- Door alarm breaking.
- quick question about my clutch job!!!
- Overheating after water pump install
- Installing Tokico Illumina kit, hints/tips?
- HIGHER headlight fuse AMP
- suspension upgrade pros and cons
- ks wire harness
- Bad struts?
- Best speakers for 4 x 50w head unit
- Help!! check engine light
- don't know which springs to get (if any)
- Repaint or not?
- How loud is the stillen SS muffler
- Cleaning glass fog lights?
- Keyless Entry
- what could this HORRIBLE noise be?
- how do put your pic on yor signature
- qaulity radar detector
- Scotch Gard - does it work?
- Help with o2 sensors....
- skyline maxima? tee he he
- Stillen Vs Warpspeed B Pipe??
- stock 96 gxe time
- Ignition switch
- is gear oil transmission fluid??
- ok guys...
- Lookin at this 1996 maxima 5spd to buy
- someone needs to snatch these right now!!!
- Lets see all those 17 and 18 " oem nissan wheels
- Who's max is this?! (ver. seeing a tricked max in my town is threadworthy)
- Are the plugs pre-gapped?
- Vibrations at high speed
- Help! Vehicle Speed Sensor removal
- no power to ECU plug
- Tool to remove the airbag?
- Car wont start after sitting for 3 months, tips?
- Anyone w/experience with zinc plated discs please
- New Rims- I have a love/hate relationship
- Guys need lil. help here (tired of issues)
- RED LINE MAX y-pipe who? wat? y? where?
- extra $1100
- !?Bank1 o2 Sensor?!
- alignment question
- Anyway 2 stop the HeaT?
- Full 97+ conversion
- wobbly crankshaft pulley...
- v2 kit/FS
- Control Arm Question
- Is my engine supposed to do this????
- My car shakes a bit during traffic...
- DAMNIT! I lost my keys!
- Stone Mountain Racing headers
- So...what do guys think?
- maxima spring rates- GLE/SE/GXE comparo
- Door Courtesy Lights --> Electrical problem???
- what type of shop will mill down the 300zx rotors?
- auto transmission fluid and filter
- $693.54... Did I get jacked?
- auxniss adapter
- Which harness to get?
- Motor Mounts
- clock and others do not work
- idler pulley bearing going out
- 0102 MAFS ECU code help
- is the clutch hose made up of 2 parts?
- Greddy SP2 fitment
- How many quarts in tranny?
- Before and After accident pics (please comment)
- Mods that increase low end torque?
- Install LEDs on Door Light and One Doesnt turn off.. EVER!!
- 5spd swap reliability
- axle assembly question
- where can i get parts to build my motor
- 97 max 02 sensors i mixed them up : (
- how long??
- Car Acting..Wierd...Transmision?
- Look at the condition of this max
- Widebody kits available for 4th Gen Max.... almost!!
- Fog Wiring
- Ahhhhhhhh.... Someone help me.
- There goes my tax refund!!
- What happened to my grounds?
- How manny years in a row did the VQ30DE win Wards Top 10 Best engines ?
- Caliper slider pins seized - change the pins or new mounting bracket?
- Oil Change?
- Under Douche!
- My Exhaust Video
- Best place to buy MT90 tranny fluid?
- De-flap question...
- When I turn the Steering WHeel I hear Groaning/ growling!
- Breaks, Rotor, Caliper...wheel bearing maybe. Whats up?
- Warped rotors -- replace pads?
- a/c place?
- Looking for a great mechanic in South SF Bay, CA
- trunk lid lock
- Are my 300Z calipers on the wrong side???
- 2,000-3,000 RPM IDLE! What sensor to replace?
- shifter issues
- Engine and trans
- Transmission issues
- Mod Suggestions
- hard to put projecters in e36's?
- Need new exhaust; Walker or Bosal opinions?
- brake pads and rotors
- Ethanol Gas or E-85???
- need help quick
- Good Fixer'Uper?
- It took me 5 hours to change out my alternator: Am I a dork?
- I m about to get a bose h/u for my max does anyone know how to install it
- Heat/AC Fan stopped working
- Can I use 97-99 outer tail lamps in stock 95/96 rear end?
- Shift knob, shift boot, arm rest cover
- would this size wheel work?
- Need tiny help with front valve cover gasket part number
- Power trunk not working.
- Need writeup on installing/tuning Ksport Coilovers
- cheapest place to buy front hub and bearing?
- good price on maf
- Wheel studs and vibration
- After new gaskets...
- lowering spring question
- Stupid intake question
- Stupid bulb question
- car doesn't get enough throttle when starting? check this out!
- Maxima price range
- What Brand RSB better?
- dead battery after 2days???
- oil question
- Brake Hardware Kit
- Strut and shock replacement
- help with trunk lid
- Changing brake pads
- Huge Issue.. Could Effect my Poker Game
- who do you think would win?
- Lookin Aroud Ebay
- looking to make LED tails, need lights to trade
- Need help choosing Carsound Cat
- Ground control different part numbers for different struts?
- Steering Wheel Vibration
- Pics of 4th Gen with 6th gen SL 17 inchers
- Need Bulb #'s for everything
- Problems all fixed
- Automatic Transmission problem?
- Brake Kits
- SP2 Exhaust Intalled :)
- SEL light blinking randomly?
- Oxygen sensors - clean before replacing
- Road Rager had it out for us, Maxima took it like a man...
- 2 questions. Need some help
- aftermarket exhaust/muffler question
- is there a way to add stereo input
- vent's constantly blow
- G35 sedan muffler pics
- rev limit
- A32 black cefiro headlights on white maximas
- Just got from junk yard so excited :)))
- my clutch doesnt disengage
- Rumble noise when braking down a 20-30% grade.
- Yokohama Advan S.4 Opinions?
- fix transmission leak , without really fixing it?
- Code P0450 (0704) ..... HELP
- Code P1446 / 0215 ...... Help
- What the hell happened to budget?
- Should I paint grill?
- Best way to manually shift an auto?
- I need a grounding kit
- need help with sensors
- need help on removing black outer or inner bracket for stereo install
- What brand/type of oil & filter do you put in your car!
- 99' brake rotors on a 02' & Exhaust B-pipe interchangable?
- Best Spring/strut combo.
- best muffler for budget Y and B
- Bose system with tweeters?
- grinding noise
- h techs and illuminas
- o2 sensor reading voltage with car off
- with s-techs do i need camber bolts?
- Best Tranny fluid?
- Anyone put a 97+ Stillen lip on a 95-96?
- Sweeeeeeeeet, Got Some Extra Cash
- Spark Plugs
- tire size help??
- thoses with carbonfiber trunklid
- y pipe quick help
- H&Rs, Illuminas and ??????
- unknown noise
- 1995 B-pipe to 98?
- Where do i find all parts for 5 speed tranny swap?
- 99 ecu picture
- Rattle knocking turning hitting a bump under dash
- Riced out Maxima
- Should I fix this leak?
- got a load sqeak coming form the drivers strut
- anyone know where to get red vinyl tape i v looked at walmart and nothin
- Starter problems
- Gasket material vs rtv
- Muffler Recommendations
- What is this weird smell from my car?
- Euro Clears vs. Crystal Black Headligts?
- Ordered most of the suspension, should I worry about ...
- Tein H,S and Sprint spring compare to Eibach for 4th gen???
- What Should i Get?? ( Caliper )
- dynomax muffler, welding or clamping?
- Thermostat Temp
- Projector Foglights for Me
- auto tranny problem
- Experiences with eBay Bumpers?
- antenna is getting stuck!!
- stereo broke, replaceable?
- Rear shocks removal??
- --Fugly Wheel Swap?--
- new 5th gen clutch installed. how to adjust
- I believe these are one of a kind :)
- Rear Brake Calipers FAST HELP Please!
- Rear Brake question. . . maybe an easy one.
- New Exhaust Question
- Weird morning noise when driving please help.
- 125 amp in the place of a 110????
- LSD? How do I know? Doing clutch show I do flywheel?
- Stock Springs & Illuminas??
- who has better brake pads for the $?
- shots of my $1200 maxima
- Bent bolt on sway bar end link
- I have ALWAYS wondered about these, and I know im not the only one..BS or Legit ??
- Bastards Stole My Bumper Lights!
- Replaced my struts, terrible squeaks
- dumb question (just need quick answer)
- Help from those who torched out old motor mounts
- 350z wheels on a Max
- Brake pad recommendations
- NEWB Questions SORRY!
- top speed
- No...why!!!!!!!!!!!!
- Replacement for Resonator
- One of the cylinders misfiring???
- Rack & pinion all by myself?
- Strut recommendations?
- How would the white needles look on EL Guages gauges
- No reverse lights or A/C???????
- MEGAN-R catback hang low?
- Knock sensor dissected w/pics, 56k warning
- weird crinkling noise when braking and turning
- I'm completely stumped... Alternator question, please help!
- Just Intalled It All :)
- Budget Y pipes..
- Question concerning Illuminas + Springs deal..
- CV boots
- squeeky noise from front suspension
- 2 leaks found(with pictures). need help
- Is my dealer trying to gouge me?
