speed
- Just installed headers; have a few small issues...
- NOOB fuel questions
- auterra odbII scaner
- Hybrid Q
