- Quick question for Budget Y-pipe owners...
- CV Joint replacement Question
- Installing STS and Can't get the stupid shift knob off
- Got a body kit...Step in please
- quick question about brake lines
- EBAY coil over springs for 4th gens... YAY or NAY?
- Staggered wheels?
- Short Throw Shifters?
- white max's w/ tints- post pics
- 18 X 7.5 rims whats the widest tire i can put on there
- 1998 Nissan Maxima...Toronto/GTA area
- C.F. Hood and Trunk question
- need some help...
- Funny noise at startup
- Wire Fog Lights on 96 GLE
- what to buy first..??
- Hub/Spindle Damage . . . Advice.
- ANyone have expeirence with this???
- Check Engine Light code p1447. Help!!
- Are these Ebay TIE rods any good????
- ? about continental contitouring tires
- Purchasing 34K engine from salvage yard.??
- Flashing AirBag light
- Storing the car for 6 months, comments / advice pls
- I Need Knock Sensor Info
- Quick help, PB blaster response time?
- Smog Help
- Pictrues of my '98.. Finally washed it...(56k..go to lunch)
- Quick question...
- Does replacing clutch or replacing flywheel impact tranny fluid level?
- Pissed...Verry Pissed...Any Help?
- Having hard time shifting my 5spd sometimes.....
- Is this a good buy?
- P0140 after catback instalation
- Offset questions Please Help
- 0902 code HELP plz
- Best dash kit for tan interior
- spring installation
- 97 Maxima Service manual? Also need help with problems..
- where to find MINT 4th gen w/low miles?
- Ultrasonic Injector Cleaning
- is this ground?
- Trouble starting in Cold Weather
- need new mid-pipe...advice?
- what size tire for my sawblades?
- Starter change on 99 (with ABS valve box)
- When u race
- Someone school me...
- simple question...
- Signal Lights and Hazards Cutting Out!
- Who Has Ground Control Springs? Please Post Pics Here...
- need help deciding on possible springs
- Knock Sensor code 20k after replacement
- High Pitched Whistle?? help!
- 5speed tranny swap
- door pillar question
- Now lets see the UPgraded brakes!
- post pics of 4th gens with s-techs
- knock sensor results
- Hood Struts....??
- PBR/Axxis Ultimate brake pads...
- clutch engagement point?
- Adding a 2 stage shock sensor, question.
- What the b-pipe height on stock suspension?
- Battery Question
- Quick question about fuel injectors..
- Best Place To Buy Flywheel & Clutch! ***Please Reply Soon***
- Any good paint shops near NYC????
- Quick question: How much should I pay for a service manual??
- Car died, @ Stealership! Pls help techs!
- Best Clutch?
- Any Pics of Brushed Aluminum on Black??
- How do you tune ignition timing?
- Melted Dash Kit
- Trunk torsion bars separator
- TYC Tail Lights
- Axle Change + Trans flush
- leaking coolant
- Hayden 403 or 70255 B&M SuperCooler, auto tranny cooler?
- Axles - LSD vs. non-LSD
- Starters for 4th Gens
- 95 max+18 inch murano rims need help!!!!
- how long until bearing fails?
- 4th Gen 97-99 - Anyone with a cargo net?
- Power Steering Leaks
- live in florida sucks!!!!
- R33 body kit owner plz step in
- knock sensor
- All red tail lights?!?
- Square Trade Warrany. Should I get one??
- way to test knock sensor?
- Know anything about this CF Hood?
- 300ZX MAF on the 4 Gen. Possible?
- not starting
- 4g's with grey interior, help me out
- AC problem
- Getting 12V from Fuse Box..HELP !!
- Suggestions on 2.5"+ inlet OEM mufflers
- Front sway bar
- Will a tow truck be able to tow my car???
- HOwcome no one on here . ..
- Light Question
- Post a pic of your favorite 4g -
- stock hood wobble
- Light Weight Flywheel
- Anyone Seen Pearl96Max
- Engine Movement
- ebay find question : carpet mats
- how to take out tranny
- Starting problem
- Best Clear front light color combo
- think these coil overs are worth it ? quick only 15 min left
- Name of headlights
- Lets See Them Retro Headlights!
- Advance timing for 5th Gens and the 99 Model
- 97 Maxima with 00vi
- What should I check first? Battery is being drained
- coolant leak
- Realistic expectations?
- Best test pipe
- Y pipe install...ECU reset?
- Water Pump?
- Underdrive pulley
- Botched Y-pipe install? [weird sounds]
- Airbags
- 97 Stock Wing removal
- Heat fixed!
- Chattering from Timing Chain
- just did BRAKES, need ideas on matching pads w/ brembo blanks !
- Hid's or Fogs???
- What Do You Think??
- **looky looky**Pics of my drop**
- Weird Sounds from Tranny. Please Help
- Fitament issue with CF hood and trunk, also tail light change..?
- Painting lesson well learned
- Possible tranny problem?
- Amber light folks...step in.
- Headlight troubles
- Diagnosis please
- Window Problem
- im bored. lowered 4th gens come in !!
- 300ZX Injectors
- where to get y pipe
- Replacing Rear Rotors
- knock sensors, hands, and tape
- How low too low?
- Starting Question?
- OEM Brand O2 Sensor
- Stillen Kit Owners Inside--->
- 1st gear grinding when downshifting
- rear main seal & clutch ?
- ks for sale
- how to wire up heated seats?
- Look what my car can do!
- Does anybody else have an exhaust leak with their y-pipe?
- Alarm issues
- Does anyone have these?
- 5th gen suspension fit a 4th gen?
- Gained 17whp in the past week or so...
- need emissions; SES = o2; where to buy o2?
- headlight liner
- im a new in tires so here's a question
- funny noises.... PLEASE HELP!!
- My retrofit HID's Dying?
- ok lets see those head lights
- Should I replace my axles?
- Question for 5=Speed Experts
- New Interior black and beige.
- Bulbs for tails, bumper lights and head lights...
- Is auto supposed to roll back on a hill?
- Need help with my buddies car.
- mystery trunk wires
- hid shield pics
- Where is the starter relay
- thought yall 4th gen owners would like this
- antenna mast wont go up
- Quick Reply Is Needed!!! Help!
- It is me or??
- lets see your tails
- this is for you marco!!!!!!!!!
- instrument cluster replacement (compatibility)
- Location of 98 ECU
- Gained 20 ft-lbs of torque...
- How do I know if my oil is circulating or not?
- Adding more outlets
- Corvette (GM) Transmission Fluid In Our Transmissions
- ipod connect to aux input
- replacing struts, just a few questions
- Help: Back to stock intake -- what is this piece?
- link for stud replacement?
- Ypipe causing clutch to slip?
- steering wheels
- Pulled Engine Codes
- is my starter bad?
- You ever hear this NOISE?
- White LED bulbs for gauges
- Brake lines clarification
- spaced in elt100: can i wire directly to battery?
- Pop. . . goes the driver side axle boot (rant)
- Those who have taken their steering wheel off
- Budget minded bolt on mods
- eastern (maxima) AKA i30
- CEL Self Diagnosis Problem?
- need help with the 5th gen clutch set-up
- ipod mounting
- hummm, ha something broke (PICS)
- Led Tail Lights , Question.
- Very tuff decision, which one is hotter!? need feedback and comments, please vote
- got paint??
- Shocks....
- 3 Quick Questions
- Highway Vibration 70 plus any ideas?
- I think I can I think I can...
- Does anybody have pictures of a white maxima with Gunmetal or Black rims?
- late xmas/new year/birthday gift to myself
- ACT Clutch questions!!!!!!!!!!!!!!!!!!
- Sea Foamed TB, fuel and Crankcase and CEL popped up
- Aftermarket Suspension shopping list - tell me what I need!
- Stick shift problem
- Metal Radio-Kit install......?
- Hit a deer last night :(
- Pacesetter exhaust opnions
- Speedo gauge problem, elec. gurus step in
- E S Front Control Arm Bushings
- Gauge Bulb "Holders"?
- What do you think?
- Help: Max wants to die when cold. hessitages during acceleration
- 97 SE Brakes
- 1st Gear 50mph 3200rpms???
- What's Your Sound System?
- sputtering sound at 2K rpm?
- Labor hours ? on suspension work
- People with 5spd conversion
- Tranny acting very weird
- orger helping an orger.
- proper headlight height
- Things to know about an auto tranny...
- humming from the front end
- d2 Camber Plate Problem
- Help! Recommend me a new suspention?
- 4th gen in NFSMW
- slight accel hesitation after MAF replaced
- 00vi
- SS Clutch Lines
- how much would you pay???
- help need choosing rims..
- Cheapest price for 5th gen Clutch Kit??
- Air Ride Pros and Cons
- Where to Dyno
- How to get air out of brake master cyl?
