- 00VI running lean and aftermarket ECUs
- My enigine is dying...i think it spun a bearing
- Is this normal for jwt ecu?
- Problem with MEVI
- need some help with my codes that never go away
- $$ in all motor setup
- IACV and EGR
- questions about using 00VI upper with the 4th gen lower
- jwt ecu vs. piggyback system (emanage, SAFC)
- 97 auto 00VI Dyno
- Problem with Fidanza Flywheel Install.
- Question about intakes for swapped motors, TB's, and IM's
- Mounting Points for 00vi + 4th Gen Lower Intake Manifold..PIC provided
- 3.5 swap and california emissions (smog)
- those with complete 00VI motor swap in 4th gen
- BOOM goes the fuel line
- 5 Speed swap throws CEL
- What mod comes next?
- misc parts needed for 00VI swap
- anyone have part numbers for stock VI bolts?
- VQ35 swap q's
- EGR plug for rear manifold
- Why should I not build the VQ33 stroker?
- Nees some help w/ custom VQ swap, cranks but won't start
- 00VI question concerning IACV
- piggyback vs. stand alone ecu tuners
- need 00VI swap parts?
- *Microtech Engine Management Systems*
- VI swap, ? about EGR cooling and rear supports
- Just want to verify with peeps that have upgraded ECU's
- help with 0210 code with VI
- Is my fly wheel okay?
- news on catmann standalone headers?
- RSF50A or RSF50V, how to verify?
- 00vi question...please step in
- Traction control
- Hey guys need help?
- QUICK Question :: Can I use the Stock Air Intake with the 00vi
- Proven facts?
- Need help with 00' VI
- Can we Adapt a 350z Intake Manifold to a VQ30DE
- VQ OEM and Aftermarket Cam data
- VQ30+VQ35 ARP Studs Interchangeable?
- Transmission removal
- mevi or 00vi?
- VQ35DE & 4th Gen 5MT
- What involved in a 3.5 swap?
- EGR guide tube for 00VI swap
- Hood Spacers
- 3.5 on Ebay
- Spark plug repair on dohc heads.
- vg35de rods, piston, crank swap
- 00VI smog legal?
- Understanding compression
- What would cause this? Take a look.
- How Much Does a VQ30DE Weigh?
- Pathfinder VQ35 has same cam timing signal as VQ30
- Gearbox model numbers
- stroker???
- Can any of these codes be NA power robbing?
- DEK Engine in 4th Gen..Anyone Do It !!!
- Before & After VI swap dyno
- SAFC II, SMT-6, SMT-7 What's the scoop?
- Whats Needed for VI Swap ??
- 00vi cali or fed spec?
- Smt-6
- 00vi help!
- Guys that have swapped over to the VQ35
- Seeking advice during Valve Cover removal
- RPM Switch Reliability
- Where to buy engine?
- Mix and Match coils
- Tuning, A/F Ratios, Etc What's the deal??
- 00vi swap, how to avoid grinding coil mount towers
- 300zx Ecu conversion
- vq30 w/ vq35 cam spacers
- ?'s on doing a VQ35 swap?
- Looking For Someone, Anyone To Make 00vi Adapter Plates!!!
- do you agree with jim wolf?
- Production Date Mystery
- help,lost hp. with headers
- How to make 2k2 VIAS work
- SMT-6 gains !!!
- Need info about running W/O EGR.
- VQ35 swap pictures
- Need IACV adapter plates, who makes them?
- Anyone run a 4th gen w/o the coolant lines on the TB?
- True dual straight pipe?
- Weird VI swap issues
- VQ35DE Stroker kit anyone?
- JClaw/Nismo3112
- 4th gen 3.5 swap: Stage 2 LTB fitment?
- Help: Atlanta Georgia: 3.5 swap on a 4th gen
- Pics of DE-K swap into my 96 I30
- 2k3 VG33E xterra engine w/ Blower
- If you have installed the 00VI on a 4th gen, please answer poll
- 300ZX motor
- 2k4engineswap
- Rough 00 VI How-To
- Rev limit...7000RPM or 7200RPM
- VQ Engine Specs
- SAFC owners: what MAF % r u getting?
- SAFCII issues
- 4th gen with 5th gen fuel rail - damper or no damper?
- Mevi Activation Light (those with one)
- Cam Testimonals
- 2003 vs 92 se engine
- new injectors what kind to get??
- 4th gen knock sensor on VQ35!
- What kind of work should I be expecting (VI)
- OIL Pressure Sensor
- my new ecu in 99
- So what does the stock MAF max out at on an NA car?
- compression ratios
- Rebuild
- ARP VQ35 rod bolts....$125+$6S&H
- Stupid q.... mevi + 3.5?
- would hot shot headers for 3.5 will it a 4th gen
- Advanced timing through manually adjusting CAS,possible?
- good engine books?
- will 3.0 headers fit on the 3.5 bottom end?
- VQ30 = Interference?
- Port And Polish
- Next Best Mod?
- 00vi
- 2K motor swap
- Tranny ques
- Is It Worth it ??
- 3.5 swap
- VQ Intake Generations Questions
- VQ35 up and running!
- Fired up the 3.5 Today, little bit of smoking
- swapping ecu's
- Old idea, but has it been tried? 2k3 Path IM...
- Would a SAFCII help me N/A?
- Is there a height difference between DE and DE-K lower IM?
- Another 3.5 up and running
- Re-use 3.0 oil pan?
- Electronic Exhaust Cutout
- 2000 VI and 4th gen lower IM for sale
- Can you post your hybrid motor config? (Block config and manifold)
- VI swap misc question
- Alti guys talking to Crawford Z about a plenum ..
- Tested: 04 VQ35 IM on 98 VQ30
- 3.5 swap w/ ecu & e-gas - no full car re-wire
- 3" exhaust piping on n/a engine
- Anyone know if a Pathfinder VQ35 Block will work for VQ35 Swap in Gen4?
- OBDII -> OBDI conversion
- The weights are in (valves)
- not sure what the problem could be
- mild A.M. set up need advice or opinions
- 00-01 engine swap into a 4th gen ???
- IM talk years 95-05
- Unichip
- B Pipe
- vq30det intake manifold, anyone got one?
- Non LSD 5th gen tranny swap question?
- 2000 vi swap pictures
- Swapping fuel pumps
- Start up problems
- can I use 3.5 from 350Z
- 00vi
- VQ35 cam spacer dimensions
- timing advance and VQ35 swaps
- Need help
- high compression or low compression engine...
- Another modified 00VI
- motor swapping a 95 with a 97 has it been done ???
- Will somebody confirm this? (Related to VQ35 swap)
- Where to purchase a VQ35DE?
- Timing chain tensioner help
- 1995 Fpr
- Timing Chain installed Correctly?
- Intake Manifold options: 2004-2005 Maxima
- 04 IM on 97 VQ, long story short?
- wideband comparisson NA 3.0 ?
- 2004 Vq35de
- Question on installing a 00 tranny in a 96.
- VIAS timing
- I'm sure this one will get me flamed but here goes...
- Factory Fitted Mevi - MEVI Experts please.
- Vehicle speed sensor location??
- How does this sound.
- Front crank pos.sensor necessary?
- Need massive cam/VTC info
- JWT ECU "the big 8" by-pass?
- Deck height adjustment - VQ33 stroker
- Guaging interest in manifold flanges
- VQ30 Pistons and Rods
- wtb vq30 low mileage motor and 5 speed trans
- My New (used) VQ
- VQ35DE: Question about fuel rail
- VQ30 liner thickness?
- 00VI Installed Wierd Idle Issues
- Building custom intake manifold
- calling exhaust gurus.
- TB Question
- 01 motor in a 98 with 6 speed
- All Race NA 4th gen 3.0 update.
- Will this work? (fuel)
- mafs
- VQ35 O ring?
- What is the difference between Pathy heads and Maxima/350Z heads?
- Different Hybrid Setups
- has ANYONE DONE THIS
- 00VI How To?
- Newb ? about 3.5 swap
- 4th gen tranny
- HELP on headers installation?
- Anyone done any engine TUNING to their max?
- how to clean rust from water jackets??
- Summit RPM switch
- 3.5 5 speed trany in a 4th gen
- Would the VQ40 be a worthwhile swap?
- Tune-up
- Hotshots are on 2000 fed spec WOOOOTTT!!
- Will 3.0 lower IM bolt up to 3.5 heads?
- What can cause a motor to eject a rod and can this damage a tranny? PICS
- engine balancing?
- Who wants to control RPM changeover and A/F mixture with one device?
- problem with eagle rods
- what needs to be fabricated for 00vi?
- Lets talk Fuel Pressure Regulators
- Car won't start after installing 00VI
- Vq35 Tranmission
- 00VI question...what to do with these?
- Big headache here (3.5 swap). Anybody's help appreciated (Tilley, SR20DEN.
- E-GAS to cable TB in less than 20 minutes!!
- Help with instilling a 00VI
- Help, some problems w/01 vi swap
- 00vi
- 01 motor in an 98 with 98 mevi
- Newbie question about the 3.0 to 3.5 swap.
- 02 VQ35DE Engine wiring harness Available.
- another job
- engine work
- 00vi writeup anywhere?!
- Another 00vi installed
- 2001 setup???
- Why do 3.5 intake cams have to be modded to work in VQ35DE going into 4th gen?
- Tuned my SAFC2, found a few more hp
- Making NA history March 11th
- need help on some diagnosis
- Two ECU's
- VQ30 w/VQ35 sleeves/liners possible?
- quick ? vq35 pistons and rods in vq30
- 95 Steering column (for swap)
- OEM VQ30 cam needed
- Important question about RPM sensor
- Vq35
