- Help tightening belts!
- Wear What?!
- What brand radiator hoses?
- wiring power seatts
- Front end rebuild
- IS IT All worth it?
- TOKICO illuminas settings / how to change rear
- Need Advise, Car Won't Start
- I need new center caps!!!!!!
- Transmission smoking!! Help please!
- Finally Got A Code 0605
- CEL Throwing code P1447
- Front and Rear Bushings
- A dumb question
- QUICK Illumina question
- INJEN CAI owners CHECK this out
- wierd chattering knocking sound when driving slow
- Cloth -> Leather Seats...
- Plenum Gasket?
- '97 Max GLE overheats at prolonged idle
- OMG! I think something fell off my car...
- Packing front wheel bearings
- Advice on what b-pipe to get
- Where are the Engine mounts
- Power Steering Fluid ??
- Knock Sensor Questions Finally Answered
- NTK o2 sensors any good?
- Anything under the cup holders?
- help! wiper motor
- Ball joint question
- 99 max 5 spd Stalling, Lurching, and Idling
- left bank or front bank?
- O2 sensors
- Need to finally figure this out... light bulbs
- Jerk when driving
- Weird idle noise?
- New front grille
- Is there a way to make flat paint glossy again?
- What are the components of a maximas suspension...
- Weld quality important on subframe connectors
- Headlight ground points...
- thought you 4th gen guys might find this interesting...
- difference between a 96 and a 98 I30 exhaust
- Just installed RSB
- heres the swirl valve schematic
- brake and battery light on....
- Stone Racing Headers
- 5-speed ecu into auto
- 95 maxima running very rough
- Two ?'s Sunroof And Carpet
- Ooglie Stock Cold Air Intake Question
- remote control not functioning most of the time
- shop price O2 sensor and unclog EGR pipe?
- How do i remove this?
- So I got a catback...
- window regulators
- OK, I just donated but cannot use the Search button yet. (code:0903, 0304)
- Needles in gauge cluster...
- Ugh tranny again
- Ballpark Estimate???
- Shifter trim piece idea/question
- How to remove the bumper signal lights?
- For guys with auto 4th gens
- Passenger Side window problem - strains...and rolls up slow
- Cold Air Intake question need help...
- 0102 Faulty MAF Sensor
- What Oil Filter Brand Do You Guys Use?
- Getting new speakers
- loud "bang" when accelarating
- ? for those who painted there wheels?
- subwoofer in Maxima
- D-side window off track?
- bleeding clutch issues
- Will these swap out from 95 to 98 Max?
- Should I snag this $400 95 max, 160k mi?
- Blown Motor Laying Around ? Please Read !!!
- Timing Tensioner finished...please read.
- covert analog speedometer to digital
- Installed a new starter now weird burning smell, help please!
- New engine and tranny for 99 SE
- Most random problem ever?
- My MAXima Money Pit$$$$$$$
- Removing rear-most heatshield...foreseeable problems?
- obx cat back ?
- iat sensor
- Hard to shift
- Rear Suspension Beam is bent!
- Alternator belt
- My yellow retrofitted fog lights: (How to w/PICS)
- Fitment with warpspeed
- Anyone ever do a converison?RWD?
- Check engine light......????
- bent suspension
- custom dynamat install
- identify ecu
- still clunking ..grrr..
- jus tinted tails.......pic
- Spoiler repair? Can it be done? how do i take it off?
- Vibrating noise after installing budget Y and B
- 305Z projectors?
- Code 0111, P1447 done A LOT of research.
- Anyone ever black out the corners?
- changing head lamps
- My new SLUG *pics*
- Getting your wheels aligned when lowered
- 4th genner's. How Do YOU Clean Your Fogs?
- Monza cat back
- reverse problem
- obx headers
- WTF??? 04 09 code??
- Ebay Lower Control Arms ??
- Light-weight Pulley
- replacing the radiator support
- Y pipe question
- Want to Order Cattman Exhaust, Question
- Vibration
- car cut off on the highway
- Coolant System Issues, Need Advice and or HELP!
- Just a few questions about funky noises...
- Changing Bose Cd Radio by MP3 Player
- Vibration at 40mph
- Mounts?
- Weird Sound....
- spark plugs and air filters
- maxspeed springs vs. you
- Removing Bulb Shield
- Gabriel Struts?
- motor/tranny mounts
- CEL question
- swirl valves
- clutch install?
- MIL on but no codes!
- S techs.....good????
- are automatic & manual starter's interchangable?
- What are the best shocks and struts?
- for those who took off their spoiler.
- 5spd related question.Help needed!!
- Dry type air filter?
- license plate location - 95/96
- poorman torque wrench
- Greddy SP2 VS Apexi WS2
- confirm ecu
- question about brake light and battery light...
- Is "BOMZ Racing 3" inlet Cone Air Filter" any good?
- opinions on progress springs,RSB/AGX combo?
- Replacing front wheel bearing
- temp sensor/s location anyone
- PRO's&CON's of lowering(Sorry if it s repost!)
- es motor/tranny mounts..
- Does any one have these on?
- stock size pulley upgrade
- Inaccurate spedo reading
- Opinions needed: Tokico Blues+Eibach Pro kit...
- Another A/C question
- Turn Signals, please read.
- electrical problem - why cant the fuse just have blown!
- Picture of rear strut assembly?
- brake problem?
- Grinding Noise
- 3.5 or dek?
- Why are both my cooling fans on all the time???
- Goodbye.
- Wood Trim From I30 Fit 4th Gens?
- How deep has your Maxima gone?
- Trunk problem
- what fluid to use in clutch cylinder?
- Carfax VIN request
- high idle + lower idle when lights are turned on?
- Need To Get Motor Changed !!!
- Its a whole new car *pics*
- knock sensor?...Is this normal????
- Can you ride on just lowering springs w/ stock shocks?
- Belts and Filters....
- Maxima headers
- HELP- Hard to start!!
- poorman HAI
- drive belt how to = me confused.
- The big 250..
- brake and battery lights on?
- HOW-TO WORKLOG: LED Loaded Instrument Cluster (+60 LEDs!) BRIGHTEST ORG CLUSTER YET
- Trunk wont open With Key..WTF
- replace stock shifter on automatic
- difficult installing HID kits ??
- Ever hear of a 'slick shifted' trans?
- Air conditioner recharge: EZ Chill?
- Maxima wont start
- Inhibitor Switch, Code 11 01.
- Driveaxle Leaking Oil
- Knock sensor on ebay
- Oxygen sensor are they all the same?
- Loose suspension
- dumb thread......qwik question....
- ac only works on high
- stuck on 2nd gear
- Help! Cv Joint Came Out While Changing Front Strut!
- What is wrong with people :(
- MECP picture..
- Car loses Voltage
- Facing $2,000 repair and dont know what to do...
- What did you pay for Tune Up
- PRICES for painting body kit/bumpers and minor repair
- 9007 Harness and bulbs
- Squeaky Struts/schocks
- Driver side axle replacement
- WTF is this
- Started My Motor Swap...Teaser Pic
- Stealthy installs for radar detector in 4th gen
- abnormal engine noise when throttling
- Installing Stainless Steel Clutch line on 4th Gen.
- Rear o2 Sensor yuck...
- more lca removal question
- Cheap Muffler thats kinda quiet
- screws stuck in stereo
- car is stalling
- best ceramic brake pads
- Where to get exhaust gaskets
- should my car do this
- Inner/Outer Tie, LCA. . . (rant)
- advice please on a system idea ...
- Max went out of ? gear ? twice
- How do I remove this?
- Driver window sticks to inner weather stripping?
- 4th gen dash kits
- truck stuck shut
- Painting trunk keyhole and antenna
- engine stalling while at red lights
- car trouble
- Endeavor To Fix The Sunroof Minus The $$$
- Once And For All, B-pipe Hp Gain
- Custom Y Pipe with installed pic goodness
- Front Emblem
- Misfire on #6?
- Shifter acting up. (automatic)
- not important, but real annoying
- Brakes
- quick ksport adjusting ?
- Which HID Kit to get ??
- Car Poping-Backfiring
- ATTN: '99 autos w/ more then 125k miles and LSD, final drive noise
- help help guys!!
- Ignition switch update
- synthetic oil
- What's missing?!
- Y-Pipe Q - I know there's an increase in noise, but where should it be coming from?
- droppin my *****
- trunk wont open
- which sensors do i unplug ?
- Max broken into - San Antonio
- Any Good Head Gasket Shops ????
