- Stillen Sway Bar?
- Inspection time, need opinions...
- Should I start hacking away on the Sarona Rear Bumper ?
- Seafoam question
- Grounding kit
- Codes 1001 and 0908
- A/T ONLY: Who uses their E-Brake when parking?
- ok, new suspension but......
- Vac leak and wont run
- Add the OEM Spoiler
- Steering wheel vibrations over 70mph
- timing or drive belt question
- WIRING TO BOOST SENSOR (AKA INTAKE TEMPERATURE SENSOR)
- Wireless remote problems
- Exedy OEM or 5th Gen Clutch setup?
- Ebay is dead to me! (well kinda)
- Possible place to run wires to cabin?
- NEED SOME ADVICE PLEASE exhaust system damage
- window tints
- Maxima FSM available online
- I dont see a flat spot or anything..
- Gas smell
- MEVI activation using Emanage Blue
- trunk lip
- does anyone know??
- Headlight and Taillight customization.
- Udp+ Battery or Alternator? (longish)
- Center panel lights
- dek swap question
- my intake
- LED Boards For '99 tails
- price for the bearing job
- price for OEM water pump
- Lower Suspension Question
- What's this wire for ???
- engine mounts??
- Underdrive vs. Stock diameter pulleys
- Running Rough Issues
- How to convert 95/96 to 97-99 Front end??
- Questions on CODES 0705 + 0903 (related) and other random things..
- I swapped for another 97-99 trunkld for my 95-96..
- Upgrading headights from 9004 to h4
- Paint Codes
- Where can I get a black flesh grill setup like this on a 97-99?
- Need help on oem paint colors
- Somebody help!!!!!!
- Camber bolt/alignment help
- Any general interest in buying clear/red tails?
- looong cranks, losing fuel pressure??
- Helppp
- Cluster trouble
- doing a dek swap any tips??
- Need to know about which ATF to use, received no replies in Fluids and Lubs. Help!!
- Anyone using Mobil1 ATF synthetic in their Automatic 4th gen?
- MEVI Rpm Switch Question
- Megan catback for a '97---- Extra Sensor pipe?!?
- Squealing noise near starter area
- 97-99 bose speakers on a 95
- Ok...pulley problem....how hard to fix....(pics)
- Tint vs. Nightshades
- Can rear O2 cause EVAP problems?
- Program Sixth 6th Keyfob with 4th Gen
- 97 fogs in a 95?
- DIY Odometer Repair
- Strut replacement?
- Trunk Light fix!
- New Paint! v pics!
- Headers and Y-Pipe
- Suspension - Need Tokico Part #s
- wird noise from the tires
- Where is REAR Crank Position Sensor located?
- Decisions, Decisions
- Slight Shaking/rumbling randomly at idle
- fog light cracked
- TB butterfly valve alignment
- Opinions
- What's it called? Again...
- Brake Pads / Rotors Suggestions >?
- How much is OEM Antenna ?? $$
- Oil leak
- Tried to fix starter, noise did not go away!
- Running lean after complete exhaust upgrade?
- Codes
- R.I.P. Maxi!
- 99 double DIN non-Bose radio = no worky w/o antenna?
- Bad Fuel Pressure Regulator?
- 3.5 swap!
- flywheel or no
- Black Bumper Lights
- brake jamming
- Help! With weird engine code light
- Y-pipe installatio guide (dont hurt me, plz!!)
- I need this part Number "purge control valve"
- Tornado Fuel Saver for the 4th Gen.
- auto shifter o/d ?
- Wind Deflector for sunroof
- Removing Door Panel
- Hood struts that dont blow
- Found why E-Brake light dies not come on (Pics)
- exhaust thoughts
- Steering wheel differences
- Where is the post showing a WOT switch?
- A heavy question about tires
- 4TH GEN. vs 5TH GEN. KEY FOB
- how do i swap 9004 bulbs to 9007's?
- Is this my IAT sensor?
- Security Code needed for 1999 Bose Headunit?
- megan racing coilover question
- Pic of where Camshaft Postion Sensor is located
- How do you tell if an AXLE is bad?
- Eliminate LED hotspots! Guage install!
- Rusted Rad Support
- so yea today my maxima got hit with a tree branch
- Cleaning throttle body worth it?
- ideas about rotten egg smell
- KS installation and Lower Core Support replacement in Chicago area
- looking at a 99 SE...have questions for org
- How To: Trunk Strut Install (No More Torsion Bars
- New Wheels?
- Exhaust smell in the Cabin
- car running lean...
- Steering problem
- Crappy acceleration
- window switches and bezels
- Req'd suspension parts
- dash light needs replaced...
- Thinking of selling 4th gen and getting a Q45
- 95 max RIP CHECK THE PICS
- 245/45/18 Rub?
- car bucking?
- Anyone put their floormats in a washing machine?
- Corner Lights
- Master Cylinder ByPass
- JWT
- Automatic is hard shifting.
- Where to get this fliter...
- interchangable parts??
- Battery Light + (!) light means bad alternator?
- Lowering + Mud Flaps
- what options do i have for tranny
- Wet floor board, any suggestions?
- looking for a new 4th gen - is this max worth it?
- Need pic of trunk struts
- New suspension, problems already...
- Climate lights out?
- L E D interior W/pix---->
- HAI/Short Ram intake info
- Should I get these headlights?
- Trunk carpet, where can I get one?
- AWD conversion using G35x drivetrain
- Anyone add a hood scoop?
- Weird Stalling Issue
- Replacing roof panel and sun visors
- Squealing on Start-up
- Trunk lid arms?
- Maxima Needed!
- 4th Gen Maxima Goes Off Roading
- 300ZX brake swap
- Tips on keeping strut piston rod from turning?
- "Yellow or Fogged Headlamp" FIX
- Help maxima on 20"S
- "YELLOW headlamp" FIX
- HELP: P0710 Transmission Fluid Temp Sensor? Hard shifts & no O/D
- 95 maxx blowing massive fuel smoke out tailpipe
- Custom fiberglass work
- Settings of Illumina Shocks
- Illumunias + S-Techs
- suspension help can't get bolts into knuckle!!
- CEL p0443
- Rear brake pad problem
- Foglight stop workin???
- 5spd vs. Automatic Starter...difference?
- Show or Go?
- Can someone run a CARFAX for me?
- Cleaning IACV
- What 5th gen clutch fits our 4th gen?
- Underhood light?
- 97 MAX NEEDS HORSEPOWER
- Rear suspension sag with Progress/Illuminas
- Transmission out to repair leak
- Manual Climate control lights work when they want too?
- Cheapest factory quality replacement struts?
- is one front strut tower bar better than the rest?
- suspension question
- Window regulator replacement DIY anywhere ?!?
- Looking for Suspension Installer in CT area
- polyurethane bushing
- idle jumping
- Need a second opinion
- Where to get decent price engine?
- My tranny...
- Starting issues, 95mt
- IM temp seems hotter than normal...
- Glasspackss?
- Extreme Enginebay Detailing (56K Warning)
- changing wheel stud pattern - possible?
- Bleeding the Clutch
- Ouch my max is in trouble
- reliable place to buy front and rear strut mounts?
- Painting all clear tails - 95/96
- what is included in Tokico Illumina package with springs
- is there anything i should know??
- Painting the dashboard and pillars
- locked my car....
- wheel studs broke/brake problems
- DE-K swap threads
- Possible oil change problem
- m45 Seat Installation
- Need help fast! Brakes don't work.
- Turn on foglights without turning them on with headlights
- Deformed y pipe, need repair suggestions. [Pictures]
- Synthetic transmission fluid change....or not.
- FED or Cali Spec
- Exhaust Pipes..
- Any way to touch up a chrome grill?
- brakes??
- replacing rear drivers side door
- What do I need to do to get 5th gen seats to fit in my 4th gen??!
- Swaping ecu
- Some crazy crap
- Broken Cruise Control
- A/C Evaporator Condensation Leaking in car
- Hard Shift
- map light and some other stuff doesn't work
- Confusion about Stock spring rates
- 5 spd rebuild kit ??? any good?!?
- vlsd 2001 20th Ae tranny problem help
- ABS sensor removal..grrrr
- good psi on tires
- Hard Starting completley GONE!!!
- KYB AGX
- need help with ECU
- VLSD in Canadian 4th gens
- 5pd swap -> perma check engine?
- ?s about Light.
- MEVI, JWT feels slow
- Ques??: BACK WINDOWS WONT go DOWN..MUST READ
- Camber bolts or plates?
- Has anyone used 225/15/15 tires on their 15" OEM wheels?
- Radiator support rusting
- Which sensor controls the radiator fans?
- Please help with codes....P0325, P0440 and P1448
- exaust installation
- good service manual
- What is this on the left side halfshaft between the inner and outer joints?
- CF hood on a sterling mist?
- Car wont start again...
- Quick Inspection question...
- AG Springs
- Anyone know the dimensions for a fornt wheel bearing?
