- Disassemble MAf sensor connector
- Knock sensor: change or not?
- More wear on passenger side brakes. Caliper or MC?
- 3rd Gen Floor Mats in a 4th Gen
- 99 production date variations - LCA and B-pipe interchangeability
- 95-96 stillen front lip sucks
- order of importance
- Typical Manifold Vacuum Pressure
- Gas Needle don't reach full
- LCA Recommendation
- Odd Stalling on Start-up 1 in 5 times...
- Antenna Issue - 97 GLE
- Question about TC tensioner
- Need clutch mstr, slave, SS line QUICK!
- Help me wire up my g35 seats? (schematic inside)
- Will it work?
- Spyder Headers
- Anyone Else Skip-Shift?
- Window regulator
- Few issues with a 1997 Maxima
- MT Trans Rebuild Kits?
- CLutch issues..
- Torsion springs that hold up the trunk?
- 4th gen aftermarket hood design
- idle issue after valve cover gasket replace
- Can 97-99 Headlamps Fit in 95-96 ???
- 300zx Calipers
- Koni Ground Control... Spring too short?
- Is this normal or Oil Leak?
- Maxima Clutch driving me crazy
- Battery and Brake Lights on
- pretty sure its my starter, but i want to make sure..
- '99 Engine Problem
- Help me find something
- cruise control always on 1999se
- What is a synthetic resinous fuel filter ???
- Muffler Tip
- Alternator Interchangability???
- HELP!!! Signal Lights flash fast but only rears work!!!
- egr-c solenoid valve harness
- VQ intake support bracket
- 10-tooth starter wont engage in 95 SE
- Sudden starting problem :(
- Fun Quick Fix
- Infinite QX4 parts?
- 95 maxima se will not start?
- Need help from my 4th gen brethren.
- Loose Shifter
- Need help with starting
- fuXXing clocks! wtf.
- ideas help dressing engine
- Lifter noise, I think.
- Code P 1492 need help.
- 4th Gen Go Boom
- Vacuum Hose Sizes
- tranny question
- Adjusting camber
- Front end overhaul
- How often do you change your brake fluid?
- Lets talk noobs having some patience...
- Are the '09 Maxima rims + tire too big for the 4th gen maxima / i30?
- I30 Mirror Question
- 1995 Max GLE - 2 error codes - infinite frustration
- Anyone still sell the SS master to slave clutch lines?
- key wont go in lock of door, what options?
- Smoke & Smell @ Startup... Any suggestions?
- '99 Maxima coil problem
- Help me out here. Im throwing the same three codes all at once, everytime
- Vacuum Lines
- 6spd guys, please step in
- Auto vs Manual HP?
- pass. side axle question
- Maxima to I30 leather seats
- i got codes, 8 of them
- 95 Maxima throwing codes ECT/EGR
- 97 fogs
- Trying to change from tan to black interior.
- Electric Cutout install
- WTB- 97 Maxima power folding mirrors
- 3rd and 4th gen front strut tower bar interchanablity
- Hanshins and Mistubishi Coil Packs
- Did OBX come out with a new header?
- 1st real snow in 3 years and my windows where open.
- weird initial idle
- How long do I have to drive before my system is "ready" after a cleared code?
- headlamp low-beams blew after 7ish months
- Exhaust straight piping.
- New Cardone Powersteering Groans
- Last night my tranny broke i guess
- FS - 95-99 Maxima KYB Front (SB103) and Rear (SB108) strut boots
- Going to retro,few questions.
- Back in the drivers seat
- Replace Heater Hoses?
- 1998 Maxima Seats- HELP
- A/C compressor
- Complete 00vi With Vafc-2
- Car overheating...
- What a $1000 got me
- Throttle Position Sensor Help
- Y pipe install slight glitch
- Is anyone selling finish led boards for the map light ?
- ASAP question - CEL with ignition on or no?
- Heated seat switch led
- LED GAUGES semi Failure
- how to replace Rear Valve Cover Gasket?
- master or slave
- nissan maxima seats
- Need help
- Strange starting problem
- Changed my VSS(Vehicle Speed Sensor). Problem solved (malfunctioning odo/speedo, CEL)
- Very strange electrical problem.
- Installing new crank pulley need help!!!
- rear illuminas are bouncing too much, dial caps lost
- Rubbing noise while driving?
- For those w/350Z, freeway blasters, or a nice big horn
- 95 Max: Service Life of Stock Timing Chain
- No Start
- V-Power cured my engine, but threw a code...
- FINALLY....time to KILL the SQUEAK
- New but old
- Will 17 X 7, 50 Offset rims fit on 4th gen w/o rubbing?
- Timing advance on Nissans?
- How to upgrade/update the stickies- Your input!!!!
- HELP- SEATS WONT MOVE, WINDOWS WONT MOVE
- Strange Accel Problem
- anyone else having trouble finding the maxima.org decal thingy?
- Tranny help please
- i30 hood
- Help plz
- Popping Noise
- Just blew a Brand new Moog balljoint in 5 days. HELP
- Window Louver's
- QUICK QUESTION ABOUT RACING SEATS
- dropping on tein s and have a question
- Missing Gasket...
- Shuddering While Accelerating (Stop and Hwy Speeds)
- Powersteering Fluid Question
- Brake fluid question...
- Oil and Coolant leak troubles...
- None of my inside lights are working
- 96 Transmission PROBLEMS! (after used swap)
- Bose vs aftermarket
- Spectra Premium Radiator - Any Reviews?
- New 55w/100w 9004 bulbs? wiring Q?
- Replacing Powersteering Hoses
- ECU trouble
- Help!! with tranny
- Intake comparison
- Help installing Ultimate/hks ignition
- 5-spd. shifter noise...still
- !!!!!!!The Stickys for all Stickys!!!!!!
- 95 Max engine dead, gone, and partly burned!!!!
- Fender Mounted Blinkers
- autozone radiator?????
- Rough Engine
- long time no .ORG :(
- Engine Check Light Code P0500
- 5-speed transmission replacement question
- possible part-out... How to??
- Map Light...
- Causes of starting problems: 95 Max
- Need help figuring out why my '96 still overheats
- question on 300zx tt injectors
- HELP! half my key is stuck in my ignition!
- Production Date Question
- 01 rear calipers?
- Brakes need work - Is this a reasonable quote?
- Location of Oxygen Sensors in a 1999 Cali-Spec Maxima
- Clutch Hydraulic System...
- 04 wheels on a 97?? Help me out...
- 95 Max PowerSteering fluid leak?
- what bank is what?
- r34 headlight problem, both fogging up
- Shifter Bushing Install
- What bulbs do the r34 headlights use?
- Need real quick help on axles
- Bent strut or lower control arm??
- Any DIY on how to clean the IACV?
- Max WROTE OFF...
- Design of the Water Pump Location
- Rear Timing chain o-ring leak
- Ebay intake problem, questions. Help!
- How to make remote work while car started?
- Radiator Drain plug stripped
- Stock Alarm Going off randomly
- header question
- rough idle with break booster hose detached
- LED gauges driving me nuts...
- broke off a bolt in the Intake Mani
- Voltage regulator. Worth the money?
- NEED SWAP IN NYC
- Help, smoke coming from the rear of the engine???
- 5 speed swap -> Pilot bearing?
- wont start
- Extremely wet driver and passenger floor
- Where can I get new Poly Engine Mounts for a decent price?
- Stock Max Top Speed
- Pulley questions...
- Engine not idling at steady rpm
- DIY replace tie rod end and ball joint using Autozone? Possible?
- Got 0509, replaced O2, then got both 0509 and 0115
- bad alternator history, ignition seems weak, should i be concerned about this...?
- i need some input.....
- Brake lines rusting badly.
- 95' fed spec tps & jwt ecu question
- Lower radiator support differences
- Is this a good way to get at the EGR valve tube?
- ES LCA Bushing install
- Power steering fluid in my gas tank
- need a part for my vehicle
- Starting issues can't figure out
- Brake light staying on
- IACV and TB
- Lower Rad. Support Rot - replacing lower rad. support (DIY questions)
- Front License Plate Bracket
- 99 positive battery cable
- Hey guys, Need some help ASAP with my DE-K swap!
- 95 Maxima with 98 Engine- HELP HELP!!!
- to those with creaking door hinges....
- When I buy D2 coilovers, what else do i need to buy?
- starter over crank
- alternator replaced, now battery died. radio is odd too
- Car not starting, no spark
- how do i clean Rust "dust and stain" inside corner light?
- Hey Guys :: My '96 Maxima
- 1995 maxima very hard to start when cold and have 2 codes..p0400 and p0325?
- So which year should i get
- rear wheel bearings
- CV boots and Vinylex/303
- wtb pigtail for A/C
- suggestions regarding p1400 code
- illuminas fail again!!?
- Headlight goes off then on when I bang on hood. Help!
- Mysterious sound while turning
- Replace Seats
- Questions about front turn signal lights....
- Garmin GPS friction mount?
- I got my cake, and Im eating it
- New member to 4th gen community
- Lop-Sided Suspension
- 99 - Will not turn over.
- Can you tell what problem is causing this sound?
- 95 tranny kickback into first, possible solution????
- Backup Projectors.. Stock Wiring?
- Missing, stumbling, slipping, and loss of power...
- Would you replace OEM struts if you did axles?
- 1998 Max for 1800?
- Anyone replaced your struts? I need a parts list!
- Car wont start right...has never started right for that matter...
- anybodys elses 5 speed whining in 1st?
