- check engine light!!!
- HELP!! Alignment problems
- STARTER guru's please help!
- How's e-bay control arms
- Lock problems...
- How to Change MTF
- carfax
- Muffler recommendations?
- alignment question?
- 97 Nissan Maxima SE vs. Porsche Cayenne Turbo Video
- gas smell (i cant search for some reason)
- new KS on ebay
- Something banging near the rear right wheel
- Reverse Lights
- Climate control?
- Lean Right Bank Code 115
- Any draw backs to running test pipe?
- Conceal the V1 concealed display
- Turn Signals Problem
- Car Cranks but wont fire
- Auto shift knob, Cut to perfection????
- Rear Brake Pads Slightly Touching
- HELP NEEDED NOW - Tie Rod End
- wow, I can't believe this...need help
- Parts needed to do the rear main seal
- Anybody dealt with Car Parts Wholesale?
- odometer swap
- Brake pads hanging up?
- Stock Intake Manifold Question & EGR
- clutch question. yes i searched first
- tranny swap
- intake manifolds
- Fixed my IDLE problem. Is this yours?
- Working on my car is becoming impossible.
- Friend's max got hit, airbags went off--totaled??
- Iacv question for the dek swap I got a idea?
- Clutch sinks to floor, doesnt come up!!
- SS break line banjo bolt broke WTF?
- Thoes who have seafoamed....
- JB Weld question. Will this work?
- Need more power!
- Light Bulbs
- couple questions about FSTB / RSB
- Got them codes codes codes
- Is this normal MPG?
- Cheap replacement exhaust cat-back
- replacing the dashboard
- Power Seat
- Is my clutch slipping or a bigger problem?
- Ben's rear suspension mounts
- Injector Mystery
- Spark Plug and idol . question
- today did KS and hood strut almost starter too
- Lookin for a full exhaust
- 00vi price vs 00 engine price
- RPM issue
- Looking for a good price on a B pipe
- 2000 5-spd tranny in my 95?
- Axle Problemssss???
- Need little help,,, electrical!!!
- Adjust IAC valve after Throttle bottle cleanup?
- Will a 98 Gauge Cluster work in my 95?
- Removing the Climate Control.
- after market muffer?
- Anybody who installed their own b-pipe or exhaust step in
- exhaust leak under front seats
- How to determine a bad ECU?
- carbon fiber front lip pics?
- intake manifold swap
- Cheapest suspension set-up thats better than stock
- 95/96 Taillights. Need your Opinion
- Winterizing car (heated dipstick)
- BMW M3 trunk lip spoiler for maxima
- diagnosing a technosquare or JWT ECU for a CEL
- Car sounds like a dump truck--Test Pipe??
- Starting problem FIXED!
- evap code - bogging and running rough
- Sway Bar Link Kit (97Max)
- Turn signal question
- a short vid of my car
- any idea what this connector is? (pics)
- Battery died now remote key wont work
- Heads Up Display - Has anyone ever tried their own?
- HELP asap!
- Axle boots torn, what to do?
- Stupid mistake a massive annoyance?
- how to remove center vent cover
- Where is NSS and the BCM
- Size of Hub nut
- coil packs
- Car will not start...on it's own
- How-To Q: Evaporation Pressure Sensor
- Body kit or Lip kit
- sell the max
- LED Interior Lights
- car wont start.. tried to get a jump, no use
- URGENT HELP NEEDED (Overheating) !
- 99 cali spec MAF help?
- Type of grease used to grease the starter
- Replacing BELTS any suggestions
- Free 1995 Maxima parts for a limited time!!!
- Final Suspension question
- ebay smoked tails FTMFW ?
- My Maxima got its Mojo back
- I think my struts are going
- Ipod placement
- TEIN Basic Coilovers Thread
- scan tool
- Radiator Coolling Fans - options/advice
- Bad O2 sensor after exhaust install???
- Clutch acting up. Only when warm.
- Engine Shudder
- Air intake elbow under snorkel
- Own a 1999? Having IDLE problems?
- engine cutting when low on gas
- End of bad starting woes!
- #$&@&^$^!! idle issue
- Door won't open...... Part II
- upgrading to technosquare ECU. question
- WTB: 97-99 Stillen Lip *used*
- Very strange ECU problem...
- Squeaking noises when starting my car.
- my bose blows fuses
- ever had a CEL for your intake?
- Ugh...Starting Problem Is Bizarre
- rattling noise coming from dash
- Brake shims necessary??
- Bosch Platinum +4 Plugs
- Problems after Alternator replacement
- misfire in cyl3, checked coils, resistance is too high..wat are my options?
- Air Intake Sensor and Knock Sensor
- brakes / front suspension
- Airhog Air Filters for cheap
- Warning to all guys with blown hood struts
- Installed new headlights and corners *pics*
- Anyone with Aftermarket Springs off the Car
- tranny shifts smoother at high rpm
- !!!Fidanza & SPEC Stage 1 Setup HELP!!!
- ae mod for 95/96
- Spark Plugs NGK replacing....
- 97 bumper with a 95 trunk?
- Where to Mount HID Ballasts/Ignitors
- Exhaust question: What’s missing here?
- Serpentine Belt Help
- aluminum radiator
- CD player always has ERROR!! RANT
- ATF in spark plug holes???
- wow. i messed up :(
- 95/96 aftermarket fog/driving lights
- JWT ECU installed, now motor lagging
- 5 spd swap (auto vs man ecu)
- Time for a exterior upgrade... opinions needed:
- 95/96 fog lights
- PIAA wipers and fog lights
- Got a code for a cylinder 3 misfire....help
- Studs snapped?
- rear seats
- Thoes with SS brake lines
- Looking for a rim for '97 Maxima
- Can I read ABS codes?
- Engine stays warm...
- Weird grinding noise in the rear
- Hi Perf torque convertors: recommnedations?
- Tranny cooler: which brand to buy???
- Grinded into 2nd like a dumb@#$ ... can someone explain what happened with the syncro
- FPR.......need some help on a part?
- 97 auto GLE wont shift pass 2nd Gear anyone?
- Auto Climate control
- FRONT ROTORS PADS HELP opinion.
- intake question
- Where did you buy your ypipe?
- how does your maxima drive when the engine is cold?
- EGR valve replacement
- How many Miles do you get per full tank??
- why is my temp gauge doing this..
- Question about the remote
- Vehicle Speed Sensor
- I may get flammed for this....additional interior light options
- what do u think of some 18x8.5???
- Need some suspension ideas..
- hook up VI
- car wont even turn over...?
- y-pipe, b-pipe and stock muffler?
- 87 octane vs 93 octane
- brakes squealing
- Bulbs in dash etc
- Recent Mods!!! Opinions Welcome!!!
- battery light question
- How to take a part Right side mirror?
- spark plug gapping
- flashing SES at WOT
- Unknown ground wire bolted to driver side tranny mount
- Clutch stuck to the floor? HELP
- hey Cylinder layout please
- Y-pipe install = Big Problem lots of $$$$$
- Cheap Gas makes my 99 Maxima misfire!!
- 95/96 and 97/98 stillen differences
- What is this bolt and where do I get another one?
- Replaced Alternator and got Vibration in Idle
- Can someone tell me all possibilities of cause of fuel pressure loss?
- Need a new key...
- cels - yes they suck....i think im just going to remove the bulb :)
- Quick question about air filter
- Low idle, 200->400 RPM's
- brembo roters?
- taking off and cleaning headlights
- IMPORTANT! Need part number confirmation on Bosch O2 sensor
- Low fuel light WTF!!!
- Best price on rear rotors
- intake setup...pics
- Need help opening flap for heat!
- VQ30DET?? turbo JDM engine???
- Autozone Rotors?
- somone help with my idle
- Type of engine in 4th gens
- serpentine belt replacements?
- has anyone done this with their air filter?
- VQ30de engine question about swapping
- HOW TO: knock sensor replacement?
- Key stuck in ignition..
- A quick rant and an update
- eibach or progress??
- p/n switch bypass
- Transfer kit?
- Weird O/D on freeway
- The verdict on suspension: stock or aftermarket?
- Fuel Injector Harness Question???
- How much to install b-pipe?
- Coil pack out, waiting for new
- Brake Noise and Bad Idle
- Low range power loss with CAI?
- Need a new clutch.
- New Muffler?
- Wheel allignment
- Exhaust question, PITA!!!
- Fog Light Problem HELP ME PLZ
- Hard start
- Applo_1's Maxima UPDATE
- How To Adjust Brake Calipers ?
- After fog mod, door won't open?
- Fuel leak... wtf?!?!?... continued
- Pic without mudflaps
- Leather seat fitment
- Idler pulley - please help
- Carbon Fiber hood
- New AE tranny; passenger axle bracket bolts won't line up
- gr-2's and eibachs??
- PIC of egrc selinoid valve!
- Alarm/Panic button doesn't work
