- AC blowing hot air
- Spark Plug Tube FILLLED with oil!
- ac and front window defroster not working
- Suspension install question....
- Half my electrical system is not working
- 1999 SE-L (Production number)
- PIC request: black max with oem headlights+superclear clearance lights
- Need help with my aunts car-failed inspection
- What's my max worth?
- Ball joint and/or lower control arm?
- 99 max misfire
- What size center caps will fit our cars?
- Crashed my car this weekend...
- fuel pumps
- Door moldings/protectors
- How much does a rebuild cost?(On Avg)
- New wheels+tires *pics*
- stock shocks vs aftermarket??? help??
- Need Quick Help to anyone with a couple of minutes and a clue
- finally buying a 4th gen!
- Car runs like crap but no codes HELP
- A little help guys.
- Looking for 95/96 rear bumper
- thumping from RR, and smooshed parking brake cable..
- Firestone Brake Service Quote, Need Suggestions
- Converting Clearance lights into blinkers
- cant get ECU out?
- Test pipe?
- Replacing Struts.....Need advice
- Would these fit my 98 Max exactly?
- black smoke on start up
- Beeping Alarm
- Exhaust HP amount?
- How much $$$ to replace bushings up front?
- Where can i get OEM Floor mats or close to..
- Seats swap
- springs to pair with illuminas
- rear window wind deflector
- Shake Shake Shake...Brake Brake Brake...
- help, my car sounds ricey as F***
- Failed Emissions Inspection - "Not Ready" Status
- 97-99 Rear Conversion (95%) Complete. Pics inside.
- 95-96 owners with CAI, step inside.
- AC Fan slows down on long trips
- Need some advice with my cooling fan.
- ECU fuses blows!!!
- how do i tell if my shocks are shot?
- i just slid off the road 10 minutes ago. what do yall think
- Spark Plug pics?
- intake + y-pipe + high flow cat = better gas mileage?
- front struts
- hood pins - are hayame brand okay to use?
- brake calipers
- keyless entry question
- My car smells like gas
- Testing Ignition Coils
- alignment after ball joint replacement
- Fuse panel diagram
- Fuel Pump Fuse Blowing!!!
- Sloppy Steering
- Air Bag Light?
- Radiator support rust out
- Best clutch kit??
- ALTERNATOR FTL ZOMG My Brake and Battery Lights are on
- Bad Struts or Bad Bushings?
- Steering issues
- Ive joined the 5 speed club
- question about evap canister please
- Parts disaster! Need help!
- De-Lining Glass
- Should I Keep My Chrome Wheel Fender Trims?? 5 PICS
- gasket for y pipe
- programming home link again!!
- ignition question
- rear wheel rolling resistance
- Nissan Quest wheels-- any reason they wont fit?
- Crazy Shaking & "pup pup" Noise from exhaust
- BBK Installed Pics (56K Make Dinner)
- Motor Guys...step in. Misfire
- Recharging A/C
- headlight problem ?
- Sway bar price & installation
- Check engine soon light....
- full size CF roof spoiler made by IONIC DYNAMICS!!pics! pics!
- Gauge Cluster
- ECU error code 0412 or P0134
- Homelink visor signal very weak
- cost for shop to install exhaust
- Can you lower the brake pedal?
- Need New Brakes for under $800
- Tranny Problem???
- SS Clutch Line install help.
- CEL code = 14 05 WTF!?
- what's the best brake upgrade?
- Programming visor garage opener
- Cold Air Intake Owners
- check it out 95/96 owners
- EGR valve replacement
- **Interior Swap Questions** Help!
- Need Suggestions, Get a car or not!
- help..how can i tell if i have abs?
- Oversized brakes with stock components.
- BBK/Suspension Install **56k no way**
- what type of ngk plugs to buy
- My brakes suck... step in if you can help
- ran out of gas, car won't start after refueling
- Are These BreakPads OK?
- Stereo does not work - Fuses?
- allignment after axle replacement ?
- Wut exhaust setup to go with??
- Mitsubishi Evo 8 Enkei's on 4th Gen
- NISMO wheels
- PICS: Bad wheel bearing + Hub + ~2k miles = ....
- Another 99 calispec question
- 5th gen. muffler ?
- Spitting in muffler right before it reachs idle
- replacing Steering wheel
- fog light aiming?
- wheel alignment
- AT howls when cold
- Ran my brake fluid dry, cant bleed!!!!
- morning start up question?
- New cat??
- Engine/Exhaust is getting buzzy
- Looking for ECU will all work
- Identifying a 95 ECU
- Newbie ECU code report
- what is rear bose speaker size?
- Yellow max?
- for those of you with Tein H-Tech Springs.....
- scratches on my wheels from hitting the curb!
- 97-99 Stillen Front Lip Install Questions
- need confirmation before i buy it...........
- Noise from front hubs = front bearing seals squealing??
- JWT ECU worth it??
- center console heating up .
- New Exhaust system - Too Loud - Need help!
- Fog Projector retro?
- Best Insurance for the MAX
- Window Tint...How Dark??
- Fuse under hood 7.5AMP "ALT. S" question
- Score! Low milage LSD.
- Fuzion cars...
- Rear Wheel Bearing WTF?
- axle / LCA related ?
- Caliper Pin bolts
- HELP!! I think dealer is trying to take me for a ride!!! HELP!!
- My car is dead - and i'm stumped - AGAIN. $100 offer.
- HELP-02 sensor wires Identity
- ecu codes = 0103, 0304, 0908????
- Odd suspension noises, help!
- Buying a rebuilt title...
- ecu code
- Carfax Anyone?
- 5 spd swap with auto ecu ?
- replacing CV boots only??
- Knock sensors at $47(brand new)!..canada only
- Testing Coilpack w/ Multi-Meter
- tranny humming..
- I need some parts.
- replacing hood struts
- Can an exhaust leak make the car slow???
- My car apparently hates girls
- Car won't go above 2000 RPM
- this maybe a dumb question...FSTB off of ebay?
- Help me not spend 1K on brakes please!
- What a day today!
- wheel alignment after lowering?
- Bad fuel injector?
- Window Trim
- Tokico or Progress Springs???
- tried cleaning the TB
- Sway Bar End Link replacement How to. (pics)
- Knock sensor sale at pinacle nissan
- motorvate.ca??
- Body Side Moldings.
- rear suspension problem, need help ASAP
- CV Joint Replacements - anyone know price and a good place to buy?
- My Window wont come up all the way
- Question about rear brake pads
- Maxima vs. Altima OBDII codes??
- Fender Repair. With Pics!!!
- Aftermarket Radiator upgrade?
- brake change experience
- Stock Fuel Pump Output?
- Starting problem
- So a tree fell on my maxima
- Security system disabled my car
- Bleeding.... tranny... dying...
- New Horn - No Alarm Siren!
- Install heated mirrors
- sunroof rebuild
- about to purchase 99
- another LED bulb thread,
- 97-99 standard equipment question
- exhaust leak
- Sad News...
- need help with rear break pads--------
- quick question bout oil pressure light on dash
- IAT sensor
- Pimped out 4th Gen on MTV's 'Yo Mamma!' !!!!
- Flange Bolts
- PCM(ECU) Question
- Just changed my spark plugs and DAMN!!
- Tranny Release Bearing Issues???
- worth putting a intake? which intake is good?
- Which Part of Tranny?
- Preference on Coils or Shocks/Springs
- Intrax springs
- steering problem please help!
- i have a hissing sound comming from my passenger wheel...
- front end rebuild
- Can somebody get a carfax for me
- Stock Air Filter Cleanable or not?
- Whats the part number?
- Condenser issues, what can i do?
- How are the PIAA headlights ?
- visors 99 in a 95
- Axle question, yes another one.
- Fidanza Flywheel Fitment Why only 96-00?
- Looking for fogs and headlight pics
- My iPod Mod
- radiator question
- Transmission swap
- No idea what just happened to my car
- ignition system help
- Trouble turning over when gas is low.
- another jdm tite dubbed maxima
- Gauges in the Maxima.org Banner
- EGR system (03-02)
- H.I.D kits
- more evap problems!!! HELP!
- OBD code reader/scanner
- Easy technique for changing fuel pump?
- Did a compression and leakdown test today
- strut question
- Where is Cam shaft position sensor?
- O2 sensor Q:
- another max on tv
- Grinding noise
- power steering squeek
- How can I tell if my fuel pump is going bad?
- anyone have it????
- vent control valve
- rewiring OBDI to OBDII
- Front struts for 97 max in Socali
- caliper is locked up..
- what do i need for 300zx brake upgrade
- Transmission Issues
- Noise from front driver's side wheel
