- tail lights?
- 97 Maxima won't run
- Anyone know how to contact MaximumTuning
- Michelin Pilot Exalto A/S
- cant use u joint for ks
- LED turn-signal & DRL
- tein h-techs w/ gr2s good or bad?
- HELP with changing rear breaks
- Need more info on 5 spds rebuilt **Pics**
- which fog lights are best in fog?
- Rear Strut Bar
- Is this possible w/ an auto?
- Blue LED plate number illumination-yes or no
- Do i HAVE TO jack it up?
- Question for you 4.5 gen owners...
- surge in acceleration
- Holy hissing Y-pipe!
- Freakin Coolant
- 95 with a y pipe and short ram 1/4 time
- stock fog on a gxe that dont have them
- Comparison
- Fuel pump or injectors? Starting problems.
- Anyone have aftermarket fogs in the stock hole of 95-96??
- anyone had experience with this
- My Manual Is Constantly Getting Stuck IN REVERSE
- Chime in on this
- Stock fuel pressure regulator question
- BEN's rear strut mounts
- $513 for clutch replacement labor?
- Cylinder 5 Misfire
- Is it factory alarm or just keyless lock-unlock
- Which Walker 02 sensor ?
- brake sqweaking question
- High Flow Cat Converter (Ebay)
- floormats
- service manual
- Popping noise while driving when turning steering wheel back and forth?
- clanking noise near axle
- URGENT help needed with o2 sensors code 1001 an 0901
- break pad smell
- Retrofit gurus step in please!!!
- Better LED writeups?
- $500 for this??
- Anyone know if 02/03 rotors will fit on a 4th gen?
- foglights
- squish squash noise from the Driver side wheel
- Legit or not legit ???
- new paint job
- tranny question
- Recurring Code
- Few Problems that i need help with please?
- woodgrain 5spd shifter
- Gasket on EGR Tube
- Calling all Apexi N1 owners
- Grease Fittings -- Do we have any???
- Clicking noise when car is beggining to move
- Cleaning out fuel lines and such
- Anyone around Boston interested in working on our cars together?
- Jumping Idle and Bouncy Accel.
- Reasonably priced Nissan mechanic around Boston?
- Who makes the best drive belts? OEM? Gaterback? Who?
- Is it safe to go with an aftermarket fuel filter vs OEM?
- shifting problems
- Is it safe to go with an aftermarket PCV valve vs OEM?
- Camber problem
- Who have the Jt autostyle(aka Evo) rear bumper please post pics
- does this look ok?!?!?
- hard tranny shifts
- Please help service engine what did I do?
- alunimum dash vs. carbon fiber
- Anyone experience this dealer tactic?
- How long does it take for the stock exhaust to cool?
- For those with EverStart Batteries
- PLEASE, where is the "ignition signal primary circuit"?
- Apex'i Filter
- Car idles at 900 RPM???
- Glad I lent my Max to the wife.
- Why can't I go 140?
- Guess I was wrong...
- Let's see your side skirts! (and I don't mean a female's)
- Hub Bearings
- Need to buy new gaskets for my y-pipe
- Maxima crash video
- sloppy steering response
- 5th gen clutch on a 96
- Front disc brake question
- 18 inch murano rims
- O2 sensors
- My MAX is running sluggish
- Advice with spark plugs
- Redlinemax.com, anyone know of anything going on?
- HELP ME Need an oem 16" tire Kuhmo-spt/Fuzion-hri?
- Altenator problem
- apexi WS
- anyone wired up the msd 8950 rpm switch for 00vi?
- Having a hard time finding this
- Eibachs or H&Rs?
- my gas mileage
- ECU options for a 99
- Does a Faulty Tranny Affect the Idle?
- going from 2.25 to 2.5 exhaust more noise?
- Bad Accident..
- Progress Rear Anti-Sway Bar
- Headlight Flashes on and off
- 97 se obx headers and down pipe install
- How many have had diff bearing failure???
- Cost of auto to 5 speed swap
- 5-speed: Never heard of noises like this...
- accelerating vibration help
- Ball Bearing Replacement help
- Starter reassembly - Please Help!
- notchy steering after a lot of rain
- My Max just died. Help!
- electrical problem
- gearshifter bushings
- real quick please
- Common 4th gen problems, is timing chain a problem?
- Location of ABS sensors
- ECT and KS problems due to harness
- Replace Tranny Fluid (not in sticky?)
- Fog lights
- y-pipe install, do I need to lube the gaskets?
- '96 auto tranny locked in 3rd gear, help!
- Weird starting issue
- Spark Plug GAP
- need new struts/shocks???
- Anyone know a good muffler installer in NYC?
- How hard is it to wire a VIPER alarm? Anyone have instructions?
- Y-Pipe Hanger Question
- Clutch Leak?
- Body parts
- ** My Oils Leaking (help)**
- bobbly
- 17's and 18's + no drop post pics...
- Easiest way to wire a kill switch????
- springs w/o blowing struts??
- Greddy SP1 hangs too low...anyone have this problem or have pics?
- 3 pictures of CE type II spoiler...
- High RPM problems.
- How to pinpoint where a tranny leak is coming from?
- 3.5 swap???
- Help would be GREATLY appreciated. Ticking noise.....
- Gas and Temp gauge problem and also saw some smoke
- Sanded Headlights. Need Help
- Knock Sensor
- Purge Valve
- question regarding retro'ed cefiros
- More grille choices (pics)
- Remove transfer paint from accident
- Anyone ever insulate the wheel liner?
- Some foglight questions...
- Where is fuse 51?
- What do you guys think ?
- oil pressure sensor
- Can anyone help me out
- One more on 20' chrome, who is next lol
- Can I put cone filter on air intake?
- dont buy from umnitza... need help identifying bulbs
- Car Is Apart, Can"t Pull Passenger Axle Off!!!
- Ksport riders check in
- Garage advising: EGR hose+valve...
- Hks Sport Exhaust
- Where to get the clips that hold the spoiler to the trunk?
- Got bored this weekend....
- Unusual noise coming from headers-99max!
- Trunk liner/carpet + letters
- Hard to Start
- Owners with muffler tips check in...
- Brand new set of four kyb agxs for sell
- how to install jdm 1 pc headlights???
- approaching governor
- Code:p0443/0807
- Uh oh, wrong cat?!
- Interior Painting
- Car won't start
- Ignition Switch going bad?
- I have a huge problem....Thrust washer (cam)?
- These effing belt tensioners.
- P0340 and P0301
- Intake Manifold install problems
- 95 feels like new car :)
- Metal braid on flexpipe
- CA to Fed Spec Exhaust manifold conversion
- Sway bar help?
- please post photos of your piston tops
- do 02 sensors effect gas milage?
- Fast when cold..... Slow when hot......
- Rear Strut Mounts
- Transmission Shift Lag...PLEASE ADVISE
- Auto tranny slipping
- ATF? What type do you use?
- I hear squealing when the car starts...what is it?
- * Gear Fluid/Anti Freeze Leak ** HELP
- 95-96 Fog Light removal
- ** Stage 1,2,or 3? **
- 93 octane, where do you find this stuff?
- 02 bung on greddy sp2(bypass 02 sensor)
- e-brake light always on.
- Maxima Low Gas Mileage
- is this a rear main seal leak?
- A/C Expansion Valve??
- sub frame rust - what can I do?
- Got bored, did a little mod. 56k GO HOME.
- Springs Time!!!!!!!
- 16" 97-99 maxima mags
- Best place to buy Knock Sensor?
- cefiros
- $140 for a y pipe install?
- god damn otto racing FSTB
- 0304 knock sensor replacement
- my alarm keeps going off
- Do I need a new battery?
- junkyard tranny owners??step in
- No Rear Sway Bars On A 4th Gen?
- Wheel size question
- For those who changed their knock sensor themselves?
- ??????? DropZone Racing Struts/Shocks+Springs
- ABS Codes - Manual Pull
- How could I switch Bose to Navigational??
- Does Maximas Have 6-Speed?
- Greddy SP2 catback found at pretty cheap price
- help: rpm does not go past 2k...
- starting problems
- Pinion n rack should i replace anyone ??
- VQ35 cam adapters
- 95-99 leather seats 2 hrs left
- Fixing the bose
- Sagging rear 97 GXE maxima????
- Turbo?
- My 2 Car Pics
- BBK Finally Installed
- Who is SSautochrome??
- my 300zx brake calipers
- Anyone have Blehmco stage 1 or 2 lower tie bar
- emissions and saftey check
- belt wear and tear/.
- Do EL "Maxima" Door Sills for 4th gen exist?
- Looking for perfect switch for the DR mod
- Alarm system help!!! anyone??
- 95-96 grill without Nissan Symbol
- Headlights dim
- How to mount stillen front lip? Anyone have close up pics??
- .4mm gap spark plug ok??
- cold air intake -help-
- Rear brake help needed!!!!!!!!!
- #4 spark plug
- Question/Concern about shifting and auto trans.
- Leather Restoration
- HOT FEET!! lol
- Checked my car today...wish i hadn't!!!
