- PRCAI + High Idle
- Fidanza Flywheel doesn't fit...
- will a bad shock or bushing mess up alignment ?
- Replacement Alternator
- LEDs for Auto Climate
- Weird pull on my 95
- Die Car Die!! ....Oh wait you do that fine yourself
- New Hood Struts: Where to buy, can i replace just one?
- cheapest place for rebuilt calipers online?
- Keys: Transponder vs. Non
- Buy back my 4th gen with AE VLSD?
- i think i have a bad coilpack
- Crank but no start- help!!!
- Tails
- question on touch up paint from dealer....
- Removing starter any comlications to deal with?
- Revisiting Maxima.org, a few years later
- Misfire problem
- starting issues
- Buying New Starter - New Nissan or Rebuilt?
- Metal Maxima's LED Assemblies
- how to remove rear bumper?
- Fuel- all OVER the damned place
- Blew my clutch AGAIN - please help choose
- DTM'ng and all the possibilities
- Car Shutting off while driving! Help!!!!!!!!
- Altima SE-R calipers?
- Firing Order?
- New Check Engine Code
- Paint- how to get baked water spots out
- Please Help!
- Maxima is MISFIRING!!
- A/C squeaks/squeals
- Houston max owners go check this out
- Bouncy or Loose Engagement of 5 Speed..... IDEAS?
- belt on UR pulley
- 99 motor in a 95 - Starting problem
- Need Pictures of Trunk Latch, both on the lid and car body
- I feel like an idiot...Again!!!!
- Crashed!!! Need help!!!
- Need Help! Suggestions! Car Shutting Off!
- ACC/Ignition Problem!
- Resonator Needed Step in
- Anyone need a new knock sensor?
- Harness question
- Tps
- Are 97 SEs prewired for power?
- Nismo Exhaust Hangers
- P0135 Code
- which tranny?
- Rusted Rotors
- Help me 'steal' my car, please!
- Help! How do I take out my signal lights to replace them with clears.
- Do I have a fuel pump problem?
- what do Coilovers replace?
- Popping sound while turning?
- Re-key lock....HOW
- Budget Ypipe/ Cattman / or Warpspeed?
- Dealer suggestion for bad starts!
- idle problems
- Low idle
- Does anyone have any experience with warranty coverage for KYB struts?
- God damn car
- Taking out rear/back window
- 99 max with NATS failure
- What would you recommend?
- Just added an Amp+Sub to the Bose system, having problems
- Cleaned Throttle Body And Got 1400rpm Idle(cold)
- where can i get these?
- AutoTrader...55% off
- Need Sealant for rubber/paper gaskets?
- Transmission Problem
- be careful with tails you buy from ebay!!
- What is the alternator rating on a 99 Max SE-L?
- all these problems in 2 days.
- Microvision TV for maxima
- Brake Hardware Kit
- Heated Seat Mod....
- Which One Looks Best? Pt.2
- power steering resovior
- Brain teasing behavior !! any guess
- Need help: need to remove 98 bose deck
- Brake Vibration
- power steering problem
- need help wiring head unit.
- New Y pipe - observations
- Braking Idle
- Auto-Trunk Open (Video of Mod in action)
- whats up with my steering???
- $440??!!
- What to do for MEVI cover brace/bracket?
- Exhaust Problem Need Help!!!!
- electrical help! 98 i30
- Sunroof Drains?
- why is there oil on spark plugs?
- What does a Stock 95 SE muffler look like?
- EVAP code 1440 and 1447
- Exedy stage 1 clutch won't fit
- Left Windshield Wiper Broken!!what to do?
- GunMetal SawBlades on car.
- No map/dome lights, fuses and bulbs are OK....
- coolant problem please help
- I'll say it if no one else will.
- coil boot connection to the spark plug
- oil on spark plug threads
- seat belt light
- Had GR2's now thinking about Illuminas
- South Florida Maxima's step in.....
- lugs nuts became loose ?
- Cooling system question ??
- I NEED HELP ( Im out side trying to change my belt )
- Help...EL Gauge rewire
- Sawblades... Gunmetal?!?! <<<Pics
- Rear brakes..... caliper....need help..
- Trouble code help.......
- Subs/Amps questions
- Exhaust Support Question (PIC)
- rear defog+ harzard button + Dig. Climate control lights???
- Suspension help...
- Recent Max Mods.. (Pics)
- strut mount please help ASAP
- 00vi on Cali-spec
- Anyone Help me change Alternator in Jersey
- de-k swap Questions
- 2 back seat pouches??
- Loose Parking Brake - HELP!
- Alternator Died Today gaH damit!!
- Click and Clack on Installing Private Parts
- Do I need a new thermostat?
- Gas Pedal vibratin'
- part #
- Ebay Kyb Gr2 Struts
- One Touch Sunroof Mod - Update
- Another crazy idea
- Mods to be installed sooon
- Brakes?
- Last night my radiator took a leak
- write up for the spark plug tube gasket?
- Help 1999 won't start--starter? security key?
- Cefiro Headlight questions...need help
- Leaky sunroof issues.
- Fuel filter?
- Oil coming out of crank case breather?
- Stock plugs?
- crank no start, help!!!
- Up all nite in the rain doin my Suspension
- Rear Stance
- 97 steering wheel on a 95?
- WTF..Hu Problem
- New suspension
- How to replace EGRC Solenoid Valve
- I Hate This Guy!
- Can I make it so my A/C does NOT come on whenever I use defrost?
- Is taking off the catalyctic converter such a good idea?
- Digital A/C: Lower Temp=Less gas spent?
- Stock Intake question
- A little Vinyl here, a little wiring there, CUSTOM Heads and Tails. check em out
- OBX fixxed thier headers, but still not equal length
- Driverside axle won't tap out
- 2 1/16" gauges that match stock SE panel
- Transmission case split..Dont see spalling on driver side
- Need help with parts
- Not a good day...
- Carsound Cat-Warpspeed
- WTF i failed inspection because of clear bumper lights?
- Rusty Y-pipe Bolts...Impact or breaker?? Help ASAP
- Catalytic Converter? which one
- power steering oil leak when replacing belts
- 4th-5th gen clutch
- 95/96 front bumper mod
- fender
- How manyof you are from Vegas?
- speedo not working
- cruise control tripping out
- illumina's and dustboots
- wheels or exhaust?
- tokico hp strut/spring question
- Y Pipe Gaskets
- drivers rear door will not lock
- Does my 98 GXE have keyless entry?
- oxygen sensor O2
- Dial Gauges Do Not Light Up
- Megan Racing
- Creak/rattle?
- Antenna Problems...
- How To: Remove Pinstripes
- 95-96 Diamond Style Lower Grilles
- Suspension / Front Sway Bar
- New Brakes... Still VERY squeaky!!!
- stock bose + wiring harness?
- Broken ECU??
- DAmn Parking LIght wont come out
- Steps to Clean Intake Manifold?
- Wheel bearing replacement
- Do not park on big streets.....
- B-pipe(w/ resonator)
- 15" Sawblades - BLACK?
- Anybody seen this radio setup?
- fiberglass fender?
- LED Brake Light
- Squeeky throwout bearing, soulution w/out pulling tranny?
- HOOD PIN pictures thread
- Questions
- rough idle due to air filter?
- couple quick flywheel install questions
- 97-99 cloudy/yellowed headlights fix
- 95 vs. 98
- turbo question?
- I need a Resonator!! Help
- Race Legal tommorow anyone?
- Frame Noise while braking on slow speed
- Help: Emanage or OTHER ECU???
- question bout head unit uninstall
- Pcv
- Grounding kit pics
- Ignition coils or something else?
- How to tame Eibachs?
- I need BBK!!!!! and some Q & A
- overdrive off light button not working
- Tranny gone ... selling 95 MAX, what can I expect to fetch ?
- battery dying in traffic - short somewhere?
- Urgent question/rant
- Idle problem?
- loud stock exhaust
- Maxima on 24's again!!!!!!!
- Need your advice!!!!
- how bad are my nuts?
- Say hello to paradise
- Frankencar Intake
- People with lowered Maxima's Please Read.
- My MAF unplugged itself... Damage?
- Where is Coolant Temp Sensor
- Automatic/5-speed swap questions
- 3 out of 4 pwr. windows will not work?
- Worth switching to 5th Gen Clutch so soon?
- anyone who has done a full interior swap, com on in.
- How to build light weight sub box mounts.
- tach dips to about 500rpm when braking around corners
- HELP! Need new MAF
- My car sounds like an OLD CHEVY LUMINA :(
- 5th gen clutch
- Radiator - Radiator Barn?
- Cattman Headers
- cruise control issue
- annoying squeaking suspension
- need 5 spd swap
- Anyone heard of Megan Racing?
- Am I a one-percenter?
- Headlight assembly
- speedomoter
