View Full Version : All Motor
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12
  1. Causes of detonation/pinging? Loud noises coming from engine...
  2. Differences between 04 and 02?....
  3. So i run megasquirt // lets talk advance timming
  4. VQ30DEK Exh Manifold, what year has the EGR plug?
  5. VAFC II Install Problems . . .
  6. Stock or aftermarket cams - moved out of F/I section
  7. 3.5 swaps re: 51 PSI
  8. Hybrid swap
  9. almost done with my 3.5! Couple Issues
  10. Idle@1500 rpms
  11. Torque converter ?
  12. new cosworth head gaskets..anyone?
  13. I own the slowest f-ing 3.5 swapped fourth gen in history
  14. VAFC II tuning on a 00VI
  15. More problems with the DEK/EU...
  16. Timing Chain Rattling on 1st start..how long
  17. Probable inline air filter?
  18. 300hp N/A
  19. A/F graph observations please
  20. 350z IM in a maxima
  21. To all the 4.5er's with EMU need some input.
  22. apexi neo + jwt ecu?
  23. Lack of torque in 3.5 swap?
  24. 3.5 Swap, what timing components do I use?
  25. NX rpm window switch
  26. BBMAF Installed!!
  27. GI in 6speed timing rings for the vq30ecu
  28. Q45 TB on 00VI
  29. 3.5 swap stalling after WOT runs
  30. VQ35 swap: MSD 8969 Question.
  31. XJinCT's 3.5 swap problem thread
  32. Would i be better off?
  33. causes of clutch disc spring failure
  34. vq 35 swap with 4th gen knock sensor?
  35. How To: Correct jumped timing...
  36. head stud for mild build?
  37. Pulling Motor/Trans Question
  38. cryo and shot-peening the transmission
  39. ? Good cams for a 3.5 build ?
  40. Bought a VQ30DEK for a 95, befor I get started . .
  41. Recommened parts to improve top end VQ35de
  42. UTEC in a 4.5
  43. Butt Dyno with my 3'' MAF
  44. VQ Dry Sump?
  45. Found some alternate 5spd gear ratios
  46. VTC Solenoid Blockoff plates (pics)
  47. Manifold coming off.. port and polish??
  48. VQ35DE question....
  49. mevi + what ecue in a 99?
  50. flywheel timing ring question
  51. gas puddles in cylinders
  52. VAFCII install help.. CEL
  53. Intake valve timing control solenoids on 3.5 swap
  54. New HR goodies...
  55. PLEASE HELP? 6sp swap in my 00 vq30dek
  56. Ign Timing Logs Relative to MAF & Correction- Need Help
  57. Knock Logs
  58. Stock valve springs + aftermarket cams
  59. VAFC removal question?
  60. FS: PLX R-500 wideband AFR datalogging computer kit
  61. breaking up after 6speed swap
  62. Removed the butterfly on my vq35 today
  63. 350z TOB in Maxima 6spd?
  64. (3") Big Bore MAF Housing (General Discussion)
  65. Air Temp & Humidity: Effects on performance
  66. Cant get Autotune to work on my EU....
  67. Complete Port/Polish VQ35DE Intake Manifold + Spacers
  68. for those with a n AEM FPR
  69. Stock MAF Housing VS Big Bore MAF Housing (76.2mm ~ 3") Technical Discussion
  70. Timing Advance - Definitive Proof
  71. Yet another 300+ WHP build....
  72. Where to get....
  73. 3.5 swap getting me angry now
  74. Air Filter Restriction %s
  75. Datalog sheets
  76. TQ convertor removal???
  77. Tis the season for Oil Pumps
  78. Brian Crower Camshafts?
  79. quick 3.5 question
  80. Stupid question regarding chain guides (3.5 swap)
  81. Fidanza Doesnt Fit
  82. 3.5 swap on a 4th gen central Florida?
  83. XJinCT's VQ35DE swap/progess thread
  84. **Read-me** VQ35 and 00VI swap info
  85. Anyone with Stillen Camshafts, please step in!
  86. VQ37VHR Tech Data
  87. Opinions need on recent mods...
  88. Exhaust theory on x/y-pipe placement
  89. Quick question
  90. How much horse can 6 sp. and 3.5 Handle?
  91. 3.5 swap with 3.5 pans
  92. Another 6speed 4th gen up and running
  93. AFR 1st gear vs 3rd
  94. What are these wires coming out of my JWT ECU?
  95. 35 swap on the cheap.
  96. SMT-7 Basemaps
  97. 00VI on Supercharged 4th gen rough idle and then dieing
  98. quick question on 3.5 timing
  99. 3.5 swap no start...
  100. TB with 3.5 swap
  101. TB Restrictor plate?
  102. techno squares ECU
  103. Finally!! Emanage Ultimate installed in a ’99
  104. VAFC2 Tune
  105. WOT - heavy miss, intake backfire, stock VQ30/ECU (lengthy)
  106. Question: 300zx in a Maxima?
  107. 3.5 timing question
  108. RPM signal for mevi on 99 max
  109. Problem after swap....
  110. Its official. The 3.5 swap kicked my butt
  111. 00VI idle problem
  112. strange timing position of 3.5 cams
  113. how to prime a timing chain tensioner?
  114. Can't remember. Anyone use Split Second products?
  115. PF TB adapter plate trouble...
  116. FP gauge and fuel tee
  117. TB cable bracket...
  118. Enlarged MAF...
  119. question
  120. Chain Tensionor ASAP
  121. another 3.5 timing question
  122. SOOOO mad right now
  123. Pathfinder TB w/ 00VI, does not fit?
  124. Taller 5th gear?
  125. 3.5 upper oil pan dust cover plate?
  126. i cracked a damn cam so i need one, and some 3.5 swap questions
  127. Wideband o2 Hookup.
  128. E-Gas what exactly is it?
  129. Has anybody done a true dual exhaust on a 4th gen?
  130. E-manage Ultimate Rev limiter
  131. ECU Swap vs timing gear swap
  132. high idle after eu install
  133. 6 Speed Starting Problem
  134. Pulled 3.5 oil pan, found a metal chunk
  135. anyone with a 5speed swap figure out how to get rid of code 1003
  136. eu install and tuning questions
  137. hesistation and hick ups between 2k-4k rpm...
  138. Where do I wire VAFC to NX window switch.....??????
  139. VK45 Throttle body.
  140. dek hard start
  141. Quaife Differentials V. 3.5 Swap
  142. Lean when braking
  143. Is a UDP worth it?
  144. Pcv Question
  145. First AFR/Timing Map, Opinions Please!
  146. Weird hesitation/stalling with 3.5 5 speed swap
  147. injectors
  148. Typically how many rpms can the 3.0 handle before something breaks?
  149. radiator/fan assembly
  150. 3.5 swap cam question
  151. tranny gurus please step in(3.5 swap)
  152. question about 3.5 swap
  153. Crank Shaft?
  154. Stroker motor build ?
  155. Tuning settings for DEK and VAFC II HELP>>>>>>
  156. 4th gen radiator after VQ35 swap, help please!
  157. Stock pump to walbro... problem? help..
  158. 1/4 Mile Time in a 3.5 Swap
  159. Flywheel rust?
  160. 04+ Max EGR into Gen 4 Swap Q?
  161. Need Help Asap!
  162. Exedy Stage 1, is it enough for 3.5?
  163. Fuel injector question
  164. 3.5 swap question
  165. vq35 and vq30 water pumps
  166. 3.5 exhaust cam gears
  167. Pathfinder TB
  168. Upper Oil Pan Removal
  169. 3.5 swap slowly but surely
  170. Knocking and Ready
  171. '07 Altima IM
  172. 3.5 help...fuel is driving me insane...
  173. 6 spd in a 4th gen swap procedure & faq
  174. EVAP code 0111 since doing 00vi swap
  175. Nissan WONT touch it! WTF!
  176. VQ 37 HR dyno!!!!!!!!
  177. 3rd gear vs Axles, Raxles, and rotational mass
  178. Well it was the oil pump...
  179. 30 Valve covers on 35 head Q's
  180. ECU code and stored info....
  181. Vq35de(350z) cams in a Vq30de
  182. DEK jumpy Idle
  183. Tilley Still Sell Preped 3.5's?
  184. 3.5 from which cars
  185. starting problem after 6spd swap
  186. Air/fuel ratio Guess
  187. What parts needed for LSD trans swap?
  188. 5 speed swap stalling issue
  189. 3.5 with 3.0 Valve covers, possible?
  190. What am I missing from this motor in order to complete this swap?
  191. Switch Panel Finished
  192. HKS Pistons and Connecting Rods... can they work our swaps?
  193. 3.5 swap, Cam drilling
  194. Technosquare or E-Ultimate for 3.5 swap?
  195. DEK Swap - Vacuum Problems
  196. q45 tb on vq35?
  197. EU/car difficulties
  198. Engines out and apart... what can we do while i have it open?
  199. 4th gen 3.5 swap compression
  200. fidanza flywheel install problem
  201. Throttle Stop Canister
  202. Datalogging/Tuning?/Motor IssuesSo
  203. How much did you spend on your 3.5 swap?
  204. Napa vacuum canister part number please? (MEVI install)
  205. issues with neo and 00vi
  206. List of members who have done the VQ35 Swap
  207. 3.5 swap cold start problem
  208. Who has the Cleanest VQ35 Swap?
  209. OK! Whats going on with my car?
  210. Installing Flywheel Tomorrow - need advice
  211. Let's see your mallfinder throttle bodies.
  212. Where else to get Crank POS Harness?
  213. Installed VAFC2
  214. Clutch recommendations
  215. Power loss after 80 - 90mph
  216. 00VI/VIAS help
  217. 3.5 short block
  218. which air fuel system to use for 3.5 swap
  219. 4th Gen TCU Wiring
  220. 3.5 swap SOOO worth it
  221. 3.5 swap help???
  222. 3.5 Swap, EGR, and Pilot Bearing?
  223. Walbro 255 + Stock FPR + E-manage Ultimate
  224. flywheel break-in?
  225. DEK swap
  226. 3.5 swap good for a Daily driver?
  227. Fan Control Mod
  228. Some 3.5 info Needed
  229. 00vi swap
  230. 3.5 horsepower
  231. 95-99 VAFC II Writeup Complete.
  232. VQ Valve Spring spec. charts
  233. 5-speed transmission rebuild/overhaul
  234. Mevi Swap Questions
  235. What would I need for a 6 speed swap?
  236. Those with 3.5 swap....
  237. Fellow 3.5 swappers-- question
  238. 00VI EGR Problems
  239. How much is a 4.5 gen worth?
  240. VQ35 in a 2k1.
  241. fuel pump wiring question
  242. Drop in RPMs to 200....
  243. apexi neo tuning
  244. 2nd Guessing Cam Install due to difficulty
  245. oo vi reliabillity feedback
  246. Returnless question
  247. 00-01 injector plugs
  248. need help with 4th gen vq35 swap
  249. 305 WHP all-motor 350Z!!
  250. Congrats, new All Motor moderator!
