- Rear O2 Sensor verification needed
- Exhaust problem, input please
- Sold my Blue Baby!! Driving my Dad's 97 Gold Max Need Opinions on the Grille!!!
- Some 2.5", some 2.25" exhaust pcs...problem?
- Headers question
- Emanage blue problems..
- pics of my car on greddy website FTMFW
- cigarette lighter
- Emanage maps
- 2002 auto tranny in a 4gen
- Wonna rewire my fogs
- Is the 'Big 3' What I Need?
- P0138 Code Searched have a few additoinal questions
- Can I hook up a turn signal to this?
- ebay intakes
- Where to buy AC Compressor, Hardstarts & Stalls
- TCS, SLIP and CEL!!
- Interior door panels 95se
- ok this is the second freaken time this has happened
- 95 Maxima shuts off while driving. please help
- amazing what a $5 PCV valve can do
- Dash lights acting different
- 1999 Cali -> Fed Spec Conversion Questions
- Navigation harness?
- Newbie To Suspension Stuff
- Exhaust tip hangin out
- Weird sound from front suspension
- Front End Makeover - sneak peak
- need help, please give your experiences and solution to p1320
- errr FING CAR
- shot in the dark, but Q about plastic that covers speedo/tach/etc
- Swapping 5/5.5 Gen seats into a 4th Gen how-to
- A/C Issue
- Charging Problem...again
- 5spd swap
- charging system or electrical issue
- Brake Pad Wear
- I got HIT
- Cant get the shifter out of park, button stuck? Someone help
- prostreetonline.com reviews?
- Hazard lights stopped working...ahhh!
- Made it just past 200,000.....
- Drive belts
- Code 02-01 Ignition Signal Circuit
- Which 5 speed tranny's will fit??
- True dual exhaust?
- Climate Control Bulbs
- Noise won't go AWAY!!! woot woot woot woot :(
- Greddy Emanage Blue pinout
- Major issue with GOODRIDGE SS brake lines
- Need some information on transmission bolts
- HELP!!! New strut went bad after 5 mins Twice.....WHY??
- Strut Mounts Question
- help!!car awkwardly dies
- What alternator to buy
- code 180, fuel temp???
- Progress coilovers or GC with shortened Koni yellows?
- sarona design hoods
- Feedback for oxygensensors.com?
- Thinking about trading my auto for a 5spd...
- Tokico Illumina's settings
- Lower Control Arm Pricing
- Towing
- !!!! HOW do U know if ur starter and alternator are goin bad?
- light chimer thingy......
- Oil pan will not seal properly: Anyone?
- Help !!!!!!
- Symptoms of a bad IACV??
- signs of a bad caliper
- HELP: Will I30 seats fit my Max?
- HELP HELP!!!!! WHAT are these???
- New info on strange Battery+Brake light problem.
- Shudder on clutch release - 1st gear
- Having an odd clutch issue
- New Mods.
- Starting Issues - '96 SE 160K
- Ordering a LSS y-pipe tommorow, Anything I need to prep for?
- Bulb number for rear licence plate bulb
- Chattering in second gear..
- An old trick
- Crank-Case Breather ID" ??
- replacing rear bose speaker?
- Removing the chrome from the door handles
- Question on Exhaust
- neone know the brightest bulbs to put in the dome/maplight? also where to get them?
- help: idle drops
- Clicking that increases with raised RPM
- another a/c question
- ebay body kits...
- torn steering rack boot
- 97-99 Headlights on a 95 max?
- This sucks
- Coming back looking at 95-99 5-Speeds
- Starting problem
- which rotors fit?
- Have a little bit of a problem...step in.
- Mmm exhaust suggesitons
- Anyone who swapped 00vi back to stock
- Minimum thickness rotors-yes, did a search first
- grill
- help: need snap rings!
- Left side of hood shakes up and down
- Cams?
- Is there a thread that has the best tuneup brand parts for our cars?
- Post-Cat O2 Sensor - How do you remove it?
- Nav/DSR/Radar Detector Hardwiring Guide
- suspension setup
- Aftermarket gauges with speedo in Km/h?
- question about iacv adaptor and bleeding the clutch
- just need your opinion on this timing chain?
- Maxima Smuggling Compartment (WITH PICTURES)
- Cheap Suspension set-up
- i thought i fixed the damn thing
- Control arm question
- 98 Maxima rear brake
- HELP!! car wont let me shift!!
- rear brakes on sale at rock auto
- Help Gauge not illuminating
- Shifter housing lens has a blue tint?
- Good Place to get an A/C Compressor ??
- suspension question
- To clear up any confusion - this is supposed to be securely attached to your engine
- Y-Pipe hiss fix?
- Noisy climate control fan?
- Power or Looks?
- axle seals
- SES light disappeared?
- DIY Question (alarm beep)
- No gas mileage improvement
- what next...
- Top Speed video..(140 mph)
- 4th Gen Oil light
- Week of exhaust questions..got another one. Greddy SP2 fitment..
- not again....ebay com'mon
- Clutch Pedal... leaking
- whats needed to do a 95->97 grill conversion
- Well today my front lip was.....
- rough idle problems
- Fog light keeps blowing fuse
- Clutch Re-condition....
- can't solve p1320 code, replaced all parts HELP
- total loss with this much damage???
- where do you put in your oil?
- Floor jack block--what's it called?
- Strange diff./ axle seal problem
- please help....big egr tube
- Fuel Filter Replacement
- Strut bearing price
- Cattman vs. Apexi WS2
- Split A/C Hose
- Those with z32 calipers and cobra rotors, im getting grinding noise need help
- Head Gasket Sealing Liquid?
- Not another HARD START thread...
- Front Suspension Problems
- Car crash, seek advice
- Time for a major tune-up, need help
- whats a good suspension setup
- filling my motor mounts...
- frequent CEL 0505 code, plus engine ticking, and manifold leak
- Please post pics of VAFC/SAFC install
- Reseting ECU
- Cattman vs Greddy SP2
- Smaller tire diameter
- serpentine belt snapped
- Replacing antenna mast
- Pic request: 97-99 w/ CF Hood + Stock SE Front
- Replacement help...
- Suspension Renewal
- 95 Max stalls and hesitates
- Will it kill me not to repair these right away?
- Nismo Short Shifter
- Faded Pearl White roof?
- You can't have a hotrod without pinstriping....
- Is it possible to replace front struts & rear shocksfor $500 including installation?
- my prediction for th week....
- quick starter question..
- axle seals
- In "___" *blank* miles, My 4th Gen is the Best
- remote door locks
- my baby got stolen
- 1995-1996 Fog Light Removal
- Another o2 sensor thread
- grrr...still stalling!
- A few problems I need help with...
- Problems with RPM's and Idoling.
- Strut Replacement
- Shuddering
- Problems with clutch slave or master cyl
- Fiberglassed a hole in my fuel tank
- JWT ECU - beter fuel economy
- Muffler installation cost?
- Death of my Max :(
- OBX Short Throw Shifter...
- I searched... what kind of gas mileage are you getting?
- todays new updates....
- 5spd swap'd... PROBLEMS!!
- HELP!!!!!!! I broke it!!!!!!!!
- quick 02 question
- budget fitment problems lately??
- knock sensor
- Making turn signals runing lights
- Anyone Order a Budget Y-pipe lately?
- errrrrr wheel hop
- So, anyone managed to accomplish this?
- Overhaul a window lift motor
- Pre-painted bumpers/parts off e-bay?
- ebay is using someone picture!!!
- 95 SE, A/C intermittent between cold and not cold
- how many of u?
- so i used sea foam..
- Do I need new Rotots?
- Car Starts and then dies, what gives?
- David L red/clears for 95 96 available
- got a/c clutch off!!!
- lug nuts
- need help installing ground kit
- Clutch pedal issue
- Non Bose Head Unit
- which mod next?
- Where to buy MAF..Autozone is $230.WTF
- changing rear brakes
- Recall- 1996 SE
- How to adjust clutch pedal? my clutch pedal is stuck and I need to pop this thing out
- Car goes in gear w/o clutch
- GAS guage?
- Speed gov'nor?.
- Vulnerability of O2 sensors on aftermarket Y-Pipe?
- Intake Manifold Discussion
- Lssexhaust.com....Where has it gone?
- Blown Rear KYB AGX
- suicide trunk
- Let's play, "NAMETHAT NOISE!"
- Suspension Combo
- Ksports on E-bay
- Fuse question
- Help.!!Wont go into programming mode.
- CEL Code P04000
- How long do ignition coils last?
- anybody recently got an injen knock off from ebay?
- fuel injection cleaner
- Fluttering temp gauge and inop climate control unit
- Summit RPM Switch Question
- Speed sensor bracket.
- Yet another clutch goes down to the floor problem… little different this time.
- Steering wheel vibrations over 70mph because of worn suspension ?
- GXE's come prewired with AutoClimate UNIT?
- Suspension clicking noise question.
- Speaker whining noise
- Whats Up Guys
- Cheapest place to get rear calipers?
