- Help car starts but dies !
- A/F Gauge
- Shop Blames TS ECU For Hard Start
- Tire Info Needed
- code p0446
- Rear Caliper Frozen?
- Cost to repair rear main seal leak????
- Cefiro headlights same bulb as oem?
- running rich... with my de-k motor
- Rough idle
- Gas Lite
- Clutch recommendations
- Fuel pump relay?!
- Radiator Recommendations
- Very strange engine behavior,
- y pipe question
- A light thunk right when I shift...
- Ratcheting tow strap to reduce wheel hop
- bought new 97 max problem starting allready
- Diagnosis Request: Drivetrain Sound and Vibration Through Gas Pedal
- Window regulator failure
- Thoughts on Dynamat Under Hood Liner ??
- quick question about pulley
- Trans. problem
- PR Mid-pipe
- AT- tranny fluid drain needed to swap out axle?
- Question what is the name of plastic box under truck left side
- nipple on door
- has any one try this adapters (cefiro)
- anyone swap their transmission while their car has ABS?
- Exedy clutch?
- Oi - i stripped the stupid plastic bolt for the ECU readout...
- Code P1335 which sensor to replace?
- Anyone figure out how to get better radio reception?
- $3k easily spent @ NISSAN !
- What's the cause of this......??
- How to replace water pump?
- How to replace crank position sensor?
- Anyone else being called to trade-in their MAX?
- Fuses fuel pump
- How can I make my PR CAI fit a VQ30DE-K?
- where to find upgraded motor mounts??
- Why is my clutch whinning?
- Someone HELP! Accerlation issues!
- oh man, need help
- Front OS sensor
- Where could i find (if available)
- Help diagnosing a couple electrical problems.
- more EGR stuff... BPT valve test?
- Tick tick...tick tick
- my poor door any suggestions?
- Aftermarket headlights
- So I broke my car, part 2
- Electronically controlled front engine mount
- New problem
- Best struts for SE springs
- A new addition to the family (Kinda Nissan related)
- Revenge of the SES (vs. wtf is going on?!)
- Quick Question?
- 00vi install
- need help ASAP
- City lights for stock headlights like the Cefiros
- *pics* red led interior + 95/96 red clears
- Why would these only fit a 240sx and not a maxima?
- Replacing license plate bulbs, my sad tale
- Where can i find a sunroof part?
- Brake light on, how to reset?
- Where to buy a cheap Timing Chain Kit
- DIY question clutch pedal
- SS clutch line comparison
- Car died on Freeway - Electrical Problems
- rear strut top hat bolt just spins
- stalled out then CEL went off? but new codes
- Stuck E-Brake cable
- Whining noise on startup
- lights are dimming, starting problem
- WTF? Driver's side front tire keeps popping?
- Cold start + Clutching in = Lights dim? wtf?
- water/condensation dripping out of muffler end
- 9007 Headlights on 98 Max
- Could this hurt my car?
- More Starting Problems And Oil On My Plugs
- heated mirror wiring
- Locked ignition key!
- Flywheel timing ring...
- weird smell
- my car is shaking HELP!
- Exhaust tip?
- 5 speed rebuild question.
- It's Freezing out I have to pay a shop to fix my Brakes
- clunk clunk clunk on the right side...
- Big Problem. Right Rear Suspension
- Placebo? or is there something weird?
- Cant start, Nothing happens when turn key
- Suggestion on parts please
- Where Can I Get A Good Price
- Engine surge from Drive to Park
- HAs anyone done this? Possible?
- ECU's
- xdrill/slotted rotor
- Starting issue
- changing right half shaft.
- What struts to get
- Which headlight bulb to buy?????
- Short throw shifter
- rebuilt trans, pops out of third....
- yep, my spoiler fell off . . .
- How To Remove Defrost Vents?
- Have anyone ever done custom Titanium exhaust setup?
- Start up, and then shut off
- Is it possible 9008/h13
- Blow-by hose- What size?
- Anyone had that kind of problem with them?
- Who makes the softest riding struts/shocks?
- Normal or bizarre? Revs increase when steering wheel is turned
- RPMs drop then shoot up to normal 1-2
- How long does it take to install Ypipe?
- new b&M STS? never seen this before
- headgasket replacement..anyone did?
- clutch (hydraulic problem)
- Axle replacement how to?
- Start up squeak
- Code#0807 / 1008
- 95-99 NISSAN MAXIMA 1PC HEADLIGHT possible repost
- NEVER DONE BEFORE HEDLIGHT RETRO. HomerMAC a pioneer on the headlight retro front.
- Car dying after start up...NEED HELP
- dying in the cold?
- 5 spd problems
- Very little heat! Hang with me on this one..
- Transmission Problem....(uggghhh)
- WEIRD AUTO TRANNY PROBLEM. No Reverse, No Neutral. WTF? Help please...
- What color to paint car.
- Fuse keeps blowing for fog lights...
- How do i test a damged (stuck) caliper?
- Vibration between 700-900 RPM...
- Coilover Binding noise? Suspension related....Video
- New ride for my daughter?
- Y-Pipe/new Cat Converter...before I install...
- Some engine help please
- Clutch makes loud click when pushed in
- FYI...Good Price on Knock Sensor
- Car smells like Gas
- Opinions Defi Blue or Blitz BLM gauges?
- I need help finding a part....
- Gauge Lights
- a couple or things (brakes + 02)
- Tighten your throttle cable
- Rpm jump at start-up and ticking noise
- help maxima is sputtering
- Coilover Coments
- how much do you think i could sell my salvage title max for?
- found leak after seafoam
- Airbag Module Replacement
- Budget Y + Cat + SP2 = Weird Noise
- Installing Indigo Gauges
- Audio question
- Door Lock
- clutch problem
- Kill 2 birds with 2 stones
- Removing the speedometer needle?
- Warpspeed ypipe question.. please look in...need help...
- serious gas mileage drop
- Possibly selling the max
- goodbye...............HELLLLLOOOOO!!!!
- HELP! Car Runs Sluggish Won't go Over 30MPH/Shuts Off!
- Chrome Bulbs?
- engine bore
- Clutch swap done (v. pix and profanity)
- please help: part fell out from under my car... can i still drive it?
- huge alternator problem
- Wow i need help real bad!
- anyone know how to hook up o2 simulator?
- WANTED: EGR and IACV Cleaning Write up
- so... i need help! please!
- vg30de > vq30de?
- is there a way to eliminate rear o2 sensor?
- Axle play... Diff bearing problem for sure?
- 0304 and 0102 After cleaning TB and IM?
- Torque steer?!?!
- What kind of wheels do you all have?
- Removing starter motor attachment bolt
- 3.5IM Fit on a VQ30?
- Will my rear progressive spring coils touch and squeak?
- Clutch problem in cold weather
- Storing a car for 3 months
- Techbical advice for no crank
- anyone with 99 cali spec with DEK engine?
- y pipe and mileage
- So, I broke my car.
- KA-CHUUNK... Engine Misfire? Faulty Starter? HELP PLEASE
- So I got some codes
- changed PCV valve- now its making a whining noise.
- knock sensor frequency
- Blown fuse? Or worse?
- Exhaust piece removed, how important is it?
- Reccommended Sticky?
- what kind of oil for wintertime?
- i think i blew a fuse
- Tire PSI Question
- Which color temp. for HID?
- ongoing starting problem now car doesnt start
- how do i remove the rear speakers??
- HELP. Im Stuck Removing Rear Bumper
- Exhaust system
- HVAC control question
- Freaking passanger door is not locking....
- So is anyone rockin yellow bulb headlights?
- belt squeel ?
- I have a really quick question if someone can answer!!!!!!!!
- Engine swap question
- door open switch not working
- Disconnecting starter motor trigger wire
- Help with Installing Rear Bumper and Trunk Lid
- Squeaking When Turning The Wheel
- power steering problem
- Alternator removal
- Has anyone used body parts from Pershing auto body on ebay?
- WTB LEFT REAR bose speaker
- need help with the radio......
- wow
- Any of you guys still does CARFAX reports?
- ebrake question
- Idle bump(drop) and WOT stumble
- are coilpacks interchangeable?
- upgrading timing compenent
- Oil diluted by fuel
- exhaust with supercharger question
- Anyone want to reupholster their leather seats?
- PICS Check it out.
- RPM's drop out, car stalls while moving
- Motor mounts from ebay???
- so i bought Q45 calipers and im missing half of them..wtf
- battery draw
- will these rims fit my 4th gen?
- Repair Fog Lights / Where to buy
- Radiator no coolant at all?!!!
- Not a bad deal!
- Slight exhaust leak.....gas mileage/power...
- 3.5 altima muffler
- Last call - STARTING PROBLEM
- Car wont stop running RICH
- dash swap
- Finally fixed stalling issue by grounding MAF sensor
- NEED SURIOUS HELP with gas mileage!
- Some power windows dont work
- O2 sensor signal wire from ECU
- Front left O2 SENSOR LOCATION
- My Max almost overheat. HELP~~
