- Cefiro Headlights
- Are 99 EGR's diff than 95-98?
- Problems With My Clutch/Shifting
- Slaming jerky shift from P to R (and from gear to neutral)
- Hard to solve problem with popping/jerking, need help
- Got big problem - I can't make thread titles
- IDLE issue after complete IACV and UIM clean up!
- need helppp
- How do I clean the IACV?
- suspension problem advice needed (pics)
- tire advise
- Need help with remote power windows
- My turn signals, burning fuses
- Eibach Pro-Kit & GR2's
- 5speed rpms while coasting to a stop
- RPM drop at stop
- where's the engine oil gone? very low level before 3K
- 95 Maxima SE starting problem
- Wheres the Warpspeed SS Y-pipe+Hi flo Cat?
- How much do you think this car is worth?
- thinking of rewiring the fogs because of short
- do I have 2 bad o2 sensors?
- where is the bank 3 o2 sensor on 95 max??
- se and gle rims
- Coilovers
- After market fog lights
- Does anyone know how to give the maxima an angry look?
- Are 5th gen maxs faster than 4th gen ??
- alternator & battery keep going out need help bad
- Awesome bad discovery? (Exhaust Tip)
- Need help ASAP car stalls....orgERS jump in
- No Power to 96 Headunits
- help with diagnosis - engine mount or flywheel
- What to use to seal Headlights ??
- 4th Gen Paint Poll
- my updated car repaint
- 5spd ecu in an auto
- Crank No Start- Low Compression
- has anyone ever found that new motor oil can do this?
- NEED MUFFLER ADVICE...............
- Whats going on with my car?
- the ultimate question about a Bosal b-pipe
- Clunking noise from front passenger side.
- front end squeal
- Ebay FSB fittment issue
- What's wrong?
- "DTM"ing the inside of the OE Amber Bumper lights...
- Steering wheel balding
- 96 Stumbling and stalling
- LED Front Turn Signal solved
- Need help looking for a 00VI thread...
- making a cai intake
- About to replace a/c compresor. Need advice
- Hesitation after Stop and Stalling Problem
- fixed the TICK TICK TICK now more problems
- Right front fender
- groaning noise when steering at slow speed
- Failure to Launch (Hard Starts)...FIXED!
- Spark Plug "screw-up"
- Car shakes at idle.
- Typical Radiator Life
- can the IACV tick really loud?
- Remote window roll down
- Starting Issue & Codes
- Picked up a Oil catch can @ Home Depot
- Which would you guys get?
- Adjusting Timing Chain
- Looking for complete VQ35 swap for a 4th gen in Tri-State Area
- trying to add fogs...
- Suspension Question
- crank and cam sensor
- Rehabbed Max
- A/C Fan Stopped Working
- My Budget MAx
- RE4F04V Auto Tranny Problem 165k miles - No Reverse, and barely moves in drive
- maxima not cranking
- Wierd Radiator Hose
- Jumpy click from (P to R) also from (in-gear cruising and neutral)
- sensor's kncok, crank, cam, o2
- Rear Pads changed now there is a wierd humming
- Lucas injector cleaner really works
- Squealing like a pig
- 95 AT accelerates on it's own after some work done
- Question about A/T behavior
- Cash for Clunkers question
- paint
- Comprehensive Pictures and Directons - EGR Tube Cleaning P0400
- keyless programming
- Auto tranny kickdown too sensitive
- to debadge or not debadge? 96'SE
- A VQ loping like a Diesel or a V8
- Cel 1008 need some help!!
- Doing clutch... Should I do a Performence Flywheel? To do or not to do?
- Carbon Fiber Hood on eBay
- Car stopped: Gears grind.
- 4th gen riding like a model T
- RPM needle on drugs
- Some Help with Adding Aux In to Your Bose
- Axle Popped back out!!
- body side moulding
- cant tell if maf or knock sensor problem?
- Loud POPPING sound when accelerating hard
- A simple way to replace antenna mast
- Eibach Springs
- Variable Wiper Swap problem
- Misc. Car Problems and ?'s
- stock intake install
- Replacing rear struts
- a/c general ?'s
- 5th Gen starter on a 4th Gen?
- Factory Alarm Beep
- 4th gen maxima macco job pics plz
- Driving with O/D off
- Rear bank of plugs wet, gas out of tailpipe
- If you don't want to talk about Seafoam,Please Don't enter here
- I want to use a non NATS key the hard way... How do I?
- 99 cluster in a 96 ?
- Cheap price for rotors and brake pads?
- Engine vibration at low speed, need your opinions
- Got my warpspeed y pipe installed on my 99 cali spec have a question about the hanger
- Got rear ended, car considered a total, they sent me a check. Can I still sell car?
- Differential Bearing Replacement
- brake pad help
- Intermittent Bucking under light acceleration
- Annoying sqeeking
- how do you add a trunk opener?
- Couple of questions
- Knock sensor question
- just a quick question on lower ball joint removal
- Loose exhaust?
- What happens if you put Auto Axle in Manual Transmission?
- Engine oil got dirty after 1k miles
- Ok.. You guys remember when i asked which color i should do?
- Removing Upper Intake Manifold (UIM) w/pics
- Gas cap goes pssf - normal
- what's this pigtail for?
- inquiry into catalytic converter prices/95 max, +
- 2000 mile roadtrip coming up - what to do ?
- Its gone!
- 1998 passed inspection (177k)
- Sentra CAI fits on 00vi 4th gen
- JWT ECU 96 in a 97 car - 0707 CEL
- Speaker Wiring Question
- Cold Type or Standard Type Spark Plug
- ok to buy front wheel bearings from autozone?
- HELP! Rear brake lights stay on when car is off!
- I found a bunch of un-used 18-NPT taps - how do i find pitch size of my 00vi barbs?
- Gear Oil (MT only)
- Motor Mount Change Concern!!
- coil pack resistance
- Brake pad replacement
- A couple issues
- hard dipping when on stop light waiting for green light
- interchangable seats
- New 4th Gen i just got Blk/Blk
- *HELP In Neeed of a VQ35 motor*
- leatherseats.com leather question
- Has anyone ever tired one of the Universal TB off Ebay??
- R34 Headlight guestion. ( do they Leak ?)
- Removing Fender...
- Wire LED's into corner light housings
- Corner Light Mod - Be Careful...
- ac wiring?
- Quick easy question about AC Compressor
- Help with diagnosis please
- EU data logs needed
- MY slow starting FIX! (yes it is fixed) '96
- Question about starting issues.
- Blower Motor Noise? [Video inside!]
- RPM drop around 3k with auto trans
- Traction Control Bypass
- my 96 5spd, couple problems....
- Speaking of Fuel Pump Control Module.....
- Air Conditioner Compressor question
- Help with programming the 97 Visor Homelink
- Brief hesitation from stop to go (Auto)
- warning: strange question inside. quest parts on a 4th gen?
- Does Idle speed affects car performance ?
- Climate Control Question - Anyone ever taken it apart?
- 0304 code
- Still Craaaannnnkkk Slow Start
- Need to OG guru's to check this out
- Painted Spark Plug Cover Finished
- starting problem, it cranks, sputters and starts
- Fuel Pump Control Module Ghost code????
- I hope its ONLY my clutch goin...
- 4th Gen CarPuter Installed and working!!!
- Coolant leak, please help if you can
- Rear Speaker Amp Fix? Or I'll Buy Yours! Bose Sigma 975 Rear
- Door is TOUGH to open
- 98 SE no longer starts like a champ
- Knock Sensor, o2 Sensor related?
- 4 da Mech Headz: Worth Fixing Up?
- Excellent how to videos for 4th GENS
- Steering has too much wobble room
- How do you replace the boots on the power steering rack?
- Verify my oil leak
- Front Motor Mount Removal Tips
- Double Din Screen cover up
- Sluggish 3.5 swap
- megan racing springs w/ gr2s?
- Where to find Fine Threaded Cat O2 Bung?
- hard time finding starter mounting locations
- Too much back pressure,Hindering Performance,Sh*tty exhaust work,All of the above ?
- what projector is this?!?
- clicking noise on acceleration from stop
- wow!!! doing the Maxi's motor mounts was like Night and Day difference. NO joke
- Thickest tire for 20" rims
- NWP Engineering Engine Torque Link Bracing Kit Installation and REVIEW!!!!!
- Need NEW Battery any suggestions
- anybody have these on their max?
- Complete brake job, Excessive rotor heat ?
- Odd rear rotor wear pattern
- Cig Lighter Not Working
- Oxygen Sensor question (4 wire)
- Keyless entry remotes???
- Battery and A/C problem
- oil pressure light flickers upon start up...??
- need some help - I DON'T KNOW HOW TO MAKE A PROPER THREAD TITLE
- test pipe question
- Brakes weaker after brake job.
- maxima makes no power
- getting engine washed ok?
- NSA Starter
- Those of you who have done the vq35de engine swap
- Open ended Engine vacuum line- normal?
- Car won't start, i need some help
- Radiator fans always on
- Is this a fair price
- 99 Max stays running after I pull key out ignition
- wheel spacer
- Installing an Altenator 99 SE-L
- Question about ecu
- ionic dynamics lip kit question
- 95 Max hesitate to start
- Auto Dimming mirror lights not working
- Battery Issue after radio install
- EGR question
- Thinking of doing the clutch myself. Only did one in School :eek:
- performance tips
- really high idle after workin on upper intake manifold
- 98 max needs new struts
- How to tell if Control Arm is shot
- Awesome...my window won't go back up.
- Quick question for 1999 maximas.
- hard time starting on cold starts
- My sunroof repair kit experience and broken shade :(
- 1999 Compression Test Results
- SLIP, ABS, TCS dash lights always lit
- Steering Rack Leak??
