- 2000 engine in a 98
- Want a VQ35 in my '98
- How to make '00 VI work with 3.5?
- 2k1 motor in my 99, what else do i need
- Fuel going to be ok?
- Fuel pump worth it?
- Getting the 00VI on my 97
- Advice on headers install
- Crank shaft Knifed Edged?
- Yet another, 00VI question
- New and "improved" 2005 VQ35 Rod Bolts <$30
- TS ECU with upgraded limiter is complete :)
- new at NA forums...
- Darton mid sleeve kit
- JWT cams for VQ35
- Nissan Consult
- Somebody throw this in a 4th gen
- EVO II (Wanna be) Didn't fit so well
- which new parts for cam install?
- ARP rod bolts "NEED INFO"
- FrankenVQ
- Head talk
- Sizes of Various Throttle Bodies
- NA 2002 Maxima goes 12.859 @ 108.00
- Car is going under the knife need advise
- auto to manual swap questions
- Pathfinder TB for sale
- ecu question
- Extrude Honing
- Frontier
- Removing pre cats on 02 3.5
- Difference between the 00vi and mevi
- what can i do...?
- Whats the best NA IM design??
- Exhaust gas velocity ?
- MAF opinions?
- VE on our VQ?
- 4th gen MAF?
- 2000 Maxima motor, Will it bolt up to 95' 5speed Tranny?
- 00 VI question
- Basic VI checklist with some questions
- Is there a writeup for '00 vi on 4th gen?
- 2k1 5spd Fuel Cut Increase?
- AFC wiring
- VG30DE vs VQ30DE? 300ZX motor top-end swap..
- Compression testing
- VQ35 Piston/Piston Ring Options
- NA fuel upgrades.
- New To This...need help.
- all motor with greddy emanage
- Question on 97-2003 custom max. straight pipe?
- Throttle Body
- VQ35 in 2k max?
- 01 cams
- 3.5 down!!!!
- Speculation at gains on a VQ30 just from stock VQ35 cams?
- interesting find with pocket logger
- Crazy Tach
- Need help ASAP before i make a Purchase!!!
- 96 with a 3.5 in it link inside
- 3.5 head on 3.0 bottom
- vi question
- need help with 3.5 swap
- help vafc to control 00vi
- Abs
- 3.5 Bottom And 3.0 Heads Finnaly Running
- 00VI install help
- any 4th gen ecu work with 5th?
- Adapter plate? I don't need no stinking adapter plate..
- Making adapter plate for '00VI help.
- '00 VI Cali or Fed Spec make a big diff.?
- Advantages of full 3.5 in 4th gen, as oppossed to 3.5 bottem with 3.0 heads?
- Its Alive!!!!
- Heads Q
- Question about headers?
- Nissan Engine Geometry & Connecting rod guide
- Who thinks i should go all motor
- 00VI produces 14.5 ft-lbs more tq than MEVI
- yes more VI questions
- Cylinder head and valve train miscellaneous information
- N E 1 here installed a Pathfinder
- Which would be better if you could do only one
- Another 00VI installed on a 4th gen.
- Are VQ manifolds symmetrical?
- Cam swap. Help!
- VQ35 engine pics after mods
- VQ35 valves in VQ30 heads
- REbuild Question...
- 3.5 tb on a 2000 max
- NeoVVl On VQ
- What activates the power valve on 00-01 IM.
- VQ35 cams in a VQ30
- Anyone know 4 gen rod length?
- Nismo cams
- Who wants too see a full 3.5 4th gen on 3.0 ecu
- 00VI questions
- potential and future planing
- anyone see a problem with doing this?
- tryin to get back in the groove
- ok I am now in the hunt
- What Would You Perfer??? Jwt Cams Or 3.5l Cams???
- VQ35 longblock + VQ30 Cam Gear = What?
- Whats up with using a 3.5 bottomend with 3.0 heads???
- Got another ques?
- Best ECU
- motor guys, need help with options
- spec and stillen combo!!!
- All this talk about VI's
- Used Engine Break In?
- Heads and cams by CrawfordZ
- new header, no egr connecter
- What has to be done to get 4th gen injectors to fit 00VI lower manifold?
- Two ECUs
- *****VQ30 Head Porting*****
- Change Final Drive ratio
- 00VI customized IM
- Hows the 3.5 working out in the 3.0 ?
- Crank???????
- Best ECU to get
- 00 VI finally got one
- GRRRRRRRR clutch slip
- Need socket size to do engine work...
- Revving Higher??
- HP Gains...All Motor Add Ons
- NA 1/4 list
- Heard JWT cams in a VQ35 last night...
- JWT GD great for all motor guys!!
- Engine Effiencey
- 3rd Generation Fuel Injectors for VG30E engine
- 3.5 internal parts
- ARP Rod bolts for the VQ35!!!
- engine rebuild???
- What the hell?
- Heads from a 2K3
- been viewing my car with auterra...?? about TPS
- altima/maxima 2002+ transmissions
- Vq30de
- Other Displacement Options
- 8000 - 9000 rpm VQ30DE valve train.
- SR20DET Bluebird on 2k Maxima?
- the 3.5 swaps future
- bore out or engine swap?
- Internals Upgrade Kit
- Exhaust?
- Should i get a SAFC-II (dyno inside with a/f plot)
- Links to threads with useful information
- A/F tuning?
- How does the JWT ecu change rpm limit?
- Who will be the one to be in the 12's ...
- Who here wants to see a all motor drag 4th gen
- Good place to have Rods ...?
- ****IMPORTANT**** Please read before posting!!
- Wut cold air intake should I get?
- Post your all motor setup:
- Thanks Sprint
- First Test Drive Finally
- 3.5 in a 4th gen
- VQ35 Secret Sauce manifold nearing completion.
- The Great Gearhead thread
- VQ35 internals in VQ30 makes VQ33 stroker, bolt on! PICS!
- Cattman VQ30 headers installed on my VQ35
- 3" PVC MAF Project. Works fine.
