- relay noise help
- Tein S Tech + AXG __ Any Issues with this combo?
- Zinc primer and rust
- DR Mod & SES light ???'s
- CV Boots
- replacing speakers
- Removing Pillars
- Shift lever problem
- Bose died
- Cooling System Problem???
- Do I have a malfunctioning fuel guage?
- 95/96 clear tails vs. 97-99 clear tails
- Should i buy this??
- 99 Maxima ignition issue: please help!
- Motor slanted
- Car jerks alot, i dont think its the coilpacks
- My clutch sounds like brake moan! Like a dragging caliper.
- Creaky coilovers. Help?
- My Maxima gets over 31 mpg avg. Should this be possible?
- HYPER GROUND WIRE KIT ?!?!
- p1320 Ignition signal circuit HELP!? '95 Maxipad
- ???Throttle Body Cleaned....Now Higher Idle RPM 600 to 900
- 00vi users who have passed California Smog?
- Opinio on new ball joints and sway links
- P0135 p0155 p0141 p0161 grrr
- rear brakes hanging up
- Is my alternator bad?
- Motor or something is shaking while gunning it or tapping gas pedal. Can't Figure out
- E-brake sensor
- Need some insight please...
- retros from depoautolights?
- Gauge Lighting
- how much C4?
- rotor scrape sound
- clunking noise/bad transmission mount?
- Decent Seat Covers?
- My '97 Stick Maxima won't go into 1st or 2nd gear
- Car will not even crank after tranny reinstallation
- Advice please .......
- Immobilzer went out after resetting ECU - Wonderful
- Clutch problems
- ECM harness/connector location on a 97 max
- Vacuum in Absolute Pressure Sensor line?
- ecu installation and weird idle
- Keyless Entry Remotes
- HID Experts Step In
- Testing Digital Climate control/and Understanding the Codes
- Need Best Deal on Starter....help
- Had a Bad Day, need some advice...
- noise in neutral
- Exhaust smell inside the car?
- Gauge light issue
- HID's
- CPS o-ring leak + bad noise
- My hazard lights and the defroster lights don't work
- VQ30 sandrail
- Bringing one back from the dead???
- VQ30 Gurus I Need Help
- intake sensor question?
- I need help with this problem
- bad fuel injector?
- Alternator causing problems ?!?!
- A/T service
- I was on overhaulin! But not really
- Voluntary Service Campaign: 1996 Maxima MIL issues
- bad cv joint?? only about 3,000 miles?
- Alarm Malfunction????
- Loose wheel lug
- What are some cheap fixes for our 4th gens?
- should i make these??
- Warm air when AC on. WUTS WRONG?!
- replacing differential seal
- 4th gen maxima for 600$ ?!??!?!
- Changing Wheel size from 15` to 16` ?
- Red Lion Racing Traction Rods
- New Spark Plugs Installed
- Need your instructions on removing CV axles, picture attached
- Opinions needed! what would you guys pay for these headlights?
- 99 Fed spec 00vi swap - Questions on newly discovered coolant hose routes/EVAP *PICS
- how to tell whether the engine or tranny was replaced?
- 99 to 95 engine harness swap
- Evap System - bypassing/removing vacuum cut valve
- shifting without clutching with car off
- 95 max with Bose, amp question
- Brake Light On Intermittently
- 97-99 Red/Clear templates
- Random hard starts.....
- Window base screws... part number?
- Excessive oil consumption!
- Crank, no Start. Replaced fuel pump already..possible alarm problem
- Lets get down to the gritty on this front end vibration stuff
- raybestos quiet stop brake pads
- Throw-out bearing retainer clip part numbers?
- Which one do you prefere ?
- Hoses on passenger side of trunk inside body??
- Rusted body panels - replacement
- too much for Auto trans rebuild???
- new design for 4th gen motor mount
- running bad and no ECL?
- Found a free way w/o additional parts to get louder exhaust!
- Air conditioning issue
- passenger side axle replace
- *New* Pioneer AVIC - U310BT CD w/ Navi [Demo Video]
- Steady Power Pulsation When Accelerating...
- Troubling Trouble Codes P0136, P1320, 0202
- Engine Replacement?I got antifreeze in my oil
- finally got my projectors in...:)
- Hard starting, extremely hard and black smoke
- car not starting..
- ODB II reader for a 1995
- door alignment
- 1995 Hood on 1997 maxima will it fit?
- Grinding/clicking noise before shifting
- Brake/battery light on.. alternator right?
- I might be back, but I need some help!!!
- Gauge Lighting question
- Depot auto lights 1 piece headlight opinions
- cali spec or not?
- Help! Power cutting in and out
- ATTN MN Maxima owners. FOUND GLASS. VQ30DETT?
- Debadge trunk yes/no
- Rad Fan Difficulties -ECU cant control them anymore-
- What's wrong with my car?
- Decent brake pads for a cold climate
- Inspecting Calipers?
- "broken" cat ... new your opinions, what would you do next?
- bogus 1/4 mile claim?
- Transmission Lockout - Occasionally
- hid problem lmao
- Idle speed at 500 at stop
- ES FSB and end-link bushings req jack up? Are ES bushings crap?
- Can I go any lower?
- Headers?
- Support bar behind glove box?
- How do I repin ECU connectors?
- NWP Engineering thermal intake spacers and high idle
- Meyle Rotors W/ GEOMET Coating __ Anyone tired them?
- ECU Decisions
- stumble at idle....
- Flushing Brake Fluid, ABS system - difficult?
- Idle question: jumps in neutral
- Interesting promotional vid for 4th Genners
- brakes ??
- Timing Cover/Alternator help
- Automatic Screen Nut Won't come off
- Gas Gauge and Temperature Gauge
- what is a good tire size?
- 99 rear leather bench seats
- Advices needed for choosing and buying a spoiler
- sHaDyOneDeath's Tokico Illumina Kit Installation thread
- DEK burning loads of oil, wobbly crank pulley, loads of frustration.
- OE or Aftermarket Fuel Injector?
- I'm new here and need some opinions..
- cloud of blue smoke after parking on a slope!
- Hids Flickering?
- what is this? and do I need it?
- problems involving emissions, OBDII....
- Dirt cheap fix needed!! - Lower control arms / bad alignment / etc.
- fog help
- How serious is this exhaust issue?
- Tired of manually adjusting dimmer, which wire is it?
- Bent rear axel
- 1996 SE drivers fog lamp assemble?
- 1996 SE Full exhaust replacement
- running rough under 3k rpm?
- Parting out a 4th Gen: Is it worthwhile? Money made?
- need help asap with a 96
- Have our cars been known to throw axles by hitting hard bumps?
- Car started then died......
- Any info On Rear BBk or conversion to bigger rotors?
- ok. finally finished my projector mod
- has anyone thought of...
- HowTo Link doesn't work
- Snow tires - anybody run 195 65 15?
- Love your Maxima too much?
- Is she worth the $750 ??
- bose aux input questions (i searched)
- Was about to install my Illuminas myself and noticed a leak in Driver side CV joint
- Weird rattling noise w/ Vid
- Fobe Question
- clutch slip?? kinda wtf?
- slow warm starting
- P1105 / MAP - Solenoid
- Brakes... what did i do wrong?
- 00vi info, help please!
- eBay brake rotors.. how do these look?
- short ram intake hose question.
- Car will not get off from floor...
- 5030 O2 sensor location?
- Do I have an exhaust leak???
- Spoiler for the max
- Constant rough idle / intermittent loss of power
- JWT ECU with an autotragic
- '95 Maxima hood realease cable loose and frayed
- Car cuts off at high rpm
- car running cold?
- Looking for a nice new muffler for my Ypipe? Any recommendations?
- how to torque with a wrench, not a socket?
- where is the crankshaft position sensor
- Belt tensioner on 1996 I30?
- G35 wheels on a '97 I30, Opinions?
- Help me find my o2 please.
- Rear VC on front head?
- any recommendation for new drive axles ?
- CKPS POS Pin 49
- 00VI Manual
- Belt issues (emergency!)
- NEED HELP PLEASE!!!
- retrofit question
- need a trans for my car what will fit?
- Park/neutral position switch on a 95 SE
- Rear Passenger Caliper Leaking
- 1995-1999 eFan Wiring Question
- Cassette player in BOSE acting up......
- valve tap!!!!??????
- Finally oil leak diagnosed, should I replace the engine?
- Oil leak after water pump replacement- mechanic's fault?
- Looking for tips installing leatherseats.com leather on a 99-99 seat with airbags
- What on earth is this on my hub area?
- stubborn outer CV joint
- Can the A/C system be "flushed" properly if the compressor is not working?
- What involved in replacing exhaust?
- Time for a new "N00bie" question thread...
- How does the exhaust differ on a 99 from other year models?
- Broken thermostat bolt
- Foggy 4th Gen Headlights...Best Way to clean?
- Repair Manual Question?
- Are maxima and I30 headlights interchangeable?
- will re-grease save drive axle ?
- Anyone here had experience with Auto-RX? need your opinions
- Build date location? Help!!
- how to know if mirror is heated or non heated?
- foggie hid problem
- shifting issue w/ auto
- Help! Bought a/c compressor and Drier, Do I need these too?
- The best reman front brake calipers?
- Window switch relays
- starting problem please help!
- strange wurring noise
- Maxima Died, my mods to blame?
- Something wrong here?
- Concealed carry
- Why RPMs fall rapidly from 3rd gear when releasing accelerator ?
- headgasket needs to be replaced
- NEED HELP! Starting Issue
- My alternator is most likely starting to go
- Timken Input Shaft Bearing part #'s?
- catalytic converter
- 20MM H&R Rear Spacers
- o2 Sensor Question..
