- Any good mechanics in Covington GA? I need help
- 1996 Maxima SE with Cloth Seats-heated seats.How do I install the heat switches-?
- Skippynet knock sensor removal
- 2006 4th gen of the year Award.
- Engine Service Light is ON!!!
- Squeal When turning.
- Which clutch?
- E-Brake Light and Battery light randomly lit simulaniously.
- Do these look like the Tein S Tech springs for 95-99 Maxima?
- Oxygen sensor upstream, right bank??
- JDM: Myth or fact?
- JDM myths or fact?
- need a little help
- Getting Avic N2 how to hide it
- Heated Seats??? Get the F out!!
- 2 inch drop with exhaust??
- Chain Job??
- Clutch release replace... Problems *HELP*
- STILLEN FLYWHEEL SALE - today only.. FYI
- Vibrations at certain RPM only
- 4th Gen Maxima in Lexington, KY
- Clarion In Dash DVD Q's
- I think my CV Shafts are messed up? anyone can help?
- FM Modulator for Ipod - Will it work?
- another happy customer with Catmann performance
- Codes keep coming back after you've fixed it?? Step in.
- Weight...
- B&M Shifter
- What Kind Of Bulbs Do You Have?!!!
- Passport 8500
- fog lights
- Superpro Beam Axle Pivot Bushing fits A32
- Tint percentages
- Maxima Eating Batteries
- Changing leaking valve cover gaskets...what else should I do while I'm in there?
- Clutch replacement - questions for those who have done it themselves
- temp disabling FR brake
- Cracked rear main seal, HELP
- When Is Inner Tie Rod Replacement Necessary?
- question on tint and bubbling?
- flashing air bag light is....
- How many more miles do you think I have left?
- starting problem v.immobilizer key
- Pic of 4th gen with black gen 2 Altezza please
- HELP! factory Anti-theft gone crazy...
- Setting O/D off as default
- Looking To Get Lowering Springs!!!
- Cheapest place to buy OEM parts?
- AE Aluminum pedals = 03 350z pedals
- Which exhaust hangers do u guys use?
- Noise when turning steering wheel
- acura totaled, mom gave ****ty 96 maxima, fixed it up + mods PICS OF ALL!!!!
- Smoke and whine coming from engine...
- Which O2 sensor brand?
- How in the F*%$ Can I...
- Stores to buy bumper clears with bulbs?
- cefiro headlight bulb replacement
- Can't find seller for 9006 capsules...
- car wont start...what could be problem??
- 2 Qs- loosening PS belt, and removing crank pulley
- 5 Spd. Swap Parts.
- so who got car parts for xmas
- anyone need close up pictures of how cefiro's mount up?
- Quietest Full CatBack for 96 Max?
- speakers
- Pick My Gift!
- size of exhaust bolts
- Tokico Illumina Shocks & Springs???
- Idle too high
- Battery Relocation Advice...
- moisture in turn signals
- Shifter Issues
- Pictures of IonicDynamics Carbon Fiber front lip on 96 Maxima?
- Places to buy a 4th gen Poster and Diecast?
- hesitation at 3k-3100rpms
- Crank Position sensor troubles
- car jerking terribly..
- Removing KS, by not replacing right away?
- what do you guys think of this shift_maxima.org sticker?
- help with rim offsets
- My max didnt come with fogs, how would i install them if i wanted to?
- Merry X-Mas
- Key won't go into ignition?
- Pics of 6th gen 18s on a 4th gen?!? anyone?
- what headlights are these???
- ECU wiring harness
- walbro high pressure 255 lph fuel pump
- check engine light on since y-pipe install
- how do i make the side markers brighter?
- Can't Find Repair pdf/Cd for download anywhere
- Burning/heat under dash
- Any Photoshoppers>
- i get 500 km on a tank on a 97 is that normal ?
- what type of oil?
- A quick q re. 1995 trim piece
- Engine Wiring Harness....
- 5th gear popout: not how i wanna spend xmas
- WTB - RF clear lens indicator
- Transparent paint?
- anyone ever done an r33 tail light conversion?
- 6 speed swap?
- Tranny Code...?
- 97 Maxima Problem
- Only 4 wheel studs,How safe?
- sum pics of RETRO's
- MA inspection failed for no spoiler?????
- 85watt H3's safe to use in OEM fogs?
- My Heat stopped working!
- Does the non abs passenger side axle have a gear on it?
- So my mom gave me her 96 maxima after my 92 acura vigor got totalled...
- Exedy stage 2 install question?
- Subtle whistling noise at idle. Vacuum leak?
- No start on cold days !!
- 95 5-speed maxima hesitates, strong gas odor
- Cruise Control surges on mild hills...
- Will 245-45-18 fit a 4th gen?
- Starter replacement...will a 97-99 starter work on my 95?
- what kind of 194 and 1156 bulbs do you use???
- trunk hinges
- mp3 player to bose HU??
- Has anybody ever taken both headrests off and reclined both seats all the way?
- Freakin' PCV Valvue - Suggestions?
- Mother F'ing 09-01 and 10-01 codes.
- P0136
- Engine Temp Reading Cold
- No parking lights.....uhg
- Humming noise
- some suggestions please
- Door panels + speakers = crazy rattles
- GR-2's for $450???
- OBD-II Scanner Question
- Check It Out..........
- Auto Tranny died
- how to clear codes with no scan tool?
- Anybody with a gunmetal/charcoal gray 4th gen???
- Driving, honk my horn, and Speakers Go??
- Windshield Washer motor
- LED maplight mod
- Z32 calipers part numbers
- How did you get to the O2 sensors on the y pipe?
- Serious Help Needed Cylinder 4 Misfire
- 96 remote
- Screwed O2
- Help: Trunk Lid problem
- need image of assisting, trunk-opening rods
- which SS brake line is better?
- transmission problems
- Anyone need CV boots?
- Putting the tranny back to getther FINALLY!
- problems with 00vi swap please help
- Keyless remote won't unlock all doors....help
- Auto RX
- Yet another starting problem???
- HELP ME PLEASE - Insurance installed Infiniti Engine In My Max
- lots of squealing on startup + startup problems
- aftermarket electronically controlled motor mounts.
- rims width question
- Broke stud on Ksports...how to replace??
- whats the best spring-strut / coilover setup for 4th gen?
- Microvision 7" screen
- I30 side mirror compatibility
- rolling fenders
- 95-96 owners please step inside
- EBAY Suspension:TRASH!?!?
- Help car barely startups in morning
- skeptical about the venom 400..
- Looking to buy a '99 Max. Carfax anyone.
- Paint Question
- o2 sensor
- i30 hid setup in 4th gen??
- just bought a 4th gen
- MAP/BARO SW Solenoid/Valve????????
- Water Pump issue
- hid's in this damned stock housing
- EGR hose question *pic*
- Max in an accident :(
- - anyone got a spare alternator sittin around, mine's whining and won't work
- hesitation/misfire at 2800rpms, only noticeable in 4th and 5th gear
- e-brake adjustment after brake change???
- vent control valve on EVAP canistor.
- New mods..
- Clutch Goin Out Help
- Speed Sensor? OBD Problem!
- That's freakin' LOUD!
- My random video compliation
- What Size OF Windshield Wipers ?
- Possible injector failure
- Seat swap?
- Well I rearended a Durango this morning
- Whats Wrong in this Pic. . .
- CEL P1105,, 13 02,,map baro solenoid
- Anyone else with ebrake boot installation problems?
- Jacked up Floor Pans
- windshield washer
- car stalling?
- help with check engine light....
- Brake problem
- car not feeling like it should be
- Fog light question ('97 GLE)
- 5th Gen Muffler Questions
- 6th gen SE auto tranny?
- My New Suspension Setup!
- park brake question
- jim wolf ecu??
- Oil? leak and type?
- Removing the rear bumper cover
- what is a ignition signal circuit??!!!!!
- Crank position sensor POS and REF
- ok, I can't stand it anymore, after 202k miles my suspension is totally shot
- NEED HELP- car is sluggish off line then power is strong
- Hooooray my car is fixed!
- Is this dangerous?
- Whats 4th gen fuel pressure?
- Low rpms, Stalling
- Neverending storrrryyyy.... (dooo daaaa SES dooo daa)
- Need help with hood support
- cold squeal - alternator or idler pulley?
- Front left tire area is making a squeaking noise (help)
- coilpack numbers?
- Help needed with Y Pipe install in NJ
- starter ground
- Exhaust hanger question
- Check out my Twin Turbo pics
- Where to Buy OEM Infiniti/Nissan Front Wheels Bearings
- Anyone in SoCal want to help install my springs?
- power steering belt -- is this normal?
- Clutch Issues
- Does anyone know?
- How to install new springs into a 96?
- Car wont start! help!
- HID question
- Electrical issues.... Please step in!
- Where can i get the M bumper
- Need Advice on Centercaps
- Why isn't there a stock-sized aftermarket pulley?
- Help!! My maxima is destroyed.
- This a good deal for these tails?
- How do I Changing the clearnance light????
- RPM Swings Up and Down!!
- Will auto-tran cause engine shut off?
- In the X-mas HID Plug/Play kit sale thread do they come with the bulb?
- Whats the deal M/T Tranny throwing a A/T Code
- Taping for Paint Job?
- O2 sensor code pulled and rough idle issue, smog coming up.
- difference between a 10 and 11 tooth starter
- Disection of a B pipe & why you need a new one!!!
- o2 Sensor Question
- did buget do me wrong?
