- Need Help in Denver-
- Are calipers easy to install?
- Hids
- Does Bosal make good exhaust products?
- Lost 2 Tenths? What?!
- Valve, and engine cleaning trick!!!
- Starting Problem
- Labor Rate on V/C gaskets
- bbk
- Front Right Heated O2 sensor
- All Maximas post 1995 are OBD II compliant.
- rim fitment possiblity
- Was there more than one beige or gold?
- Odd hum sound
- o2 sensor simulator question
- Did i just skip a tooth on my timing chain?!
- noticeable pull to the left
- just bought a y-pipe, a few questions
- Spacer Mod, interest needed
- 97-99 carbon fiber front lip pics??
- What was the reason you bought your first maxima?
- Dont Know What To Do! I need HELP
- Clearance Light Question
- Polyurethane Control Arm Bushings... ?
- antenna advice
- Attention MA area maxima owners
- Anybody who needs some hood struts...
- Which Optima battery should I get?
- windshild washing- cleaning?
- Brakes brake fluid
- thought some of you guys would be interested...
- can this be welded
- abs on after hub change
- Odometer problem
- replacement bumper lense clip in plastic things
- New Hawk Hps + Brembo Blanks = Dark Rotor?
- Brakes?????
- Engine making weird noise at startup! help!!
- Replacing the stereo HU question...
- Big auto tranny question! Auto owners! Come in!
- Killed another battery last night, Need help for rewire of heated seats
- Question about the airbag light
- Stuck bolts
- Hydrolock.questions and opinions....
- Yes, Virginia...the AGX's finally softened up!!!
- Are All 4th gen hoods the same?
- Stillen Flywheel??
- 3 questions regarding tinted tails (baking, paint thinner...)
- O2 sensor replacement
- Received a Replacement Altenator Free Under Shop Warranty.
- Maintenance Question..
- Running Lean
- Difference in starters?
- Has anyone ever told you? USELESS thread of the day...
- Seized Caliper: Drivers Side Rear
- Help with Red/Clear Taillight Install
- tranny leak from shifter rod?
- INJEN CAI Intake Install Help
- quik question about 01 vlsd tranny in 4th gen
- noise?? wondering if you have any ideas?
- Need some info.....
- Changed my alternator now nothing works, please help!
- Front Brack Repacement Pads and rotors. 1999
- well i guess i finally did it.
- paint/body guys step right in....
- 00vi upper with 98 lower..help..
- 1157 corner lights
- 97-99 Lip on a 95/96 Bumper **WTB as well**
- No 3rd Gear Maunual Trans
- What to use to cut strut bodies?
- Buying: 04 Maxima or 03 G35 Sedan?
- Factory Nav. On A32
- has anyone seen this before?
- White SE cluster w/blue LEDs (KEPT OLD ODOMETER TOO!)
- Problem With Screws On Fog Lamp Brackets
- Squeaking Clutch
- Door Lock Problem... HELP
- Key Code?
- Radio Buttons Falling off
- Hard starting+Knock sensor
- HELP! SES Randomly Comes On...
- 04+ Gauge Cluster in 4th Gen
- need help with making a wire harness conversion H3 to 9006
- pics of my car
- Replace 'oil cooler hoses' oem or not
- about to install coilovers...what should i also replace?
- fuel hose
- Why is my steering so sloppy/loose???
- Idle Problem
- hard to shift into gear
- O2 sensors voltage range
- Both of my Rear calipers are F'ed up...
- New rear shocks problems!!!
- Quick Question ABout Carparts.com
- Clicking when turning the steering wheel?
- IMPORTANT info about the STICKY threads- PLEASE READ!!!
- SE-L owners: who has the highest mileage?
- Studdering problem on rolling acceleration
- jeff/matt
- anyone rockin' 350z seats?
- Car sounds like Jet engine plane??? WHY?
- strut and spring day - all done
- FED spec ECU in a CALI spec max
- Heater blows lukewarm and temp gauge shows "C"
- changing out the corner bulb
- fuel pump location
- Anyone tried these (HID)
- Lip kit question...
- After changing a coil...
- stumbling... coils?
- Noob messed up my car
- New Key
- Car wont turn on?
- Front Wheel Bearing Replacement
- JWT ECU guys(weird problem) - 97gxe mt using a 95se mt JWT ECU
- Please help me identify some rubber lines
- ODB 2 Issues
- Just installed B&M sts
- Replacing rusted exhaust parts
- Remote Entry Key Fobs
- Help plz this makes no f@#!ing sense!
- need some help with the panel that seperates the sunroof from the interior
- AMBIENT Button MOD how to
- A little insight on my CV axle install
- new starter teeth worn, this normal?
- Wiretuck??
- Did foglight rewire and headlights come on with parking lights
- What wheels should I get for my Maxima
- 19x9.5 20 offset is it possible?
- Which ignition coils?
- converting from cali to fed spec
- Sold the Max, moving up, take care everybody.
- Code 0707 wont go away!!
- has your m.p.g. gone UP or DOWN since 17" rims?
- weird rear o2 code. arrrrrgh
- ECU problem
- fixed my $600 bad coil problem for $1
- 05 05 - CEL has me stumped after several resets
- Akebono Brake Pads - Any good?
- Need New Brake Rotors - Brembo or PBR?
- Never replaced brake pads before - should I attempt it?
- Taking apart TB components?
- weird starting problem
- blehmco
- Car runs rough sometimes
- Broken in clutch
- Opening up outer taillights
- Custom Engine Grounding Kit
- i think my o2 sensor went out..
- Headlight guys step in...
- picture request of hks catback
- Coil Packs?
- Question on 1996 O2 Sensors
- Smog Issues
- j30 brake up grade
- STS Review?????
- Fuel Gauge not working - ideas?
- Winter sucks cant wait to put summer rims on!!
- transmission cooler question
- Line-In to the Bose Head Unit?
- I need help deciding what spoiler to put in... (pics)
- New 4th gen gas tank for $198.30 shipped
- Led Spoiler isn't coming on
- 0503 - Front right heated 02 sensor Q's
- Car wrecked, is it fixable?
- I have a question about the 1999 SE "Limited Edition"
- Ok... Wierd problem with Speedo...
- 5th Gen Catback on 4th Gen
- Help Diagnose! Runnin rough, need advice
- motostorm pulley result
- manual trans gear oil?
- Wheel Bearing
- Pearl White paint code for 1998 SE
- 1200 dollars later..... :D
- Fuel Filter Jungle
- How do I disable the steering wheel lock and/or remove the ignition?
- Question for the electronically enhanced!
- Need Help On Oscai
- Cleaning fuel tank
- Car dies on start? VID inside.
- my idle drops to 500 when coasting!!
- Can i put in a 99 BOSE HU in a 97?
- how often do you guys get a tune up?
- low idle and beginnings of a misfire
- AMSOIL Gear Oil
- My new suggestion on idle and surg problems
- Where is the Park/Neutral Position switch located?
- Bad day for the i30krab
- Vibration while driving
- need some pics
- Tranny life
- cruise control light flashes
- (Pics)My FSTB & EVAP/other too close?
- Fog light question
- tail lights
- Anyone interested in a Chrome Guage Ring GD?
- cant find my catback (apexi ws2)
- ECM compatibility
- Rear Caliper Sticking Replacement Alternatives
- Free Fram Air Filter
- fried ECU
- Is spoiler the same on 95-96 and 97-99
- ECU, fuel, or something else problem... Please help!
- Chrome grill and Bezel Trim
- deja vu???
- Reinforcing front doors
- question about bose speaker....
- hosting pics........
- Question about Bose HU
- Good bye 4th geners! it's been a great year
- Don't these times look kinda fake?
- 95 headlight question...
- i h8 to start another exhaust post, but...
- EVAP Canister Vent Control Valve Circuit Malfunction
- ECU code 0509
- What engine should I get?
- ATTENTION: CHECK your OEM oil filters!
- In-dash tray jammed in 1999
- Please Help: Rear Windows and Locks Don't Work
- heating system makes noise when below freezing
- My cv joint is broken what are my options and how dangerous is it (for my car)
- bolt size
- Door Locks Help
- Recommendations for a new intake?
- bose stereo problem
- Help starting my car
- Locking or non lockin differential
- Clean or Replace MAFS??
- Minute Rough Idle
- Torque converter
- blown or boosted vq35
- oil light question
- Injector question
- When to change spark plugs?
- Need Advice Quick (Plastic in wheel well came off)
- brake upgrade
- HELP!! Car turns off by itself!
- where did this come from?
- Check your welds holding front seats to the floor
- Custom catback
- Bondo or not to bondo HELP!
- VIP style max
- Passenger door "courtesy light" stays on when doors are shut. Do i have a short?
- Fastest Maxima known to men?
- How to Replace Intake Air Temperature Sensor?
- Poor Mileage, Help me out if you can,
- Turning Lamp Option
- HELP! Interior lights stopped working!
- Monroe Shocks and Struts
- Dents, Dents, Dents!!!!!
