- check your stock boxes for me
- Engine swap question
- Need Help
- instruction for cefiro headlights install need help
- I got a nice deal coming
- crack on my windshield
- can u clean filters
- anyone have problems with the fitment of the stillen rear kit?
- check engine light came on 2-3 weeks ago
- new bushings project.
- Suspension jargon
- some pics
- Holy Codes....!
- GI: Before i put this in the for sale section.
- Need help regarding code 0702 and possibly purchase of new Cat. Conv.
- Want bigger injectors, need some help
- Front Orange Turn Indicators
- Frankencar Big Brake Kit
- Earls socketless hose is a pain in the a**s to put together
- my max has the hiccups
- firestone lftm alignment??
- p0306 code
- Smoked Tails?
- Question about shocks and struts
- 4th gen vids
- As if I didn't need more things to do...
- 4th gen FOGS on 3rd gen...
- Can a failed O2 sensor and Knock sensor stall my car?
- An old friend found me.
- car stalls while driving!HELP
- Need new shocks
- Changing O2 Sensor Readings...
- Neighbour's bought an 04 now
- Quick dumb question about factory alarm/panic
- How Do You Replace A Clutch
- cobra bbk install with minor mods.
- alternator ground location???
- injen vs stock
- Broken shift linkage?
- 99 max pricing?
- Shielding
- Tenrai catback
- how do u post pics
- Rear (cat) oxygen sensor - Resister replacement
- Suspension Questions..
- Best way to connect XM to 96 Bose?
- Tranny Oil
- Water in trunk
- keyless entry
- Sunroof Help?
- Some new parts today :-D
- Rear end lenses...which ones?
- Driver's brake caliper dragging...
- Car won't sell....
- Dropzone lowering springs and struts.
- which performance pads do you guys use/recommend?
- check this maniac out
- Looking to buy a CHEAP RSTB. (Not Stillen)
- Corner light bulbs
- Camber bolts
- Installing wheel stud?
- stillen adjustable sway bar vs. progress non adjustable
- phantom grip lsd good or should i get a real one?
- Doing brakes all around, pad assistance.
- Squeeky noise
- 96 & 97 front bumper interchangable?
- Amsoil Manual Tranny Fluid
- AC/Heat only works on "4"
- ECU Codes - O2 Sensor
- Alignment cost
- What's the difference?
- My new look
- difference in 95 and 97 maxima bodys
- need a motor
- Are 4th gen & 5th gen SPRINGS interchangeable?
- my maxima feels unstable on the freeway??
- 1996se wheel alignment
- Intermittent no-start when key is turned
- fan resistor pics
- Is my mechanic trying to feed me bull?
- How to remove bolt on tranny
- Does the 300zx fuel filter fit in the Max without modification?
- Questions - Brakes & Supension
- My motor mounts are torned. What should I do?
- Brake Hardware and Caliper Seal Kits
- Big Brake Kit
- Blinkers gone out
- Clearance lights don't brighten when signaling.
- Y-pipe to cataliac converter question.
- Water Pump. NOOOOOOO!!!!
- Guys that went to ES Motor Mounts
- Pictures of how 4th gens in the Bahamas are kept.
- Anyone Experience this problem
- now the POS won't start
- Cracked Radiator Top Tank :(
- Need Mounts and Cooling fan, where to look?
- Front hub bearing
- Interior Swapping Help...99 into 95..questions:
- Changing Tranny Fluid?
- 100,000 mile service
- Should i pickup used motor mounts then urethane them or use my broken ones?
- Brake Rotors
- Question on vent visor?
- Tail Lights
- Trunk floor
- Noob question about check engine light...
- 20th ann. shift knob on ebay.
- !! HELP Car Vibration 80+> HELP!!!
- Rusty caliper slider, what to do??? NEED HELP!
- any difference???
- soooooo loud!!!!
- Finally installed coilovers - pics
- Where are o2 sensors located on 99 Cali Specs?
- Right Rear Noise
- quick electrical question
- Need rear brake pads suggestions
- Big Decision, Need The Org's Opinion ( chime In Please)
- LED wiring
- rear wheel bearings
- Turning Crank Pulley ?? Picture !!
- part name??????
- debadging
- Anyone finally solved this problem? Help to find a thread
- Hood pins on a blk carbonefx hood? should i??
- ** ETHOS FR Program? ** FALSE PROPHET?
- Electrical problem, bah... 97 SE
- emission question
- ECU Reset
- Last straw for the vQ30DE!!!! 56k no-no
- grease leacking from from axle
- Oil Change Question
- ECU question after a conversion
- NEED HELP, Fast!!!!!
- Just an update on the SFCs
- I think I have a leak (need doctor's diagnosis)
- Calculating value
- 16*8 rims
- Cefiro's and S5 grill
- Question about a gauge cluster
- Suspension
- A/C Smell
- Motor mounts and clutch shudder
- how much do i trim bump spots with s-techs?
- Rear Bank O2 Sensor Question.
- 4th gen owners with m3 rear view mirrors
- Steering Noise???
- Weird noise after insalling FSTB, can someone help!!!
- Oil leak through spark plug tube
- thinkin bout sellin the max and gettin a 4th gen Prelude...thoughts?
- wheel spacers (for bbk) questions
- The fading steering wheel dilema
- What's causing this noise??? help
- Egi Harness Wire Breakage
- Headlight question.
- Freshly washed!! pics
- AC light's fade in and out?
- Hot air
- Control arm bushings
- Megaflow SS Muffler on 4th Gen.
- Got yelled at for using sea foam
- knock sensor - where to buy?
- Front driver window won't work anymore....
- moonroof wont close
- CE Black housing headlights and mevi shots.
- Anyone Swap out Core Support?
- Nico Nopi showat Firebird International Raceway.
- best way to clean intake cone filter
- please no flamming but what are these?
- Cobra BBK Done
- Gauge Rings
- how long after k&n filter is oiled can i reinstall?
- 95-96 Stillen Lip Only
- HID Question..
- Egr & Iacv
- Evap Fault-Where is it located?
- braking issue - rotors?
- How do I go about pressing the rubber bushings off of my LCA?
- Problem installing y-pipe on a 99 cali spec
- This is maxima.org. Not honda.org.......
- how dark should i go?
- Problem, please help!
- 90k mile service...
- DTC's Help
- Are there any other types of Carbon Fiber hoods other then OEM style?
- 99 TPS on 00 TB
- Paint Opinion
- Acetone in the fuel tank to improve gas mileage?
- photoshop request..........
- Ionic Lip Review
- Failed CA Smog with y pipe...help
- Doing my Y Pipe today
- Which O2 sensors are good?
- Well guys my Max is totaled
- high-capacity ACC wire in dash/console?
- Headlight Bulbs
- air bag light blinking
- Break Light ........
- axle bad again after a week???!??
- Y Pipe
- 01 Eclipse 17s on a 4th gen
- WTH?? Any ideas?
- URGENT HELP NEEDED (Overheating) !
- nismo fuel pressure regulator question
- 9007 light issue
- Spark Plug Types
- Wanted: Pics of Illuminas
- how do you install camber bolts???
- noise
- question about calipers could they cause vib.letting me think rotors are warped
- Best swaybar endlinks??
- Is it dangerous to drive with a bad wheel bearing?
- Oil Blowby
- knock sensor
- Juiced Scooter, can you beat him?
- replacing suspension components?
- Removing a Dent?
- how difficult to replace a front wheel bearing??
- Ebay Intake...
- need some misfire help
- 96 max on 5-spoke 350z wheels Finally dropped!! w/pics
- CF hood
- Brake repair tips with pics
- For those with subframe connectors: Weld Quality question
- White Signal Lights !
- All 4 windows 1 button
- wierd sounds when i make a turn !! help
- wierd sound when i make a turn !! helpp
- Stillen body kit question
- Where is EVAP Canister Vent Control Valve???
- Control Arm Bushing Install
- axels cause car not to work?
- which plugs
- Alignment how to...
- Lumincs or Nokya Yellow Bulbs
- Bose Rear Speakers. Any 4th gen speakers ok?
- Found a place thats building SFCs for my car
- Genisys 2.0 Scan Tool
- Quick question about spark plugs
- anyone have some 4th gen stock springs they dont need anymore???
- hacked air box
- speedo works, but odometer doesn't
- stock front with body kit rear
- Need Help ASAP! Key Pops Out of Ignition???
- AC receiver/dryer, compressor replacement
- Question about harmonic balancer
- Replaced Alternator, still have batt and brake light
- Re-grease starter
- What are the signs of a bad rear hub?
- Redline....cut off?
- Trading my 95 SE for a 95 ACCORD
