- Sticky clutch
- leaking iol neer camshaft position sensor
- Need help getting drive side axle in....
- Alternator Belt Tensioner Squealing
- 3rd gear pull n stock 95with a dek (data log) air fuel
- thinking about buying 4th gen ANY INFO HELPFUL
- Clutch Replacement
- I cant figure out this belt problem
- Suggestions on Tranny Cooler?
- BBK Part Sourcing
- Who has lowest price on Red/Clear taillights for 96 max?
- preventitive steps when going dino to syn ATF
- 95-99 coil packs the same?
- Bad Inner Tie Rod - Usual Symptoms?
- TS v JWT ECU
- 5spd VLSD in need of bearings...
- alarm keeps going off
- SOrry for this rant but I had to get it out
- B&M supercooler??
- rattling after installing struts...
- ECU Question
- Idle Issues
- ***Car is dead need some help***
- Engine hesitation or missing?
- I had some good times w my I30t 5 speed...
- Ebay XTD stage 2 clutch?
- Problems with New Tranny
- ebay headers!!
- Don't know what to do. Car won't stay on under load
- new style black clear bumper lights? also orange clear lights? *pics*
- Wireing up Bi-xenon Projector/Ballasts
- need help on this?wreck car.
- squeezing more torque out of the maxima
- Can any1 do a 5spd swap in OK area?
- Oxidized spoilers
- Vacuum line ??
- 98 Maxima Stalls when Clutch is Applied-Need opinions/
- Few questions that I didn't find in the faq
- Difficulty of a tranny swap?
- Before you go and replace your Knock Sensor...
- brake light stays on
- Security Film for windows
- Car not starting after some repairs,
- Replaced MAF after 160k miles...what a difference!
- short shifter opinions
- Alternaotr recall?
- air bags
- Anyone have pics of the stock exhaust manifold?
- How much should I ask for my 96 Max SE 5-speed w/102,000 miles?
- Look at what came from ups today.
- Fan not working at position 1 but works well on 2,3,4… what’s going on?
- alarm goes off randomley
- happy halloween .org (pics)
- Trouble starting
- anything bad about adjusting your idle down to 400rpm?
- Where can I get a high output alternator?
- It's Official 5th Gen GXE
- Cleared Tail Light Bulbs
- Help...Bad Slave Cylinder on 96?
- Any reasonable Suggestions?
- Dynomax Ultra-Flow Welded vs. Super Turbo
- going into gear shuts off
- 3.5 swap
- Axle: Advance Auto vs Raxle? LCA Replacement?
- Exhaust Question
- 97 ecu in a 95 ecu question
- Brake feels rubbery & lost braking power after broken wheel stud change...any though?
- Whos interested in a cheap adjustable fuel pressure regulator?
- Best ECU upgrade?
- diff between maf's?
- Fixxin dem hurtin saw blades
- Will my alt last another day?
- bad shoft throw install pic inside
- Antenna question
- Possible Fix For Evap Valve!!!
- Battery Dead After Sitting 2 Days
- is my car sick?
- how much HP is lost from the greddy sp2??
- Cefiero headlights But what about the GRill !!!
- Some Different Headlight MOD?
- whats needed for oem fogs on a 97 gle?
- Spark plugs indicate bad coils?
- AC belt squeeling noise!
- EGR issues
- Is there anyone who actually like KYB GR-2
- ECU Fuel Cut
- Autotranny experts inside please
- automatic magic
- clutch issues !Please HELP!
- How does our RSB work?
- Coolant Leak
- Diagnosing engine ticking and rattling noises (video clip)
- 100 pt inspection?
- which struts.
- wondering if anyone has done this???
- Rear Sway Bar Recommendations
- z32 brake upgrade q's
- mech sprayed wd-40 on my PS belt.
- 95/96 owners
- Cold Start Idle Surge
- Bunch of questions.
- Help needed, Messed up repairs
- Y-Pipe and Cat back are not so useful when you have this.....
- check engine light???
- What's up with my shifting?
- OEM Style LED Mirror turn signals: Post Pic
- replacing tranny at 147k. makes a difference?
- Brake Light Problems...please Help!!!!
- Counteracting crosswinds in the 4th Gen
- Front stabilizer bar replacement write up
- help with cel P0171B and P0174B...
- Hose from nowhere!
- Help! Not my KS, what could it be?
- Sunroof Visor thing is loose?
- Radiator Fans Not Working
- oil change intervals
- crashed VALUE
- need y-pipe help
- Did KYB change their SB108 boots?
- @Black Maxima: Body Kit
- Accelerator and Car shaking
- need help!
- Tachometer Dead. New ECM ?
- Great Butt-Holder
- Alternator/Wiring problem.
- VSS and TCM....how do i change them?
- Help! Slow acceleration, 0-60mph in 11+ secs :(
- tinted maximas
- What do you guys think? Should I buy these?
- Who can service my 96' A/T Max in IL Area
- MAP sensor. where? how? why?
- Free 100pt Inspection By Stealer
- Is there something to be said about the O2 sim?
- Getting new muffler tomorrow, need suggestions...
- what am i doing wrong?????? (struts)
- 00vi ??'s
- Help on RSB installation.
- Can someone further explain how to fix these CEL CODES
- Urgency of Code?
- E brake and Battery light flickering/ Bad MPG?
- Drop'd and Tint'd Part 2 :)
- unstable idle
- Nissan/Datsun Z show in Mobile, AL
- Can I take centercaps off?
- good deal?
- does this look legit?
- help! in middle of changing struts....
- Finding a new MAF
- Is 100 bucks fair?
- A picture of my Max
- A33 5spd question
- '99/'99.5 SE-L roll call!
- OH SHIX 95/96 Max in Tokyo Drift!
- New Motor Mount?
- 1996 Maxima SE 216,000 Automatic... is AutoRx dangerous for me?
- I'm proud of her
- Best DD springs...
- Need Help!! Rear License Plate Light
- HELP: Car will not move. Clutch in or out. 5 spd.
- Sprint to 85 done in July VS. one done last nite
- which red/clears?
- where can i find smoked turn signals?
- AC Compressor clutch does not engage
- wing
- SS Clutch lines for lower hose
- Foglight question...
- Installation instructions: Shocks
- tranny id plate...got a new VSLD i think I might have gotten ripped off!
- Which boots/bumpstops for Tokico blues?
- Glass Headlights Are On!!!
- Alternator from 350Z ?
- Needs some help guys
- Rear suspension on GXE
- Any One Have Carfax ??
- Its that magical time of the year....
- help w/ lowering rear of my 4th gen
- vaccum line open - is this right? (pic)
- Couple ?'s: Fog light and timing adjustments
- 99Max brake pads fit 97 correct?
- Clutch replacement time...
- How many ORG members have done the 3.5L SWAP on their 4th Gen?
- CAI 3" hole template
- Fail smog test due bad ECU help!
- question about getting new TIRES
- weird starting noise, not the normal complaint
- 4th Gen Forum Rant
- Battery - Need Group Size
- starting problems???
- Help probelm with manual AC controls
- grounding kit?
- shocks and struts
- Hey guys...PLEASE look in "ALL MOTOR" and read my 3.5 swap problem post!!!
- put in 96 ts ecu got some expected codes.
- Venom400 Control Module
- Tranny Swap
- Hks Hi Power On Max?
- Great source for 13" rotors
- car misfiring, no codes.
- Straight Pipe or close to it?
- Power loss with dual exhaust?
- Axxis/PBR Deluxe Plus Pads ?
- ground control coilovers
- help with parking cable
- Help with dead cylinder
- Should I lower my max?
- Update.... Exhaust Question
- Mobil 1 Oil Change , How Many Quarts Of Engine Oil ?
- Sudden increase in gas milage
- aftermarket fog lights
- FS: clear bumper lights
- Poll: Wheels All Bronze, Or Bronze W Polished Lip????
- Tips/experience cleaning mud from leather?
- How often do you break brand new axels? on your 4th gen
- when i turn off my car it groans (fuel pump?)
- Is this the MAF?
- cyl. 5 misfire....help!
- cv axle
- Does you exhaust look like this?
- I love this max who's is it?
- Need HELP W/starter and throttle body
- Catback System
- After repair list is completed...
- 95-96 exhaust on a 99?
- Seafoamed Today But No Significant Results
- Help!!! Car won't idle.... have tried almost everything!
- Steering Wheel Vibration- need help please
- Clear corners
- Please help rear strut ASAP (agx and stock spring)
- Please help Dino ATF
- autozone 02 sensors any good?
- Parts that make up the upper strut area?
- Do 350z pedals fit the maxima?
- Egr Clog?
- Damaged ECU?!?!
- The Max Has Been Raped
- Fog Light Bulbs
- My dad got a Pathfinder and that 3.5 is a BEAST! I WANNA SWAP SO BAD!!!
- Airbag Light Question
- '95 5spd hard start, not cranking
- Clear Coner light Question
- Small noise from under car back seat middle FUEL PUMP?
- Axle shakes when applying gas
- estimate of power and times of the max
- Fog Light Question
- Needed Transmission Flush Symptoms
- Heater/AC wont turn off
- Who has had their 5spd rebuilt?
- Just got in an accident FTL
- Just need a few answer
- how much??
