View Full Version : All Motor
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12
  1. injector CC sizes.........
  2. anyone take out tb/manifrold spacer in 5th gen?
  3. Please Read....
  4. Vq35
  5. internals
  6. what are the vq30 and vq35 head CC's
  7. 2000 engine in 99 max: engine swap
  8. Motor Rebuild
  9. ve/vg hybrid
  10. 6 spd onto a 3 liter?
  11. 2k1 DE-L Motor in 97 - Now car wont start :(
  12. 3.5 problems
  13. anyone done an all out VQ35 swap?
  14. Helpful Info
  15. computer upgrades for 00 vq30
  16. rpm switch connection quick please
  17. VQ35 and strut bar?
  18. Sleeper cam suggestion
  19. Tilton 350Z Clutch/Flywheel installed
  20. Pic of my new engine (slapped a little paint on)
  21. Need help, inital setup for V-AFC-II
  22. 99.5 Se-l 00vi?? (ca/nlev)
  23. getting a 01 motor what should i do.......
  24. 2k Lower IM swirl valves
  25. Searching for 00VI in New Zealand, photo included, does everything look the same ?
  26. Ordered my 00VI DEK Manifold..Look what I got...
  27. Why no 00VI writeup?
  28. 00VI Kick-in Point
  29. VQ30DE motor swap/ engine differences?
  30. Auto to 5spd convert with horrible wheel hop... What to do?
  31. Better Power/times JWT or TECHNO?
  32. what else do i need for the 00vi swap?
  33. I bit off more that I can chew!
  34. ve mods?
  35. Good deal on used slicks
  36. where to find a MEVI gasket?
  37. VLSD 5-speed swap info
  38. Safc or Emanage for n/a?
  39. Voltage for crankshaft position sensor
  40. 00vi
  41. Weak spark??????????
  42. ? on SAFC tuning
  43. another 00vi question, bear with me..
  44. questions need some answers
  45. Skunk2 plenium spacer
  46. Transmission Shims
  47. Anyone who wants 3.5 cams installed
  48. Possible problem?
  49. VQ35DE in 2k Maxima?
  50. Cold Start saga continues
  51. My new all motor vehicle
  52. No spark on cyl 2&3, tested...coil drivers?
  53. Custom Internals
  54. Motor Mount Questions...
  55. Vi ?
  56. Signal Plate change for 3.5 Swap
  57. Vacum problems
  58. need help making decision, 3.5 swap
  59. DE-K Swaper(LIS-ONG)
  60. 00vi bolts and whatnot
  61. DE-K into fourth gen
  62. 3.5 Swap -> 3.0 ECU -> VTC possible with piggyback???
  63. Project: Tilton
  64. Clutch problem...
  65. What would be the ultimate IM design for the VQ?
  66. 3.5 cam spacers, cams, and sprockets
  67. 3.5 swap, problem with POS pass. side axle
  68. 12:1 heads from nismo?
  69. Kinetix SSV Prototype for 3.5 Alty
  70. 2k VI installed...Now what? (Long)
  71. Emu
  72. 5th Gen Trans in 4th Gen Speedo fix
  73. how hard of a swap is this
  74. RPM switch.
  75. Strange metalic rattle noise coming from hotshot headers
  76. Completely Removing Secondary Oxygen Sensors – Guru’s step in..
  77. Blown Headgasket?
  78. Rear LH valve cover vent, needed?
  79. Input on My Future Mods ?
  80. Clutches?
  81. motor weight anybody?
  82. General 00VI Question
  83. Anyone using Megasquirt yet?
  84. Timing advance
  85. Counterfeit 3.5 EBay Cams
  86. Guys running different Throttle Bodies (Pathy, '03, '01, etc) please read
  87. Aiming for the 200hp/200tq mark
  88. AC system removal
  89. Guys with anything to read knock (SAFC, R500, anything else) do you get knock at idle
  90. Could JWT Compensate?
  91. Why can timing not be ADVANCED with Emanage Blue?
  92. info on the 3.5 4th gen swap?????pics
  93. quick ?
  94. VQ30 Headers/ Do they fit on VQ35?
  95. Having starting issues, '97 with VQ35.
  96. 5 Speed Parts List
  97. 98 engine in a 96-won't run
  98. knocking on vq30de
  99. VQ35 Plenum Spacer
  100. 3.5 swap MPG's and emissions questions
  101. Question on other parts needed for mevi
  102. Running without EGR ??
  103. Anyone running w/o an IACV?
  104. Guestimate on VQ35 engine/tranny swap
  105. Just ordered Mevi from Nismo car parts where can i find the other needed parts?
  106. MEVI / 00VI swaps please step inside.
  107. VQ35 timing chain question
  108. VQ30DE-K camshafts in 4th gen maxima
  109. Guys Who've Done The 00VI
  110. Vq30dek
  111. A/C Compressor and PS pump switch to VQ35?
  112. Is my timing bad....
  113. ignition coil question
  114. What is the stock timing advance with stock ECU on a 4th Gen
  115. Cold start issues on '97 with VQ35
  116. tranny cooler
  117. 00VI questions/understanding options/suggestions please
  118. Mallfinder TB + jwt or techno ecu
  119. procedures for 3.5L block swap
  120. accessory pulley's for vq30de
  121. Hypothetical Question
  122. Any dynos of 3.5 with 3.0 components?
  123. Motor on stand, loud CLACK when crank is rotated.
  124. 3.5L 6spd question, clutch slave cylinder
  125. 3.5 swap procedure and FAQ
  126. EGR problem
  127. MSD Ignition upgrades?
  128. 00VI question.
  129. DE-K Injector harness splicing
  130. 3.5 swap questions
  131. Would the Plenum spacers that the Z/G guys use
  132. 3.5 heads or3.0 heads?
  133. How many people are using Digimoto for scanning and mod comparisons?
  134. HKS Twin Power
  135. Ignition timing with N/A 95 VQ30 JWT ECU
  136. 00vi setup verification
  137. Some questions for the all motor project.
  138. Score!
  139. need more information about the 00vi
  140. Help,Still 00VI problems
  141. Finally got a chance to to Timing Advance to my max
  142. Is a 95ECU on a VQ35 still the way to go?
  143. VQ35DE Block with VQ30 Heads.
  144. i regret doing the vi swap
  145. 2004 3.5 Engine swappable?
  146. DE-K Engine Swap?
  147. egr and coolant lines vi swap
  148. How much more timing with step colder plugs?
  149. help with evap hose on vi swap
  150. Ignition Advance logging after KS replacement
  151. Leavin NA section for awhile
  152. VQ35 in my 00 cali? waste of time?
  153. MEVI not opening under load
  154. If I went back to stock manifold, would I still need a tune as badly?
  155. SER altima engine?
  156. VAIS Solenoid harness?
  157. would oil cooler be needed to raise rev limit towards 8k safely?
  158. Laptop OBD2 Software
  159. doing 3.5 swap have aot of questions, pls read
  160. questions about upgrade routes. input needed!
  161. help with vias bolts
  162. those using vafc II
  163. Wiring my 00VI up.
  164. 00VI up and running ^^
  165. 2000 blow-by hose part number
  166. Quick Vi Question
  167. upgraded clutch w/ 3.5 swap
  168. Removing pcv system
  169. connecting a 2000 iacv to a 4th gen
  170. Direction of coolant flow
  171. jwt cam spacers for 4th gen 3.5swap
  172. VI switch...
  173. How Much HP????
  174. JB weld for the 00vi
  175. It's Back.........
  176. Ignition timing/advance
  177. Anybody used ARP cylinder head studs?
  178. Pathfinder TB
  179. Mevi Or Oovi
  180. Quick-ish 3.5 full swap question (yes, I've exhausted search)
  181. home made headers
  182. custom ITB for Maximas
  183. Any negative effects on running no thermostat
  184. My 96 is going to be a toy/drag car
  185. Is it ok to remove plate that ac compressor bolts to?
  186. 3.5 Swap Around Or In NY
  187. 00VI/VIAS Mystery Problem
  188. Proof that 00vi owns MEVI
  189. SAFCII owners: ur knock count?
  190. Can someone help me with my 02 sensor? Nobody seems to know what to do!!
  191. fed spec 00VI with my Cali spec car
  192. running lean
  193. 4th gen DEK intake manifold swaps and higher engine temps
  194. need basic info on 3.5 swap 56k to slow to surf
  195. 00-01 ECU in a 4th gen w/3.5 swap
  196. 550cc injectors
  197. 5spd Swap- Part II ***PICS***
  198. Whirring noise explained in detail. *PLEASE HELP*
  199. Spark plugs for higher compression engine?
  200. questions about safc II
  201. What are people using to monitor and datalog ignition timing?
  202. 00VI with missing ERG......Work involved
  203. Help with starting...
  204. help with intercooler endbanks
  205. Consult Scanning Software
  206. best bang for the buck??
  207. best mod question
  208. does the VQ33 stroker work and how much does it cost?
  209. just bought a vi00 quick question
  210. 201.33whp/191.27wtq MEVI/STOCK ECU
  211. Tips on pulling motor
  212. JWT ECU and SES Codes
  213. Vg30DE Fuel injectors in my Vq30 ?
  214. 95BLKMAX's DYNO - Something REALLY wrong......
  215. vq30de-k a direct swap for 4th Gen?
  216. ECU swap.
  217. SMT6 Now officially is working
  218. Full DE-K motor swap complete!
  219. 4.0 vq upper on a 3.5 lower.
  220. JWT vs Emanage Ultimate
  221. cheapest 00VI
  222. 00VI install begins soon...
  223. Aftermarket Fuel Pressure Regulator
  224. Using e-manage to actuate power valve?
  225. Big Problem with my VI
  226. Similar ECUs?
  227. 00VI vs. 01VI
  228. SAFC-II benifical being N/A??
  229. quick help with 00VI
  230. Trans swap questions
  231. 2k2 Fuel Pump Installed!!!
  232. Car is slower
  233. Wiring Up Summit RPM Switch
  234. 6spd on a 3.5L in a 4th gen
  235. 300 Hp
  236. Has anyone done a 2002 Max Engine/Tranny swap in a 1999 Max?
  237. confirming understanding of 3.5 swap
  238. So, what is the final answer on 4th gen timing?
  239. MEVI vacuum problem, Please Help
  240. 00vi installed with 1302 code
  241. Hard starts in morning
  242. Anyone have the part # for MEVI butterfly Screw?
  243. Upgrading rods and pistons
  244. It's in... without the built tranny.
  245. Can the timing chain cover be removed without removing the crank pulley
  246. Vq30de-k
  247. Little help with learning about my max
  248. 13s on motor?
  249. Do any 00vi write-ups exist?
  250. injectors
