- Tires Tires? What kind to get!
- is this an elecrical problem or what?
- Fitting issues
- So that battery light + brake light still boggles me...
- Avoid ramming SUVs, or this could happen to you
- HELP rear bearing replacement
- Studdering, Vibrating Brakes
- ticking from engine
- Intake q's
- Bose Headunit tape player problem
- LSD! Woo-hoo!
- Hey Tranny issues 97 auto max
- ksport clunking noise....
- Bypassing Bose Amps
- Radiator Frame Support Rotted Off
- Rear Brakes - Need help
- can i get a picture of a stock battery terminal
- Call For Hid Retrofit "Contractors"
- spark plugs
- Is this a worn clutch disc?
- Failed NY inspection
- New R34 headlights causing problems already
- parts from 94 Q45
- Misfire - Coil(s)?
- How to setup summit rpm switch on the road more accurately
- Look what he did to my car
- BUDGET B PIPE BANGING on GAS TANK
- carfax report pleaseee
- wiring?
- Can this really happen????
- hissing sound behind radio
- Keyless Entry Module for a 95 - help needed!
- Need TECH opinion...codes P0400,P0138(egr,o2)
- what side skirts are these?
- CAI question...
- Big brakes stop well and make me happy
- Grinding when entering 2nd Gear
- Popping/Clunking when coming to a stop while going slow.
- Will a sunroof assembly from a 94 (3rd gen) maxima fit on a 95 (4th gen)
- Junkyard
- How much would....
- body kits advertised on web...legit?
- So I was doing this...And noticed this...
- Cleaning Stock Glass Fogs (97-99)
- 87 octane causing hesitant acceleration? ses light?
- why ?
- g35 wheels
- 350z Wheels on the RED Joint Pics
- A Productive Morning
- haynes or chiltons?
- Pedal travel versus throttle travel
- Need Help with my IACV
- Max is Detuning itself
- Fog light projector retrofit?
- How do you like your B&M ?
- somethings wrong??
- Will my wheels clear a BBK ?? PICS !!
- Question for you Paint Guys ??
- Spacer for 4th gen?
- FOB Remote - roll ALL windows down (and sunroof) -- is this possible?
- why no recall for coils???
- Plastic oil pan cover hanging
- hissing sound coming from shifter
- car cuts off when place in drive
- car makes a whining sound
- Serious problems with BBK.
- I'm now a proud owner of a RED!! 4th Gen
- check out these gauges..
- How do I adjust the timing on my maxima?
- horn
- 300Z TT UIM Swap
- CE Clear/Black Retro
- Today was my birthday 5/2/07 so I treated myself
- clutch opinions
- What rpms to shift at for optimum gas mileage?
- help blue maxima running bad need help engine experts step in
- Cai
- Low end torque
- wd-40 works on the antenna?
- Tranny leaking after Drag Racing.
- 4th Gen vs. 5.0 Gen
- 99 Max - Multiple Misfire Code - Not Coils
- driver axle side didnn't "click" in, do I need to take everything apart now?
- Oil on the muffler + Stalling
- Emission test hook up...
- ebay oil cap
- opinions: N/A or N20
- Have you bought a Nismo shift knob? If so, read me!
- Front strut mount question?
- is it the axle?
- will a 4thgen steering wheel fit a 3rd?
- 97-99 with red/clears spotted in Subway commercial!
- Horsepower Gains
- Can water in the gas tank cause intake backfire??
- Paint Faded on windshield wiper arm
- new mod! 6 home link buttons!
- Need help diagnose
- HOW TO? Replace foglamp bulbs???
- Replace Valve Cover Gaskets?
- does all bose radio work
- Best Year for 4th Gen? (97-99)
- Who knows about clutch line?
- Camber question
- FSTB Fitment Issues
- Catalytic Converter Bracket?
- HELP! Headlights not working
- Jerky Acceleration with Autotragics
- Spongy feeling brakes?
- snapped lug stud... what's to be done?
- Wtf!!!???!?!??!
- 95-99 cps interchangable?
- UMMM......Is this bad??
- need help???
- How do you take entire headlight out?
- Where is the MAP sensor?
- 17" Ftl
- lower RPM's for $$cheap??
- Kinda stupid...Dorr hard to open..how to fix it...
- whats to come of my max....
- Power loss after 80 - 90mph
- removing the refractor in the fog light.. .. ..
- Exhaust Question
- may sound like a stupid questoin but i was just wondering...
- ECTS & Exhaust question
- 4th Genners... need your opinions
- Brake rotors are threre and diff in perf??
- Exhaust sensor pipe
- What is it called? in the fuse box passenger side
- advanced timing
- My header arrived today...
- Starting Probles... CEL Codes keep coming back... Running out of ideas...
- What is this hose and why is it crucket? *pics*
- tranny problem plz help
- Just got new R34 headlights! Come in!
- Hawk HPS PART #
- car just died, who can guess y?
- Engine knock when accelerating from idle
- car starting issue
- Tired of Changing Parts
- 3rd Gear. . . .
- Good Deal?
- Springs question
- keyless entry
- Does anyone have the Megan Dual Fireball on?
- headers?
- 3.5 a/t swap
- Best Low dust brakes?
- engine coolant temp. sensor
- service engine light poped up
- using KY Jelly on the maxima
- Stalling question
- buying a specific piece of the gauge bezel
- Another starting problem ~ ...help?
- how to know when ignition switch has gone bad
- Where to get Cat bolts..
- Code B6
- battery relocate
- which way should i go?
- Stock Intake Hardware
- respekt
- for those who have the short ram intake.....
- Just replaced the alternator and now a CEL!
- flashlight mod
- o2 sensor
- engine knock
- Wiring And Aftermarket Steering Wheel
- $350 Shipped for 5spd Tranny?
- tax refound
- going back to stock...
- "No fat chicks!!"
- Should i get this radiator or not?
- CEL...Cat converter or O2's? HELP!!!
- Clearence issues, any ideas?
- Crank sensor??
- batery light blinks at WOT......battery, alternator or what?
- Brake light problem
- J and S safeguard check engine light fix
- Combined group buy on Truax Motorsports SFCs
- catalytic converter stock inlet outlet
- reverse indiglo gauges wiring question
- EGR Temp and TPS codes KEEP coming up WTF?!!?!
- So exactly how much oil will leak if...
- 96k mi on Fuel Filter observations
- nissan rear brake calipers
- Trouble With Wheel Caps
- Drone Or Not?
- New Jersey Statutes - Question
- How to Install Clear Bumper Lights
- Brake flush with DOT4 fluid
- exhuast is going :-(
- Some KS info to pass
- I hate immature little kids that think this is fun!!
- Best Place to Buy 300ZX Calipers ??
- Hey Maxima Buddies!
- Question about the "next" mod.
- This is in the wheels and tires section but not getting many replys
- Steering wheel cover
- 5 speed swap wiring question
- IONIC DYNAMICS Kits?
- I Really Need Help This Is Costing Me A Fortune...
- What is the proper way to install the valve cover gasket (front) see picture.
- 9007 tips and trick for seating bulb
- How do I remove my steering wheel with airbag?
- Autobody guys: Every heard of "paint variances?"
- quick o2 sensor advice
- How to change Starter
- how to get key mark out
- 10 Percent Ethanol
- best prices for coil packs and fuel pump?
- Speed sensor
- Knock Sensor
- 1999 Cali Spec O2 sensors
- check engine light will not turn off!!
- how do you paint this part
- Front Lighting - Post Pics!
- KS - CEL issues
- a/c blows hot!
- Code 0603
- Problem with A/C on 95 Max
- Do you have major problems with your car?
- daytime running lights wiring? projector mod
- help w/ installing ebay cai
- What did I do to my gauge lighting?
- Myth busted - dynomax superturbo
- Flushed transmission now it slips
- What part is that?
- Arrgh!! Alternator!
- No CAI, other options?
- yay cel!! (with codes)
- Rear wheel bearing/hub assembly
- Drop question
- Carfax
- can you test the crank POS harness ?
- CEFIRO 1 Piece >>>'second bulb' Q's<<<<<<<<
- H&R Drop question
- rpm's
- 5 speed (swap) questions
- Needed: Rear Tail light
- A PUSH GUARD? on a MAXIMA?? .. :-)
- Recommendation on headers?
- Look at what I did!!
- ok question of preferrence, but more of maxima respect
- Read this for a chuckle
- Hey need some help
- High pitchED whine coming from brAKEs (edited)
- Noob question on grounding
- Sp2 catback or....
- steering rack boots torn? Should I worry?
- suspension install in progress
- exhaust mount?????
