- amp mounting
- replace window trim/moulding
- belt squeal
- paint y-pipe
- ok noob question
- Lightened Flywheel
- replacing valve cover gasket
- This'll F**k You Northern Hemisphere Guys Off
- AT Filter replacement...Possible?
- Hood Shocks
- adjusting tps
- installing tokico blues
- Brake Pedal Feel
- Chilton v/s Haynes
- Why me!!! need lil info.........
- starts when cranked twice only
- KYB GR-2 Maintenance Questions
- KYB GR-2 or AGX? Please help.
- Need some suggestions on getting power behind the radio and A/C...
- Used y-pipe?
- 4th gen with g35 rims
- CV Axles
- Optima red top problem
- need some good comebacks
- cry02 kit worth it?
- help with window motor
- front bumper removal
- Startup Issue
- A knock sensor for $231.69 ? WOW
- Knock Sensor Replaced, Still get 0304
- electronic flasher
- whats a good price.....
- Spudder in acceleration
- gotta go to court friday, can you do this for me?
- New MPG record
- Anyone using Luminics Ultra/hyper white?
- Bought a 97 Max, what to do first in terms of maintenanece?
- Partially Complete 00vi $300 shipped
- Lower control arm bushings
- steering rack of 97+ on a 96?
- 96 fog light question?
- Need Insight on SS Clutch Line
- HID kit not working?
- Time for radiator hose replacement?
- Windshield Wiper Housing...
- pics of short ram intake on maxima?
- New Winter Wheels..Pics !!
- This noise can't be good (video)
- Who Has 20's On Thier Ride??
- so my alternator puts out 57amps at 2000rpm
- Bag of Fun- CEL
- Yet another Photochop request...sorry.
- CEL need some help
- Headlight Cleaner...Worth it?
- whining noise from engine bay
- Quick engine bay detailing
- cool that i have no gears . . .
- Cefiro headlights and HIDs
- Torque Member Bracket
- B&M shifter install ?'s
- HID kit?
- Preventing Rust
- 4th Gen HU wiring problem:
- Anyone made mudflaps?
- 5-speed Help...?
- does this sound norma??
- Best Strut/Sway Bars
- Shift Knob
- How to install Grounding Kit? 4th Gen
- Ever had a cop compliment your car???
- one (last!) question/Steering Wheel
- busted Rack
- timing cover and noisy injectors
- Why did my car just die?
- What the dumbest...
- Will these buttons be lit when I turn on the headlight?
- It happened guys accident need help ASAP
- nissan factory battery question...
- LED Gauges with NO Hotpots - Need Tips
- Need help from 5spd. conversion guys - Have CEL code 10-3 (park neutral pos. switch)
- Taking apart key to get immobilizer.
- HID installation
- My Signals don't work
- 01 seats in a 98
- Front end juggling feel.
- Is this a Thermostat problem?
- WTF happened to my mileage?
- Funny story :-D
- headlights dim when bass hits
- Wheel Spacers
- Are ABS Brake Calipers Diffrent then non ABS?
- Can I replace my manual climate control with Auto one?
- Any auto trans gurus?
- 99 Five spoke Se wheels on a 97 ES Can model, and what type of cleaner to use on TB ?
- Need A new 5speed gear box!
- Best exhaust for my application...
- Gone Fishin'
- Help with HID Harness Build
- my hand is all cut up and knock sensor still not changed!!!
- Evap Canister Control Valve
- stalks install help
- Does anyone know if the 17" 2005 Maxima rims will fit on the 4th Gen?
- 97 Steering wheel in 95/96
- creek/squeaking when cutting the wheel all the way
- cigarette lighter fuse
- If using OEM Air intake, is it worth it to drop in a K&N Filter?
- How hard is to replace all 4 wheel bearings
- Mystery Coolant Leak
- Applo_1's A Sad Day.
- Still learning, have questions
- couple of weird probs
- Has anyone ever wore out a 5speed shifter lever?
- Brake Caliper Question
- Ebay fogs?
- Need serious help!!
- I need to know what code this is, can someone help me?
- I got my max back!!
- 90K service question
- best transmission oil for max?
- Custommaxima.com went bankrupt??? Fell off the face of the earth!!
- What performance mods do you recommend for the 4th gen?
- car has a mind of its own: locks 3 doors w/o using remote
- best websites
- The luckiest Max?
- 1996- Rough and low idle when cold but good idle when it hits normal operating temp??
- TPS problems?
- Steering Wheel Cover
- Manual Tranny Fluid
- ignition ring light
- sunroof stuck on 1 side!
- Strut Mounting bearing replacement???
- When do we??
- 4th genners interested in moving on
- Would this work?
- Tokico Illuminas/spring combo are fantastic
- These cars cold natured?
- What do you do with your maxima
- Having trouble starting
- Remus Exhaust Q's?
- throttle body spacer
- Ok to use Redline MTL instead of MT-90
- Just to let everyone know.....cheap knock sensor
- Rear valve cover gasket:How hard to change???
- Wiring lights into ignition?
- shaving cream on windshield
- Can you use 2K coil packs on a 96SE?
- Shift Light Opinions
- How to put Projectors In cefiro's
- Heater Core How-to
- Can squeaky radiator fans be lubricated?
- used KYB AGX struts
- Heated seats for 98 SE
- 3.5 Swap Into 1997 SE
- Maxima vs Hondas and Acuras
- What I like to call: Strummin' the Banjo.
- How to replace the pistons/shocks that hold the engine cover/
- Best batteries for our cars?
- need some advice on urathane engine mounts
- 5-speed Swap Help
- popping sound while turning. any ideas?
- power features not working when cold
- The right headlight keeps burning out.
- Squeeking from front end!!
- Synthetic gear oil
- 5th Gen clutch
- KYB AGX, Blown, or not?
- 2K Bose in 96? (already posted in stereos)
- 300zx brakes
- Odd speaker shape in 4th gens?
- R34 Light Retro! Tell me what you think?
- Fog mod. then HID?
- Brake lights not bright enuf?
- Changing front crank seal
- Altenator question
- I30-cefiro body kit--please read (need help after car got wrecked)
- Hey is Toyota copying Nissan?
- turn signals dont work, cant figure out why
- How many Amps you pushing?
- What is involved in removing gas tank?
- Crazy amount of fumes and smell from exhaust
- cleaned aicv and now car wont start? HELP
- Where to buy Clock and Vent dash piece
- How to Ship Hood ?
- Car Shaking
- Replacing Fuel Injectors/Knock sensor questions
- will a 95 3rd brake light fit in 99/are they different?
- Need Help Changing Battery
- Cefiro Crank Pully
- What the *ell!!
- car will not start
- Rack and Pinion
- is this flywheel resurface-able?
- electrical question
- ES poly motor mount bushings=terrible engine shaking???
- Grounding kit
- Weird Starting Issue
- knocking upon cold start up
- heater blows cold at idle
- Code 0111 The jackpot code???
- check engine light help please
- Driver Side Sun Visor Lights
- Turbo Kit for all maxima's
- How much time to remove upper intake manifold?
- rims Q?
- Speaker Sizes?
- Muffler + Bumper= not too happy
- Hardcore Knocking
- Can the PCV valve cause stalling
- Need help.. no parking lights
- Car Just Shut Off!
- Removing 95-96 headlights to swap 97-99 ones?..
- anyone blow a koni yellow yet?
- Finally ! Evap system problems fixed
- Snapped a lug nut stud...what now?
- Tokico Blue question
- Maxima about to die. SUPRISE!
- 0115 ?
- Painted dash pics
- greddy cat back gain
- Engine buzz at highway speeds
- car shaking
- P0 1165 on a 99 Max cali-spec (OBD-II)
- Car not starting....
- 4th Gen. featured in Nissan Sport Mag.
- center cap problem
- Non-Flame Post for the Ultimate Maxima Construct (IMO)
- cold start & warm-up -- best method
- Anyone ever get code 0710?
- Problem with BOSE stereo
- Few Questions: JWT Ecu, MEVI & Nitrous.
- o2 sensors
- Need INFO on 95-96 catalytic converter
- universal bosch 02 sensor question
- R34 Headlights, good deal?
- What is this?
- side marker lights
- i want to retrofit my lights, but dont know where to start?
- Redline Maxima
- diamond cut corners
- TC or SC in 3.5L
- need help installing trenz grille on 95/96 asap
- removing the dash
- whats so special about the SE-l
- Issues after 00vi swap: need some help
- EGR or Knock sensor?
- Gas needle question??
- So, I have sort of a problem..(56k, no)
- putting auto climate control
- Digital climate controls on GLE
- A/C ground problem. any suggestions?
