- New CAI From Ebay
- sounds kinky, but gets annoying after a while
- please help me out???
- How do you fix the hazard switch
- A new way she won't start...
- 95 maxima horn, please help!!!!
- Clutch problem
- excessive play in steering wheel***
- 6spd writeup for 4th gen??
- What intake can i get for my 98 max auto
- UNGO alaram
- What is wrong here
- Wiper pivot mount
- For real 2.5K for a repair? Need opinions
- im an ebay noob...
- 2008 Hesitates
- Tranny bolt size
- Car-Sound High Flow Cat, or Motostorm UDP
- Tan interior with black dash??
- 95-96 fog light clip?
- 6th gen bench seat in 4th gen?
- help with heater
- Emanage Blue Questions
- Anyone else notice excess heat from inside cabin when accelerating?
- Failed emission
- Strange Oil Leak
- transmission rebuild write-up??
- How do you tell if the HID bulbs are authentic?
- 0302 (EGR) ; Light's ON only when i'm pushing it ...
- Airbag Control Unit (ACU)
- ~viberation~ please help
- To HID with white or yellow bulbs in yellow IS300 projectors?
- I30 Dash
- fuel injector cleaner
- Taller tires on stock 99 SE rims?
- ebay suspension question
- Alternator caught on fire
- Got my new Modas Baby. Check it.
- fuel rail adapters
- Do not overfill brake resevoir!!!
- Air intake recommandation.
- Destroyed 3rd gear and Diff Bearings?
- closed loop module
- My radio, clock, cig lighter, and washer fluid system died today
- Replacement Air filter
- No shifter resistance (manual tranny)
- leaking engine coolant
- Sqeeking noise after UDP install...
- 0210 CODE.
- anyone know anyone with a 45 offset set of rims?
- Anti-rattle spring clip
- passenger side axle
- o2 simulator - where can i get one for my 99
- Anyone had a cracked radiator?
- What the heck is this connector for ?
- Giw to install my HID conversion kit on my 4t gen.
- tranny problems :(
- Crazy Idle when engine cold
- Leaking rack and opinon steering is......
- front hub assembly
- Who here likes the stock gle honeycomb rims?
- Selling price for a 96 SE
- ebay red clears
- cruise control problem
- Add to crazy97's post : "Starting problem"
- This sucks... broken shifter.
- CAR NOT STARTING CLEANLY!
- any1 know anyone with a 45 offset set of rims?
- Homelink/garage door opner
- I want this keyless entry pad so bad - but apparently it's only for "newer" Nissans?
- Mystery Electrical Problem
- Knock Sensor
- Does anyone have a Cosmo Underdrive Crank Pulley?
- Will these tires fit on my 99 maxima? 245/40/r18
- Door lock issues?
- what is happening
- what sealent to use for fogs?
- question bumpers.....
- need help with a few questions
- So, my alt. caught fire today...
- problem with starting? help plz!!
- Ignition Switch How to
- Burning up RF brake pads only
- Holy bent caliper batman!
- Need help quickly! New seat + no side airbags= Oh no
- Block Heater Location???
- Maxima vs. Deer--Son of a......
- smoked tail lights
- Glare Sheilds for headlights
- Yep, I think my alt went out today
- Nissan “diversity” antenna adapter
- clutch problem/question
- D2 drop hieght
- did one of the four b pillar plastic removals today
- Squeaking when letting out clutch, chatter?
- '97-'99 LED Tail Light Protoypes!
- r33 gauge cluster!!! check it out!!
- SS clutch line???
- Final drive in 5-speed 4th Gen. bought the farm...
- Cant adjust Belt correctly, loud squeaking
- Infinity FX Projector Shrouds
- Front strut replacement
- Story with cel questions at the end
- Need help with strange noise
- Maximus Prime
- So my Chain tensioner piston fell down the chain cover... BIG MISTAKE
- Check engine codes 0201 and 0603...coils...how to fix?
- those who LED'd their guages
- Between idle and 1500rpms, I get a hard grinding sound from left side engine bay
- Heat wrapping WS y pipe to fix noise?
- Fixing the Clunking sound when making a right turn
- anyone else like cloth over leather?
- Anyone taken apart the gauge cluster before?
- Tail light fuse...
- CEL blinking steadily while engine is running
- Lmao! Sand Thru Intake
- starting problems
- loud sound from engine bay
- Thoughts on swapping an NX1600 Gauge
- Question about 95 Fed ECU
- Whos Maxima is this?
- Does a Deep evergreen look right with a CF Hood?
- JWT ECU RESULT
- Hesitation upon acceleration/revving...
- Wierd TPS and transmission problems please help
- Mevi Question..
- Can I get pictures of Engine bay grounding?
- Gate type Shifter
- shock and spring combos
- Shortened Shifter
- 4th generation engine monitoring thread
- stuff for sale.
- need help car wont start
- Short ram pipe
- post pix of your CAI
- Bose Display
- Changing E-Brake Boot
- can i have link on how to resize pix
- Red Bumber lights on Red Max instead of Clears?
- changing rubber trim on rear window... is it possible?
- torn between headlight options
- 97 Max 3.5 Swap...tranny upgrade...
- Suspension/rims
- clank-clunk from under armrest area over bumps?!
- Question on rims
- Custom Enterprise is back but do they still have..
- How about this Maxima taxi?
- JWT VS TS ECU Which one is Better for a 00 VI conversion
- Just ordered some Nex SS coilovers...
- Loose Axle Nut
- wtf.. pinstripe rant.
- 4th gen 5 speed sucks
- Help me set up a money savvy exhaust
- 1995 Maxima Diagnostic/tuning
- found a tsx projector conversion kit
- check engine light help
- 8 gauge Oxygen free wire. Where?
- OEM Stage 2 Clutch?
- stock ride height again?
- WTB: Trunk Spoiler ASAP
- Opinions on this chop...
- Hydraulic clutch 2nd bleeder/tubing question
- budget y pipe issues???
- Alternate intake that bypasses the MAF
- Rear Strut Tower Brace: what's the deal, here?
- Got 0302 EGR System Hi/Low Flow Code, Need Help
- Sabotage?: CV boot busted (2nd time in probably 50K miles)
- 4th gen. Tint
- Trunk Lid swap
- Show off your ***!
- what should i do with the headlights? HID? NEW bulbs?
- ok, wtf??????
- question about traction control?
- Warpspeed Y-pipe (I know, I Know)
- H4?? I don't get this....
- Anyone have a spoiler plug?
- Solutions for trunk/spoiler rattles?
- Gas goin up to much in NY
- Dual projector retro completed (pics)
- new headlights
- taking apart mirrors
- is tha pad ok!!!????
- check out my new sub-forum!
- Leaking exhaust gasket...
- Installing I30 gas release button
- y-pipe
- Ebay headers
- Am i just stupid or can i not find this?
- Weird cold idle
- Custom Steerling Whees Column Gauge Pod
- any Good Maxima Mechanics??
- REMOVING SMALL CORNER WINDOW
- High Pitched Front Wheel Noise
- MPG dramatically dropped...
- My hood doesn't line up (pictures)...and its pissing me off
- eBay clutch kit?
- Looking for the wire
- Need Help ASAP Please!!
- Installing New Exedy Stage1 Clutch
- rear end conversion
- After AE headlights........
- having problems with hid and suggestions?
- Car is dead! 1997- Maxima -auto
- Is my 4th Gen an SE or GLE?
- Is my clutch shot?
- Passenger axle
- ECU Flashes 0215 Why?
- Engine Clearance
- is this a fair deal on my tranny
- Yellow Top Battery
- red out ambers?
- Fan-assisted air box: another home-made mod.
- Should I get a VLSD or a low mileage open?
- heated seat switch + more
- y-pipe 95-2001 fits right???
- Pacesetter or Megan?
- front end problems....
- crazy brake light
- Which struts to get??? Need some advice
- Question about lip kits
- Urgent: A/c delete info
- att: Daniel B. Martin, I'm stumped
- how much is it gona cost to get a diagnosis on my maxima?
- Let's play "name that noise"!
- Worn Suspension Questions
- Tranny leaking!
- What is that part called???
- PROCLUTCH
- This is what an ebay clutch does to your tranny v. pics!!!
- 300ZX TT ENGINE CONVERSION
- What the hell is this crap?
- axle again???
- Going to buys some coilovers today....need some advice
- Got a code need some help
- ObdII To usb
- Replacing exterior door handle...Help
- Where to buy triple gauge pod??
- tapping noise in colder weather starts...??
- finally fixed my hard start problem
- need brighter fog lights!!
- rattling noise??
- Re did my niteshades.
- sudden loud idle
- Catalytic converter install
- cel from air intake?
- P0420 Code for CEL. Catalyst??
- I need a paint (KH3).
- All peeps on Tokico full suspensions... pics of your drops please!!!
- Confused on which model this is
- Need a new rear window defroster
