- Car Violently Shaking.
- What Rpms
- Help with rear O2 after 5sp swap
- Should I change my A/T Fluid??
- Where to hide spare keys under Maxima
- 14MPG WTF?
- Changing the Shift knob on a 5-speed
- Rattling/Grinding noise coming from front end, 97 SE 5spd
- need help deciding
- Oil on rear coil packs...
- Auto Climate control lights
- I need a CARFAX check....
- suspension work
- How much is my car worth?
- Replacement Parts
- What is MEVI????
- how do you know when your car is misfiring
- who has the best online tire prices
- Bipolar Alarm/Security system
- misfiring!!!!
- BRAKE light on
- MPG Boosters
- 98 Maxima Air Bag light flashing
- Key remake??
- Which o2 sensor?
- dealership
- Fog lights
- front end noise
- Replaced mostly everything Still hard starting?
- 4th Gen Lost Archives (eye candy)
- Best way to remove knock sensor?
- putting in illuminas
- Whos the fastest 4th gen?
- Break pad replacement issues
- Stillen Body Kit Question?
- Lights dim when window motors used, new alty.
- The perfect 4th Gen tool box
- Mysterious power door lock…. Opens and closes itself while driving.
- Been driving w/ blown struts & shocks… will it damage my max in any way?
- Random Bad Starts: Ignition switch? starter? what is causing this?
- 2nd sensor location
- Air/Heat Only Blow On 4
- Going to trick out my Max, Need Advise.
- WTB: Fuel Pressure Regulator
- New Y pipe gasket part # ??
- Power folding signal mirrors w/ ground light
- headlights blink every 10 seconds at night?
- Loud "crack" noise passenger wheel
- Help, I can't take the rear caliper off
- k-sport coilovers those that are slammed question
- O2 Sensor Location
- One of the lugs in my wheel broke!! how do i replace it?
- Is there anyway to replace the weather stripping on the tail lights?
- Air Bag Warning light blinking
- suspension advice
- Chrome trim on door, HELP
- FX35 Bi-Xenon Wiring from E46
- Need help 97 Max OBX headers & y-pipe install
- Starting Problems Again!!!
- Auto transmission trouble-2nd rebuild 3months
- y pipe ?
- ECU AND WIRING HARNESS HELP PLEASE!!!
- MAF Question
- Different interior squeaks..
- Question on tints
- Engine 1/2 way fixed...update on the situation with the new motor
- fuel economy went south
- 160,000 miles too many to buy ??
- replacing automatic shifter/steering wheel
- Release Fork for 5 speed swap
- 07' Murano Wheels on a 4th Gen - Post Pics/Opinions
- Where to find Mille Miglia Rims
- help with swap of homelink
- so tommorrow i lower my car.
- How much should I ask for this?
- Transmission re-install: any trick method
- Good Price?
- Yay Sun is out = New Pics of the Red Joint!!
- i noticed something.......who has the answers?
- maf question
- MEVI Question!!
- How do i do the quick shift mod?
- need part number for 2001 AE vlsd axle seal
- Found the car immona buy...
- Headed seats
- how to remove headlights?
- illumia numbers for the rear...
- Error code 0210
- want fast blinkers?
- Faulty Coils
- Wiring question: need an open connection, or one on which to piggyback
- What seats fit in a 4th gen?
- Big EGR tube Broke! P0400
- hmmm powers gone?
- Am I getting ripped off? Struts/springs install
- What's the downside to poly bushings?
- alternator advice
- Power and Weather
- Maxima runs better ands sometimes bad
- Taillights on '97-'99 fit in '95 Maxima?
- USIM vs. MEVI
- new clutch
- What parts have you replaced due to excessive rust?
- New Maxima Mod.
- fog lights
- 65F00 oil filter
- need help my car wont start
- how do you know when to replace control arm?
- Topping off too soon
- sub
- Drop resistor mod question
- Heated seat switch bulb?
- RPM Switch wiring
- No crank/no start help!
- Anyone else have problems with coils like this?
- Topping out too soon
- Ebay 02 sensor purchase, HELP!!!
- Need indepth clarification of these codes.
- fidanza flywheel....
- 95-99 Engines all interchangible?
- need help with ac/heat control
- Will 5th generation seats fit in my 4th generation max?!!!
- jersey maximas
- 5spd shifter bushing?
- Shocks
- Temp Gauge.
- LINK to changing VSS (Vehicle speed sensor)
- M5 body kit for 1997 Cefiro
- CV Joint Dilemma
- Rear Caliper
- 6TH Gen Brakes
- Head lights off ? ignition
- LED lighting in the gauges
- Can bad wheel bearings not show play?
- Flowmaster
- Unique Problem With KS (Detailed Pics)
- how many kilometer/miles when tranny went kaput?
- which MAF: $250 Cardone, $110 New Chinese, $70 used
- Are my Tokico Blues defective or ?
- Suspension Bushings Needed
- I'm beginning to think this new engine is a lemon.....
- ANY PICS OF COMPLETED 00vi IN 4TH GEN!!!!
- Engine swap...
- NEED HELP!!!PLEASE!HOW TO INSTALL 00vi!! PLE
- 99 Immobilizer Bypass?
- When looking for a used transmission, look at......
- ABS & Air Bag lights need to be reset
- tachometer 400+ bucks!
- How To Keep Both Bumper Lights On And Turn Off During Signaling?
- Hesitate At Start
- spring removal question
- My headlight is moving
- HELP! car is shuttering at idle and acceleration
- Anybody know anything about Sensor Boost?
- vlsd vs open diff
- guestion about aiming the head lights
- Can you cheat with MAF sensor readings to run leaner?
- EVAP questions
- Upstream O2's
- CV Quick boots
- Have you removed a Maxima engine before?
- 99 ECU, Manual & Automatic the same?
- Best Budget Strut Replacement ($300 & under)
- where to get spark plug coil-packs besides stealership
- tuned ecu for 1999???
- Question about ethics from engine sellers...
- Rear brake light strip
- Help with Removing Axle/Halfshaft
- got some 4th gen options - maybe a 5th gen?
- Custom center console DIY How To
- lug patterns the same? 1986 maxima? asap!!
- so finally got my H.ID's
- Will y pipe (fed spec) fit Cali spec?
- Key FOB problem, any suggestions?
- FADED DASH
- Transmission & Front Axle Shaft Problems
- Ebay knock sensors - has anyone tried one of these??
- Got projectors and now high beams stopped working?
- How much extra time for rear main seal change while doing clutch?
- What tool to use to remove EGR solenoid valve?
- Problems with alternator or battery
- Intake Pipe Size
- picking up a 4th gen
- transmission problems!!!
- Two part numbers needed
- 99 Cali-spec KS Help
- Best Spring Set up
- Name this part...
- 5th Gen clutch parts list
- 5sp Transmission making odd noise??
- Little paint missing
- Horrible sound comming from passenger side front wheel, wheel bearing?
- question about ebay dash kit and tinted tail light covers..
- Changing clutch today. Got some ?'s and lookin for final words of wisdom...
- need a less expensive exhaust alternative
- Car would not start the other day... please help
- Scoop on hood for SAI ???
- EGR FLOW MALFUNCTION!
- How to determine manufacture date?
- Thanks Everyone!
- Belt issues?
- Clutch pedal saftey switch???
- Stock GR2s with s-techs
- Please Help Car starting problem!!!!!!!
- Tight gears
- Quieting A Really Loud Exhaust For State Inspection
- Something missing???
- MAXIMA GEARHEADS PLEASE HELP!!!!!
- Wow the Max is getting old...
- Want music in my car
- best oil for maxima
- shift light problem
- How to Install Hanabi Kit? Anyone?
- A/T Revolution Sensor
- what to do next
- how to change transmision oil
- A/c works intermittently, compressor lets out pressure
- guys help with HID they wont fit
- Video: 97 Maxima gets pulled over by Cop gone wild
- KYB gr2 with vogtland springs
- Problem with bright lights
- Any feedback on this mod?
- Help!!! Transmission is stuck in 3rd gear
- Sticky Shifter
- 5th gen muffler finally went
- where to get trunk latch?
- Keyless entry???
- Trunk Light won't turn off...FIXED!!!
- sunroof + rain = Wet interior
- Batt,Brake, and C.E.L???
- Brake pedal feels soft Please HELP!
- Mobil 1 LS Gear Oil
- What are the signs of your torque converter going bad?
- Light Upgrade In China Or Taiwan?
- SAFC2 install
- Trunk Rattle
- Maxima Seats Baby!!!!!
- retro time out/on lights
- STS too long
- Royal Purple tranny fluid
- Control arms, Sway bar links, Tie-rod end links
- HID conversion
- What size is the Axle Nut?
- New Suspension
- Seafoamed, i think i made a mistake. Is it recoverable?
- Stock struts with Tein H springs
- Searching
- Kyb's with tokico springs??
- Drivers-Side Door Hinge Problem
