- Illumination on Auto Climate Control Buttons Stop Working Again
- HOW TO: ADD HEATED SEATS & Interior Overhaul
- White Smoke From Exhaust
- Problems with 5-Spd
- Wheel Lock Fitment
- Is it Repost day? WTF?
- O2 sensor 2 BANK - 1
- Creaking noise only at high speeds?
- New Clutch: Am I hosed? Grinding noise while accellerating
- I tried to but it in maxima disscusions but i couldnt so...
- what does this code mean?
- Burning smell on highway?
- Mysterious Battery Drain ??
- Low idle,stall on startup-fixed!
- Which 02 sensors typically fail on the 99 Fed-spec cars?
- 00VI vs. MEVI
- 99 coils got the best of him
- 2200 Km road test.
- want to hear exhaust vid... sp2 and cattman headers
- Rear Sway Bars
- Taillight Removal
- key value clutch?
- Greddy SP2 Clip
- the clutch and flywheel of choice
- MEVI installed with Technosquare ECU
- Finally did my knock sensor
- Question on cleaning my Head Lamps
- Wheel Locks
- brakes sticking
- Should I opt for Alignment with Slightly bent front sturt
- RPMS hang up then drop...5spd
- Squeaking noise in the rain
- Pics of Sterling Mist with CF Hood
- Oh just wow... v. Midas techs are morons.
- HELP with weird tire leak
- Seafoaming...what Are The Benefits And How's It Done???
- rear strut tower bar?
- Fog lights burned out by HID kit?
- Aftermarket antenna?
- Air bag light blinking
- Oxygen sensors
- I need quick help (oil pan problem)
- power steering belt
- eBay rotors
- custom enterprises?
- how to break in new clutch/FW?
- I Sold the Maximas
- Gas tank pressure
- Spark Plug question
- cold start sensor for 1997 Nissan Maxima
- exhaust question
- ecu question
- code 1003 help!
- AC Problem
- Oddest shenanigans today... read inside!
- Can't find TAM screw
- How hard is it to change A32 accelerator cable
- Advise me on prospective purchase
- ☼☼ AC PROBLEM, Help please!!
- studdering problem - MAF sensor - Please help
- Where to get flex sections?
- Whenever I go over 50mph
- Tranny/Drive Shaft Issue
- stillen body kit out of shape
- Check out this video (poor max)
- Apexi WS2 (97-99) owners... help!
- Am I missing something or...?
- Changing Break Pads and Rotors - Which ones to chose?
- Feedback regarding ebay tails needed...
- NOOBIES: "I AM NEW HERE BUT HAVE A QUESTION" thread. Read FIRST post BEFORE posting!
- Demand!
- So i got another one under my belt.....
- 9004/9007 conversion
- Screw missing on ecu, cant pull codes
- Got a 2nd car while my max gets its tranny rebuilt.
- 96 EVAP system question
- Need advice with changing strut / jacking up the car
- steering wheel "ding" noise
- Violent shaking below 2500 rpms.
- code 400 egr..........
- Which Clutch would you recomend?
- 5-Spd Gearbox Trouble
- need quick help (workin on car now)
- cattman headers
- *video* of my 4th gen with Budget B & Y Pipes & Greddy SP1 Muffler
- Can someone do a quick photochop to my wheels?
- need help wiring heated seats...
- High pitch squealing in reverse
- got some serious issues
- vortech v1 SC
- Drl..
- Bigger throttle body
- New suspension - clarification questions
- Mice... i've got mice help
- Differential Question
- Taking another leave of absence from the org... Iraq tour #2
- Yooooo Two Codes And Im Mad!!!!!!!!!!!!!!!!!!
- changing rear rotors
- Front axles
- I did something pretty stupid today... need help!!
- Warpspeed vs Budget Y-Pipe
- alright, i feel like a complete meatball. (wipers)
- Painting interior
- Tranny w/ Auto Cooler Only
- question about so-called "Performance chips"
- Recharging A/C
- Car stalling / Rough Idle
- My R34 retro - not done yet
- Change black transmission fluid or not?
- Which OEM rims for a 97 Black Max?
- left headlight socket keeps freaken burning out
- good rubber maintenance
- No A/C again
- Gas Tank reading issues...
- Possible timing chain noise on a 97?
- For those that have done the 5spd swap
- **HELP**Bad front wheel bearing
- Universal O2 sensor question/rear o2 sensor
- Door sensor fix, HOW TO w/Pics
- in/out size for catalytic converter
- Help - Squeaking Noise Driver's Side
- Should be a big weekend...
- Misfire, fuel injector problem?
- Greddy SP2 Installed. I got two Questions
- Locking Differential
- Bolt size for driver-side rear manifold bracket?
- Help!!! Car makes loud humming noise and drives rough
- O2 Sensor Thread Size
- The VQ is quiet but is it supposed to sound like this?
- D2 top stud broke off..where to get one..
- PICS finally, of my 2" drop and 350z rims
- N1 STYLE EEVC fully adjustable muffler
- dynomax super turbo muffler
- 97 max passed emissions test but failed MIL/Check Engine light
- 25k on Vpower copper plugs --- pics
- Oil leaking on AC compresser?
- couple quick questions
- Some new pics, microvison,E01 boost controller
- Restoring low-end power
- Anyone gone from Stillen cat-back to Greddy SP2?
- Aftermarket not as big as I thought?
- Install hardware for full exhaust
- Unique Interior and Exterior Styling...
- Fuel Pump On the way out or soemthing else??
- bad day
- suspension/strut/kyb gr2 know-it-alls needed...
- stupid ABS question
- window visor
- Whats going on, & what to do?
- Who makes the best UD. pulley for vq30de(k)
- What exactly is gear oil?
- how to re-fill auto tranny?
- Starting problem
- Y-Pipe -> Cat Bolts
- So i hear that clicking noise from my front struts
- Fuel & Temp Gauge Help
- Transmission Kickdown?
- Alternator trouble, had to drop engine to get it out/ one question
- 01vq ?????
- Worth getting HID on stock Foglights
- going with 9004 or 9007 HID's kit
- Help please! Engine failed to start and now does not even crank
- rant broke my belt tensioner!
- CEL after installing non cat test pipe?
- Who is this, and what all do they have done?
- Clunk noise from front wheels side
- Drivers Window Problem
- CEL 1302. Random consistent blinking. Need help!
- Know where I can get Sanoma Designs full body kits?
- High Beam Fuse
- Split visors?
- HID for cheap
- 6th gen maxima projectors used as retrofits?
- pasanger door wont open with key > help <
- Quick Fix: Loose doors.
- rear axle nut size?
- Brake Calipers
- Climate Control and Bose Radio lights turn off when I turn on headlights...why?
- SFCs on eBay...
- Exhaust smell with windows down
- For those who say "you should search first"
- Cars in P with revs in 1500-2000 and this weird clanging and clunking noise.
- weird headlamp (help)
- A Nice Surprise today!! (Turbo Max) 56K NO!
- Last time: PRCAI?
- Spring Tune Up....what do you think?
- o ohh .... um airbag
- VQ30DEK Swap - Drilling 00VI
- Knock sensor code only when using a Scan tool?
- My Maxima lags like 56K, i think i know whats wrong
- Quick Starter Question
- Passenger Visor
- OEM front and rear bumper
- Sludge While Draining Oil
- For those with an Air/Fuel Gauge...
- Lower Radiator Hose Came Off
- Where is the "inhibitor switch" located on 1997 Maxima?
- What compares exhaust wise to cattman
- 92 Octane? Less?
- Car Wont Start Need Help!!
- Cattman headers installed
- Code 01 11, EVAP Control System/Flow.......What to do??
- what would you pay for this car.
- rear suspension toe-in and front camber
- need some help
- Warpspeed catback magnaflow or the clone Q'?
- need some help
- Fuel Injectors
- Can You Tell If This Is A Rear Main Seal Leak?
- Fender Rolling TECHNIQUES
- KS Wire Harness or Knock Sensor?
- code 504 need help from guru's
- Transmission bearings?
- Clutch Hydraulic Line Problem
- Torn Y-pipe flex jacket
- Catalytic Converter/rear o2 sensor.
- '99 150K tune up, bad coils too...
- need stronger spray paint...
- motor experts step in...
- Are bad rotors a maxima chronic problem?
- Custom Enterprise
- ECU problems
- Anyone Have These Rims On Their Maxima?
- 02 Sensor Wire Length
- HELP hard start after pulling tranny.
- HELP, locating new badges/emblems
- Should the ECU look like this?
- quality of innovatek
- 18x8 on Stock SE Suspension?
- IACV or TB
- Finally I got myself a 5spd, Black on Black leather...
- Auto tranny swap
- adjusting fog lights
- Electrical help needed. Tach pegged and won't move.
- AC compressor
- TCU Code tps short circuited
- Proud of my max!!! can yours do this?
- @*$## ! Lower alternator bolt
- Stalling problem
- Catalytic Converter Options?
- Help with P0400 error code
- Header Question...
- Buying a max - Checklist?
- 95 and 99 interchangability
- Rough brake pedal but no shake
- auto trans experts come on in
- Question about Center Bore
- Looking ahead at mods
- Cold Air intake
