- 00vi
- SS Clutch Lines
- how much would you pay???
- help need choosing rims..
- Cheapest price for 5th gen Clutch Kit??
- Air Ride Pros and Cons
- Where to Dyno
- How to get air out of brake master cyl?
- Ebay +20hp Chip and Blow Off valve
- Auto Transmission temp gauge port? overcooling?
- Lock Or Nonlock?
- I30 Rear Seats **56k**
- Power Steering ?Gasket? tear
- mevi q's
- Quick question about a 97 SE w/107K miles
- P0443 "emissions control purge valve fault c"
- Drilled And Slotted Rotors no ABS
- Car won't start
- NEW 97-99 smoked red clear tail lights
- Anybody ever done a timing chain??
- tranny question
- Motor Mount Help
- question from a friend...
- Photoshop guys: 4th gen se with alty se-r wheels
- Wheel Bearing or Tire out of balance?
- what alarm and keyless entry are you guys using?
- Problem HELP!!!!!!!!!!!!!!!!!!!!!!! :(
- Pics of 4th gens with Tein H-Techs???
- Helios or Umnitza brands only, who has them?
- Those with DTM Tails...
- whats happening
- I need 60K service data
- Mystery Loser Poses as Max4speed
- Did I get ripped?
- Cd Malfunction
- Tein Springs
- 5-speed tranny problem
- P1105/1302 code??
- Muffler Tip Size
- Quick question about debadging...Are there holes behind the Nissan emblem on the rear
- Crunched frame with jack
- ECU Code 0308
- Need help with auto climate control - the button illumination is out.
- People with HID's on 95/96, what are your thoughts?
- Shell Dexron III ATF
- Spring Rate Question
- Crank sensors ?????
- Canadian Spec?
- LED tail lights
- Really weird fluctuating idle...
- Race fuel
- It finally happened
- auto climate control dimmer wire?
- Loss of windshield wipers, radio and clock...
- Main oil pan leak.
- Will this setup work/fit correctly?
- Installing airbags today do i need the sensors as well? i dont want it 2 blow up onme
- Leaves or dirt stuck in heater blower motor...help with removal!
- Annoying 1005 Code...
- Installing Ractive Pedals... help
- HOW TO: change heated seat switch LEDs
- VB mod question
- whats squeaking?
- Macco quality
- noise from front of car ????
- CV replacments
- Clutch job conclusion...
- max makes humming noise@ idle?
- Removing Map Light
- Has anyone tried this?
- Possible trans-computer gone bad?
- need help from members with cold cathode experience
- HID...High Beam Light???
- posible new headlight idea?
- antifreeze leak
- Stock rim size
- What belt #'s u need for UDP install?
- What is the center cap from '97 SE wheels called?
- Trailer hitches?
- Caliper / Raybestos Quiet Stop Pad / Shim Question
- RSB or Remote start?
- Few things I did over the holidays...
- changing struts ...got a question
- 2 Cold Start problems
- Won't start after engine wash
- Not even brake pad wear!Car pulls when braking!
- caugh caugh *shplurrssghdgjhsf* *die*
- 2 peice Cefiro's installed **56k = no no**
- Replacing strut mounts
- Radiator from eBay
- Quick Help!!
- Alternator?
- moto got replaced, now i have trouble, some help with this please
- Shaving trim off car
- 02 Sensors, Does Left Mean Front or Rear??
- Do you like this kit and would you reccomend it to me to buy it?
- euro/clear headlights
- 5 spd conversion question
- New Speed chip +20HP EBAY????
- High Speed Instability
- Inner Tie Rod?
- Here's My Max
- Sloppy steering.
- after TB cleand? what the hell?
- Check Engine Light 0701
- Trans diagnosis help needed
- I missed a gear and may have blown my motor
- Quick reply needed!
- buying a 95 with bad motor need a dek maybe
- Air Filter
- WHOOPS! I Broke It!
- Better IAC valve cleaning pic or description please
- Custom made Red & Clear tailights with L.E.D.S.
- CEL Self Diag
- What are the signs of a bad axel/wheel bearing?
- Coolant Leak?
- washer fluid light
- 3rd Gen RSB on 4th Gen? - Other swaps possible?
- Clutch slave replacement info needed.
- Oil Leak How Serious?
- what do these codes mean?
- Q 45 Valves
- Anyone have or know where to buy volk/gramlight replica wheels?
- Exterior Parts
- safe to use PIAA 9004 bulbs?
- Buzzing sound from front end when coming to a stop???
- chop please
- Tranny mount blown?
- IDLE problem when Braking!!
- short throw shifter?
- Power steering line question
- brighter parking light mod 97-99
- 96 Maxima "Bucking" under light acceleration
- 95 Maxima P0100 code
- Stupid Ebay question
- Part Out VS. Sale
- VQ is in bad shape
- grinding sound after starting in the cold
- OBX Racing Headers 95-99 Nissan Maxima 3.0L V6
- Which is bank 2?
- ks and power loss(yes I read the stickies!)
- Vacuum Cut Valve Bypass Valve (0801) help!
- 97-98 Bose CD Player in a 96?
- Power Steering Belt Removal Pic
- Wheel Spacers and Longer Studs
- 300z BBK installed....can't move....
- question about fixing timing chain rattle for those who did it.
- Didn't start, then it did.
- Help! suspension question
- I'm about to take off my factory "racing stripe"
- About to buy a 1995 SE, 5 Speed w/184K...
- So farking pissed!
- Brand New David L's?
- aftermarket keyless entry - wont unlock
- The saga continues.....
- Belt tensioner to replace alternator
- Anyone have any dyno results or #'s on the 00VI swap?
- RPMs expected with locked wheels?
- Post pics of their two tone Wheelskins?
- Anyone have these on their car!? ...
- Failed Smog NEED HELP!
- Fog Light Install Questions
- larger oil filter for the 3.0??
- Happy New Years Everybody!
- In Dash Screen the Cheap way?
- quick speaker question related to 4th gen
- 235/45/17 tires with drop...lets see!
- Tires
- hidplanet.com is down, so i'll turn to you 4th gen hid gurus [3 pics]
- Serp Belt Replacement
- HELP: OEM Leather Install
- Squeaky rear suspension
- which springs do you recommend?
- just received my greddy sp2 (pictures)
- GLE to SE conversion?
- Coolant Hoses - How many and how frequently should I change them
- Having timing cover leak fixed, anything else I should change?
- light bulbs
- How hard would this be.......
- No gains from Y-pipe?
- where to buy oem parts online?
- Panel my wagon
- best suitable struts for S-Tech Springs
- overhead(dome light) not working when door opens
- Flywheel Differences for 95 Build Dates?
- are the headlight wiring screwed up?
- Question on the rear defogger button.
- Transmission Removal Question
- How to replace the washer reservoir?
- Powder Coated SE Rims-Glossy Black
- Can you swap a non-Nissan horn in?
- Drivers side power window whines on its way down.
- Drivers side power mirror whines on its way down.
- Are those knock sensors on sale at EBay any good?
- The max is grilless!
- 99 max auto climate control lights burnt out
- are these all parts i need for new suspension install?
- Someones gonna have a red maxima!!!
- new small mod-used another nissan trunk pop button in different location
- 98 Trany Problems
- I cannot get my horn to work.,......
- CE red/clear tails for 95-96 question
- Instruction For Installing Remote Starter?
- Blew tranny and Vlsd question!
- Auto Tranny Question
- quick answer
- Opening stock fog housing!
- Fidanza short shifter?
- How much to fix the Max? I wrecked it....
- i think my front ksports r shot.....
- New '98 SE owner checkin' in w/pics
- problem with my cornering lights
- Pointless to paint y-pipe?
- Considering the vq
- Helios HID Install Question
- The Great Coil Mystery
- advice on engine swap!!
- rims
- Problem with CD player???
- What clutch did I just install?
- Loping Idle, fuel smell, EGR code
- MAF sensor -same as 5th gen?
- I couldn't find a writeup anywhere on cleaning out your EGR so...
- shes throwin me codes =(
- Got in accident, how much damage do you think?
- Rear Rotor and wheel stud removal?
- For those with flowmaster dual exhaust.
- Engine Knock after manifold install
- Suspension setup...
- Is this normal? (y-pipe related)
- Aicv
- Energy Suspension Shifter Bushings?
- drained the block (by rear exhaust manifold)...
- Does the nissan production date matter for ignition coils?
- Franken Car Install
- Used Maxima Parts
- Bad Noise. . . Not too sure.
- How are the K-Sports ??
- Weird vibrating noise coming from rear right passenger wheel/rotor area
- New CF goodies!
- Tint question
- KYB AGX/Eibach rear suspension makes noise when going over any bumps?
- HID in stock housing=no glare
- interior LED replacement
- bushing on the shifter?
- whut is in your dash
- 350z leather seats in my maxima
- I30 Autodimming Mirror Installation Writeup
- Help? Primary Ignition Circuit Fault
- Hit a deer, where to buy hood?
