- HID question and what HID bulbs that fit.
- Blue Fog lights
- Trunk stuck closed! HELP
- 4th gen max with different trunk lid?
- Clanking/Clattering From Rear End - Video
- LED Tail Retros
- Trying To Remove Silencer From OBX Catback..
- Help with repainting door pillars
- need help check engine light keeps coming back
- New Wheels and few mods
- CEL stuck on
- Engine Swap: No Start, just crank HELP
- Noise coming from front end when driving over any "not smooth" surfaces
- water pump woes.
- 4th Gen w/ 5th Gen GLE/5-Spoke Wheels?
- Bose Unit Retrofit?
- Magnaflow 14316
- RMS or Upper Oil Pan leaks
- JDM Power fold mirrors
- Question about obx headers/cat back exhaust
- Multi Use key opener problem
- Antifreeze Leaking...
- How Do You Get The EGR Solenoid Out?
- drop
- front lip
- Painted wheels.
- Green 4th Gen
- Are the 98/99 GLE/GXE gauges different from the 98/99 SE? (besides the white faces)
- PIAA extreme white bulbs
- Uneven brake pad wear
- Question on headlight Retro,
- What will happen if I say "FO" to CEL light ?
- eBay Exhaust
- Windshield Noise
- Getting Back into a 4th GEN!! Help me out.
- Sports springs on stock struds/shocks?
- squeaky serpentine belt
- A/C Compressor Clutch is shot????
- Just a couple questions for installing aftermarket glow gauges.
- Cloth to Leather door insert swap?
- Alternate signal for TPS?
- Spacer Questions...
- Price of new stock springs
- how could i verify if my car is off timming
- ecu differences and compatibilities
- 5 Beeps before starting the engine ..
- What fuel to use ?
- Help!! Anti-freeze odor and cloud of "smoke/fog"
- Vin Check
- knock sensor? will it do the job?
- leaking gear oil
- Goldtooth?
- only two coil without sparks, the car no start
- Rear window removal replacement "port window"
- rev limit
- LED Strips
- Door Hinges seem weak? Sags a little.
- Just finally my car after two-weeks
- Steering Wheel Question
- I Need Help!! I have a question about my axles!!
- Parking Brake Sensor
- H&R's + Lipkit Any issues?
- Will a 96 ECU work in a 95? (both 5 speeds)
- replaced knock sensor..now whats wrong
- Still have a problem with the r32 after putting silicone around
- fail safe mode
- Looking for information on KS bypass project (470k ohm resistor)
- Cloth Seats to Leather?
- Lowering Cold Start Idle
- What would clean my grills?
- Does it matter if i have an ABS front right hub, but dont actually have ABS?
- Headlight mounting bolt
- Car Stalling...Now Not Starting...
- WTH ECU??? emissions rejection
- Crashed my max =/
- Slight shake and vibration when shifting from 4th to 5th on hwy.
- what a bug out- car turns itself off than back on
- Need Some Advice on A/C -- Not Cold...
- cleaning iac
- Anyone ever had this problem?
- 1997 maxima 5sp tranny saga contines....
- Clunking noise from front end
- rear brake light is always on
- New brakes and rotors why are they smoking?
- BALL JOINTS/ STRUT BEARING??? or BOTH ??
- Speedometer swinging between on and off !!!
- My tranny sounds weird. HELP..
- temp gauge needle
- NOOB question: rear strut tower bars
- help..Best place to tint in Philly area???
- '99 ECM
- What are some little things that make the tone of your engine different than others?
- Car starts, but only runs for a minute or so, then shudders & stalls...alternator?
- Is there anyone thats sassy enough to change the leds on the bose headunit?
- opinions wanted on these G20 headrests...
- Need to drop Tranny Pan at 90K?
- want your opinion
- those who have replaced LCA bushings..did you have them pressed in?
- can I swap from manual climate control to auto?
- in-carbon microfilter Change?
- Whats wrong with CAI?
- Radio Worked...Then Stopped
- Replacing the small 3" filter to a 6" on my Injen CAI.
- Throttle Body Cleaning
- y-pipe nuts and bolts
- Parts Source for Calsonic A/C Compressor
- LCA Replacement- HELP
- Intermittent Engine Problem
- I'm officially out of ideas on these front end noises...
- Horrible Tranny Sound
- Clutch questions and who too buy off of?
- Performance improvement after cat-back installation
- Front Timing cover seal........
- need pressure plate torque spec
- P0171 ~ Yes Sorry
- AIght so how do i fix code P0300 or 0701???
- My 95 isnt acting right Help!! please
- o2 sensors
- Y-Pipe Question
- Dead Maxima - What to do?
- Speed sensors for sale
- valve cover gaskets?
- How does this L.E.D. strip work... For spoiler brake light
- help with clutch master cylinder
- Angel Eyes Car light Rings Kit
- no posts about 09 wheels on 4th gen??
- Question about the air bag
- replacing flywheel tomorrow..help :)
- Need some clutch help please...
- Were can I find a list of parts that fit our car that can fit others?
- Rear end grunting and shaking.
- car will not go into gear
- Need help ASAP. 4.5 gen won't start.
- 0505 is the best CEL code ever...
- dipping when on stop light
- EGR Change now whining and still P0403 and now P0105
- DropZone struts with Sprint springs ?
- 1999 maxima knock sensor change
- Brake hardware kit?
- Looking for the Opinions on the best & cheapest suspension setup in our Gen4. List
- How good is warpspeed?
- LED Savvy Members - Please step in!
- CEL has a mind of it's own
- Trans fluid
- WTB fog light
- Car wont start battery and starter both good
- Cold Air Intake vs Short Ram Intake
- Much, much better
- Mystery weather stripping off of Sunroof
- What size spacers for stock wheels?
- Brembo Brakes
- PA Help
- A/C radiator fans - when does each come on?
- Have a dumb suspension question
- Tuning N/A motor
- How illegal is it to change my corner bulbs from amber to red?
- Brakeless
- q: does altima ser seats fit in 4th gen
- need a good mid-priced brake set-up for my 95...
- Are the 98-99 gauges the same for the SE, GLE, GXE, and Infiniti I30?
- P0135, P0325, P0600 CEL
- Daytime running lights
- Aftermarket fender
- White signal lights
- Catalytic Converter w/O 02 question
- Could P0134 show up as P0154?
- Need Parts 1997 Infiniti I30
- Fixing intermittant power to the cigarette lighter
- 95-96 rear tail lights
- Cold air (no heat) at idle
- Product review thread(read here before posting on what parts to buy)
- maxima running rough according to startup?
- How would Warpspeed y-pipe,Stillen b-pipe,Stillen muffler, RT cat sound compared to..
- Running Light problem
- 4th or 5th Gen?
- Weird Chassis sound?
- Horn fuse keeps blowing???
- Aftermarket Steering Wheel in 4G Maxima (?)
- What are the best salvage / junk yards in NYC???
- Muffler is rusting out, should I replace w/ OEM or aftermarket?
- New Max, gotta get parts
- if I DO THIS???
- O/d Buttin not working
- spilled coffee and stuck overdrive
- Worth a check: Vacuum Leaks / Engine Idling Problems
- P0135, P0136, and P0155
- Will the OEM Maxima mud guards directly fit onto an i30?
- Automatic Transmission Questions
- lowering spring question.
- Coilover Opinions
- Cylinder 4 Misfire or Fuel Injector Help?
- 3.0 coil packs on vq35?
- Transmission Pan Gasket Problem
- Front seat parts-don't know where they go
- P0420 and P0440 code help
- 4th gen front brake caliper mouting bolt size?
- Radiator support Question/Help
- What fluid do you use for power steering?
- Transmission Question
- '95 Foglight Issues....
- The Exhaust Pipe has a catalytic converter and an O2 sensor, right?
- Temp. questions?
- 1-11 code miss at low RPM
- Need Info Quick!
- Got a 0407 code after swapping tires...
- Changing Gague Bulbs
- installing illuminas need diagram or somethin
- it has been raining and now the electronics on the door wont work
- 96 Fog Install
- used tranny what should I replace before installing?
- NEED HELP ASAP!!
- Sunroof Question
- Funny startinng noise
- Running Issues. PLease read and help
- stud thread pitch?
- A good deep cleaning
- P0136 even with o2 simulator?
- My car radio/clock/and cig lighter wont turn off even when cars off
- What is more hard on your engine and transmission? (for autos)
- How do you remove the front seats back cushion
- asked my mechanic about the 3.5 swap
- Car rocks back and forth in neutral?
- A pillar tweeter grills
- cefiro glass 2 piece headlights
- My CLUTCH ENGAGEMENT KEEPS SHIFTING.
- Clutch pedal no longer throws the clutch
- Where does one pickup "Nissan" decals for the calipers?
- diagnostic trouble code help!
- Which bearing could it be? *Trans*
- has anyone gotten harrased by the cops for the clear corner light mod
- 96 se died at stoplight tonite
- is my replacement 5MT good?
- Starter Not Cranking Engine
- MEVI collector gasket
- OIL lamp questions
- De-K Swap
- Unladen weight?
- ROTOR REPLACMENT
- DASHKITS
- GLE vs SE stance?
- Steering / Suspension question
- side mirror removal help
- Disassemble MAf sensor connector
- Knock sensor: change or not?
- More wear on passenger side brakes. Caliper or MC?
- 3rd Gen Floor Mats in a 4th Gen
- 99 production date variations - LCA and B-pipe interchangeability
- 95-96 stillen front lip sucks
- order of importance
- Typical Manifold Vacuum Pressure
