- steering veers right..PLEASE HELP !!
- Pic of the progress on bbk for max
- CEL on....a day later.... off....then on...wtf
- Dash lights on, car stalls out, that means the ALTERNATOR
- How many cranking amps should the battery have
- Rocker Panel Damage
- ECU Harness
- Temp needle barely above C, low heater
- Real Quick; Why wouldnt coils get power/signal?
- TC Installed (Kinda long)
- New exhaust from cat converter back
- make your own oil catch can?
- Intake Manifold Spacer
- I got screwed
- would I have to replace cluch, if changing flywheel?
- How to change O2 Sensor for 99 Max
- Left front drivetrain problem
- Problem with screw falling in engine bay??
- Short Ram Intake
- Want to lower but...
- Any maxes here in the 13's without FI?
- 5th Gen GLE 17's on a 4th gen
- 300zx calipers and stock rotors
- this really blows.
- So Ive got a catback on the way...
- 96 mud flaps on a 99 - Will it fit ?
- Feeler: Looking for 95-96 driverside fender!
- To Hi-flo cat or not
- What's the most beneficial A/F ratio?
- Defected CE Red/Clear Tails?
- Buttons around heater controls.
- Remote keyless entry fixed.
- Nissan factory OEM clutch disc made by Exedy
- Front Engine Cover Leaking Oil
- Question about radio????
- brake upgrade sugg???
- F/S 1999 keyless entry trunk module
- stupid cali spec car
- Making ground kit, What needed?
- headers and y pipe deal on ebay...worth it?
- Engine question?
- EVAP system problem code 0807 / Dealer is useless
- perfermance vs looks
- Tein Basic One Piece
- Q about cefiro's, can you make 9004 hids fit in cefiro's?
- Fender dent
- greddy sp2 starting to whine
- Those 99'ers With Aftermarket Keys Step In
- Auto-RX safe? (oil forum is dead)
- Windowgoes down but wont go up!!! Help!
- car stalls in reverse in cold weather(sometimes)
- car stalling
- Fuel pump control module
- Power Steering Fluid
- Eibach Ground Control Coilovers
- 98 trans on 96???
- Steering rack boots
- Found weird gooey cakey yellow stuff under my car...
- Need pics of black max with black 300zx(z32) wheels
- Security Light On After Starting Car...
- quiet rear section
- Running lean
- Lower Control Arms from eBay?
- Kit without drop
- Push button
- ebay and cefiros
- Desperate need of help once again.
- 4th gen interior
- Stillen Kit Question ??
- How many hours of labour?
- removing strips on doors?
- Clear Bumber lights...should I buy Otto Racing or Custom Max??
- Service Engine Soon Light popped up today.
- rearend question
- I just burned my hand touching my SP2
- Glass Headlights!?
- Help!! Transmission failing?
- another BBK with pics (56k warning)
- Headlight Wiring Harness
- Maxima Door Sills - Fitment?
- 300z fuel filter replacement interval?
- Evap Code & Noise from EVAP Charcole Canister
- Grounding Kit
- Running amp power through firewall HELP!?!
- 99 i30 won't start
- sloppy steering at highway speed, bump steer??
- alignment needed after new wheel bearings?
- Looking at 5-speeds: Question
- does anyone have 18" 6gen rims on their 4gen, can i see some pics plz
- 5sp whining noise in reverse
- now driving 5 speed
- grinding noise in ignition
- ah!! Help with cosmetics (dashboard, window frame, roof top) hurricane damage
- Front wheel Bearing/Hub - less than 2 years?
- I can't search, can you guys post pics/links to the removal of the pillars?
- Brand New Tein H-Techs still in my garage!
- Where can i get mud flaps for my 99 max ?
- anyone with LED's in manual climate control
- Replacing belts
- VI00 setup in a 99 SEL?
- Idle Dipping below 500RPMs and then returns...
- injen dyno
- Vroom vroom, crap!!!
- Im in the market to buy a 4th gen. The one that I found needs 2 fenders. z3 slr ?
- Spring Question
- Cost to paint a spoiler?
- Gauge Clusters?
- Power Programmer for 1999 SE
- after spring installation
- Headlight options
- Muffler Bearing
- Please somebody tell me it isn't the flywheel
- Need to replace passenger side wheel bearing.
- Painted Trunk Max Logo
- 4th gen rattles
- how to remove tranny from bottom
- Heater not warm... bad thermostat?
- Finally a cardomain page.
- Installing Bumper Lights
- Home Made Rear Sway Bar Project - Need Ideas
- Good Exhuast
- dumping exhaust
- Car doesn't start on first try
- Rear-ended, what should I do?
- Help need fast reply 96 vlsd tranny will fit in to 99 nonlockin?
- turn signal removal
- Woooo! Pics! 56k beware!
- Is anyone making and selling Projector Headlights?
- tint %
- Questions regarding brake pads selection
- Starter negative cable connector is a MF
- valve body job
- Rear Window Defroster Slow/Weak
- F/S: Parting out Engine
- How to remove steering wheel and pass. air bag
- 99 Limited starter spins, engine doesn't
- $600 for my exhaust - reasonable?
- 300zx rear caliper conversion
- Battery and spark plug recommendation...
- All these lights.....I'm confused
- symptoms of a stretched timing chain?
- Rear Speaker Removal (specific Question)
- Windshield questions
- Radiator Leaking
- Alignment specs?????
- knock sensor harness help
- o2 again at 55mph
- Idler pulley problems
- 2004 maxima seats
- would something like this fir our cars
- Need help finding ignition coil thread
- Automatic Transmission problem, takes long to shift ??
- proper way to break in new clutch
- 5th gen interior into a 4th gen?
- Code 302 Again
- Pic of my car after meting with a deer :(
- Quick Cali-Spec Question
- clutch fell to the floor this morning.
- Trust voltage from SAFC-II or Beltronics Radar Detector?
- Megan Exhaust
- Warpspeed or Budget?
- pics of the motor tranny removal
- HID went out.
- Car's voltage.
- Where is 96 maxima block heater plug?
- intenna
- CE 95-96 tail light owners come in!
- need help, hyper blinking problems
- Painting Head Lamps
- how does this give you more horsepower?
- best/cheapest place to get 02 sensors...
- keyless entry
- Quick help please!
- Hit and Run
- Do you think this is Legit?
- Could these three problems be related?
- DAMMIT! Found a fluid leak in line right next to Oil pan...
- Drop Resistor final word
- 12 Volt Soure?
- Got my high stall TC
- Help - Thinking about buying a project Maxima: Doesn't start, elec. problems, cheap
- Speedometer illumination mod support:
- 3 gear on auto
- Low speed auto shifting.
- headlights?
- Havent heard much about this...
- 6th gen tranny in 4th gen
- 5th Gen Clutch...WOW
- i keep blowing fuses, HELP
- need a link
- Aftermath of Axle change.....
- Yippee!! Just picked up my 97 SE today...
- Transmission Filter nut removal issues .. heed help
- Brake light problem. HELP!
- Is This A Problem? *Pics*
- Keyless entry unit off ebay
- HID retrofit
- My tranny ?
- Might buy a 1995 Maxima:
- Toms Trannys?
- About ready to give up
- Upgrade Brake opinions
- Ya Gotta Give Some To Get Some
- changing the head lamps
- Annoying creaking sound from the rear...
- DIY tint difficulty
- 96 GLE Headlights
- does anyone have fender flares on their car to make a wide body?
- Power Steering
- What I learned...
- Where i can find nissan part#
- Resonator effect
- Foglight bulb question...
- 97 BOSE HU Question
- grinding sound upon coming to a stop, dont think its my brakes.
- Heated seats
- 5spd swap info
- Steering wheel sits slightly tilted to the right when car is driving straight
- Strut bars
- What were the opinions on the WSP Super-Flo Y-Pipe?
- possible starter problem?
- springs vs coilovers
- BRIGHT *** REVERSE LIGHTS (any1 know bulb #)
- Crappy auto
- Beating Up on MAX
- Fuel Injection Cleaner Through......
- Engine hesitation on pickup
- Dash bulbs have green caps?
- Do you have a 1/4 mile timeslip or time for your 4th Gen?
- Max with its new tint
- Got an alignment but rear wheels tilt inward
- 97-99 Bose AUX installation Help
- Headlight Removal Issues
- Repetative CEL
- Where can I find a write up on changing the rear valve cover gasket?
- grease in wire harness clip?
- Help! Loud scraping sound!
- Fuel Pump fuse Voltage
- This a good buy
- Broken Buttons on Bose dash (98 gle)
- urgent: o2, bank 1 sensor 2, which o2 from oxygensensors.com? link.
- Need some info quick: Starter issues
- As i'm making the door pillars the same color as my car....
- Heated seat busted. fuse ok. what now?
- hesitation/slipping? 5sp, clutch?
- Dash Painting.. Ideas?
- Cheapest Place to get illuminas?
- quick help needed: Separating control arm . . .
