- Intake removal proceedure??
- 97 Magnaflow cat work in a 96???
- passenger side cv axle installation help
- how do i find the Nissan part number for a CV shaft?
- EGR valve to cap or not to cap?
- Maxus SFC sale
- Anyone see that Vq30det Sawp??
- Injen Intake -- not so bad afterall
- Do I Need new grommets/brackets for my radiator?
- question about shaving emblems..
- Auto JWT Ecu in 5spd
- Starting problem.
- best matching headlight
- Need some SERIOUS help. Put on your techie hat and help a brother out!
- Have to sell the max
- gear noise
- Suspension squeaks
- anyone buy the front end set from ebay?
- Pics of Max with only front spoiler
- Tire pressure when hot: fronts vs. rears?
- Good store (where)
- Door Inserts
- Couple quick code Q's
- Installing power seats in a nonpower Maxima
- To those who retroed TSX projectors
- looking for underdrive pulleys...advice
- A nightmare in Hesperia CA
- Mega squirt?
- Pic Requst:DR Mod WOT switch
- My Es300 fog retro.. I need help
- Lights on Ebay
- yellow fogs; yellow tint film
- jacking up a car with strut bar/torque ?'s
- Sway bar sway to much!!(rant)
- New exhaust and air intake (HELP) suggestions please
- strut cushioner bearing.....
- Shaking Pedal And Car!!!! Help
- Bubbling noise from coolant overflow
- Changing Base Timing
- transmission
- Found where oil leak is coming from!!
- Got sound? - The process
- wiperss on 4th gens
- Motorized Trunk
- Tranny Problem Getting in To first gear
- A/c Compressor Clutch wiring
- diameter of power steering return hose
- Sloppy/Loose Steering...
- question concern rear wheel hub/ bearing
- Is This A Good Turbo Kit?
- Changing Belts Tips
- Changing Front pads and rotors.
- Noise (low pitch whine) near idle
- 5spd flashing O/D light?!! hmmm
- Help Me Decide! D2 VS Ksport Vs GC With Konis
- 4th gens on 18's without a kit
- Heated Leather seats conversion
- Hit and Run!!
- Wheezing noise on acceleration
- SunRoof deflector
- ECU gone for Broke, now what?
- High Idle now
- Tap size for O2 sensor?
- wiring o2 sensor help
- Whats the difference in these springs
- How to change brake shoes?
- Help CV BOOT broken still driveable?
- Keyless entry(the clicker)
- Heat risers for exhaust headers -- do they help?
- Cigarette lighter doesnt work?
- projector guys
- jealous civic driver
- Big Problem help!
- HID retrofit harness question
- seat motor wearing out
- odd cold start and oil level sensor problems
- Getting an Emissions Test Waiver
- wtf - ss clutch line - am i just new???
- Car is totalled..
- Stripped bolt
- fogs refused to open
- Oil consumption
- Could this be possible ??
- No more MAXUS for me!
- Super Glue Issue
- Boot!
- Rear Bumper
- Bi-xenon wiring ???
- Starting Problem Looooooong Starts
- Pre maxus subframe deal
- How many miles??
- Turbo or 3.5 swap?
- exhaust help
- Rear strut easy fix?
- muffler opinion off ebay
- Need Help With Exhaust Leak
- i dont know what happened but...
- 97-99 red/clears
- Air Conditioner performance
- kn cone filter
- eBay Testpipe install
- H3 HID (not h3c) in stock foglights?
- Airbag ??
- HID Bezel, which one did you use? Or, did you make your own?
- GI:A32 JDM Cefiro Dual Piston Caliper w/ JDM Nissan Brake Pads
- tint your tail lights
- fog lights
- Seafome works
- hypertech tuner question????????
- The bad luck just continues.. guys
- Egr flow?
- Wtk Lsd
- Any reason for this extra cost?
- what muffler is this??
- throttle bodies
- Need info asap passenger side axle bolts
- Seating problem.
- Sunroof Needs Repair
- Help me decide on suspension...
- Put in 470k Resistor, but 0304 Code Returns. Help!
- HID Conversion Kits on ebay
- has anyone bought aftermarket o2 sensors w/o a connector?
- Painting Valve Cover
- Springs
- 3.5 with a 100shot of nitrous
- Tranny Issues
- GREAT Headlight Polisher
- stone racing aka ssautochrome
- clutch noise when going into 1st/Reverse
- help needed ASAP
- CODE 08 01 - what is Vacuum cut balve bypass valve
- Jiggling my shifter
- wtb best coilovers and ride for a maxima
- I need some immediate help guys
- Battery Post Corrosion....Prevention?
- BCM shorted causes nonstop beep
- How long does a VQ last? 138,905 miles, apparently...
- 4th gen with 3.5's chime in
- Replacing Fuel injectors, how do i prep?
- 300zx fuel filter fit comfortably w/ maxima?
- engine removal how to?
- 2 quick questions for u guys....
- Looking for a y-pipe sound clip with everything else stock
- plastic connector for coolant hoses on firewall
- Changed KS and cleaned TB and IACV in one shot
- DR Mod - Kickdown?
- How much transmission fluid did you get?
- F....U.... goodyear
- Auto climate control swap?
- Full axle assemblies: OEM vs. Aftermarket
- serious engine problem! need help ASAP
- ABS Light Went On!
- a/c clutch stuck!
- The "boost Sensor"
- Pulled four codes from Maxie!!!
- rear o2 sensor question.
- Wheel hop
- o2 Sensor on the FRITZZZZ
- Gauging Interest - Lighting Overlays
- How much did you pay to paint your lip kit
- Quick Question: What is the stock spoiler made out of?
- headers and ypipe
- i need to know the size of bolts for slave cylinder
- Bad Alternator maybe?
- Help I'm Screwed!!
- painting a chrome grille body color
- Help!
- Odometer stopped working
- trunk measurements?
- vq35 parts in a vq 30
- has anyone installed a trailer hitch on thier Maxima? Directions?
- is it time to replace my fuel filter?
- Front Brake Install
- Auto VLSD?
- MAF Upgrade?
- 95 Maxima Fails Emissions NOx 1900 limit is 1100
- GI- If I Sell right now, how much would YOU Pay?
- CEL Code 138
- !!Constant Squeek!!
- Good Night, My Max......
- manual transmission differences
- A/C lighting (auto climate control)
- Short Throw
- Borla Muffler
- manual radiator fan control question
- help with a cig burn hole on fabric....
- Rear rotor install question...
- 4th gen Carbon Fiber Hood
- Egr Sensor Replacement Help!!!!
- I have been absent...
- My first mod need some feedback??
- Exhaust Question
- What can i use from a J30 ?
- MAF Sensor
- wtf budget.......
- Need help with spoiler rust please
- I think its my wheel bearing?
- timing chain?
- RPM's Gone Wild
- sparkplugs for 95-99 max...NGK only?
- How long injector cleaners are effective
- Best suspension setup?
- brake problems, many
- windshield wiper arms
- rear wheel bearings
- Common Suspension Upgrade on HM vehicle
- new suspension !!! cant wait!!
- question.
- 300zx 32mm calipers?
- Question for Greddy SP2 catback owners:
- Stalling issue... still
- Performance Decreasing
- Engine code po420 some advise
- stock injectors
- swapping clock with radar detector
- 2006 Q45 Projector Retrofit?
- Brake question
- Cefrio Headlights
- thunking noise when braking
- WD-40 vs. lubricants
- Mechman alternators
- blew my head gasket whats next?
- Strange "chug" when I accelerate in low RPMs
- sunroof HELP!
- 1995 to 1998 Gauge Cluster Re-wire
- Passenger side door arm (very Stiff)
- billet grill for 95-99 max
- Paiting taillights all Red
- Chrome/stainless fender trim - HUH
- !!Winding Sound @ Clutch Release!!
- EVAP Vent Control Valve Diagnostics
- recomended tire psi level for auto-x? (posted here as well just for more input)
- how does exhaust diameter play a role in performance???
- corner headlights question
- 300ZX Fuel Filter
- Scratches need to be fixed
- What do you think about these starting problems? Related?
- Can somebody look at my ride and see how the rims look?
- 1995 max antenna problem
- rear brake problems new pads wont fit..
- 4th gen coilover drop rubbing and fender rolling
- Going to remove TB and IACV for cleaning, need to clarify some things
- Steering wheel ping
- USIM rant
- lowering question
- SE door trim
- My engine die ...
- '96 Max, replaced struts, now odd noise while turning wheel
- Rear Sway Bar
- HID Projector Retrofit information
