- Some power windows dont work
- O2 sensor signal wire from ECU
- Front left O2 SENSOR LOCATION
- My Max almost overheat. HELP~~
- Do I get new struts or tires first??
- knock sensor question
- Hunting for negative battery cable bolted to block/chassis
- Where's the first place I should look for a coolant leak?
- Would the Ionic Dynamics lip fit on my car?
- Actual yellow fogs?
- got a code: 0302
- clutch problem
- I35 engine swap
- Constant power supply in dash
- Look what the UPS and FedEx men brought me!!
- To anyone having seasonal coolant leakage
- instructions on taking off interior pillars?
- 98-KH3-5MT-SE Crew Step Inside
- Waterpump going bad? Vid inside
- Do you drive with overdrive on or off?
- License Plate Lights
- How much trimming to fit 5th gen muffler?
- Doing a 95-96 to 97-99 font end conversion. Question about fog lights.
- Completely Totally OWNED!!!
- Clutch problems
- How to take off headlights??
- Allignment
- what happens if you fun fuel reverse through the system?
- How do I put "Cruise Control" on this steering wheel?
- Clutch pilot bushing question
- Motor mounts taking a crap??
- Rough Idle?
- DEK Swap...coming soon
- Stiff Power Steering?
- stupid me... ne1 good with wiring?
- !!help noob with suspension please
- Doors locking on their own at times
- Ques on O2 Sensors
- strange intermittent clutch problem
- Belts/pulleys starting to squeak???
- Attempting the impossible?
- Alternator INFO
- 98 MAXIMA WHEEL Question
- heavy shaking when accelerating
- ZACk342 Questions about your original 99JWT ECU
- EBay O2 sensors
- Urgent! Loud Squeel at startup. Starter?
- tire size Q (slick size)
- A- pillar and headliner removal
- which filter
- 95-99 NISSAN MAXIMA 4PC JDM AMBER BUMPER LIGHTS (installed)
- Holy suspension overhaul Batman!
- Lots of sludge
- 5spd in Neutral when changing axles?
- HUGE HESITATION help!
- Wiring
- EGR solenoid valve removal?
- Whistle from intake at cruising rpms
- Thanks all!
- Help - car won't start!
- Broken Nissan Wheel Lock Key
- Oxygen Sensor 2 Bank 2
- Neutral safety switch?
- Chrome Trim Removal
- Warning do not buy PCV valve from autozone
- HID fog light recommendations?
- 245/40/18 will they rub?
- Need a link for yellow capsule mode(LOOCKED THROUGH STICKIES)
- Part # for 1999 Chipped Key?
- PIcs needed of R34 rear bumper and opinions
- in need of help!
- Steel clutchline question
- Interesting way to flush out engine
- Clutch Problem.. please help
- wheel bearing replacement
- Best NON-synthetic oil for 97 max?
- What car do these come from?
- Leak
- Where can i buy the S5 grille?
- why does everyone say drill holes to hack air box?
- left headlight doesn't work and can't figure it out
- Can't find coolant temp sensor
- New to Forum, Where should I start?
- "Sporty" hubcaps for 1998 Maxima GXE
- Damn hood shocks
- Need help about leds
- Rear Tail Lights
- LED standards*
- sunroof dome light assembly
- 95 ecu fed or cali spec??
- Grounding kits?
- 97 Maxima Vs Rotary Powered Lawnmower Van
- I'm a BAAAD, bad man....
- I'm going to do some maintenance (first time) some questions before i go about it
- rear door power window
- Throttle body Vacuum line... connected to?
- drop resistor mod installed
- Clutch Questions
- Water pump/coolant leakage!
- Help! Bolt snapped
- So I've converted.
- What the EFF is up with my radio?
- Transmission Fluid, API GL-4 right?
- Which do you prefer? Painted interior or not?
- Need help diagnosing Hard Starting issue
- Anyone done this before?
- Removing Dash Scratches Question
- I Need Help!!
- Fan speed control resistors
- Rear Bumper Cover Removal
- Steering problems after strut/shock installation
- HID's installed, now car stalls
- Annoying Dashboard Squeaks
- Aftermarket Security System LED
- Flashing Dash
- No ABS???
- Cold Start Problems
- HELP! pulled 2 different codes. What do they mean?
- Oh joy another project
- Shim rear wheel?
- After 11 years she's finally dead... :-(
- Where can I get new Motor mounts for....
- Need a lil info
- Is the flywheel resurfacable ?
- I need help about coolant temp sensor.
- I Neeedd!!!!
- anyone every had to replace their EGR valve?? Step right in!!
- New fuel injectors????
- anybody got a shop????
- How to put filter on CAI?
- 4th gen transmission problem
- Apexi WS/WS2 owners.....please step in
- Slight Ignition Delima.. opinions needed
- red guage lighting *Pics*
- fuse box labels ?
- change clock color "mod"
- code 0902 rear oxygen sensor heater -- sensors have heaters ???
- weird and hard to start
- Clutch fluid
- Replacing Bose Unit with Pioneer CD/MP3
- Does anyone have a Car remote Starter installed in their car?
- TPS Question.. Help
- dek motor in a 98...how hard
- p0136 0707 - Dreaded rear o2 sensor code, need help...
- Help! Smells like AntiFreeze
- Pix inside a stock muffler
- Rough running and 0301 ECU code
- Monroe Struts any good ?
- Taillight fuse keeps on blowing.
- Question about Crank Pulley......
- $411 to replace alty and 'serp belt'?
- New tires, but old valve stems!
- To buy or not to buy?
- Fog Lights on While High Beams On??
- Changing Plugs - What Else Should I Do While Intake is Off?
- Wheel spacer queation
- What shocks???
- FC/Stillen Intake, Warpspeed Ypipe, Poorman's cut out, wutcha think?
- Rear Caliper Rebuild
- New "trim" piece sets ebay?
- Question on Coil Packs
- 97 ecu options?
- SNOW DRIVING- Chains or Cables
- please please help?
- anyone with any experience with code P0744/1107? step inside.
- Modded ECU Question
- Cold start has unusual noise
- adding
- Tranny removal question
- Defroster question
- Can pierced Y-Pipe trigger a 0901 SES Code?
- What Tool To Use to Loosen Nut on Idler Pulley?
- Pad heater to stick to your oilpan
- My Radio Suddenly stop working??
- Simple…. Best location block heater
- 1-2 shift
- Ridiculous Noise
- It's been a while since you heard about MAXecutive ... new pics inside
- Tranny rebuild Kit on ebay
- busted cv boot
- shifter feels squishy/mushy after running at the track
- So i cleaned my MAF...WOW!!!
- idler pulley bolt
- exhaust from warpspeed
- worklog: E39 retrofit
- EGRC Solenoid Valve - where can I get one?
- Interior Door Light Wont Work.
- aftermarket clears
- SS clutch line?
- Replacing TPS, quick question
- what shocks
- Just got my new car today!! 97 SE
- e bay JUNK!
- Hks Vs. Pacesetter Exhaust Perfromance/sound
- Max won't start
- Fuel Filter Replacement Question
- New muffler right under bumper.
- Speed Sensor
- My day was going well until I saw this.
- Heater/AC Blower
- Magnaflow too loud
- Extra noise at startup
- Poll: Radiator core support rust
- Short throw and short height shifter...
- Width of stock 4thgen pressure plate
- Rear Deck noise need thread
- AE (Black) R34 1PC Headlights Installed Pictures & Review
- Starting question
- Smells like gas on cold engine
- 3M Squeak Reduction Tape - Where to buy?
- Ebay Struts? Yay or nay?
- 02 Sensor goes bad after Fuel injector install?
- Where to get decent Indiglo gauges?
- Removing screws from stock FPR
- Got a new hood (pics)
- 01 Swap In A 99
- How to Change PCV Valve
- How to make your Front Bumper and Side Marker alternate when giving signal
- Comprehensive KS R&R, on a 97
- dextron 3
- E-Brake light not shutting off?
- is it ok to get a fender from ebay?
- Engine tick
- ignition coil input wire?
- help?!? don't know a good thread name
- 19" Konigs rubbing
- Tire size (Dont Kill Me)
- 2nd car or Mod the max? NEED HELP!
- Has anyone seen this 4th gen yet?
- WTF is this ish?
- brake pad question
- Help with tire size
- Ebay car seat covers
- Help suggestions?
- Will a 95 cat fit a 98 max?
- Help!!! fan speed control switch
- Starting Issue...
- Instrument Panel
- The bolt that holds the 1.5in plug in tranny
- back up lights fuse location
- Tokico Suspension ok?
- here's a pic of my hids 6000k
- pic of black turn signals
- Clutch recommendation...?
- I've done the search. HELP!!!
- where can i buy a new rubber window seal
- help...car shuts down after braking
- which rear section??
- converting from cali spec to fed spec
- People with CF hood!
