- How do you replace fuel filter with aftermarket fuel pump?
- ABS Light while getting out of the snow!?
- anyone have a pic of g35 19s on a 4th gen?
- Megan Racing springs
- Blizzard of 06 pics!
- Wiper Motor
- 4th Gen in Malaysia
- BLEHMCO 4th gen stage II lower tie bar? thoughts?
- I cant make up my mind
- bolt pattern
- opinion on over wattage bulbs with upgraded harness
- So whats up w/ my ECU?
- JClaws traction bars install auto trannie
- Mystery Coolant Leak
- Crap-steer at low speeds
- TONS of Codes, 1 Solution??!!
- ...cops suck
- Anyone use/have experiences with the "Sonus" system ?
- LED corner lights screwing with dash illumination???
- Codes showing after Greddy SP2 install...
- drop resistor mod
- Stripped a screw when trying to get the bose head unit out
- Currently installing aftermarket head unit with ROEM-NIS2
- Bose head unit disconnected and reconnected - doesn't work
- Currently installing aftermarket head unit - speaker making weird noise
- Code 9-1 Front Right Htd 02 sensor heater
- Paradox systems coilovers
- Need some Input on Wheels and Tires
- pinging after 7k in 1st....
- help with axel
- air bag light on
- installing a temp display...help elec guys
- Those going to performance nissan meet
- Just got a parking ticket. But I think I may be able to get out of it.
- clearance lights the same on 95-98?
- photoshop of 240sx SE rims on a 4th gen
- front blinker/corner lights rewire
- Heat not working
- How much $ for '99 immobilizer key/keyfobs
- Any difference between 95-96 and 97-99 stock exhausts?
- replacing MAF?
- Bi-Xenon RS6/TL HID Retrofits
- K-sport GT springs..anybody have em?
- $226 for complete fog light assembly
- RPM needle jumps up and down....
- Opinion on bumper signals
- your seats? pics?
- spoiler detatchment
- BIG PROBLEM!!! Really need ur help guys...
- Control Arm Bushings
- Who is the steering experts in here?
- cost of tierod
- Windershield Wipers.. Non existant?
- where to find door lock cylinder
- rim question
- Help! Strange A/F behavior
- Cf Hood Question???
- Front end drop with Tokiko AND manual transmission
- 96 Box Lid fit a 97?
- Is it really big difference between Syl. Cool blue & Silverstars??
- coolant leak-water pump replacement
- Auto tranny problem
- putting in y/b pipe... replace 02 sensors?
- PBR Brake Kit - Stillen
- aftermarket fog: has install bolt in center, max has no hole. help?
- Auto Tranny Acting Funny
- Compression Tester Question
- drop resistor mod for tranny?
- makeshift stillen front lip
- Which mod yields better (if any) performance gains?
- P0300 P0325 Need Help!
- Yayyy!! Bearings fixed and new 5th gen clutch
- Air Bag Light
- Who has the cheapest price for Illuminas?
- Is it easier to put a 3.5 in a 4th gen or 5th gen
- engine coolant...any green type is fine?
- Bees in the can...Y-PIPE!!!
- Trunk won't stay closed.
- Ever use Spring clamps or compressors?
- The Best B-Pipe!!
- 9004/9007 wiring upgrade
- Transmission ECU BrOkEn
- Squeaking noise from rear of car
- Exhuast or something else? HELP
- energy suspension motor mounts, automatic
- stange sound when I turn my wheel to left
- alternator/ac belt question
- ABS sensor
- I need an advice on rims and tires
- totaled Maxima
- oxygen sensor brands
- Vinyl paint protection......? anyone try it.
- how do you think these would look?
- Radiator blown?
- Post pics HP Racing EVO's
- insane windshield wiper
- System to Lean
- belt ripped, what the...
- Strut Mounts Gone
- Guys with the Microvision 7000bct?
- 00VI Info
- Which roads do you prefer to cruise
- Starter Price
- E-brake light stuck on
- Underdrive Pulley vs. B-Pipe
- 4th Gen spring comparison gallery
- car not starting
- I want the .org's opinion on this matter...
- Odd problem
- CD deck removal?
- somebody please link me to budget y-pipe
- code : P0130
- 97 SE 5-Speed will not start.
- need to buy 18s
- ~~hid Help Please!
- Notches in steering wheel
- hissing sound from fuel tank area
- How to replace camshaft position sensor??
- help..rear caliper!
- ebay tail light question w/link
- Guys what the best psi for fuel efficency (205/65/r15)....
- Front end weight without engine
- Motion R H3 Fog Bulbs
- Good aftermarket speakers?
- Rattles!!
- Wider tires?
- Good Exhaust System Brand?
- most useful gauges? your educated opinions
- Loss of turning radius?
- Part # for Cat/Y-pipe Bracket
- crank REF sensor?
- Sunroof and Antennae Drain Hoses Clogged?
- removing bose system
- Clearing codes vs resetting ECU
- CE Tails?
- Dual Gauge pods
- for those with wheel spacers
- CEL/SES light comes on & off
- Clutch Ques...
- clutch drops to the floor
- Crackeling when making low speed sharp turns
- Fuse question
- another ks question......i'm sorry
- cooling system
- just got illuminas, which dust boots to buy?
- For thos with eBay X-drilled/slotted rotors
- pics of my E46 xenon projector retrofit...
- Sensor Plug
- vibration in gas pedal?
- Does your reverse go on vacation?
- confused about fog light wiring stuff
- Saw this and thought of yall
- Cigarette lighter question
- 99' Maxima burning oil problem
- Another ebay maxima
- Opinions on what may be causing....
- anybody else tired of their max?
- anyone install cd changer under seat?
- maxima hitch?
- Have you experience with this...?
- strut mounting bearing
- \\\\What is a 99.5////
- Tranny Trouble
- Where's the Cheapest place to get KS
- cat back exhaust prices
- how to: make bumper lights remain on and blink
- Heat not working correctly on my 1998 SE...help
- 2 ecu codes -need help please fast
- Replaceted plugs now car wont start
- WTF is my clutch done?!?!?
- How to on Speed Sensor install
- Help!!! My New Battery Exploded!!!!!!
- *Calling all S-Tech owners. Step inside*
- Lucas Oil
- Sensor Locations
- Cefiro headlights
- Auto locking diff
- Sellin the 95 Max :(
- Passenger side mirror glass replacement
- Hoods for maxima
- Blue 194 bulbs any good instead of stock???
- F/R ABS Sensor?!?!?!?!
- Paint opinion
- Rear tailight bulb
- Hesitation when giving 98 max the gas
- frame cross member problem
- Help with axle repairs
- read the stickys "engine service soon"
- Quick question, P0133 : 0409
- power heated seats source?
- maxima a joke?
- Throttle Bodies
- My neglected Max
- would you rather have a 4th gen or 5th gen
- will 4th gen parts fit in 5th gen
- Have a small leak!!! need help!
- Fog Lights
- Improper main battery earth point
- Cruise Control
- Throttle body - high idle
- How the MAF works
- airbag light...
- Air temp sensor different on some 97's
- Cattman Header Issue Please Read if you have Cattman Headers
- emission problem. lost. HELP?
- Experiences with Universal 02 sensors
- Power steering belt without a lift...???
- Axle seal leak
- when listening to FM, high pitched sound that varies with rpm
- Are B&G springs worth buying?
- Quick Help Please!!!!!!!!!!!!!!!!!
- Bent Keys?
- car won't start after unplugging sensor
- VQ not bad at all!!! wish i got it sooner.
- 4th gen ABS w/different diameter tires
- front signal light won't work
- lets see those HID headlight/foglight combos
- max with 400hp???
- New rims = broke wheel stud
- Would You Buy Another Fourth Generation Maxima?
- Does Anyone Recognize My New Ebay Maxima?
- Harness clips
- Hydraulic Bottle jacks?
- Towers in Ft. Lauderdale this past friday 2-3-06
- Squeaking Noises???
- 4th Gen Won't Start....
- Needed: Diagram of the trunk locking mechanism.
- torque converter code
- Timing chain question
- Rack and pinion repair
- brake upgrade question
- best way to clean injectors still installed?
- 95-97 white gauge (link to pic)
- 95 pf parts? Good or no good
- Broken Antenna Mast
- Does the 99 maxima has a check engine light
- engine harness
- A 4-door Skyline WTF...
- 02-03 OEM SE Weels?
- What Are The Best Brake Pads????
- 4th gen interior color?
- DE-K Swap
- What reasons could cause my brakes to lock up so easy?
- How do I "un-freeze" a caliper piston?
- dirty brake fluid filter
- I'm in dispirit need of a 97-99 5 spd in FLA
- give me your vin numbers and I can run it on carfax
- fuse list?
- Just Got New Rims, Take A Look
