- Alignment Problems
- my 96 max has no spark
- Reason for Maxima's Premature tire wear? Who has some snow tires?
- Can someone post a pic of the EGR passage?
- radiator fan problem
- WTF is this???
- dimming lights
- Winter warm up...
- 4th gen automatics
- problem found. can i fix this myself?
- CD Stereo Swap - Loss of Volume/Power
- clutch problem
- what kind of exhaust??
- Flywheel question, need a response back quick
- engine experts chime in, need help!
- wire routing guide
- Exhaust suggestions
- Speaker wiring headache
- 5 speed flywheel removal
- Does anyone need a carfax?
- Y-pipe and OBDII Inspection
- Cruising RPMs?
- How do you know if you car has keyless entry?
- Help! Rear Caliper Bracket
- codes 0407 and 0101 - please help!!!!
- Bulbs
- Oil/Grease all over wheel
- What color is your radiator?
- Need Control Arm FAST!
- Alternative to stock clutch line???
- If Hella FF50 = H7 and stock = H3, swappable?
- Chariot vs V8's and more: 1/8th mile drag videos !
- Side marker lights
- Buy A New Or Fix Up Old Max..
- Please help
- where to get a new spare tire...
- POwer Acoustik 7" Monitor Install???
- Opinions on Sylvania bulbs
- Those with the yellow capsule mod please step in....
- Microvision 7in TV screen in 4th Gen headrest?
- Parking my 1996 until april..did i forget anything?
- maxima car clubs
- "Headlights On" Warning - Upgrade?
- Wtf is this sh!t about power axle?
- License plate lights?????? HELP!!!!!
- Rear Tailights Dont Work But Flashers Do What Do I Do
- catalyst converter
- Question about IACV
- overheating
- Intake Gasket
- DTM Taillight + 24/7_Flavor mods combined
- Failed emissions inspection!
- help in a few things.
- Did I just kill my Max?
- Does this work or is like the Ebay chips?
- Is it worth switching gas now?
- Water injection
- How much would it cost to...
- maxima doesnt wanna start
- How to clean out debris inside headlight?
- 2 questions
- Power Seat question
- Paint code
- MT venting fluid out of vent tube
- cold starts....even colder driver!
- MAP / BARO and Absolute Pressure CEL questions...
- 00/01 Ecu??
- Ran Out Of Gas
- 95/96- to 97-99 gauges?
- Installed new taillights and ran into issue sadly need help
- Finally found out wrhats wrong with my car, how much would it cost to fix?
- HELP!! MY TRUNK WON"T OPEN!!!!
- Best free mod ever
- Foglights on a GXE???
- need help, cyl 1 and 3 are misfiring
- need a good mechanic in BK or Queens
- DropZone Coilovers???
- O2 Sensor Question
- Rear drivers side brake grinding?
- Difference between locking and non-locking transmission
- Passenger axle is STUCK...need help!
- Need help deciding!
- Coil Packs
- I need two codes ran
- Injectors
- i changed my ks (pic)
- Coolant Leak - Water Pump?
- Starting problem...sensor?
- Hard starting once every 3 to 4 weeks
- Trouble Spots for the Maxima
- EGR Solenoid Valve
- Clutch master cylinder issues
- 6 month old battery doesnt start car
- Gasoline smell in car when heater is turned on
- Anyone have a carfax account open?
- Front passenger window problem
- can anybody run this VIN # for me
- Car hesitates at 2000-2500 rpm acceleration? bad coils?
- where is the turn signal relay located under the dash?
- Steering wheel cover's?
- Optima.....
- Spec stage 1
- does autozone sell knock sensors?
- clearance and signal bulbs to match 6000k HID's ?
- Finally Got Some Suspension Probs Resoved!!! (kinda long)
- Soo.. Clutch blew out, trans broke, Pushed my car home..
- guage problem
- Paint Rear Window Spoiler/Wind Deflectors ?
- different wheels from Nissan
- Car problems
- window install instructions for RPS
- It goes creaaaakkk, when I turn the wheel while stopped to the far left
- Ghost ECU codes
- Can't get car into gear
- Fuel Cut off during deacceleration in manual ----> converted?
- Difference b/w Walker & Bosch O2 sensor
- What can I do about rust starting to bubble and show around the spoiler supports?
- Bose question
- wtfenginesqueal.mpg - video
- Removing Door Moldings
- Rear Manifold bolt size?
- Projector Advice...
- Rip-off or Reality?
- starter opinion
- Brake Light and Gas Light... Problems
- Need help! Car shuts off when placed in reverse orDrive when first startup in morning
- squealing noise help please
- quick question
- How To Fix Scratched And Fogged Headlights, This Works!!!!!
- 9004-9007 coversion Wire help
- fan blower stuck on speed 4
- 99 SEL Red paint code
- Xmas List
- Timing Jumping around / Failed Smog - Need Help
- Are hood pins really necessary?
- 4th gen AIM or number?
- bp gas
- Where does the oil go?
- Those w/Dynomax Super Turbo- Which direction did you mount it?
- Does anyone know?
- CF lip Stillen sides - need help!!
- Juice up your Maxima?
- Coil Pack CEL
- FAST MAXIMA'S WANTED!!! Midwest region
- what else is needed for 00VI . .
- Unusual Vibrations: Advice needed. (a tad lengthy)
- 95-96 CF Trunks
- Those With Strobes Step In...
- car did not start
- Crazy thing Happened To Me Read because I'm in need of Feedback
- all of those who has the 97+ trunklid swap.....step in
- wishing i had an auto now
- max vs type-s?
- new starter ... grinding noises?
- Some minor concerns
- knock sensor
- Nissan quality sucks?
- confusion with water pump part numbers
- Hood got owned...options?
- Clutch Lines leaking..........which ones to order
- Sold my max... :(
- Tires Help Asap
- is my clutch bad or what? please help me figure out whats wrong.
- Common Oil Leak Spots?
- Optimum TPS setting......in ohms ?
- need some help
- Where to buy a resonator?
- Lowering spring or coilovers with KYB AGX struts?
- Gauges - SE or Anniversary?
- What to do in an accident!?!
- My max is hurt =(
- UDP Question...
- Led Size?
- Healing Maxima
- O2 sensor brand. What to buy?
- Coolant gauge goes all the way to H but car isn't hot..
- fog light ques.
- Programming A New Remote
- Need Help. Purge Clutch Line?? How to?
- I have never gotten so much attention
- oil in coolant = definite blown head gasket?
- remote start with manual tranny?
- pics of black chrome bumper lights
- Lowering a Max, springs and so on.
- How to tell if car has LSD
- flowmaster 40 series
- *HELP* 96 i30 auto, tach goes down when accelerating???
- Help ASAP I bought a frankencar midpipe and dont know how to install
- Brakes - size difference GXE to SE
- body kit owners
- fog light trim piece
- 1995 maxima left driver side mirror needed
- Air Bag question
- Freon recharge
- spare size
- In-cabin Microfilter replace question...
- Need a new ECU - looking for some info
- alternative to dealer key?
- VHT Nite Shades Taillight Tint
- Clearcoat coming off
- Soft Touch Courtesy Light Mod
- need help
- Dead Battery, Starter Grind & Low Idle
- A How to on LED tails?
- Cefiro Headlight took a while but looks great
- Anyone roll their fenders theirselves?
- For those of you with a '00VI please read...
- Rear heated O2 sensor
- does exhaust heat wrap do anything?
- emty gas tank light
- 473 miles on 1 tank of gas - SWEET!
- A Price from reliable mechanic...what you think
- I replaced the 02 sensor twice but keep getting the same code!! $##%#@@)(%$
- Where to buy trunk liner fasteners?
- Exhaust question
- Virbration in whole car
- spark plug boot need help!!!!!
- Clunk/ Rattle in Left Front
- Help Needed FAST! regarding drive belts
- CAI and Y Pipe
- tranny questions
- Tl projectors...HID guys step in!!!!
- how would this look
- Usual cost to replace an axle seal--- Tranny side?
- Those with LED knowledge
- All the mechanics please chime in!
- Really bad clunking/knocking from right front on left turns
- HID retrofit experts, I have a few questions before I begin:
- Hub Retaining Nut Torque
- best deal on tokico illumina kit!!
- car can't start... and need opinion on what to do.
- Car starts but dies when cold, ok if warm...
- Car boggs down with AC on - what gives?
- ecu swap.
- Trans help
- y pipe and low end
- decision guide!
- Big Ouch! Had to replace my starter today...
- 99 auto kicking in drive
- which to buy Unorthodox or motostorm UDP
- 96 max (auto) vs. turbo neon
- Cattman JWT POP intake
- Leaky Oil Pressure Sending Unit
- Instrumentation Cluster - Can I replace analog w/ digital?
- short in my car need help
- oovi injector size...
- hard starting - please help!
- need help with knock sensor removal
- What size bolt to remove rotors?
- New Brakes + Calipers, loud sound when Braking in Reverse
