- cefiro install
- Intake Question (not a newb question)
- how do i secure my license plate..
- Motor mount question
- FINALY put on my ksports
- 17x7, +18 offset...stick out?
- Z rims
- spoiler or not
- Exhaust heat shield
- awesome day.....
- removing gum from seat!!
- Opinions on O2 Sensor Idea
- Bright corner light question
- Cloth Interior pealing off
- Leaking injectors?... need help with white smoke coming out of my hood
- Help about a sound my car makes when trying to start
- Possible bent frame
- Torque Sensor?
- car show sunday
- 17x8 wheels w/ 225/50 tires
- Need front suspention advice
- Anybody have Haynes or Chilton repair manual in PDF
- Car Blew Up Last Night
- y-pipe/cat bolts
- thoughts on this turbo kit??
- 0101- Camshaft sensor
- A/C problem. Compressor won't turn on
- Killed tranny lastnight
- Which brand clear bumper signal lights?
- Valve Cover Gaskets
- a/c problem update
- 100k miles maintenance
- How much is my car worth before totalled?
- exhaust Question
- Torqe specification interpretation from Haynes manual
- sideskirt question?
- Starter acted funny.....
- Timing Advancing
- Explanation Please
- Vehicle Speed Sensor HELP PLEASE!!!
- Question about brake rotors
- The ring on my Nissan keybroke....both of them. Pic included
- Ext. Lights dont flash when i use my stock keyless entry to lock my maxima
- ebay Catback
- Transmission Temperature Sensor
- Its a sad day today..... the cars smoking bluish smoke..
- How Many Orgers??
- main seal leak- related to pcv valve?
- Check Engine Light On
- My predicament.
- Help With exhaust noise
- no keyless is getting really, really old
- ECU reset?
- Anyone ever hear of this catback?
- Repair cracked headlight?
- NISsAN FAST need someone who has it
- Correct me if I am wrong...
- Maxima front end conversion
- exhaust
- NEED Antenna help!!!!
- axle replacement Q's
- stock lug stud length?
- Err...help me(?)
- Belt question!
- Accident discussion
- 96 maxima red/clear mod
- Need help with codes. Cant figure out the problem.
- Oil Pressure Switch question.
- Tein Basics Question
- clunk noise from behind center console
- Carbon Fiber Trunk
- Injen Cold Air Intake
- Help Needed ASAP CV shaft
- Kyb Agx guys...................
- GirlFriend hit big pot hole... car now shuts off in gear or in nuetral
- '97 Owner's Manual States About Brakes...
- springs springs springs camber anyone?
- Lighter alternatives to stock muffler?
- New Toys! Should be a good couple of weeks...
- Grille question
- 97 tailights on 96
- Key fob. What are our options
- eBay foglight question
- 2 or 4 wheel alignment?
- Thoughts on grille
- Front end damage
- 1405 spin-off
- sunroof
- Custom charcoal canister
- Clunking in front end >>??what is it?
- Tokico Illumina guys...
- Changed Fuel Filter **Pics**
- Flex section on y-pipe
- Question on front seat / bracket
- what kind of loan did you get stuck w/
- modding huh
- check engine light question??
- Clutch/rear main
- Windshield wipers dont work?!?!?!
- Mud Flaps
- What type of gas do you use?
- Removing Fog Light Glare Shield (how-to)
- why two codes?
- owners manual
- Pics of the new ride....
- max broken into in broad daylight
- Is a CV boot easy to replace?
- Aftermarket mufflers?
- Hesitation when it rains
- Foglights but no switch....
- Installed Stillen y-pipe; Has bees-in-can noise
- Ignition switch installation
- Heads up display
- new pads and rotors.. ftw!
- Brake Pad Questions
- fuel pump question
- intake hoses
- 300zx seats in a max?
- 99 max GLE wheels going to 04 350Z enthu wheels
- Weird sound when turning the wheel
- Replacing Seat Belts
- 95/96 owners: who babies their car the most??
- Changing the Oil Pan Drain Plug Washer?
- Knocking Noise coming from Front Passanger side when in 1st and 2nd
- Memoirs of a new Maxima owner
- OK, so how much will I be spendin...
- Ok guys I need help this is driving me crazy.
- The Tranny Trick Drop Resistor
- How much can I get for my Max...?
- intake question
- rear wheel bearings
- Can't get calipers back on with Hawk HPS pads
- Small Mods, Few Pictures.
- Problem Changing Fuel Filter
- Custom Enterprise Closed?
- does SES light come on for 60k service?
- High rev's that important?
- Not Your Typical Intake Question Thread...
- P0420 (0702)
- Waterpump replacement Sucess
- I need seats...but what?
- David L Taillight R.I.P. - Next best light?
- Removing the black plastic cover that is covering the side view mirror bolts
- watch out for this scam
- Advancing odometer
- part numbers for seals
- Search doesnt work, Auto to Manual question
- need a better ride
- cant figure out these 02 sensors
- Can't find access to upper rear strut bolt
- Repairing a MAF
- Guys looking for chrome inner door handles...
- Exhaust in my hood?!
- Transmission Bolts
- Just found out: My 97 Maxima is really 97 Nissan Lego ?
- Need some help. 2 flat tires
- ideas for shrouds for is300 projectors in 4th gen fogs
- @#&*@#$& Tranny leak
- A/C Help - Temp Selection Switch Not Working
- Bad gas mileage. Please help. =)
- strange knocking
- what would be the best oem Bose deck
- Taking apart rusty exhaust bolts
- SFC's are available!!!
- Windshield replacement
- air intakes
- Stock Bose Speakers
- Dimming lights
- how many miles possible?
- clutch problems
- I've had it with my max
- Max Vandalized!
- Why did Nissan not use the VQ30 in the Pathfinder?
- NOPI Nationals
- 1995 Maxima GXE Hard to Start
- Stillen Sound Clip
- website request
- Shifter Bushing Part#???
- anybody ever seen these rims on a max
- So I'm thinking about buying a Y-Pipe
- 95-96 Grill with a 97 Front Bumper.... Please chime in
- so my car turns of after i race?? what the hell?
- Wheel diameter + Speedometer question
- Time to say good bye…. How much should I ask for my Max?
- D2 coilovers... Anyone interested?
- Looking for a black or carbon fiber hood for my 96 max
- rattle on hard accelaration
- High unstable idle after cleaning IAC
- ok this really is getting obnoxious...(strut 'top hat' bolt)
- Failed CV joint?
- Weird noise, sounded like air seeping out
- 97-99 taillight harness
- Cat. Converter or O2 sensor causing hard starts?
- Losing MPG and quick.. read!
- Slight dilemma, need advice
- Is there anyway to fix Urethane?
- Ripped seats. uhhhhhh!!
- S F C Review Thread
- ProLong any good?
- Annoying little thing
- cabin air filter?
- Tranny problems??
- Deft Racing CF hood
- Knocking noise coming from driver side....
- Car Wont Stop Running - Help Please
- PPL who have replaced/rebuild their auto-tranny step right in
- stock throttle body size?
- License Plate Lights
- How to pull engine wink
- Knock Sensor....to replace or not
- Rubber parts around courtesy light switch (door switch)?
- Lugs coming loose. Don't know why.
- turbo kits on ebay?
- What parts die regardless of miles?
- rear main seal
- cv axels??
- Knock Sensor Code not clearing?
- Thanks for all the help
- 4th gen /5th gen
- misfire, fuel injector replacement, no start
- Turn Signals Don't Flash when Locked with Remote FOB
- MAF sensor needed ? ? ?
- water pump removal help....ASAP!!!
- 00VI, 4th gen TB w/ stock intake- anyone?
- How f*ucked am I
- Cruisin 4 Taylor Car Show - Jacksonville Maximas
- 96 ECU in 95?
- Rear 02 sensor
- Motor oil in Air intake midpipe
- MPG Increase (Proof)
- hubcentric rings
- Momo Shift Knobs
- Need Help Removing Seats
- electrical>>??????Please help
- Next Best Mod?
- Lug Nuts Question
- lets see your exhaust 4th gens
- i hate ECU codes how do i fix this one tho?
- 5speed swap question
- 1pc headlihgts review!
- Best way to install an OEM spoiler?
- No muffler at all LOL
- Soft brake pedal feel
- What to look for when buying a 4th gen
- Timing Chain replacement?
- how easy is to change the power steering fluid?
- Illumination on Auto Climate Control Buttons Stop Working Again
- HOW TO: ADD HEATED SEATS & Interior Overhaul
- White Smoke From Exhaust
