- cruise control issue
- annoying squeaking suspension
- need 5 spd swap
- Anyone heard of Megan Racing?
- Am I a one-percenter?
- Headlight assembly
- speedomoter
- vibration from steering wheel
- I Got My Tint
- 96 max still making clunking noise
- Need to hook up mp3 player to a stock '96 fast! HELP!!!
- vibration help
- Coil overs?
- replacing y pipe
- Got/Fixed a Busted ECTS? You're cordially invited.....
- Exaust Suggestions
- K&N Cone filter part #
- Must be the new math
- Fitment of 95-96 ebay red/clears?
- Junkyard shopping cart.... what do I need?
- Front and Rear suspension measurements
- anyone in NJ fail inspection?
- KYB front and rear mounts.
- my max is poopin its cherry
- Head lights
- Anyone got a 1996 maxima emblem to sell to me?
- Clutch takes a dump
- people with/who had progress springs chime in
- Break-in necessary after resurfacing rotors?
- max vs i30 trunk lid
- Worth of 5sp tranny in need of bearing
- Some minor upgrade questions
- '96 max high idle sometimes?!
- clutch cant handle the powa ?
- can the jwt ecu....
- '97-'99 Apex i WS 2 catback
- Resonator or No Resonator
- Shaving Emblems
- I have power but the car won't even crank, and I just drove it 10 minutes ago
- Electronic control...limiter?
- Suggestions for replacement axles?
- NISMO Exhuast Hangers??
- Auto trans on its way out...
- Not in park...no start.
- MSD Digital Window Switch installation questions!
- Parking break cable
- Replaced my left driveshaft and now it's clunking
- Maaco Paint Job
- 5th Gen Clutch
- To those with 235/17's...
- Anyone changed the door shell?
- MAF Cleaner? Anyone tried it?
- Traction Control
- cafiro hood w/ grill
- fab switch
- Work in Progress
- Photoshoot: New purchase... 99 SE-Limited
- In regards to a replacement bulb harness.
- how can i ...?
- Tan interior with Black leather?
- Seafoam Verdict - Yes or No
- 98 bose HU
- wooohoo ..had a nice day today
- Accel After burner
- smoked turn signals
- wire mesh grill
- hood pins issue
- 0413 Oxygen sensor. LOCATION?
- I have LSD... Surprise!
- anyone sell maxima seats here and shipped them?
- front/rear engine mount replacement
- Rear Emblem Placement
- Walbro Fuel Pumps
- optima battery
- shaking idling problem
- Need some advice on a car.
- resistor assembly::car or tranny specific
- Greddy SP2 VS Apexi WS2
- Totaled my Max *My situation*
- Question about Door...Already Search
- Making cali spec y pipe fit a fed spec car
- Do you know if this will fit?
- Is the Redlinemax CF hood made by CarbonEFX? How is the fitment/quality?
- 15" se's or 16" se's?
- Startup Idle woes
- Turbos and Superchargers
- O2 Sensors
- oxygen sensor installation. you have to be fuking kidding
- Installing a VAFC II - Couple Questions
- 5th gen springs
- How the F#$% do you get the bush pin out of the LCA bushing?!!
- HELP/Suggestions re:P1320 & P0505... yes I searched already!!!
- Where can i get this kit?
- Help! Did the ECU self diagnostic and dont know what the code means
- A few questions about 4 gen maxima's
- warpspeed catbak
- Quick question, need SOON: Y-pipe-to-manifold fasteners
- Does anyone know to diagnose a defective MAF sensor?
- Home Link?
- Help please with injector o rings
- Taking off wiper blades
- need suspension advice...(tokico HP owners prefered)
- jerking when i drive and a rough idle when i stop....
- Does this look okay?
- differential bearing noise in an auto
- Where can I find instructions w/ pics how to adjust Idle
- looking at getting a 4th gen for $1000 to $1500...possible?
- Wireing Heated Seats
- Air Bag light
- Maxima Module?
- Axle removal/Tranny replacement
- Max is back firing!!! HELp?!
- steering wheel shakes on Highway
- Trunk lid sticks ... have to pull up hard to open it
- Need help with overhaul
- Drivers side A pillar removal
- What do ya'll think i should do???
- Where do u guys put switches?
- q45 calipers/ q45 rotors/ q45 pads
- Emission Test Help
- Gas Mileage Suffering
- Considering MEVI..
- Fleabay: Maxima Performance Chips $20-$69.99
- AE Corners
- what is te correct driving pattern to reset ecu?
- Wagner Ceramic Brake Pads
- Anyone know where i can find these....???
- Shifter Bushing Loose? Help!
- headlight socket wiring problem !
- warpspeed fitment with pacesetter cattback
- SP2 Question...Not what you think
- Headlights-on & Key-in Warning Chime
- Tire Pressure!
- My Trunk Has Just Jammed Shut! What Now?
- wires through the fire wall with a 5 speed
- HELP...my door latch
- farewell to my max...
- Windsheild squirters
- How do I tell what my ecu is
- reverse lamps after 5 spd swap
- ebay cheapest place for complete tokico illumina suspension??
- bought rebuilt 5 speed, starter location is different...help?
- car will not start, not battery
- IT WAS THE PEDAL!! But I Still need some tuning.
- 90k mile tune up question help...
- how to remove tint
- do you think this rims would look good on a max
- debadging
- OBX Catback
- Do you HAVE to change oil after Sea Foam?
- Anyone buy these?
- Converting 9004 to H7
- car has been jerking/bucking in first gear
- vent/trim painting
- In Desperate Need of Cat.!
- Budget Y-pipe special
- Symptoms of bad tie rods?
- anyone have the Diamond clear tail lamp from Custom Enterprize?
- differential bearing issue?
- Trouble, Trouble? CEL, Knock Sensor, TPS Sensor--shifting code --Comments Needed
- someone help ASAP!!!! airbag light jus came on!!
- people with JWT ecus....
- 06 civic si rims on my maxima ??
- about to order flywheel. any tips or suggestions for installing?
- blue lights in corner lights?
- can someone send me instructions for cefiro headlights?
- Tach problems on 4th Gen (created post)
- 3.5 Done some new codes
- See you guys later
- aluminized or stainless steel?
- Do I really need to get new rear brake calipers?
- 1st gear grinding, leaking transmission
- NGK Plugs....Plats or Copper?
- poping sound from front of car, HELP!
- Time to switch over to synthetic oil
- Time For a New Exhaust ?? (Full color Pics!!)
- transmission interchangability question
- Axle play?? Driver side Leaking 5spd (Pics inside)
- 95 Hood struts into 97' and vice versa
- now what
- Drivetrain clunk
- pic request blue led gauge
- NOOBIES: The "I AM NEW HERE BUT HAVE A QUESTION" thread...
- Whats the biggest size resonator the Maxima can take?
- Radiator Leak?
- Code 09-08 ECTS.What the....?
- wiring question
- what do you guys think Greddy sp2 or Cattman exhaust which is better?
- weird squeaking noise
- Need Help.. Coolant Issue
- Spotted 4th gen with rims, Going to cape cod
- coilovers?
- Can You Tap the Brake Booster Line ??
- Hid's Projectors/non Projector People Come Please.
- Car stalls whenever I get to a stop
- 3.5 Swap done, come see...
- Washer squiters
- What Kind Of Bumper Is This???
- Fuse for interior lighting? Headlight electrical connection?
- fog bulbs
- 95-96 grille-tech
- Brake Wear Heavier On Passenger Side??
- Pealing-out
- are these any good???
- Transmission filter
- Windshield Wipers
- Breaking prob!! Slotted/Dimpled
- Bad starter???
- Common issues with 97's ASAP!!
- faulty ignition switch
- sometimes, car needs extra cranks when carryin heavy loads
- Rims/wheels On 4th Gens, Post Pics
- PCV Hose
- Why does my Maxima shift hard into 2nd gear?
- rear hub....what other models?
- where to get a K&N air filter for cheap?
- Replacing front bumper
- Weird issue please help....
- Place Racing CAI Review and Warpspeed Complete System
- trade in 4th gen for 03 six speed ???
- Reasons for Maxi's Stalling and cheap solutions
- Car hiccups
- Anyone ever replace their radiator support?
- spec v question...
- Damn Iat Sensor
- jack and jackstands
- Anybody try these head lights yet?
- Tranny cooler
- IACV and injen
- Lateral Link Hitting Sway BAr
- front passenger window switch
- Replacing Engine Mounts
- Video of my old Maxima
- how to safely remove spraypaint from car paint??
- Retrofit Question
- Tint measurements
- Tint Pics.
- Removing side door moldings ..
- Locations of the O2 sensors...
- rear wheel spacers
- ICHIBA USA Aluminum Hubcentric Wheel Spacers
- why am i getting condensation on my turn signal lamps?
- wheel alignment and FSTB
- air bags
- drop resistor
- Service Engine Light?
- headrest improvement
- Digital cluster mileage
- tranny whine
- Magnet touched my t/s ecu
