- 143k on orignal fuel filter
- Stupid Vehicle Speed Sensor
- Starting problem, lots of details, huge headache PLS HELP (long story beware)
- AE headlight mod question/pics
- What would you pay for...
- LED Tail Light on Spoiler not working
- Please read.....need help on foglight rewire
- For those of you with Stillen intakes, a cleaning ques.
- How do I remove bumper lights?
- Air Filter Question
- Do I need to remove the head to remove the Knock Sensor?
- Stupid questions... gets stupid answers...
- suggestions needed
- Mac based OBD-II Scanner
- Window Switch Problems
- Swapping Auto transmission
- Has any one seen this !! Idle changes on turning steering wheel
- Who sells just the Stillen Lip, not full kit??
- Please HELP! After replacing spark plugs, got a 0201 code, engine mifire
- clutch issue
- CA Catalytic Converter
- did search but cant find weight of tsw votex rim
- quick question on struts.
- Loosened Belt
- 97-99 front end conversion question
- Remote Start add-on to OEM system
- bad bearing on my de-k, but from where ?
- Projector Question
- short throw
- '96 with CEL P0740 code, any fixes?
- Strut bearing location with coilovers?
- Why is there no way to get in contact with HIDtech?!
- headrest monitors
- Starting problems after replacing clutch.
- You probably know this BUT i will say it anyway
- Paint peeling/detailing info
- Simple question (I think)
- if you bought a cat from warpspeed pls input info
- Reverse on tranny not engaging
- Would an O2 sensor do this
- Sometimes Shifter gets stuck?
- oil sending unit, iacv, valve cover gaskets, ECPVCSV woes
- Code reader for 96
- Tach problem
- UDP installed......now problems!
- '97 clear corners?
- Opinion Changing Antifreeze Best product
- bought some projector fogs to experiment with..
- 2-second clicking in dash??
- looking for Electric ground locations
- Vibration at highway speeds
- Budget Catalytic Converter: Bullet style or OEM?
- Rerouting belt what size do I need?
- auto tranny stuck in 3rd? wut cause?
- Am I right?
- halo ring projectors
- EGR code + Knock sensor code
- electrical problem
- Please help!!!
- Who had to change O2 sensors from getting a Y-pipe?
- Grinding when turn car turns off??
- 99 SE-L Question
- Budget B pipe
- Question about foot lbs??
- "grinding" rubbing noise when cornering clover leaf ramps
- AC compressor woes
- What would a mechanic charge to fix rear main seal leak?
- Any difference between OEM and Universal O2 sensors?
- Removed Intake Manifold Collector. What should I replace?
- Throwout bearing woos, any input would help
- Anyone know where i can get SM5 parts?
- need MAF info for senior project! please help!
- Who still sells VB mod?
- 5.5 gen sides on 4th gen
- anyone use Hella or Sylvania Ultras?
- crazy sound when i tried to start the max
- what is a good MAF cleaner?
- Those Ebay HeadLights!
- stiff clutch pedal?
- Fuel Pump Gasket
- Maxima trannies own compared to the Altima
- VQ30DE swap avg labor price?
- Does anyone know where this thread went?
- What type of trans oil do i need for MT
- Headlight Install Please NEED HELP ASAP
- Mounting HID Ballast
- wiper arm removal?
- so many red SE-L's
- Ok....another help issue..or feedback
- o/d on dash cluster flashing???
- what is the difference between the models
- 97 5spd SE vs 06 Auto SE
- Clicking/Clanking sound...
- Any body scrubbing with 245/40ZR18s?
- Stock Muffler bolt on to Stillen B-Pipe ?
- how bad is it to drive with a bad o2 sensor?
- How do I remove paint marks on my car?
- help!!! my engine oil pressure light came on....
- 2" Drop Successful
- overdrive (od) blinking
- walmart bag
- hickuping lagging studdering, bogging down help please!!
- camber issues!!!
- Rotor warped?
- Maxima center cosole light
- '95 Maxima misfire help!
- Bad fuel injectors
- opinions needed: caliper colors
- Slight dilemma...maybe just spring fever though.
- Rotten Crossmember
- stone mountain racing headers
- drain vale on caliper: What size is it?
- Fog light questions
- are there any DOT approved 1pc lights?
- Difference in 95-99 armrest cover?
- 97 Infinity I30 Auto Trans
- Front Wheel bearings still going out...HELP
- my door is stuck! help!
- LED Guru's I need help w/ LED tails
- ~~~~Need yall's advice!!! help please! ~~~~~~
- SPEC stage 3 clutch on ebay
- Takin the max to Vegas and back... checklist?
- Got Board w/ razor blades and goo gone (pics)
- LCA Ball Joints?!
- BBQ Paint on Calipers
- New mirror and bumper lights
- Need help on figuring out the problem
- Coolant leak possible? I might have one...
- Changed accessory belt and now it squeaks when starting
- Abs Light!!!!!!!!!!!!!!!!!!!! Is On!!!!!!!!!!!!!!!!!!!
- Fuel related "Check Engine Light"?
- How long before ur new KS bring back power?
- Testing Coils
- regular, or hot/cold sparkplug?
- will 95 exhaust system fit 97 maxima?
- A/C not cool at all
- Buying a ’97 GXE – need HELP with these leaks
- bose ?'s
- Downshift Error
- Blown Head Gasket Replacement
- What do you call this
- LED information auto-climate
- Stolen Maxima
- O2 sensor quick question
- lug nut question
- Fuel Injector cleaner any recommendations
- Gas Tank Supports
- Need to change transmission oil. How many quarts?
- Front Brake Question
- HID's with cefiros
- lowered(H-tech/Illumina) & uneven tire wear
- Clock not lit up, emergency signal and defrost do not light up
- Fuel Injectors
- No turn signals or taillights...
- Apexi WS2....yet another thread....
- Help!! bought LED bulbs but don't fit
- I searched - how to remove stock stereo???
- Clutch Problems ... need advise
- The squeak is back
- So looks like im getting new axles
- anyone ever use any of these?
- lost wheel lock
- fuel filter pita - HELP trying to replace
- Strut bearings on Ground Controls?
- Idler Pulley Nut Stripped
- INFO on a GOOD starter for a 4th gen?
- 245 + 2" drop?
- Clutchless Gear-Shifting--Does it hurt anything? Why do it at all?
- Idle surging problem on a cold start...
- Is Winter Over ??
- Knock and O2 Sensor Heater Circuit Help!!!
- A32 I30t vs. E90 328i
- Trying to make my car safer
- Loud Clunk Upon Acceleration/braking
- 4th gen parts used...different forums?????????
- Whats the REAL diff between 95 FED and 95 CALI spec?!
- AT Transmission Pan....HELP!!!
- Can someone HELP!!!
- 5th Gen FSTB on 4th Gen
- Which NGK spark plugs should I buy?
- Is my starter going bad?
- another R34 retro
- humming sound - need input
- what is a bank 1 sensor?
- Can Back Pressure or an Exhaust leak cause low idle and stalling?
- Time to flush coolant before the summer, how much?
- PCV valve quality differences
- Anyone done a flush retrofit before?
- wow you do really cut up your hands...
- OS front and rear
- what happened to the Code sticky
- torn flex section on y pipe
- Front Brakes pads and rotors. Should Replace or Repack Wheel Bearings
- CEL Code P0010 and P0400
- hazard light question about disassemble.
- Side Mirrors Defrost?
- CarPC is done!
- Hard Starting
- Tie rod end popped out, steering rack damaged
- what kind of video headunit do you have or like
- Spark plug problem...need advice (how to fix)
- Tockico Illumina HELP
- What catback exhaust do you have?
- Fixing Up Car - Need Advice
- Micro vision screen Q's
- Proper touchup paint application?
- Fog light installation on '96 GXE front end
- In the middle of changing Knock Sensor, need help
- 00VI egr plumbing
- Name these wheels
- My AMB Button
- HID installment question
- Suspension mix and match question...
- Low idle, when stopped at lights
- ya so i got ripped off
- Need Help On A Size....
- seafoam power steering???
- what fluid goes in here?
- Help! an engine bearing on it's way out? :(
- Poor Maxi had a rough day...
- headlight poll
- I need o2 sensor opinions.
- spark plug indexing??
- Easy Out a Simple Solution?
- What chip should i go with?
- So I finally got my auto-folding mirrors from Japan.....
- Switch from Mobil One to High Milage?
- EVAP System Question
- The Fruits of my Hard Labor!!!!
- Question about tires on 4th gen
- Weird brake problem, need advice
- Rear window spoiler... Painted or leave it?
- My poor maxima.....
- Back Pressure vs Exhaust Velocity
- How important is it to torque to spec?
- Who to trust for a tune-up of the Max?
- Need a new car. PLEASE LOOK!
- they said it couldn't be done...BUT yeh
- What could this noise be??? (3rd time posted no help)
- Manual to Auto Swap
- 3 Intensity Bulbs????
- Car dies...please help.
- 5 MM Spacer question
- Should I expect better 1/4 from vlsd 01 ae trans?
- slow tranny shifts
- Need Help in Denver-
- Are calipers easy to install?
- Hids
- Does Bosal make good exhaust products?
