- Water Pump Install??
- Incessant Cassete Deck Grinding - Possible Fix or New Head Unit?
- Still throwing codes...
- What gives, alternator, iac valve?!!
- What should a mechanic charge for a clutch job (labor only)
- cold start up problem.computer reset?
- Let's see your manual shifter knobs!
- Bad o2 ruining peformance?
- WTF happened to my gas gauge? take a look, i cant figure this shiet out [pix]
- WTF, car won't open anymore?
- Fuel Economy suddenly dropped, but ks is OK?
- Venom 400 control module
- Bulb numbers for interior.
- Worth saving my rims?
- annoying problem that wont go away
- need some help!
- 5 speed internal tranny problems
- Remote Starters
- Replace rear calipers or not
- !?Starting Trouble!? HELP!
- little low end power...why?!?!
- Battery Question
- Windshield tinting
- 98 Maxima won't Start
- No Heat......Let's try this again!
- Weird Steering noises..help
- 2 screws to adjust headlights?
- wtf?? shameful max
- Speed limiter on 99 GXE
- knock sensor
- Opinion on y-pipe
- What is damaged n how much to fix it?????..asap
- Need Opinion on new exhaust and components
- Wheel Stud Sheered Off
- Y-Pipe Question
- Battery life?
- Can't make up my Mind need Fellow Orgers Advice
- accelerated pad wear with drilled rotors?
- Confused?
- 0304 code
- Battery Relocation
- SS Brake Line install not going so well
- Adjusting the Illumina settings
- This just ruined my night!
- Clear out 97-99 Outer Taillight
- what kind of batteries you guys use?
- dual intake
- My car is shutting off and stalling- need help.
- 4th Gen crash
- Replacing the passenger side transmission fluid seal
- 300zx maf in a 4th gen max?? need quick help
- Program this!
- cant get the FARKIN grille off! wtf am i missing?!
- How to avoid CEL after using drop resistor?
- Weird banging sound when brakes applied! and other questions
- question about CM 95-96 Red/Clears
- Heated seats on 95
- Key fob programming
- Anyone running PC680 drycell?
- Mod to change automatic shift RPM
- e-brake sticking when it's cold sometimes
- Eric I have a question for you
- Cold morning start problems
- Brake warning light
- Keyless Entry Question
- What grease to use for Starter
- irotors brake disc (long)
- Should i do it?
- Grounding kit?
- Driveshaft help, STAT!! Pics
- Thumping sound while driving
- Car trouble
- Re-retrofited my headlights
- Pass Driveshaft issue
- Vibrating while driving
- Exhaust suggestions
- AC Compressor Bearing replaceable?
- 0903 Qwik Question!!
- Exhaust and Headshield Question
- 5spd swap - insurance
- Weird Power issues
- Cylinder 6 misfiring...
- My TL HID Retrofit...
- 5th Gen Clutch Parts
- Maxspeed with tokico blues
- Washington State Peeps?
- OEM Starter Question
- Ebay intake
- headlight help
- Ever had lights on your console go out?
- Another new problem: Tires rubbing on something
- Audiovox AX901 Remote Stater
- flashing airbag light
- Ebay Strut Bar
- Shifting problem - Wont go from P to Reverse
- Those D2's or other coilovers with adjustable camber plates... step in.
- cold morning starting
- Cleannnn :D, but I have a few questions.
- Maxima Cooling System Pressure ??
- One fuel filter went out - what causes this
- Checking and Replacing spark plugs...
- Carpet ruined! Where to buy/how much?
- added 6th gen emblem on door (pic)
- Why is my carpet always wet?
- Info on Cry02 Cryogenic Intake Mods?
- Squeaking A/C Fan
- How to test cooling fan speeds?
- A bit of a wierd question...
- Hmmm, I wonder how this will sound...
- Anywhere to get new OEM floormats?
- it dont start.
- oil light is on, any possibities besides oil sensor?
- key fob
- Alternator choices?
- who makes the best headlight bulbs?
- Replacing Stock Exhaust Questions
- Got 357 miles from a full tank!
- 95-96 clears on ebay.
- Could this be an electrical problem?
- E-brake light on
- Need input/opinions on my ebrake freezing up this morning...
- car parts online
- Which bank is which??
- Can you replace strut bearing without removing strut?
- 4th Gen muffler
- Bumper painting price?
- Why do I not have ABS?
- Abs?
- Seriously, can you reach the fuel filter with the Intake on?
- decisions decisions...coilovers
- Clock LED goes dim
- Question About CV Boot & Brake Pads
- REPAIR 95 MAXIMA OR KISS GOODBYE>? Engine Techs step in!
- Position switch O-ring ???
- VLSD question
- Replacing worn out steering and suspension components....What needs replacing?
- Tokico Blues with Tokico springs??
- Axle Issues
- Do you start your car right away when you put your key in ignition or you wait.......
- weird starting noise
- Help Needed: Clutch Install...
- The MAX won't start! but I just drove it 8 hours ago! Is it fuel related?
- Wat should i do to ready the max for winter?
- Gauges ?
- Need Opinion On Aftermarket Rotors
- Let's see some Max's in the snow
- Need new Radiator + AC Condensor??
- water pump leak !!!!!
- Red, Red Clears 56K not so much....
- Front Bumper Removal: Instructions
- My interior lights are turning off one by one.
- where can i get my mevi installed
- Odd engine behavior
- brake pads
- Something's realy wrong with my max
- Ooo that's tight!
- antenna
- *2-Tone-Leather Interior Pics* Just Installed, Check It Out...
- EGR temp sensor...
- Major overhauling, Tips and questions.
- crankshaft position sensor leak(pics)
- Lower oil pan removal/ gasket replacement
- How to: Remove Rear Tail lights
- Horrible IACV noise - ignition on/off!
- Switching a 98 max ECU to a 95 max!!
- Rims as luggage??
- belt replaced now squealing.
- 02 sens...
- ECU Screw to check codes?
- Ts Ecu
- Does this mean i've been driving w/o an Air Filter?
- Bose won't turn on
- For people who have adjusted your clutch pedal please
- I think Starter just went out
- Battery Acid Residue???????
- PS belt change, cant get it off
- For those of you with an RSTB...
- Anyone looking for a 5-speed SE?
- Strange shifting under WOT
- Need help with Airbag light
- Problem starting with 5 spd.
- Can someone help?
- coil packs? and code 0302
- Read this before but Silverstars Suck!!!!k
- y-pipe arrived today!!
- Bomz Cold Air Intake
- Airbag light blinking??????
- humming noise ? Where from
- 911
- in the middle of the 9007 conversion and confused.
- Help: Pressure Plate install
- idle drop while coasting almost stalling
- SP2 Leak...
- Window wont go up and down
- LSS/Budget "F"-Pipe
- Is it diff or cv boot
- diagnose ABS problems
- Bose Suspension (MUST SEE!)
- Quick Quick Question
- Keyless Entry
- Wow! Mileage is STILL good
- Engine Knock - VIDEO
- pics of 4th gen with 5.5 gen 17" wheels?
- Dash light went out, none of my gauges light up anymore
- Will I pass inspection?
- Got hit today and car making wierd noises now
- Headlight bulbs
- how long have you been modding your max?
- I need some suspension info, please
- Another Clutch Question......
- anyone replace the slave cylinder latley?
- What do you guys think about this?
- how long will u keep ur max? What is ur next move?
- Unknown noise
- Stock Speakers
- question about 97 fogs......
- Ground on Cat?
- Gas smell in car only when heater or defroster is turned on!!! Help
- trouble removing cv joint! help please.
- Removal of Antenna
- Two Piece Cefiro Headlights?
- what spark plugs do you all use and why?
- Does anyone have a lip spoiler on their trunk?
- Greddy Sp2??
- Tein S. Tech Springs
- Replacing manual shifter boot/bezel
- NO Air coming from Vent ??
- bose HU question help
- How to seal the HID Projector to the housing???
- Need shop or someone in Ohio for Engine swap or tranny swap
- nicest max
- Car all of the sudden begins to bump in muffler
- Unorthodox UDP
- Headlights Flickering
- Dash LED help?
- Front and Rear Shock.struts
- I ordered red and clears from custom maxima a very long time ago
- Does a company make a clear lens for the 4th gen spoiler?
- Coolant Fluid Leak Question
- Spoiler brake light problem
- Water pump full of dirt!
- This sucks royally, and I again have to rip everything to get at my STS.
- neone install seat covers?need help/advice on how 2 get top part of bucket seat tight
- Hopped a curb, leaking trans fluid
- need some clearification...
- Another -organized- MEVI vs. 00VI thread...
- Fuel Control Syste and CAI Impact on Gas Mileage
- 95 Gauge Cluster Upgrade: ?
- Need Help!!!! Asap
- shiftlock location?
