- Can I replace the rear exhaust manifold at home?
- Absolutely Comprehensive 4th Gen Parts/Mod List (Long!)
- 1996 or 1997+ for more money?
- where to buy bushings?????
- tranny Q
- Motor Mounts...Help!
- anyone know what this bolt is for?
- Bad Motor Mount?
- HEY GUYS WHATS THE WIDEST TIRE YOU CAN GO ON A MAXIMA SO IT WOULDNT RUB.....
- Rough Idle after EGR Valve Cleaning
- steering knuckle/ hub assembly area
- harmonic balancer/ pulley question
- electronics flicker when brakes first applied?
- VQ30 ECU binary/hex addresses
- Remote Start
- Looking to become part of the family!!!
- Wiper Motor
- Best Grill
- help cant shut trunk lid!
- looking for headers whats best to get
- Missing / Rough Idle
- Antenna broke - how do I disconnect or fix it?!
- How to fix a ding/dent?
- Installing OEM CD Changer in the trunk
- strut mounts/bearings/boots
- Best Grill Insert
- QQ: 98 5spd SE Cluster work in 98 Auto SE?
- Factory Service Manual
- ran into problem changing control arms
- Gotta love BB gift cards!!
- warpspeed y-pipe and cat.....
- Drop concerns.
- Alternative ALTERNATOR
- Update on bagging my maxima
- brembo blank rotors warping easily?
- Few questions on a ground kit
- Timing pulled by ks
- Willing to pay $50 to whom finds my problem
- budget y to loud?
- Mounting engine to stand
- Transmission maintenance questions
- Lifter noise on startup tricks?
- my wing is falling off
- "D" Ring Residue Can Cause Slow Seat Belt Retraction
- heater doesnt work. engine temp rises
- cheapest place for OEM water pump?
- Maxima Stalling / VERY hard to start
- Individual throttle bodies
- Trans gear oil loss - 5spd
- oem headlight confusion
- 99 sunroof cover sliding rough
- ebay knock sensor
- front end is popping when i turn my wheels
- slight pull at turn
- TSX Projectors in R34 Style Housing
- my key broke
- Best place(cheapest) to get the Illuminas...
- Cold start rattle
- odd squeek
- immobilizer problem
- 97+ SE factory springs different than 95-96 SE?
- Noise coming from strut mount,
- quick lighting questions
- How to reprogram a new fob?
- 96 Maxima Fuel Leak - how to find
- New to the Bay Area
- XTD Clutch on ebay?????
- Removing front axles
- Pasesetter Monza
- HELP car won't start!!
- Help! power passenger seat!
- San Antonio/TX crew
- Maxima totalled
- wtb: tan leather seats!
- Gut Check
- What brand CV Boot Kit did you use?
- new pics of my ride what do u think of the look
- Removing broken antenna (an update is needed)
- what do you think about the ebay y pipe & headers package
- 350Z rims on a 4th gen....
- Almost rear ended someone, faulty brakes?
- Disconnecting tie-rod
- Coolant leak question
- Brake Pedal Adjustment
- Please HELP me find this
- I want to get new foglights. What do u org have?
- tint
- Fog light question
- Tatanko's Christmas Thread 2007
- ONE Piece Headlight
- SS Clutch Line Question
- Where's the best place to get rear calipers?
- Got a Code 0707- Rear Heated O2 Sensor
- Calling all 4th gens with black painted sawblades...
- nj ny area!!
- what exactly does the ECU do besides show you error codes?
- Where can I get sway bar endlinks ?
- Swapping springs on my 4th gen
- How can you tell suspension is going bad? (Weird FRONT RIGHT noise)
- Snow weather Accident
- Anyone in ever had water leaks in the Trunk
- mmm ypipe :)))
- deatschwerk injetor question
- annoying thud on right side of car
- whose 4th gen?
- Underdrive Pulley Installed
- replaced ks but still have cel
- Mud Flaps good/bad?
- Anyone use glow gauges?
- A32 & A33 (00-01) Weight Log
- '99 Maximas have different CEL codes than '95-'98? getting 05 13 code?
- Part supplier.
- Failed Emissions. High NOx.
- Front License Plate Removal
- heated seats question
- Wheel question
- Starter Trouble
- tranny is going... and going...
- Any write up on how to change rear calipers?
- To loose the knock sensor nut
- Any good seat covers for the Maxima? (black)
- Vis Racing Sports Fenders
- more starting issues. I can't believe this.
- WTF....My coolant has a orange color
- Wanna do some exhaust work need some advice
- Headlights/corner lights/bumper lights
- Can't remove CV bolt
- What are the symptoms of a bad starter?
- so i need o2 sensor and knock sensor....(just had it diagnosed)
- Will it rub? 18x8s
- How to fix 1003 (park neutral switch) after 5spd swap
- JWT ECU
- good price?
- Anyone ever try a DIY alignment?
- I think I broke something
- what replacement antenae??
- battery
- Rear Nissan trunk emblem?
- Just installed my new y-pipe
- EGR Valve Replacement, Search Function Not Working
- heater smells like burning after a while
- Anyone using 9004 yellow headlights?
- Tranny experts...please chime in.
- PLEASE HELP , quick question !
- need assistance with steering problem...
- 5th Gen Axel Back on 4th Gen?
- Need Advice "Car Wreck Pics"
- Can bad brake fluid make brakes weak?
- EGR system cleaned...now fuel injector problem
- What can I do wth these? LED guys step in...[pic]
- Upper spring seat question
- Does anyone make just a b-pipe for our cars anymore
- "The diappearing car door"
- How do you prevent rust on rotors?
- Powder Coat?
- Ebay Item?
- Megan can Mufflers and our cars....
- Belt tensioner
- Cold Start Stall
- crazy idle along with temp change
- To replace or not to replace...
- Defroster won't turn off!?!? Climate control will.
- car felt like it was bogging up.....
- TPS
- 95/96 Red/Clears
- Do i need a new maf???
- What would look better ?
- 4th gens have factory alarms? Mine is engaged and car wont start
- Is there an indicator light for low transaxle oil?
- Lower ball joint replacement on control arm
- Car sputters while idling and check engine light blinking
- P0420 and P1448 I HATE the cel
- Galloping noise from front end on acceleration
- How can i roll my front fenders.
- 4th GEN Govener???
- window switch LED issue, no window is on the fritz ....
- Manifold
- Driver's front seat motor dead....
- $650.00 for a used transmission!!!
- what in the hell is this????????
- Why does my IACV Constantly Click? -Video!
- 99 SE Auto Speedo Cluster Fix A 98 Auto SE?
- Power seats question......
- 15~16 miles/gal.(premium)
- ks bolt
- CV boot replacement
- CLUTCH OR SLAVE
- Mystery RATTLE >>??
- Squeaking Sound From Engine Bay
- B&M STS Help
- Bad rubbing sound from engine
- Factory alarm goes off by itself.
- speed assisted steering/ GLE vs SE
- Whose got the lowest mileage??
- so yea my car got keyed last night
- remote unlock rolls windows down
- Cluncking Sound from Passenger side
- How do you put LEDs in the tail lights or in interior?
- Different brands of ignition coils?
- Gauge Bezel template??
- Interior LIghts
- A/T Tranny Codes
- how do u open the heated switch
- P1336 code (Crankshaft Pos. Sens malf)-lightened flywheel posible culprit???
- 1995 Maxima GXE Question - Blue Screw
- HELP!!! P1336 code-set off by JWT?
- Any ideas on these headlights?
- Brake light question
- tranny going bad ?
- Are J30 projectors any good?
- cold starting problems
- Projector wiring harness
- Failed inspection because CEL doesn't light when starting car!!
- DTC P0446 Code
- Fuel smell from vents
- Clutch flywheel oppinions/options
- Creakin or squeakin noise on front end
- Speed Limiter Removal
- no lights on manual ac/heater buttons
- Ticking sound from MEVI??
- problem starting
- oil on spark plugs
- help taking off tranny
- What you guys think of these wheels?
- Turnsignal Lights
- DTC P0443 Evap Purge Vol. Ctrl. Sol.
- 'AE' sidemarker lights
- Need Opinions On LED Tails
- My Trunk
- Anybody's driver's side front door locks crapped out?
- budget y-pipe site???
- belt size
- Codes!
- Can I have AUX input on 96 I30?
- Rusty Alternator Ground ? Check This Out
- New Maxima.org subforum
- Post up you sunroof switchs Please
- Serpentine Belt
- tape or paint out ambers?
- Radiator Replacement
- can't start
- transmission slowly going, what now????
- smoke from engine
- valve cover gasket reccommendations needed
- Will PIAA 2100 series fit 4th gen?
- Coolant Temp Sensor Location; Yes, i've searched
- Will this O2 sensor work?
- Help with radiator question.
- Step inside...friend has a problem on his 4th gen.
- Accident side damage/steering broken(Pics)
