- Engine Problems, Help Please
- Fuel pressure regulator?
- engine sound question
- Can some one photo shop these wheels on my car for me? please
- Has anybody seen this yet??????
- Do I need new calipers??
- output seal on 5spd transmission?
- Warpspeed products: Pros and Cons
- injector project
- Need Shock/Spring Advice Please
- Wiring/Illumination Question for Bi-Xenon H4 Bulbs
- 97 air intake temp sensor in a 96?
- Noise from passenger side...alternator? belt?
- How to remove/replace tail light
- Tokico Illuminas suspension kits installed
- writeup for wiring ipod to bose sterio?
- hmmm my temp gauge is jumping!!!
- Anyone use auto-rx?
- BBK Questions....
- Strut Bar
- COSMO Cold Air Intake
- 300ZX Brakes
- Would these lights match?
- 6 speed
- Help! motor won`t run!!!!
- just come teaser pix of my lights
- Urgent matter regarding rears... Very burning Smell !!
- Flash Relay location
- Brighter Tail lights?
- Take off door panel to replace speakers?
- pulling 0606
- Coolant flushing question
- Carfax My Vin? (please)
- clear turn signals
- LED gauge lighting help
- OBDII Driving Cycle?
- speaker static?!?
- Spring rate questions?
- Wiring Fog lights
- Quick ECU question.... help
- getting rid of raspy sound in exhaust
- looking to replace exhaust system
- Broke Valve Cover Bolt HELP!
- auto tranny?
- what should i ask for in my custom catback setup
- AC blows very cold, then warm
- Overheating ONLY when the A/c is on and..
- Cross generation 5spd Swap
- Automatic to 5 spd conversion ?
- Greddy SP2 owners help plz... pics
- Any experience with SS y-pipes from SS-Autochrome?
- Coilovers vs spring/strut combo
- need some big help
- Need new exhaust setup soon, need opinions
- Cosmo Cold Air Intake?
- suspension info needed?
- 5-speed tranny rebuild
- high pitched whining
- Antenna
- radio ? please help
- H&Rs, Illuminas....Spring Isolators/KYB Mounts and Boots?
- Its been a while ! Post up your engine bay photos !
- Bad Luck
- Anybody Tried Headers and Y Pipe from SSAutochrome?
- poor starting
- rear spoiler brake light
- Projector headlight question.
- Lower crossmember bolt problem
- I'm just curious?
- PNP Switch Info needed please!
- Engine starts horrible...
- brake caliper painting
- Paint Shop?
- hard 1 - 2 shifts on an auto
- Need some help here some weird a## isssues.
- Performance chip?
- vlsd advantage
- 60k miles and the freaking input shaft bearing is shot (5speed owners step in)
- AC problems
- Can a rear caliper freeze up in the retracted position?
- coilover question
- cant close my trunk
- CV joint question and transmission leak
- Belt Tensioner > can't put it back together (pics)
- need some help w/ AC
- Gas Saving question...
- I found a torn hose on my tranny!!
- aftermarket bulbs?
- performance at different temps
- wiper fuse..
- Need Help!! Suspension Question!
- Front Suspension parts
- Something Leaking dont know what yet...
- Changing Alternator (arghhh)
- Math: Why you should use cheap gas - part 2
- how do you adjust or parking brake
- Speed Sensor Problem
- raspy noise coming from exhaust?
- Determining which o2 sensor is bad
- 130$ shipped for 2 bearings and mounts from nissan? Yeah or nay!?
- transmission noise
- AE corners
- Mods that increase mpg
- How to adjust your parking brake
- SUSPENSION springs shocks sruts sways the whole deal
- Car Got Hit
- optimal shift points
- fun drifting possible?
- !?P0136 o2 code?!
- will these rims fit?
- squeek when i turn left..
- battery dead / cant start...what is wrong??
- Gettin car tinted
- EGRC Solenoid valve
- Strange problem, what can it be???
- Changing Fuel Filter
- anyone here black-out their clearance lamps?
- Finally got some wheels!
- Anyone Have A Funtional Hood Scoop????
- headlights
- Ebay Knock Sensor
- Black Max's with Bronze/Gold Rims Step In
- Custom Enterprises Y-Pipe, yes or no?
- Since I had trouble finding the gates belts for a UDP
- help me please help me help me
- IAT Sensor Mod?
- Maxima Muffler sounding.
- blew the tranny today
- When to change the clutch
- y-pipe again
- peeps with muranos please post your pics
- What Would You Choose?
- Altezza Tails??????
- DIY Midpipe?
- suspension decision
- (VIDEO) Cattman Headers & Cattman Catback Exhaust Video - Must See !
- I30 interior --> Max interior???
- Everyone with Tein coilovers check in
- Left 2 strips when i did a burnout???
- CEL ->ECT->harness fault
- Windshield Wiper Removal
- Gas smell.
- noise
- Need help with digital climate control.......
- Scratch on Dash
- Codes 1440 & 1448, Replace Evap Vent Control Valve?
- RTP rotors, good buy?
- 120,000 Mile Service
- 5 Spd Swap vs. 3.5 Swap
- Anyone got or have had a BMW?
- What are the warning signs of a dying tranny?
- New Home Depot Mod!
- Coilover noise/knock/bind FIX thread. LOOK
- Really quick question for Y-pipe DIY'ers
- taking driver's side fender off.
- post some pics of oem nissan wheels
- Redline MT-90 or Amsoil ??
- Rims or suspension
- DIY Tint today lol
- 96max se vs 90 300z non turbo
- Transmission Rebuild and CEL Code Question
- New suspension getting installed today - dust boots?
- does anyone know if hooking up 2 batteries to the car will damage alternator
- 98 mevi owners!!! I need pics!
- Xtd Stage 2 Clutch ?
- changed the alternator 4 times already, whats the problem?? HELP
- abs light keeps flashing..help
- Shifter rattles
- Where is teh effin "Inhibitor Switch" on my 4th gen?
- Argued with tinter who left strips untinted near mirrior area
- intake leak?
- Brake shaking
- Stupid tree
- Seat Swap
- throttle body spacer
- Starting problem - video enclosed.
- air/fuel Q
- 350Z Anniversary rims on the 4th gen...
- 6 injectors for $125 go or no go
- Swapping a 99 Homelink visor on a 97...anyone done this??
- car got keyed up pretty bad. suggestions?
- Clutch Question
- Need Help
- What type of brake pad?
- Suspension Q
- 350Z rims?
- Consult Software.
- Gear Oil Leak. Please help with advise!!
- rims......
- tranny price...good or not??
- Suggestions for a battery???
- O2's still ok, but the CEL came back
- H4 vs 9004 vs 9007
- Is this legit?
- change out coolant or coolant flush?
- Wtb Oem Stock Spoiler 97 Se
- Cost For Replacing Transmission?
- tune up what should be changed?
- need help
- Really Quick Help
- Man....Snapped D2 camber adjusting bolt!!!!
- AE Shift Knob
- Over Drive ON OR OFF
- PPL from Guelph ON, Canada or Surronding Area
- 2 Questions (Mysterious Plug&Sunroof)
- Eibach Coilovers
- Braking Problems.
- Are my side mirrors foldable 97max
- Blowing headlight bulbs, left and right....
- Which Sensor is this? (pic)
- pressure loss in tranny???
- Will a hairline crack in a connecting rod show up in a compression test?
- alarm
- haha wing on max!..not mine tho!
- Whats the official purpose?
- Need a new front bumper - how good is aftermarket?
- Maxima Problem... Car makes nose when stoping
- Camber bolts with Ground Controls?
- Max Horn
- In need of advice -Suspension
- Y-Pipe on - disappointed? Please read!
- Feeling Bad - I'm letting someone work on my car
- Clutch issues <---- Need Help!
- Sorry for stupid q. but how bad is 20% tint at night
- Rear Brake pad change, ASAP!!
- Keyless entry tone?
- Please help me!!!
- Goodbye Maxima.org
- OIL leak (i think)...HELP!
- 1998 Ecu
- Look what I found in a new Honda ECU
- The beating of an old topic - PLEASE help, though!
- Yaaaaaaaaaaaaaaaaay
- CM type II spoiler question
- vibration in 3rd gear
- Does not beep when lights on and engine off!
- 98 maxima fuse guide!!
- Classic Problem - New Twist
- Wierd High Idle
- pics from SEMA autosalon in philly this weekend
- axles/cv
- Fuel Door is Bent -Need Help
- Koni and Progress Install
- Shifting Hard
- Timing cover gasket easy?
- My Video: Power folding mirrors, Purge, SC BOV... :)
- Windshield HELP
- Was going to build a HAI
- How to remove a Bose HU???
- what aftermarket suspension kit is closest to OEM
