- Installing KYB AGXs need a lil advice
- Wow i punched my max for the first time
- Steering Issue...
- Ques about EVAP Canister Purge Volume control valve?
- Power Steering Pump Leaking ...
- Will these fit? Please help...
- 95-96 APC new clear tails on ebay
- Radiator Replacement Report
- ECU Question
- Has anyone purchased the amber fog lights from custom maxima?
- need help: auto climate control light problem
- ECU said cylinder 3 was misfiring, replaced coil pack, misfire went away...till now
- ROUGH VIBRATION FROM FRONT END
- Air Leak/Air rush sound on highway
- Undercarriage Rattling Noise... ANNOYING!!!
- Stillen High Flow Intake
- Searching For JDM Black Parking Lights
- how hard is it supposed to be to remove the harness for the coil pack?
- ignition switch has anyone had problems???
- 2000-2003 Bose HU in a 95?
- MAF sensor issue
- best tires for 15"??
- Timing Chain Tensioner
- Do i need a mechanic?
- Let's play name that part (intake)
- Should I change my short ram warm air into a true cold air intake?
- APEXI SAFC NEO
- Clear Coat Peeling
- BANGING EXHAUST
- Finally *PICTURES*
- good quaility clear tailights?
- NWP Engineering Phenolic Thermal Intake Spacers - VQ30DE PROTOTYPE REVIEW
- Bad knock sensor and rear o2
- Check engine light is on again!!
- Starting problem w/0304 & 0901 code Help
- NWP Engineering Phenolic Thermal Intake Spacers - 4th gen VQ30DE Maxima
- Oil Pressure Light
- Just wanted to thank the 4th Gen Forum
- KYB strut boots/GR2 struts
- Tach signal on ECU, this correct?
- how much shall I offer for these used parts?
- Replacing hood lift supports
- Possible fuel gauge issue?
- HOW TO CHANGE THE BLOWER RESISTOR
- Interior color codes?
- What else should I replace when lowering?
- Suspension cost (vs. D2 coilovers)
- OBX performance
- Need help with the screeching sound from my car
- Car got hit by Old Lady neighbor, she denies it. *PICS*
- battery light came on
- Pulley help...
- SO...for a windshield wiper transmission...you can get these gears?
- Should I buy these? will they fit? Please help!!!
- Taillight Mod? Completely Lost!
- HELP
- Fixing the shifter position when using 5th gen MT
- need help with codes 0732 & 0733
- Problem with H3's in stock fogs.......
- What Tailights Shuld I Get?
- where Can I find different centers for my stock se wheels?
- Power steering leak.... anyone had experience?
- Check out my new cheap and easy alternitive LED gauge cluster mod
- What's your engine's "Sweet Spot" (or "Flat Spot")??
- Radiator Help ! Which one would be good and any tips on the job?
- 97 MAXIMA TRANSMISSION
- powering lcd clock/climate control (pins?)
- Need help locating a part
- clutch question
- water pump bolt snapped, should I do a 3.5 Swap?
- Can someone take a picture of their trunk torsion bars for me please?
- Starting problem. Please help!
- O2 Sensor not communicating?
- Difference between 97 and 99 Climate control
- How to tell the difference between Stillen V1/V2 kit?
- need a pic of underdash where clutch petal mounts
- A32shop.com/Chillin014 Prototype LED Tails
- brake problem
- drive axle boot hlep
- Murano windshield spray nozzles on a 4th Gen
- Rear brake piston won't compress. Bad caliper?
- exhaust leak noise during right turns..
- Fuel injection question
- how do you calibrate speedo needle?!
- funny door locks
- Maximum wattage for for light bulbs?
- Viper keyless entry/remote start HELP
- Bad sensor... Not sure which one
- thank you and good bye
- different types of Rims on1997 SE?
- Need help with THROTTLE CABLE and GOLD 1/2 moons.
- How To Remove Pinstripe? HELP
- FINDANZA RING GEAR PROBLEM THREAD for replacement from Fidanza(everybody should look)
- Ghetto Airbox Mod
- is this "the" M3 spoiler i see on other 4th gens?
- CAI that's not a popcharger or FWI?
- are maxima's not great in the cold weather?
- 12 mlies/ gal.(premium)
- Questions about Custom Cefiro Headlights 95-99?
- Indecission Feb 14 2008:Tokico HP or Gabriel Ultra
- quick question just changed ecu
- ok now that I have a Maxima, what are your favorite sites?
- Miss firing?
- H TECH OR S TECH????
- knock sensor
- Aftermarket Parts - Good or Bad?
- car cranks but won't turn over ...
- 1997 5 speed
- Quick Question
- why is my ecu giving me an 0505
- Are 4th Gen Windshields Interchangable: Will a 95 or 96 windshield fit my 98?
- Suspension overhaul questions
- I finally bought a Maxima today!
- Different radio antenna for 95-99 Maxima?
- Knock Sensor 97SE
- Fuel Vapor smell inside
- Change auto trans transmission
- hey should i debadge my max?
- Help with 99 max stalling/limpmode problem
- Which is better- Ebay Catch can or home depot
- I want to find a 1998+ sterling mist 4th gen...
- K&N Air Filter worth it?
- Death of my beloved 4th gen
- Please Help!
- manual to automatic climate control
- Best Setup for amp/sub Install
- how many miles does a maxima last?
- rough idle and runs rough
- good price on tranny?
- 5 speed swap
- HeadUnit Problems, need suggestions
- I really need my keyless fixed
- Coilpack wiring pin out
- 3.5 VQswap cam spacers....and a few other?
- A question on coil packs.
- Bad Injector
- Anymore places to look for a Maxima?
- additional parts needed to replace valve cover gasket?
- air bag
- brake pads?
- need help brake light stays on the dash
- 97-99 front end conversion?
- HELP ASAP - DOOR LOCK FROZEN
- Check out my really cool Rotor Glowing mod...
- My maxima on dubs!
- "Aircon" fuse keeps blowing..
- Redrilled 4th gen lower?
- 1-4 code
- TIMING ADVANCE
- where can i get amber corners
- looking to buy a 95-1999 maxima, a couple of questions...
- ABS brake upgrade...
- need help..tranny problems AGAIN!
- Little box connected the battery positive
- sound system?
- My old pebble beige maxima is no longer...
- Why do some 2000 maxes sell cheaper then 4th gens?
- how to adjust the parking brake lever?
- windows dont roll up or down?
- tranny question
- wideband o2 sensor?
- How can I fix damage leather(Tan)
- can fed car cat fit on/in cali car
- Instrument Panel Dimmer Switch
- Yes another "car won't start" thread...
- 96 Infiniti i30, adding heated seats, is there a lot of wiring involved?
- which flywheel is the best
- Q's about cloth to heated leather sway... HELP
- BIG decision and question....
- L.E.D.s
- Should I be worried?!
- Spark plug Horsepower comparison
- knocking noise
- How Long do Break Pads Typically Last?
- Heater core replacement
- VQ35DE
- Carbon Fiber parts...
- Strut Removal Question
- Suspension Opinion
- new starter, engine light is on....revs being affected
- Is there a trick to replacing your hood:having a problem getting it bolted.
- engine is ****ed. car for sale i guess
- What parts wear out/break that might strand me (at 130K)?
- ~URGENT~ car wont start,lock, unlock
- Tranny is slipping... belt?
- ignition switch cause long starts?
- ebay MaF!!!
- opinions on exhaust
- Any tips the keep the exhuast from moving around?
- how to force car to start with bad starter? tut for removal/location?
- In search of new wheels
- EBAY EXHAUST??
- 95-96 vs 97-99 catback differences
- quick valve cover question
- strut mount question
- Knock sensor question.
- WIRING ISSUE.....Pls help
- before buying Bumper Lights, what bulbs does everyone use for them?
- Worth the risk?
- question on maxima interior
- Alt. Fuse?
- 1500-2000 idle undulations when warm? Vac leak?
- ???mounting location for hood pins for a cf hood??
- noisy suspension, could it be due to my struts?
- Driver's side window glass removal and replacement...
- se Rim
- LED Tail Light How-To.
- Jugging after warmup? Please Help!!
- Motor guys step in. Having major throttle drop issues
- I'm getting some hesitation/misfire
- which muffler would you guys recommend?
- Rattling noise coming from my front right driveside wheel
- HOW TO: THE CHEAP end all wheelhop mod.
- question about shifter trim
- Pulley Squeak - Vid Inside
- Engine really loud at 6K-6.5K
- Vacuum hose from EVAP purge control valve to EVAP purge volume control closes itself
- When in doubt...MacGyver that sh*t.
- VSS- Where is it?
- pic: dirty a$$ evap volume purge control valve...solve CEL 1008?
- Help! No heat after radio removal and install!!!
- question for ecu code AND where to get part
- Brake Caliper bolt/pin question.
- will 5th gen cat fit 4th?
- OEM head studs VS ARP studs
- ? new smog fuel tank evap test??? did i get ripped off?
- part number for Oil Pressure Sending Unit?
- Battery Light On after Alternator Replacement
- Cost for Repairs?
- exhaust backpressure question
- Hub Bearing Question
- '97 Tranny issues....again
- Good bye old Maxima
- Failed Smog, please help, drive cycle?
- 2000-2001 guage cluster in 4th gen
- "Klump" noise
- Crimson Red With Black Body Kit?
- can somone run a carfax for me?
- Bad Alternator causing power (hp) loss.
- Where to buy Walbro ?
- Interesting CEL code "1B" as read from Consult port
- Cup holder won't stay in place
- Maxima Interior Disaster Cleanup?
- Eibach springs- do i need the camber kit?
- fog light removal
- so i just adjusted the IAVC....
- trunk rattling. nor will it open with button.
- blower fan motor makes noise
- Heater Issues
- Front Speaker Installation
