- why replace the stock intake air box with a K&N cone
- Could anybody help me with these numbers...
- What's the best clutch?
- Where to find Redline mt90 in Quebec, Canada ?
- I need to fix 02 sensor problem. Anyone wanna make some $$??
- idleing NOSIE
- all clear tails for 95/96...how much would you pay???
- correct ohm reading for knock sensor
- who here has gr-2's with 2" drop
- Dashboard dismantle
- 97 Max MIL lamp on Consult found P0136-H0252 (B1)
- whats a fair price for 99gxe
- trunk rattle
- How to clean Hi-Flow Intake Cone???
- Tokico Illuminas
- coutosy nissan
- Our New Maxima
- all praise the KS god!
- For those who have $$$ in their Maximas, worth all the upgrades?
- Only 3 kinds of rotors??????
- Stillen EPROM ECU UPGRADE
- Will a Infiniy I30 hood work on a Max?
- Can fuel system/fuel injector cleaner cause CEL to come on?
- Help with Drive Axel
- short shifter.....
- warpspeed rattle
- 18" 350z fitment on my Max
- more power what can i get for 150
- My impression on SeaFoam
- Pairing up Gr2 w/ some eibachs???
- JIC/TEIN/etc. coilover owners
- Axle Back
- Replaced both front O2 sensors, but still getting a code for one of them.
- Carbon Fiber Hood
- i got code 0702
- transmission problem
- Forced Air Intake partially put together; Just got back from a test drive!
- Key fob question
- Any1 in colorado
- How much would it cost to have custom suspension installed?
- custom maxima y-pipe
- FINALLY got my 4th gen!!
- Attn: White 97s-99s
- radiator fluid change and timing belt
- High-flo cats worth it?
- Broken Door Handle (Exterior)
- Driving with O/D Off Consistently
- Hard cold starts (sometimes)
- how dark to tint?
- Fog Lights
- y-pipe install
- What Air Intake to use??
- thermastat help
- [Newb] Hypothetically, I want to learn my way around through modding
- Cost to replace/fix front bumper
- cleaning the iac valve
- maxima se glow nite guages???
- Nismo LSD!!
- Ned 1 more for skyline kit....anyone interested?
- What would you do next?
- Y-pipe Header Wrap!!
- Cifero again
- Do Strut mounts make a difference?
- catback
- another clutch question/ problem
- Car not holding charge!!!
- changing injectors
- Another exhaust question...
- Looking for Deep Powerful Sound: The Cheaper The Better...
- Car shakes after 60mph
- Need new Radiator
- Wiper blade problem - connector rod? so ****ed.....
- pulley install now crank sensor code????
- Need Advice On Eng Ecu
- sticking odometer
- need help! how to secure lower mesh grill on 95-96 front bumper... *DIY style*
- stock integra v.s. stock 96 max
- did Custommax ever come out with that kit they were talking about?
- i think i have been underating the power of auto maxima and overratin 5spd acura GS-R
- Magnaflow help?
- post y-pipe install problem
- Limited Slip Question
- Greddy Exhaust?
- HID igniters?
- How do you think this would look?
- I need some help replacing a knock sensor
- my 1/4 mile time...
- What battery to use?
- New I30t is SWEET!!!!!
- a tiburon and a gti??
- replacing brakes
- Exhaust Recommendations
- Do I NEED an Intake?
- coilovers with GR-2's?????
- LED Bulb Question
- Spark plugs
- I think i orderd wrong part#
- Do you feel guilty?
- How long did your Frankencar intake...
- Diamond floor mats?
- brake pads
- diagnose bad calibers?
- Y-pipe Help.
- Eibach Pro Kit on Stock SE Struts
- Light Bulb Info?
- Parking Brake cause warped rotors!
- Autozones Troubleshooting Site...
- One person bleeder for clutch?
- HID Bulbs
- We must have very weak engines
- Sea Foamed the Max and the freakin CEL came on!!
- 2K-2K1 TechnoSquare TEST CARS please stand up~!
- franken car intake
- Yet another question on octane
- Stage I or Stage II ACT ?
- Anyone have Tokico Illuminas from custommaxima.com
- torque wrench absolutely necessary - FSTB?
- what should be done at 60,000 miles?
- H4 bulbs
- cleaned tb a different way.....
- BKR6ES-11 or BKR5ES-11 Spark Plugs
- Battery Drain
- Value of 97 SE with 300,000 miles???
- Ball joints and spring "rubber"?
- How much to get clutch replaced?
- Damn Low Lifes! Stole my New Wipers, Front Plate Holder & Plate.
- dropzone lowering springs
- Thats Another way of Making wrong Money...
- Best Clear Corners?
- Err2 - 6 Disc In Dash CD Changer
- HELP Injen CAI installed - CODE 13-02
- Keyless entry stopped working
- No Radio, Clock, or Keyless.. Help Please
- I want to put fog lights in on the very bottom grill of my 95 GXE, need help
- OEM repalcement Struts
- Plenty of Juice, but motor wont crank! please help.
- brakes spongy
- What's involved in painting the engine cover?
- changing turn signal blue
- UDP and STS review (kinda long)
- For Those with Bad 02 and KS
- low octane gas? will trigger Ck eng lite ????
- problems......
- stabilus or ac delco hood struts
- gauging interest- 97-99 front conversion package
- Troubleshooting air bag light?
- Lowering Kit for a Maxima On 20'S
- What Clutch to Buy ??
- Tail Light Fuse
- What do these tubes do? (pic)
- Cheapest place to buy H&R springs??
- Auto shifter to high
- Hood Struts
- CEL and 87 octane?
- new pic of my car
- Stick clutch question
- electical problem
- 87 Octane Fuel
- Radiator Leak
- Hi-Wattage headlight bulbs!!!
- 1995 remote system question
- fuse problem and headlight bulbs...
- Anyone have pics of their wood dash kit?
- frankencar intake
- Which one is better?
- How's the ride with a GR-2 / H&R setup?
- help bad misfire
- Tein-S on 18's
- best wheel size
- I have an idea....can you put a little breather filter on......
- ever wish forum was split into mecahnical and all other?
- Stock Intake question
- Stillen or Greddy?
- Help: Odometer stopped working.
- Temperature control
- Finally got pics of my smoked red-clears and sidemarkers *pics*
- which non-headlight bulbs is the brighest
- switches
- brembro rotors cross drilled and slotted CRACKED WTF!!
- non linear clutch feel
- Instrument Cluster Compatibility
- Shooting Incident?
- Exedy Stage 1 Clutch
- TPS not reading 100 at WOT
- How to adjust front toe in?
- motostorm udp
- Cel 0901 ..
- Bosch Spark plugs ok?
- 97 Max, GC's and agx
- how is your braking system function?
- 96 MAXIMA GXE Calipers for only 78US?
- Where to buy ACT clutch ??
- Great used Max but whats wrong with the clutch?
- speed limiter removal
- installing catback.....beginner....SCARED!
- Calipers Freeze up? Is my mechanic right?
- Cold Weather Auto Trans Warning
- question for Jime?
- Weird clutch feel....don't know whats wrong
- Trying to install Xenons. *Please help*
- Rebuilding rear brake calipers - problem
- Another MAx out of the running =(
- Need to troubleshoot A/C
- red/clear 95-96 maxima tail lights
- About to buy shocks and springs, what else do i need?
- HEADERS and Y-PIPE
- 97 GXE what to check before purchase
- Air cond leak rate?????
- ignition coils from Autozone
- Intake Velocity Stack
- Wat is a drop resistor????
- On 20's I want to lower it
- Where To BUY!!
- Phantom Grip?? Where can I find this??
- calipers painted?
- what is most comfortable shocks/struts?
- what bulb???
- Intake sound difference
- Redline Max Skyline Front Bumper
- Resistor pack replacement
- Our cars are old, PERIOD
- yea.. ANOTHER g-tech q
- 5th gen projectors in 4th gen write up?
- Will wider tires help get rid of understeer?
- Intro on my 4th gen and me. A few questions.
- Problem with wheel studs , please help.
- WTB:300zx injectors
- How do you put leds in cup holders?
- A/C Screwed, Evaporator?? Unclear answers
- 95-96 tail light idea
- New Pix - Few crappy Movies - and a question!
- Lowering plus rims, and Camber question??
- hoods available for 1995 maximas?
- Dropzone N1 coilovers..
- Tinted Tails Write-Up
- 97-99se steering wheel diameter please
- HeadLights/Parking Light bulb suggestions!!!
- NGK copper plugs
- Where is the write-up for changing the defroster and hazards lights to leds?
- Clearance light issues
- Help...fuel filter hoses won't come off.
- Anyone running stock SE springs and Illumina's?
- Installed the Greddy SP exhaust
- Quick ? about maxima.org stickers
- ***Dont know what y pipe i have!!!!!***
- which springs are better?
- Max vs. 2.2L 94 Accord
- help! check engine light on
- Maxima newbie question/ impression
