- A year later.
- bumper lights rewire question ?
- Some times you gotta Megiver that sh*t
- Suggestion for bose headunit replacement
- Serious carbon fouling after TB cleaning *PIC*
- in need of new axles and wheel bearings
- OBD II on a '95?
- Will I feel a difference with this?
- Tranny Problems?
- taking out a/c condenser-bad for radiator?`
- Stock se wheels
- Intake in lower front of bumper?
- New headlights!
- rant...
- question on 9004 bulbs
- I need a new clutch... I think
- just curious
- Vent tabs
- VERY hard starting when cold - smoke & dies..
- What strut bar do you have?
- Just when I thought I fixed my CEL codes
- I30 Door Panel fit into 99 Max?
- 1996 Maxima Automatic troubles
- How to remove taillight?
- SCARED TO DEATH ( Maybe TRANNY ISSUES) Over Drive Light Flashing
- ligit races?
- I Have Leak On The Axle Driver Side
- '97 ayto (GLE & SE) slight squeak from trans? Lost..
- CF Hood, Stillen Kit, Klasse Full Detail..BIG PICS
- replaced knock sensor and harness, 0304 still there, help!
- Need Help With My Ksport
- keyless entry help
- Need Help ASAP! Electrical Malfunction
- 36mm AXLE NUT
- Are you kidding me??? We charge for How too's???
- low idle: ECU diag. screw related
- Tranny problem
- Mirror Question?
- another tranny problem?? please not again
- Cefiro HL bulbs
- Good ebay CAI?
- right rear clunking over speed bumps and pot holes
- Re-man Starter
- question about a thread Please HELP
- ANy positive remarks about SEAFOAM Transtune?
- Bought a 99SE and already having problems.
- Passenger axle bracket
- Quandry! In need of the Max nations help!
- tinted corners and turn signals
- question on rims
- An interesting observation - what can be the cause of it?
- suspension troubleshooting, grinding noise..
- Advice on pulley!
- projector/reflector headlights???
- hard to start, need suggestions
- Fuel Injector Removal
- Exhaust Setup Comparision: Test Pipe vs. Stock Cat
- What did I do wrong?
- factory keyless
- Need Help Picking Short Shifter
- Opinion (Body kit)
- Starter compatibility
- Where can I find a double-din storage pocket?
- What Struts and Shocks do you reccomend
- CA spec exhaust what do I need?
- CEL will not turn off
- Want to replace Springs
- Sweet max at stonebriar chevy in frisco, Tx
- normal ignition timing and KS help.
- Plastic bag stuck to my y-pipe
- new intake filter
- How to remove rear bose speakers from a 98 se?
- CV JOINT help
- The End Has come. ByeBye Maxima......
- CHanging struts - Can I get hurt doing this?
- Broke the damn ECU screw
- How Much $$ To Make Off Parting Out
- Alternators Goin
- what is a TRUE 3.5l conversion?
- In tank fuel filter?
- Hangers..Exhaust Hanger replacement ideas
- I got spiders and dust flies in my car...
- Paint hood/cosmetic repair cost, advice.
- Lawsuit Advice_ Mechanic blew transmission
- knock sensor????
- M3 Mirrors installed (Pics) 56k Major unhappiness!
- tip on getting the stock ECU out of that bracket?
- Front stabilizer bar from 98 fit in 96?
- Cattman cat-back installed
- 02 Maxima Navigation Display
- Short Shifter
- Max is not starting......
- Intake Manifold Cleaning+Vacuum leak+New Gasket = Unstable Idle
- High Mileage
- Put in the Tokico Illumina set... a couple of question
- fog light
- tips on putting in 00 5spd
- Test Drove a 1998 SE auto is it supposed to be like this?
- knock sensors on ebay, legit?
- Cant figure it out charging problems
- simple question here : help me clarify something to someone else
- just dropped my car need help
- chinging pasenger side axle
- Yet Another Misfire
- link for repainting SE wheels????
- NEED HELP NOW!!! Installing STS and nut turning with stud
- Help location knock sensor and Engine Coolant Temperature Sensor
- Infiniti Auto LSD to 96 Max swap complete
- 95-96 rear bumper on 99
- ECU code 0702 on 99 Cali Spec: Bad 02 sensor?
- Window fell down
- repainting the maxima! want advice
- My Stall when i was driving
- few pics of egr tube removal
- Does anyone know where i can find these two parts?
- Rear Rotors And Brake Pads
- Power Steering Problem
- Help me Car starts and then dies I am stuck
- Replacing shocks & springs
- what brand of gas?
- Throttle body removal, how to stop coolant leak
- installed retro's.. using vampire clips to power HIDS??
- Whats better? A Supercharger, or a Turbo
- Looking 4 Inland Empire Mechanic to do tran swap
- Wow, LOTSA CEL codes...HELP!
- Did I install KYB AGX struts and shocks, or Pogo sticks?
- Shift Lock/Brake Light Problem
- Installing KS (New Jersey)
- headlight wiring?
- Car turns off while driving HELP!
- Hum/Vibration from rear of car.
- 99 maxima SE won't take gas
- Repair/install you're not proud of
- altinator went
- 97 vs 98 auto ecu
- Shimmy/ scraping when starting forward and reverse
- Exhaust install..
- Rough Idle-Almost Stall
- Dash lights/electrical problem
- Are there any good mechanics or maxima enthusiasts in NE Philly?
- New Clutch
- Marker lights Clear
- Altenators keep blowing!! Need help!!
- Looseness/noise in left front end
- body guys pls help!
- Whats the biggest differencs btw?
- trubble codes
- The boost is loose!!
- rear brakes
- Optima Red Top Battery.... are they different
- auto tranny failing? (w/ VB mob)
- Drop'd and Tint'd
- What to look for in a CF hood/trunk?
- keyless entry
- 4th gens in MN
- M3 mirror fitment question
- Opinion on Dash.. Paint or Not to Paint
- Full DEK swap or 00vi?
- Front end vibration during moderate braking?
- was i supposed to have these fuses?
- Bad headlight switch?
- Steering won't return to center after strut install.
- DIY site
- Painting my oem wheels??
- Best place to buy trim piece around shifter for a '99?
- Max gets face lift, new feet, new Lungs - and more...!!! WOOT! - (large pix)
- Does 5th gen muffler fit 4th?
- New Motor Mounts?
- Cutting out where fog lights would be?
- windshield wiper blades
- Injen Hai
- TB coolant and idling
- which of these rims will look good?
- Shuts off when at a light or idling....hmmm
- Best settings for AGX's and Progress???
- New Mod and airbag light still on!
- Help! How do I reposition the alternator?
- new guage overlays
- Base fuel pressure
- anyone wanna pm me their phone # to help with dek high idel
- Cam or Crankshaft problem
- Weekend Engine Cleaning
- main pin on torque member
- 95/96 fogs
- KS fault automaticlly retards even if its good
- Is the Dealers Engine Diagnostics Test Worth the Money
- 0604 code
- Ecu Code 201
- WTF? Why is VIP Maxima (Mike) banned?
- raed if you have a rsb, drop then took off your rsb
- Snapped the radiator dampener bolt...
- 5 speed convertion
- A few questions about heated seats install
- For those of you who bought a full Tokico Illumina kit...
- Loud scratching sound at startup/idle
- Aluminum vs. Stainless Steel
- Are muffler hangers on a 5th gen muffler the same as 4th gen?
- Grounding kit?
- Guyz i need ur help! my control arm bushings are gone
- Dash kit intrest
- Understanding an ECU code
- Corey at RedlineMax or Associates ??
- flashing airbag light
- Need help with parking lights
- BRAKE LIGHT stuck on!
- 02 sensors
- Can bushings affect steering shake/wobble???
- Motor Mount Bushing Replacement
- fuel filter help!!!
- so cal help with clutch job for $$
- Can this be caused by a bad knock sensor?
- suggestions for sways
- Bought A 99 SE
- Will this tire size fit?
- Headlight electric question
- Strange Sound from FD wheel.....
- Anyone heard of python fuel injectors?
- Brakes were quiet, replaced rotors, now squeaking..
- BF Goodrich Traction T/A H
- Those with custom catbacks...uninstall?
- Rust Issue need some advice on
- Back up light switch / reverse switch
- I want to install Bosch Compact 100 aftermarket fogs, I beg your help
- AC Problems
- HID Install Problems
- New TS ECU throwing all kinds of CEL codes! HELP!!!!! Please!
- Brake light is on
- tranny swap from 5sp to auto...anyone?
- Gauges problem
- ""Rusted Fuel filler""
- best place to buy, or good after market tie end rods
- Fog light installation
- maxima not starting
- How To: regrease Starter
- rear disc brake calipers
- Anyone have any experience with StoneRacing Y-Pipe/Headers?
- car totaled
- back firing noise from exhaust help?
- Anyones else have problems with the bolts on the Cat?
- Resistance on Crankshaft Position Sensor
- Non Obd-ii
- p1336 0905 - guess what!
- 0404 and 1308 ECU Codes
- bushings, help please asap
- Mass Air Flow Sensor
- got nismo exhaust hangers and got a rattle..
- 96 rear spoiler
- were to buy auto rx?
- Which threads strip first: Drain hole or drain bolt?
