- It runs!
- 5spd swap - CANNOT Build clutch pressure
- Need Help On Big 3ish Upgrade...being done tomarrow
- I need your opinion
- Questions about JWT intake
- Painting my bumper myself, ur thoughts please
- Orange wired in fuse box
- bose q's
- Fuel Pressure Regulator
- what struts should i buy?
- Help ASAP from anybody who can look under their hood
- HELP!! Exhaust noise and question, Apexi
- Slight kick/rumble when car is at a stop
- Will a 6spd fit in 4th gen?
- Good Bye 4th gen.....
- finished interior lighting (pics)
- Alternator fix
- Knock Sensor Resistor Mod
- radiator hairline crack
- Changing Oil Filter Without Changing Oil...?
- Holy S!@# what happened?
- starter selinoid or motor???
- CV Joints
- car wont start
- Addco rsb 4 97 Maxima....Help
- Hard start after clutch job.........fixed?
- interior lighting question
- Headers, do i need a new clutch???
- Neutral safety switch?
- Can the pass. airbag be installed with the dash still in place?
- Stalling Issue - Just started
- what causes o2 heater curcuit to malfunction
- Oil filters...
- Axle seal... I am ready to torch my car...
- fog light bent in!
- Sound of ball joints going bad?
- '99 maxima gxe or '99 accord v6
- Getting P 135,141 And 155 Codes Need Help!!!!
- Red/Clears 95-97 conversion question???
- 120 Amp Fuse
- besides 300zx...any other bigger brake conversion for Max?
- leather door pillars
- Fog Light Question?!
- I can't find my f888ing egr guide tube.
- Gas leak from Gas tank, what are my options?
- "Dead spot" around 1.2k to 1.5k
- Oh noez i gots the codez
- Whirring during acceleration
- Do 4th gens have resistors in window switches?
- VERY cheap and legit-looking HID kit
- help- brand new axels installed... vibration
- Optima Size
- Help me pick "rim" please
- Is this all in my head??????
- Factory alarm beep help!
- I need work done
- compressing rear brake pistons
- 4th gen 5th gen headers.
- soo uhh...where can i get a cheap front bumper?
- firewall question
- smoke coming from pcv. plz help asap.
- are brakes a common problem for this Gen of Max?
- Suspension install??
- Emergency brake light on???!? weird prob.
- Anybody do the Auxilary mod?
- Help w/ Oil Pump/Pressure
- gauge mounting position
- How do I remove the timing chain cover?
- changing the rear brake pads... do I have to unhook the parking cable?
- y pipe question
- Vent Control Valve? WTF?
- On my 3rd Max, considering a jump to a new make car...
- Question on struts
- *Pics* of paineted lower rad support, wiper arms, and hubcaps
- Proper Idle RPM for '99 Maxima & Odd engine behaviour at idle
- 97-99 grill
- cracked bumper and Ideas?
- Removing IACV...risky business???
- yellow headlight bulbs?
- Budget Y/B Pipe + Cattman catback..
- Removing drivers axle from Auto transmission
- New Hood Struts = Amazing
- Bose Rear speakers. wiring
- ebay used remote control units
- Another CEL light, HELP!
- Help!!!! Bogging!!!
- Quick O2 sensor question
- how do i get to my foglights?
- Lowering front engine support by 1/8th of an inch a problem?
- HOw to make a custom valve cover
- RPM Switch "Weatherized" ***Pics***
- Degenerate Bas+ards
- Greddy sp2 size under 2.5"?
- supercharger question?
- Live Chat Room
- Starting problem, could it be the ECTS?
- y-pipe knocking on crossmemeber.
- Hazard/Rear Defrost Button Lamp Replacement
- pulled codes today, got an 1101 and I'm a 5spd, huh?
- Leaving 4th gen forum: My sixth wreck in my maxima
- need new engine...will an engine from an auto maxima mate to my manual tranny?
- How to get to the throttle body
- Strange noise (suspension?).
- Remus Muffler
- What is the stock 95-99 Throttle Body diameter?
- code 0502?
- Help! with this Part Number
- Swapped Engine, now overheating
- leather question
- Clutch Is Fux0r'd
- Gentlement, it has been a fine time...
- Rear driver side caliper?
- Looking for input on 5.5 gen muffler on 4th gen
- Rough 1-2 shift on the auto transmission help
- Pushed the Max to Auto Zone yesterday and...
- So I Was At The And........
- cleaned throttle body, now low idle speed.
- Problem/question with centerbore
- 98 Starting Problem
- 96 4th gen stock drop
- best way to clean Apex-I Filter (frankencar intake)?
- Fuel cut off line? Car kicked back at high rpm
- Carbon Fiber Hood Suggestions
- Low speed misfire?
- Where to buy Mass Air Sensor
- Sagging rear end (I are teh suck at thread titles)
- premature front tire wear....do I need camber bolts?
- best deal on a radiator?
- Egrc-bpt Valve Where Can I Get For Cheap?
- Event data recorder in our cars?
- Great News!
- clutch replacement!!
- Blower motor is not working ...
- Idle at 1500, no codes....????(5 speed)
- Wonna do some interior lighting
- Brake lines
- Clearance Light Issue: Dim Setting Only
- What to look for in maxima?
- CEL codes.....please help...
- License plate screws - rust-proof
- any one have the rewired fogs along with h3 hids?problems.
- Maintenance / Tune up recommendations
- 3.5 Swap
- intake question
- tire size change for 17 inch rims
- Disappearing CEL light
- Wilwood BBK for 4th gen
- installing foglights question
- Need help ASAP, injectors, coils NO POWER!
- Idler pulley replacement
- Budget B Pipe = FTL.
- k sport springs vs. s. techs
- when hot cranks forever before start up..
- Visor Light
- Mandrel bent vs pressure bent
- why are my signals flickering sooooo fast?
- My O2 has me O for 2
- 99 Serpentine help!
- stock bose tweeter?
- Removing ash tray!?
- Took out passanger seat w/ airbag... reinstalling???
- who can rewire fog lights
- 00vi swap > misfire and vac leak
- Burning smell, some white smoke from under the hood
- VSS not BUDGING??
- Need help: R34 retrofitters come on in!
- MEVI question
- Unorthodox UDP
- Fuel Injector Question
- Strangest Rattling noise behind glove compartment area
- a few more 5 speed swap questions
- CEL: Codes Pulled P0440/400/325/P1448
- noticing some engine symptoms..do I need to worry?
- I believe it is a bad strut!!!!
- anybody ever had EVAP Canister leakage?
- Removing UIM and LIM
- replace carpet?
- mirrorman
- Tranny guys, help with auto tranny issue!
- Are the ebay glass headlights any good?
- Replacing front AT motor mount with MT mount
- Car would not start
- e-brake boot.....
- Seat covers...
- Noise from the rear
- I think my TPS is shot
- weird noise coming from rear beam
- car turns off in drive
- Would i be able to replace an A/C condenser
- Location of 3rd coil
- engine swapp questions
- Alarm Remote / Corners (near headlights) don't work
- installation prep...99 max gle fog lights
- hazard + Rear Defrost switch bulb?
- totaled maxima
- power steering fluid capacity?
- Various Minor Issues
- Misfire... help please
- Cant take the squeeking anymore!!
- Injectors
- Oil leaking, level staying the same...
- Another brake bleeding issue
- HELP: Slave Cylinder related probelm
- Cops....:( Where can i get a aftermarket license bracket
- For Sale: 95-99 v6 DOHC parts
- Changing guage bulbs
- front end steering issue
- upgrading ground wires?
- injector removal problem! Help!
- custom trunk lip
- A/C Problems
- Cornering light EXTRA WHITE
- Problems when adjusting clutch.....help!
- while the engines out... what to do???
- RPM go up when trans is in Gear
- Anyone have... (wheel question)
- Burnout with 4th gen
- how exciting... a grease question
- Chrome grille?
- HELP!! Noise all over the front end...
- Gearing up to swap Interior LED's
- Question for the 4th Gen Guru's (Re:AirBag Module)
- Mini HOW TO: How to cut stock shifter
- Am i getting RIPPED OFF??????
- For those who installed their stillen kit theirselves..
- car wont start after battery disconnected, security problem?
- rear bumper question?
- y pipe: legality
- BBK installed but problems!
- whats the rubber ring on top of our springs?
- this is funny, read the ad 1998 Maxima GL 3.3L
- need to improve gas mileage!!!!!
- 1994 Car and Driver Maxima Roadtest magazine
- Cel 0512
- stillen kit...what foglights fit with it?
- need some Oxygen
- N/A power
- Axle nut coming loose??
- What do you think about this style bumper for a 4th Gen ?
- enhancements to my car
- Replaced fuel injector and...
- simple question simple answer I hope...
- Drive Axle Problems & other suspension problem
- fog light bulb socket?
- clicking when ac is on....what could it be?
- Any link or document that says how to open different kinds of electrical connectors
- mixing injectors..
- Saying goodbye
- Battery light on when key is NOT in the ignition...
