- Stock struts with Tein H springs
- Searching
- Kyb's with tokico springs??
- Drivers-Side Door Hinge Problem
- Y-pipe question
- Car stalling
- Antenna mast broken off inside housing - any ideas?
- Now the Max is missing under load...
- To The Org Administrator
- After market intakes
- Factory spoiler install help
- My car should be back tommorow!
- possible transmision problem
- weird clacking noise coming from the front driver's side
- How to clean the bulb surface?
- Stupid SES Light!
- Back Order on MEVI Parts
- Front Bank, Rear Bank??? P0140 Help
- IAT location on a 97?
- I have a Q which i hope someone can answer...
- Will a Auto wiring harness work with a manual tranny?
- Dumbass 99blackmax locks himself out
- High Idle when its cold out?
- My new engine is giving problems... smoke
- Rpms drop to ~500 when i release gas pedal
- Is This A Good Deal
- car wont start:(wel
- Retro-fit CE lights or sale then purchase R134 1-pc and Retro
- Suspension problems - Need Help
- 239,000 miles ??? ride looks sweet though
- High Idling
- Lower Control Arm Keeps Coming Loose !!!!
- installing stainless steel lines quick question
- starter fix failed?
- Idle dipping to 500rpm
- Coolant Leaking???
- Need a wiring diagram for R34 Retrofit
- Rear axle shafts broke
- spilled drink in center console.....
- Stiffer is "worser" but stiffest is best!
- climate control
- cruise control not working!!!
- Need help setting a price
- automatic rear view mirror
- Anyone have a trunk board?
- headlight switch/turn signal switch
- O/D doesn't go off! What's up?
- so i called cattman today
- Weird idol while stopped
- Thumping from front
- Hydrolock !!! wtf !!
- need help putting together ebay CAI
- how to roll a fender?
- which pedal covers to buy?
- Antenna problems
- Post Pics of Your Rims
- help me with my brand new 99se
- Modifications/common problems
- windshield washer fluid motor dead?
- Help! KS thread got stripped! : (
- Where to place air freshener
- best place for OEM replacement parts? opinions
- What Carbon Fiber Hood should I get??
- Taillights
- Electrical issues still discharging overnight
- Shifter Fuxored
- Please help me to open the foglight housing for a retro fit...
- Shipping costs?
- Maxima makes a remix?
- Hot lights
- climate control on a 96
- Alternator Whine
- Car is running hot.
- 0505 trouble code
- <--retarded why did I wait so long! Starter fix
- short air intake missing a piece. Where to find it?
- Suspension
- compression?
- Help with Fuse
- Hit and Run - my baby is dead....
- Couple of questions about my 96 please!!!... (struts/shocks/ypipe)
- Bose AUX Write-up
- I lost my Lumbar Arm Screw
- Would Tokico blues be good with sprint springs?
- Instrument Cluster! Need help or opinion!
- Watery Clutch pedal
- Fuse box layout (under dash)
- Parasitic drain - BCM fuse
- 4th Maxima should be in a racing game
- Coilover choices
- 1997 Bose radio buttons - HELP
- Sensor Needed for I30 Mirror?
- installing rear speakers in 95' maxima
- testing coil packs
- Looking for Suspension Installer in CT area
- Where to place sticker
- Gauges are acting stupid. Please help!!! Any info would be appreciated.
- help. any throttle and car stalls
- 99 max..Passenger side...air bag light remedies?
- LAGG!!
- Cruise Control Light
- Check engine light code 1003
- Quick Q-PO136
- Tell me how to get this EGR port off??
- Need Hid Information
- Can i use 5w-40
- Debadging problems
- ss clutch lines
- Good headunit install kit?
- odd CEL code 0413 or 1304
- Misfiring on cyl. 6 after using deep creep by seafoam :(
- Looking for LINK to .....
- sunroof won't close
- 1998 Bose volume control knob
- 97 SE 16" wheel and tires - need help!
- Place to buy random 4th gen parts
- Unsolved Problem
- Very Squeeky breaks
- Auto A/C control lights...
- '97 can't run on high RPM, no CEL?
- Quick lil teaser pic
- Car wont start... nothing
- Need Newer Bose Head Unit....Help
- Tie rods for 4th gen
- Antenna Wrench for 95 Nissan Maxima
- Cruise Control and Windows?
- Any body know where/how to get a performance program for my CPU
- interior lights all died at once?
- PBR Brake Rotors?
- new parts from k-sport w/ pics
- Air horn electrical question..
- squeaky suspension
- rotor cap question
- 7L:3S Three way Catalyst
- evap canister vent control valve?? Help?
- Long Day... bad engine... good results..
- clunking sond when i brake
- Hard time puttin in new ecu
- What am I doing wrong with these rear struts?
- Help needed, after fix Max won't start...
- intake
- WTF.... why does my clock auto resets
- 97 ECU question
- It's back!
- 97 Nissan Maxima SE for sale
- IS 300 Yellow Fogs Fit a 4th Gen?
- Any members in Southern Florida that would help me ?
- Failed smog, OBDII needs resetting. How?
- weird sound coming from suspension
- Gas tank o-ring part number
- Need some ECU help
- transmission swap?
- Clutch-a-fixer?!
- need help with coilovers
- 97 max won't start
- Loose seatbelts..
- Radiator Support replacement
- Help!! Need Info on High Quality Hid - Conversion Plug and play kits
- Motorvate.ca is down ??? alternate site?
- Thud Sound when applying brake after shift from Park?
- Wow! My maxima was in the Rides newest Issue!
- Reliability of a VQ35 in a 95 Maxima....
- 00 Q45 Rims on a 97 SE Max
- 555cc injectors
- This hot normal?
- how do i find stephenmax?
- Im an idiot, need help
- Heated/Electric Seat install
- Max stalling and hesitation issue.
- So I got towed...and...
- Nothing too serious...
- so my check engine light came on in my 99 max....
- The girlfriend's 2002 Altima
- Maxxx
- Trunk lip spoiler?
- Costs + Labor on KS and related issues ??
- SS Lines Install question
- doors stuck
- short shifter
- CD Err, and its solutions
- HELP! Trunk won't open
- Anyone bought this?
- Transmission problem
- Are these worth it?
- Chrome door pillers
- Grining/Vibrations only during/after long drives.
- New rotor dilemma
- Help another problem with my brothers car
- stillen body kits
- Anbody have these headlights???
- 95 Maxima HELP with recent issue (power issue?)
- car overheated, water got in
- just got cattman exhaust
- 95' Cali-Spec JWT ECU compatible w/ 96' Fed-Spec Maxima?
- where can i find out how much my maxima is worth
- Riadiator Flush? Do I need to do it?
- New rotors for my '95 Maxima
- my ac is going crazy?!!!
- Need help assembling Cig Lighter into shifter trim
- Cluncking noise
- Stock wheel idea...thoughts?
- Problem....
- what did I screw up now? no oil cap.
- What I did labor day weekend in pics
- Swapping in 300ZX MAF
- How to wire a turbo timer?
- Need help passing inspection!!!
- changing clutch
- Dash trim kit
- My new tint
- rough idle
- Favorite Oem Wheel on a 4th gen
- flat black max
- ugggg, cruise question
- suggestions on what kind of fuel filter to buy?
- to paint or not to paint
- Brake rotor replacment and pads
- Hey guys...
- G-Stop Brakeline Fitment Issues
- Strut bar broke a hose near intake manifold, now have CEL with no code...
- A $7 repair!
- Looking for good H.I.D bulbs
- 10k H.I.D.s + Cefiro Headlights
- Changing the A/C Expansion Valve/Condensor
- Cheaper to get new HeadUnit or replace Bose?
- Loose spark plug
- Bad Steering Rack & Pinion?
- 99 KEY question
- Cooling Question (answer is in haynes manual)
- Labor/Parts Cost, Water Pump / CV Boots
- Tensioner Question...?
- Rough Riding
- TSB went missing?
- Post pics off your center console
- Keyless Entry
- Left & right side of engine?
- serious negatives in dropping a car...if ur low step in!
- turn signal problem.......HELP
- anybody running 17x7.5 wheels at a +45 offset?
- My Maxi could be done-zo
- i just have to know...
- drunk problem
- ipod icelink
- Another dead I30 - will not crank up but for a click sound
- Replacing GOLD trim on the car....
- DO 5th GEN Struts fit 4th GEN
- LCA- New bushings or whole arm?
- WTF- I can't win with the max lately. More noises.
- My trunk light won't turn off!!
