- i need 2 front struts, want factory/stock feel
- 4th Gen ABS worth fixing?
- signal reset
- small bumper light: park to signal rewire -- front already rewired
- New Design for SFCs
- Anyone buy/have iPod adaptors??
- all clear tails?
- Stock shocks?
- 1157 bulbs
- 300ZX Calipers Vs. Q45 Calipers with Pics.
- tranny hard shifts...suspension related???
- Down Pipe brace
- Sway bar end link bushings nut torque?
- LCA Bushings Diagnosis?
- Can I switch O2 sensor harnesses?
- Rear Brake Job *Pics*
- air sound while accelerating
- O2 plug bolt specs
- Sweet maxima...BUT
- Blue Smoke in the morning
- Hey check out my cracked motor(pics)
- 4th gen max, low beam doesnt work, high does
- NJ Inspection...
- Longer wheel studs
- No Horns - Factory Security System
- One fine example of a custom 4th gen :yeahright:
- anyone know the dome light # ?
- LED car change over, I couldn't find this info anywhere
- help: oil on pcv valve
- Intake upgrades on auto max
- HELP Low oil presure light red is on!!!!
- Not Another A/C Wont Work Thread....Serious Inquire !!
- clip of me and friends civic
- quick ? anyone knw the size of rear axle nut
- How much 2 port n polish cylinders
- MAF sensor
- Knock + 02 Sensor
- Anyone have a problem w/ their trunk sinking in?
- need help installing shocks
- I can't search, so excuse me....transmission leak
- When I depress my clutch it sounds like an old mattress.
- Evap canister price..
- Which spark plug?????
- Stillen front lip install ?
- Maf
- 95-96/97-99 muffler question
- Datalogging
- Where to get 4th Gen FSM pdf?
- Y pipe removal problem (rust)
- Clear LED Spoiler Brake Light
- Were 1996 and later years OBD2? Is the 1995 model obd1?
- chrome shops in CT
- Raybesto brakes ?
- auto tranny hard shifting problem solved!!!maybe
- CEL bulb messed
- Squeaks and Knocking ,Go Away Please! Need Help
- Rear Brakes- AGAIN! how much $?
- blower problem 99se help 100 degeers!
- 0311 vacuum cut bypass valve..
- Best Radar detector
- Will 5th Gen Rearview Mirror (Compass/Temp/Auto Dim) work in 4th Gen?
- Turn signals will not work at all
- need help with removing something
- Ben's shock mounts?
- A/T solenoid
- Really annoying whining noise revisited (found TSB, need more info)
- A few motor questions
- To Believe or Not to Believe?? (Codes)
- Stock "Alarm"
- exhaust hangers
- Clock just randomly changes time
- 98 ecu on 99 maxima??
- mechanic told me platinum spark plugs are bad
- Wiper Help
- CustomMaxima + SCO Gripe.
- Would you buy your 4th Gen again?
- whats wrong with my clutch??
- idle speed
- idle problems & starting problems
- 271,000 mi and another radiator fliud leak. Help!!
- Are Maxspeed springs anygood
- Help with my 97max (grinding noise)
- 95/96 Cali Spec Maxima's...Chime In!
- well, my low fuel warning light don't work
- What's wrong with my dipstick?!
- Lights won't turn off
- Which tool for Oil Pressure Sender unit install?
- Where to install the oil into a new A/C compressor
- Weird noise
- auto tranny fluid
- Water Infiltration **Pics**
- My Maxima Idle's at 2000 PRM
- 1995 Maxima Cat Back Question
- old squeaky engine belts replaced
- RPMs Drop While Accelerating - Help Diagnose
- Repainting the max.....
- Steering drift?!
- About to order a Cattman FastCat...
- Help with codes
- Damn reverse lights, please help
- New Clunk/Pop after installing new suspension...
- do intake/exhast mods improve mileage?
- Question about Brake Torquing !
- Help with tranny removal...
- Big engine problem need help
- difference between 95-96 & 97-99 grills??
- Any 4 generation maxi use nxt for wax??
- Spring Seat Alignment?
- Ground Controls VS Springs and Struts
- Radiator Forms Crack
- How can i clean the engine bay ??
- cheap rotors?
- Steering wheel not centered
- Sunroof Repair
- ram air conversion kit
- Throttle Body Size
- washer fluid dirty, how can i clean reservoir?
- VW jetta Needles
- checklist for the track ...100 Octane gas?
- tire size
- y pipe install and EGR code 0302
- Where to Buy Redline OIL
- $1800 chain tensioner
- Anyone ever do a water pump?
- Could someone list ALL parts necessary for...
- progress or addco rear sway bar ?
- Which photo looks best ? (sidebar on doors) :Comments opinions please !
- To the drivers in the CA ! i have a question
- Damn it, I almost had it.
- Will a 99SE steering rack fit in 96GXE
- Mod a 4thgen to Have a Cabin Filter? Easy Job?
- Loose Spoiler Issue, Squeaking
- stock dyno
- KYB AGX Settings ?
- 1. Fiber Optic Trunk Lid
- keyless entry issue
- 98 Maxima won't start
- 97-99 switch to 95-96 front end
- rotor - miles?
- anyone paint the plastic dash pieces?
- how to install 00VI???
- Caliper Choices
- Help...suggestions?
- wheel hub nut size.
- Ignition coils from autozone
- What is up with this code 0505?
- FAREWELL Maxima community, I'll miss you guys!!!
- Yes, another Knock sensor thread (not install ? though)
- OMG! The Skyline comes to USA spring of '08!!!
- Got Rear Ended Yesterday
- Anyone running Z32 caliper BBK and G35 sedan 6 spoke wheels?
- what is this rattling from under the car?
- power antenna unit removal/install
- how do i get the hu stereo out?
- fog lights?
- Quick ATF question...
- Cleaned TB, now i got hesitation
- PPL Replaced Axle, NEED HELP NOW!!!
- Super High Mileage 4th Gen. - What would keep it from going forever?
- Need New Exhaust or New Car? 99 Max Cali
- I tried to put new corner light bulb... but
- Shocks and Struts Problems (need help)
- I f'ed up my rear driver side.
- Major Issue with the radiator support and other things!
- Please Help - 5 SPD swap!
- LCA bushings
- Lug Nuts
- Crank & crank pulley question- car problems - need help
- dash color? help!
- Help! car runs fine, lights work, but no interior lights?
- Half DTM's
- Houston, we have a problem...
- Tis the month for grounding
- 6th Gen 18's on a 4th Gen -- What size tires?
- B&M Shifter Problem
- best place to buy front swap bar end links?
- code 01 11
- replacing tie rods
- Rattling noise from vent
- Exhaust Hanger
- smoked red/clears
- FSB End Link Problem?
- Air Intake Question
- Taking apart CE Red clears
- Crazy loud rattle in the dash
- 4th gen engine info
- Roof Rack recomendations?
- To Sell or to part out and sell???
- Wheel bearings -- OEM vs. chain stores
- Which do you prefer?
- Tips - to remove Latex white paint off side of car?
- Gotta fix Apexi SAFC-II tuning...can someone please help me
- 4th gen owners I recommend you do this (pics inside)
- led gauge problems
- Hid Guys Step In
- Wierd Grind, Passenger Side Rear.Handbrake boot?
- Knock Sensor
- O/D light is on
- maxima fuel pressure regulator
- what happends
- Rear Strut Mounts
- Gas /0901, 1001, / tune-up /
- OEM Grille Swap
- Check Engine Light With code 201
- my alignment spec sheet, translation help??
- Suspension help ASAP plz.
- My car is not smooth at all !!
- Lost A/C Fan Control #1, Air Selector
- Check this out. My 4th Gen got a spot in an Import Tuner Mag
- Changing orange signal to clear finally ! but...
- B Pipe worth it?
- Bose Stereo (CD Error)
- Squealing sound from engine bay
- 99 Power Steering Rack in my 97?
- Generic alternative to Optima Redtop battery?
- Stripped Stud
- Throw Out Bearing
- Brake Light Fuse Blown - Short Circuit
- AC recharge yourself
- 00VI info ?
- ac compressor
- Bose Amplifier....where's Waldo?
- Just put in Raxle, now vibration on accel.
- oxygen sensor help
- CRYSTAL CLEAR SEE THROUGH clear corners !! where ?!
- Climate Control Doesn't light up?!?!
- Ideal Brake Setup for Spirited Driver
- No "How-To's" on changing rear brakes?
- Need a New Alternator
- I Need advice on 45mm Offset Wheels
- Illuminated Ignition Key Ring light
- shift boot covers
- Removal of the chorme trim
- BBK clearance, opinions wanted. *PICS*
- Dielectric grease in new coilpacks??
- '97 SE: Should I turbo, S/C or swap to a 3.5?
- Parking Light, HUGE PROBLEM!!!
- Front passenger seat wires
- Car is over heating! Help!
- New bulbs, fogs still don't work. What Gives?
- 15mm spacer...new bolts?
- Hyperground DIY (pics galore)
- help!!! car wont start
- check your stock boxes for me
- Engine swap question
- Need Help
- instruction for cefiro headlights install need help
- I got a nice deal coming
- crack on my windshield
- can u clean filters
